--- ray/src/cv/pabopto2bsdf.c 2012/10/19 04:14:29 2.1 +++ ray/src/cv/pabopto2bsdf.c 2014/10/03 21:57:06 2.27 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.1 2012/10/19 04:14:29 greg Exp $"; +static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.27 2014/10/03 21:57:06 greg Exp $"; #endif /* * Load measured BSDF data in PAB-Opto format. @@ -7,79 +7,160 @@ static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.1 * G. Ward */ +#define _USE_MATH_DEFINES #include +#include #include #include +#include #include "platform.h" #include "bsdfrep.h" +#include "resolu.h" /* global argv[0] */ char *progname; -/* Load a set of measurements corresponding to a particular incident angle */ +typedef struct { + const char *fname; /* input file path */ + double theta, phi; /* input angles (degrees) */ + double up_phi; /* azimuth for "up" direction */ + int igp[2]; /* input grid position */ + int isDSF; /* data is DSF (rather than BSDF)? */ + long dstart; /* data start offset in file */ +} PGINPUT; + +PGINPUT *inpfile; /* input files sorted by incidence */ +int ninpfiles; /* number of input files */ + +/* Compare incident angles */ static int -load_pabopto_meas(const char *fname) +cmp_indir(const void *p1, const void *p2) { + const PGINPUT *inp1 = (const PGINPUT *)p1; + const PGINPUT *inp2 = (const PGINPUT *)p2; + int ydif = inp1->igp[1] - inp2->igp[1]; + + if (ydif) + return(ydif); + + return(inp1->igp[0] - inp2->igp[0]); +} + +/* Prepare a PAB-Opto input file by reading its header */ +static int +init_pabopto_inp(const int i, const char *fname) +{ FILE *fp = fopen(fname, "r"); - int inp_is_DSF = -1; - double new_theta, new_phi, theta_out, phi_out, val; + FVECT dv; char buf[2048]; - int n, c; + int c; if (fp == NULL) { fputs(fname, stderr); fputs(": cannot open\n", stderr); return(0); } -#ifdef DEBUG - fprintf(stderr, "Loading measurement file '%s'...\n", fname); -#endif + inpfile[i].fname = fname; + inpfile[i].isDSF = -1; + inpfile[i].up_phi = 0; + inpfile[i].theta = inpfile[i].phi = -10001.; /* read header information */ while ((c = getc(fp)) == '#' || c == EOF) { + char typ[32]; if (fgets(buf, sizeof(buf), fp) == NULL) { fputs(fname, stderr); fputs(": unexpected EOF\n", stderr); fclose(fp); return(0); } - if (!strcmp(buf, "format: theta phi DSF\n")) { - inp_is_DSF = 1; + if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1) continue; + if (sscanf(buf, "format: theta phi %s", typ) == 1) { + if (!strcasecmp(typ, "DSF")) { + inpfile[i].isDSF = 1; + continue; + } + if (!strcasecmp(typ, "BSDF") || + !strcasecmp(typ, "BRDF") || + !strcasecmp(typ, "BTDF")) { + inpfile[i].isDSF = 0; + continue; + } } - if (!strcmp(buf, "format: theta phi BSDF\n")) { - inp_is_DSF = 0; + if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1) continue; - } - if (sscanf(buf, "intheta %lf", &new_theta) == 1) + if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1) continue; - if (sscanf(buf, "inphi %lf", &new_phi) == 1) + if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1) continue; if (sscanf(buf, "incident_angle %lf %lf", - &new_theta, &new_phi) == 2) + &inpfile[i].theta, &inpfile[i].phi) == 2) continue; } - ungetc(c, fp); - if (inp_is_DSF < 0) { + inpfile[i].dstart = ftell(fp) - 1; + fclose(fp); + if (inpfile[i].isDSF < 0) { fputs(fname, stderr); fputs(": unknown format\n", stderr); - fclose(fp); return(0); } + if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) { + fputs(fname, stderr); + fputs(": unknown incident angle\n", stderr); + return(0); + } + /* convert to Y-up orientation */ + inpfile[i].phi += 90.-inpfile[i].up_phi; + /* convert angle to grid position */ + dv[2] = sin(M_PI/180.*inpfile[i].theta); + dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2]; + dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2]; + dv[2] = sqrt(1. - dv[2]*dv[2]); + pos_from_vec(inpfile[i].igp, dv); + return(1); +} + +/* Load a set of measurements corresponding to a particular incident angle */ +static int +add_pabopto_inp(const int i) +{ + FILE *fp = fopen(inpfile[i].fname, "r"); + double theta_out, phi_out, val; + int n, c; + + if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) { + fputs(inpfile[i].fname, stderr); + fputs(": cannot open\n", stderr); + return(0); + } /* prepare input grid */ - new_bsdf_data(new_theta, new_phi); - /* read actual data */ + if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) { + if (i) /* process previous incidence */ + make_rbfrep(); +#ifdef DEBUG + fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n", + inpfile[i].theta, inpfile[i].phi); +#endif + new_bsdf_data(inpfile[i].theta, inpfile[i].phi); + } +#ifdef DEBUG + fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname); +#endif + /* read scattering data */ while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3) - add_bsdf_data(theta_out, phi_out, val, inp_is_DSF); + add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi, + val, inpfile[i].isDSF); n = 0; while ((c = getc(fp)) != EOF) n += !isspace(c); if (n) fprintf(stderr, "%s: warning: %d unexpected characters past EOD\n", - fname, n); + inpfile[i].fname, n); fclose(fp); return(1); } +#ifndef TEST_MAIN /* Read in PAB-Opto BSDF files and output RBF interpolant */ int main(int argc, char *argv[]) @@ -102,13 +183,22 @@ main(int argc, char *argv[]) } argv += 2; argc -= 2; } - if (argc < 3) + /* initialize & sort inputs */ + ninpfiles = argc - 1; + if (ninpfiles < 2) goto userr; - for (i = 1; i < argc; i++) { /* compile measurements */ - if (!load_pabopto_meas(argv[i])) + inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles); + if (inpfile == NULL) + return(1); + for (i = 0; i < ninpfiles; i++) + if (!init_pabopto_inp(i, argv[i+1])) return(1); - make_rbfrep(); - } + qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir); + /* compile measurements */ + for (i = 0; i < ninpfiles; i++) + if (!add_pabopto_inp(i)) + return(1); + make_rbfrep(); /* process last data set */ build_mesh(); /* create interpolation */ save_bsdf_rep(stdout); /* write it out */ return(0); @@ -117,3 +207,88 @@ userr: progname); return(1); } +#else +/* Test main produces a Radiance model from the given input file */ +int +main(int argc, char *argv[]) +{ + PGINPUT pginp; + char buf[128]; + FILE *pfp; + double bsdf, min_log; + FVECT dir; + int i, j, n; + + progname = argv[0]; + if (argc != 2) { + fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname); + return(1); + } + ninpfiles = 1; + inpfile = &pginp; + if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0)) + return(1); + /* reduce data set */ + if (make_rbfrep() == NULL) { + fprintf(stderr, "%s: nothing to plot!\n", progname); + exit(1); + } +#ifdef DEBUG + fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min); +#endif + min_log = log(bsdf_min*.5 + 1e-5); +#if 1 /* produce spheres at meas. */ + puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n"); + n = 0; + for (i = 0; i < GRIDRES; i++) + for (j = 0; j < GRIDRES; j++) + if (dsf_grid[i][j].sum.n > 0) { + ovec_from_pos(dir, i, j); + bsdf = dsf_grid[i][j].sum.v / + ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]); + if (bsdf <= bsdf_min*.6) + continue; + bsdf = log(bsdf + 1e-5) - min_log; + ovec_from_pos(dir, i, j); + printf("yellow sphere s%04d\n0\n0\n", ++n); + printf("4 %.6g %.6g %.6g %.6g\n\n", + dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf, + .007*bsdf); + } +#endif +#if 1 /* spheres at RBF peaks */ + puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n"); + for (n = 0; n < dsf_list->nrbf; n++) { + RBFVAL *rbf = &dsf_list->rbfa[n]; + ovec_from_pos(dir, rbf->gx, rbf->gy); + bsdf = eval_rbfrep(dsf_list, dir); + bsdf = log(bsdf + 1e-5) - min_log; + printf("red sphere p%04d\n0\n0\n", ++n); + printf("4 %.6g %.6g %.6g %.6g\n\n", + dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf, + .011*bsdf); + } +#endif +#if 1 /* output continuous surface */ + puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n"); + fflush(stdout); + sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1); + pfp = popen(buf, "w"); + if (pfp == NULL) { + fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf); + return(1); + } + for (i = 0; i < GRIDRES; i++) + for (j = 0; j < GRIDRES; j++) { + ovec_from_pos(dir, i, j); + bsdf = eval_rbfrep(dsf_list, dir); + bsdf = log(bsdf + 1e-5) - min_log; + fprintf(pfp, "%.8e %.8e %.8e\n", + dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf); + } + if (pclose(pfp) != 0) + return(1); +#endif + return(0); +} +#endif
