--- ray/src/cv/pabopto2bsdf.c 2014/01/30 18:19:43 2.11 +++ ray/src/cv/pabopto2bsdf.c 2014/08/21 10:33:48 2.26 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.11 2014/01/30 18:19:43 greg Exp $"; +static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.26 2014/08/21 10:33:48 greg Exp $"; #endif /* * Load measured BSDF data in PAB-Opto format. @@ -7,6 +7,7 @@ static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.1 * G. Ward */ +#define _USE_MATH_DEFINES #include #include #include @@ -14,12 +15,14 @@ static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.1 #include #include "platform.h" #include "bsdfrep.h" +#include "resolu.h" /* global argv[0] */ char *progname; typedef struct { const char *fname; /* input file path */ - double theta, phi; /* incident angles (in degrees) */ + double theta, phi; /* input angles */ + int igp[2]; /* input grid position */ int isDSF; /* data is DSF (rather than BSDF)? */ long dstart; /* data start offset in file */ } PGINPUT; @@ -29,20 +32,16 @@ int ninpfiles; /* number of input files */ /* Compare incident angles */ static int -cmp_inang(const void *p1, const void *p2) +cmp_indir(const void *p1, const void *p2) { const PGINPUT *inp1 = (const PGINPUT *)p1; const PGINPUT *inp2 = (const PGINPUT *)p2; + int ydif = inp1->igp[1] - inp2->igp[1]; - if (inp1->theta > inp2->theta+FTINY) - return(1); - if (inp1->theta < inp2->theta-FTINY) - return(-1); - if (inp1->phi > inp2->phi+FTINY) - return(1); - if (inp1->phi < inp2->phi-FTINY) - return(-1); - return(0); + if (ydif) + return(ydif); + + return(inp1->igp[0] - inp2->igp[0]); } /* Prepare a PAB-Opto input file by reading its header */ @@ -50,6 +49,7 @@ static int init_pabopto_inp(const int i, const char *fname) { FILE *fp = fopen(fname, "r"); + FVECT dv; char buf[2048]; int c; @@ -77,7 +77,9 @@ init_pabopto_inp(const int i, const char *fname) inpfile[i].isDSF = 1; continue; } - if (!strcasecmp(typ, "BSDF")) { + if (!strcasecmp(typ, "BSDF") || + !strcasecmp(typ, "BRDF") || + !strcasecmp(typ, "BTDF")) { inpfile[i].isDSF = 0; continue; } @@ -102,8 +104,12 @@ init_pabopto_inp(const int i, const char *fname) fputs(": unknown incident angle\n", stderr); return(0); } - while (inpfile[i].phi < 0) /* normalize phi direction */ - inpfile[i].phi += 360.; + /* convert angle to grid position */ + dv[2] = sin(M_PI/180.*inpfile[i].theta); + dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2]; + dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2]; + dv[2] = sqrt(1. - dv[2]*dv[2]); + pos_from_vec(inpfile[i].igp, dv); return(1); } @@ -111,9 +117,9 @@ init_pabopto_inp(const int i, const char *fname) static int add_pabopto_inp(const int i) { - FILE *fp = fopen(inpfile[i].fname, "r"); - double theta_out, phi_out, val; - int n, c; + FILE *fp = fopen(inpfile[i].fname, "r"); + double theta_out, phi_out, val; + int n, c; if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) { fputs(inpfile[i].fname, stderr); @@ -121,11 +127,11 @@ add_pabopto_inp(const int i) return(0); } /* prepare input grid */ - if (!i || cmp_inang(&inpfile[i-1], &inpfile[i])) { - if (i) /* need to process previous incidence */ + if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) { + if (i) /* process previous incidence */ make_rbfrep(); #ifdef DEBUG - fprintf(stderr, "New incident (theta,phi)=(%f,%f)\n", + fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n", inpfile[i].theta, inpfile[i].phi); #endif new_bsdf_data(inpfile[i].theta, inpfile[i].phi); @@ -180,7 +186,7 @@ main(int argc, char *argv[]) for (i = 0; i < ninpfiles; i++) if (!init_pabopto_inp(i, argv[i+1])) return(1); - qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_inang); + qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir); /* compile measurements */ for (i = 0; i < ninpfiles; i++) if (!add_pabopto_inp(i)) @@ -206,8 +212,9 @@ main(int argc, char *argv[]) FVECT dir; int i, j, n; + progname = argv[0]; if (argc != 2) { - fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]); + fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname); return(1); } ninpfiles = 1; @@ -215,23 +222,26 @@ main(int argc, char *argv[]) if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0)) return(1); /* reduce data set */ - make_rbfrep(); + if (make_rbfrep() == NULL) { + fprintf(stderr, "%s: nothing to plot!\n", progname); + exit(1); + } #ifdef DEBUG fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min); #endif + min_log = log(bsdf_min*.5 + 1e-5); #if 1 /* produce spheres at meas. */ puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n"); - min_log = log(bsdf_min*.5); n = 0; for (i = 0; i < GRIDRES; i++) for (j = 0; j < GRIDRES; j++) - if (dsf_grid[i][j].nval > 0) { + if (dsf_grid[i][j].sum.n > 0) { ovec_from_pos(dir, i, j); - bsdf = dsf_grid[i][j].vsum / - (dsf_grid[i][j].nval*output_orient*dir[2]); + bsdf = dsf_grid[i][j].sum.v / + ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]); if (bsdf <= bsdf_min*.6) continue; - bsdf = log(bsdf) - min_log; + bsdf = log(bsdf + 1e-5) - min_log; ovec_from_pos(dir, i, j); printf("yellow sphere s%04d\n0\n0\n", ++n); printf("4 %.6g %.6g %.6g %.6g\n\n", @@ -244,8 +254,8 @@ main(int argc, char *argv[]) for (n = 0; n < dsf_list->nrbf; n++) { RBFVAL *rbf = &dsf_list->rbfa[n]; ovec_from_pos(dir, rbf->gx, rbf->gy); - bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]); - bsdf = log(bsdf) - min_log; + bsdf = eval_rbfrep(dsf_list, dir); + bsdf = log(bsdf + 1e-5) - min_log; printf("red sphere p%04d\n0\n0\n", ++n); printf("4 %.6g %.6g %.6g %.6g\n\n", dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf, @@ -258,14 +268,14 @@ main(int argc, char *argv[]) sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1); pfp = popen(buf, "w"); if (pfp == NULL) { - fprintf(stderr, "%s: cannot open '| %s'\n", argv[0], buf); + fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf); return(1); } for (i = 0; i < GRIDRES; i++) for (j = 0; j < GRIDRES; j++) { ovec_from_pos(dir, i, j); - bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]); - bsdf = log(bsdf) - min_log; + bsdf = eval_rbfrep(dsf_list, dir); + bsdf = log(bsdf + 1e-5) - min_log; fprintf(pfp, "%.8e %.8e %.8e\n", dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf); }
