root/Development/ray/src/cv/pabopto2bsdf.c
Revision: 2.25
Committed: Fri Jun 6 00:58:22 2014 UTC (11 years, 7 months ago) by greg
CVS Tags: rad4R2
Removed redundant address operator
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.25 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.24 2014/03/24 02:31:02 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Load measured BSDF data in PAB-Opto format.
6     *
7     * G. Ward
8     */
9
10 greg 2.20 #define _USE_MATH_DEFINES
11 greg 2.1 #include <stdio.h>
12 greg 2.2 #include <stdlib.h>
13 greg 2.1 #include <string.h>
14     #include <ctype.h>
15 greg 2.6 #include <math.h>
16 greg 2.1 #include "platform.h"
17     #include "bsdfrep.h"
18 greg 2.15 #include "resolu.h"
19 greg 2.1 /* global argv[0] */
20     char *progname;
21
22 greg 2.2 typedef struct {
23     const char *fname; /* input file path */
24 greg 2.20 double theta, phi; /* input angles */
25     int igp[2]; /* input grid position */
26 greg 2.2 int isDSF; /* data is DSF (rather than BSDF)? */
27     long dstart; /* data start offset in file */
28     } PGINPUT;
29
30     PGINPUT *inpfile; /* input files sorted by incidence */
31     int ninpfiles; /* number of input files */
32
33     /* Compare incident angles */
34     static int
35 greg 2.20 cmp_indir(const void *p1, const void *p2)
36 greg 2.2 {
37     const PGINPUT *inp1 = (const PGINPUT *)p1;
38     const PGINPUT *inp2 = (const PGINPUT *)p2;
39 greg 2.20 int ydif = inp1->igp[1] - inp2->igp[1];
40 greg 2.2
41 greg 2.20 if (ydif)
42     return(ydif);
43
44     return(inp1->igp[0] - inp2->igp[0]);
45 greg 2.2 }
46
47     /* Prepare a PAB-Opto input file by reading its header */
48 greg 2.1 static int
49 greg 2.2 init_pabopto_inp(const int i, const char *fname)
50 greg 2.1 {
51     FILE *fp = fopen(fname, "r");
52 greg 2.20 FVECT dv;
53 greg 2.1 char buf[2048];
54 greg 2.2 int c;
55 greg 2.1
56     if (fp == NULL) {
57     fputs(fname, stderr);
58     fputs(": cannot open\n", stderr);
59     return(0);
60     }
61 greg 2.2 inpfile[i].fname = fname;
62     inpfile[i].isDSF = -1;
63     inpfile[i].theta = inpfile[i].phi = -10001.;
64 greg 2.1 /* read header information */
65     while ((c = getc(fp)) == '#' || c == EOF) {
66 greg 2.5 char typ[32];
67 greg 2.1 if (fgets(buf, sizeof(buf), fp) == NULL) {
68     fputs(fname, stderr);
69     fputs(": unexpected EOF\n", stderr);
70     fclose(fp);
71     return(0);
72     }
73 greg 2.10 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
74     continue;
75 greg 2.5 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
76     if (!strcasecmp(typ, "DSF")) {
77     inpfile[i].isDSF = 1;
78     continue;
79     }
80 greg 2.23 if (!strcasecmp(typ, "BSDF") ||
81     !strcasecmp(typ, "BRDF") ||
82     !strcasecmp(typ, "BTDF")) {
83 greg 2.5 inpfile[i].isDSF = 0;
84     continue;
85     }
86 greg 2.1 }
87 greg 2.2 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
88 greg 2.1 continue;
89 greg 2.2 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
90 greg 2.1 continue;
91     if (sscanf(buf, "incident_angle %lf %lf",
92 greg 2.2 &inpfile[i].theta, &inpfile[i].phi) == 2)
93 greg 2.1 continue;
94     }
95 greg 2.2 inpfile[i].dstart = ftell(fp) - 1;
96     fclose(fp);
97     if (inpfile[i].isDSF < 0) {
98 greg 2.1 fputs(fname, stderr);
99     fputs(": unknown format\n", stderr);
100     return(0);
101     }
102 greg 2.2 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
103     fputs(fname, stderr);
104     fputs(": unknown incident angle\n", stderr);
105     return(0);
106     }
107 greg 2.20 /* convert angle to grid position */
108     dv[2] = sin(M_PI/180.*inpfile[i].theta);
109     dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2];
110     dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2];
111     dv[2] = sqrt(1. - dv[2]*dv[2]);
112     pos_from_vec(inpfile[i].igp, dv);
113 greg 2.2 return(1);
114     }
115
116     /* Load a set of measurements corresponding to a particular incident angle */
117     static int
118     add_pabopto_inp(const int i)
119     {
120 greg 2.19 FILE *fp = fopen(inpfile[i].fname, "r");
121     double theta_out, phi_out, val;
122     int n, c;
123 greg 2.2
124     if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
125     fputs(inpfile[i].fname, stderr);
126     fputs(": cannot open\n", stderr);
127     return(0);
128     }
129 greg 2.1 /* prepare input grid */
130 greg 2.20 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
131     if (i) /* process previous incidence */
132 greg 2.2 make_rbfrep();
133     #ifdef DEBUG
134 greg 2.22 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
135 greg 2.2 inpfile[i].theta, inpfile[i].phi);
136     #endif
137     new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
138     }
139 greg 2.3 #ifdef DEBUG
140     fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
141     #endif
142 greg 2.2 /* read scattering data */
143 greg 2.1 while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3)
144 greg 2.2 add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
145 greg 2.1 n = 0;
146     while ((c = getc(fp)) != EOF)
147     n += !isspace(c);
148     if (n)
149     fprintf(stderr,
150     "%s: warning: %d unexpected characters past EOD\n",
151 greg 2.2 inpfile[i].fname, n);
152 greg 2.1 fclose(fp);
153     return(1);
154     }
155
156 greg 2.8 #ifndef TEST_MAIN
157 greg 2.1 /* Read in PAB-Opto BSDF files and output RBF interpolant */
158     int
159     main(int argc, char *argv[])
160     {
161     extern int nprocs;
162     int i;
163     /* start header */
164     SET_FILE_BINARY(stdout);
165     newheader("RADIANCE", stdout);
166     printargs(argc, argv, stdout);
167     fputnow(stdout);
168     progname = argv[0]; /* get options */
169     while (argc > 2 && argv[1][0] == '-') {
170     switch (argv[1][1]) {
171     case 'n':
172     nprocs = atoi(argv[2]);
173     break;
174     default:
175     goto userr;
176     }
177     argv += 2; argc -= 2;
178     }
179 greg 2.2 /* initialize & sort inputs */
180     ninpfiles = argc - 1;
181     if (ninpfiles < 2)
182 greg 2.1 goto userr;
183 greg 2.2 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
184     if (inpfile == NULL)
185     return(1);
186     for (i = 0; i < ninpfiles; i++)
187     if (!init_pabopto_inp(i, argv[i+1]))
188 greg 2.1 return(1);
189 greg 2.25 qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir);
190 greg 2.2 /* compile measurements */
191     for (i = 0; i < ninpfiles; i++)
192     if (!add_pabopto_inp(i))
193     return(1);
194     make_rbfrep(); /* process last data set */
195 greg 2.1 build_mesh(); /* create interpolation */
196     save_bsdf_rep(stdout); /* write it out */
197     return(0);
198     userr:
199     fprintf(stderr, "Usage: %s [-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
200     progname);
201     return(1);
202     }
203 greg 2.6 #else
204     /* Test main produces a Radiance model from the given input file */
205     int
206     main(int argc, char *argv[])
207     {
208     PGINPUT pginp;
209     char buf[128];
210     FILE *pfp;
211     double bsdf, min_log;
212     FVECT dir;
213     int i, j, n;
214
215 greg 2.21 progname = argv[0];
216 greg 2.6 if (argc != 2) {
217 greg 2.21 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
218 greg 2.6 return(1);
219     }
220     ninpfiles = 1;
221     inpfile = &pginp;
222     if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
223     return(1);
224     /* reduce data set */
225 greg 2.21 if (make_rbfrep() == NULL) {
226     fprintf(stderr, "%s: nothing to plot!\n", progname);
227     exit(1);
228     }
229 greg 2.9 #ifdef DEBUG
230     fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
231     #endif
232 greg 2.13 min_log = log(bsdf_min*.5 + 1e-5);
233 greg 2.11 #if 1 /* produce spheres at meas. */
234 greg 2.6 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
235     n = 0;
236     for (i = 0; i < GRIDRES; i++)
237     for (j = 0; j < GRIDRES; j++)
238 greg 2.16 if (dsf_grid[i][j].sum.n > 0) {
239 greg 2.6 ovec_from_pos(dir, i, j);
240 greg 2.16 bsdf = dsf_grid[i][j].sum.v /
241 greg 2.24 ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]);
242 greg 2.6 if (bsdf <= bsdf_min*.6)
243     continue;
244 greg 2.14 bsdf = log(bsdf + 1e-5) - min_log;
245 greg 2.7 ovec_from_pos(dir, i, j);
246     printf("yellow sphere s%04d\n0\n0\n", ++n);
247     printf("4 %.6g %.6g %.6g %.6g\n\n",
248 greg 2.6 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
249 greg 2.7 .007*bsdf);
250 greg 2.6 }
251 greg 2.11 #endif
252     #if 1 /* spheres at RBF peaks */
253     puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
254     for (n = 0; n < dsf_list->nrbf; n++) {
255     RBFVAL *rbf = &dsf_list->rbfa[n];
256     ovec_from_pos(dir, rbf->gx, rbf->gy);
257     bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
258 greg 2.14 bsdf = log(bsdf + 1e-5) - min_log;
259 greg 2.11 printf("red sphere p%04d\n0\n0\n", ++n);
260     printf("4 %.6g %.6g %.6g %.6g\n\n",
261     dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
262     .011*bsdf);
263     }
264     #endif
265     #if 1 /* output continuous surface */
266 greg 2.6 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
267     fflush(stdout);
268     sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1);
269     pfp = popen(buf, "w");
270     if (pfp == NULL) {
271 greg 2.21 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
272 greg 2.6 return(1);
273     }
274     for (i = 0; i < GRIDRES; i++)
275     for (j = 0; j < GRIDRES; j++) {
276     ovec_from_pos(dir, i, j);
277 greg 2.8 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
278 greg 2.14 bsdf = log(bsdf + 1e-5) - min_log;
279 greg 2.6 fprintf(pfp, "%.8e %.8e %.8e\n",
280     dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
281     }
282 greg 2.11 if (pclose(pfp) != 0)
283     return(1);
284     #endif
285     return(0);
286 greg 2.6 }
287     #endif
