root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.11
Committed: Thu Jan 30 18:19:43 2014 UTC (10 years, 4 months ago) by greg
Changes since 2.10: +21 -4 lines
Added RBF peak locations to Radiance output (-DTEST_MAIN)
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.10 2013/11/09 05:47:49 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 *
7 * G. Ward
8 */
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <string.h>
13 #include <ctype.h>
14 #include <math.h>
15 #include "platform.h"
16 #include "bsdfrep.h"
17 /* global argv[0] */
18 char *progname;
19
20 typedef struct {
21 const char *fname; /* input file path */
22 double theta, phi; /* incident angles (in degrees) */
23 int isDSF; /* data is DSF (rather than BSDF)? */
24 long dstart; /* data start offset in file */
25 } PGINPUT;
26
27 PGINPUT *inpfile; /* input files sorted by incidence */
28 int ninpfiles; /* number of input files */
29
30 /* Compare incident angles */
31 static int
32 cmp_inang(const void *p1, const void *p2)
33 {
34 const PGINPUT *inp1 = (const PGINPUT *)p1;
35 const PGINPUT *inp2 = (const PGINPUT *)p2;
36
37 if (inp1->theta > inp2->theta+FTINY)
38 return(1);
39 if (inp1->theta < inp2->theta-FTINY)
40 return(-1);
41 if (inp1->phi > inp2->phi+FTINY)
42 return(1);
43 if (inp1->phi < inp2->phi-FTINY)
44 return(-1);
45 return(0);
46 }
47
48 /* Prepare a PAB-Opto input file by reading its header */
49 static int
50 init_pabopto_inp(const int i, const char *fname)
51 {
52 FILE *fp = fopen(fname, "r");
53 char buf[2048];
54 int c;
55
56 if (fp == NULL) {
57 fputs(fname, stderr);
58 fputs(": cannot open\n", stderr);
59 return(0);
60 }
61 inpfile[i].fname = fname;
62 inpfile[i].isDSF = -1;
63 inpfile[i].theta = inpfile[i].phi = -10001.;
64 /* read header information */
65 while ((c = getc(fp)) == '#' || c == EOF) {
66 char typ[32];
67 if (fgets(buf, sizeof(buf), fp) == NULL) {
68 fputs(fname, stderr);
69 fputs(": unexpected EOF\n", stderr);
70 fclose(fp);
71 return(0);
72 }
73 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
74 continue;
75 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
76 if (!strcasecmp(typ, "DSF")) {
77 inpfile[i].isDSF = 1;
78 continue;
79 }
80 if (!strcasecmp(typ, "BSDF")) {
81 inpfile[i].isDSF = 0;
82 continue;
83 }
84 }
85 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
86 continue;
87 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
88 continue;
89 if (sscanf(buf, "incident_angle %lf %lf",
90 &inpfile[i].theta, &inpfile[i].phi) == 2)
91 continue;
92 }
93 inpfile[i].dstart = ftell(fp) - 1;
94 fclose(fp);
95 if (inpfile[i].isDSF < 0) {
96 fputs(fname, stderr);
97 fputs(": unknown format\n", stderr);
98 return(0);
99 }
100 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
101 fputs(fname, stderr);
102 fputs(": unknown incident angle\n", stderr);
103 return(0);
104 }
105 while (inpfile[i].phi < 0) /* normalize phi direction */
106 inpfile[i].phi += 360.;
107 return(1);
108 }
109
110 /* Load a set of measurements corresponding to a particular incident angle */
111 static int
112 add_pabopto_inp(const int i)
113 {
114 FILE *fp = fopen(inpfile[i].fname, "r");
115 double theta_out, phi_out, val;
116 int n, c;
117
118 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
119 fputs(inpfile[i].fname, stderr);
120 fputs(": cannot open\n", stderr);
121 return(0);
122 }
123 /* prepare input grid */
124 if (!i || cmp_inang(&inpfile[i-1], &inpfile[i])) {
125 if (i) /* need to process previous incidence */
126 make_rbfrep();
127 #ifdef DEBUG
128 fprintf(stderr, "New incident (theta,phi)=(%f,%f)\n",
129 inpfile[i].theta, inpfile[i].phi);
130 #endif
131 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
132 }
133 #ifdef DEBUG
134 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
135 #endif
136 /* read scattering data */
137 while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3)
138 add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
139 n = 0;
140 while ((c = getc(fp)) != EOF)
141 n += !isspace(c);
142 if (n)
143 fprintf(stderr,
144 "%s: warning: %d unexpected characters past EOD\n",
145 inpfile[i].fname, n);
146 fclose(fp);
147 return(1);
148 }
149
150 #ifndef TEST_MAIN
151 /* Read in PAB-Opto BSDF files and output RBF interpolant */
152 int
153 main(int argc, char *argv[])
154 {
155 extern int nprocs;
156 int i;
157 /* start header */
158 SET_FILE_BINARY(stdout);
159 newheader("RADIANCE", stdout);
160 printargs(argc, argv, stdout);
161 fputnow(stdout);
162 progname = argv[0]; /* get options */
163 while (argc > 2 && argv[1][0] == '-') {
164 switch (argv[1][1]) {
165 case 'n':
166 nprocs = atoi(argv[2]);
167 break;
168 default:
169 goto userr;
170 }
171 argv += 2; argc -= 2;
172 }
173 /* initialize & sort inputs */
174 ninpfiles = argc - 1;
175 if (ninpfiles < 2)
176 goto userr;
177 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
178 if (inpfile == NULL)
179 return(1);
180 for (i = 0; i < ninpfiles; i++)
181 if (!init_pabopto_inp(i, argv[i+1]))
182 return(1);
183 qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_inang);
184 /* compile measurements */
185 for (i = 0; i < ninpfiles; i++)
186 if (!add_pabopto_inp(i))
187 return(1);
188 make_rbfrep(); /* process last data set */
189 build_mesh(); /* create interpolation */
190 save_bsdf_rep(stdout); /* write it out */
191 return(0);
192 userr:
193 fprintf(stderr, "Usage: %s [-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
194 progname);
195 return(1);
196 }
197 #else
198 /* Test main produces a Radiance model from the given input file */
199 int
200 main(int argc, char *argv[])
201 {
202 PGINPUT pginp;
203 char buf[128];
204 FILE *pfp;
205 double bsdf, min_log;
206 FVECT dir;
207 int i, j, n;
208
209 if (argc != 2) {
210 fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]);
211 return(1);
212 }
213 ninpfiles = 1;
214 inpfile = &pginp;
215 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
216 return(1);
217 /* reduce data set */
218 make_rbfrep();
219 #ifdef DEBUG
220 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
221 #endif
222 #if 1 /* produce spheres at meas. */
223 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
224 min_log = log(bsdf_min*.5);
225 n = 0;
226 for (i = 0; i < GRIDRES; i++)
227 for (j = 0; j < GRIDRES; j++)
228 if (dsf_grid[i][j].nval > 0) {
229 ovec_from_pos(dir, i, j);
230 bsdf = dsf_grid[i][j].vsum /
231 (dsf_grid[i][j].nval*output_orient*dir[2]);
232 if (bsdf <= bsdf_min*.6)
233 continue;
234 bsdf = log(bsdf) - min_log;
235 ovec_from_pos(dir, i, j);
236 printf("yellow sphere s%04d\n0\n0\n", ++n);
237 printf("4 %.6g %.6g %.6g %.6g\n\n",
238 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
239 .007*bsdf);
240 }
241 #endif
242 #if 1 /* spheres at RBF peaks */
243 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
244 for (n = 0; n < dsf_list->nrbf; n++) {
245 RBFVAL *rbf = &dsf_list->rbfa[n];
246 ovec_from_pos(dir, rbf->gx, rbf->gy);
247 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
248 bsdf = log(bsdf) - min_log;
249 printf("red sphere p%04d\n0\n0\n", ++n);
250 printf("4 %.6g %.6g %.6g %.6g\n\n",
251 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
252 .011*bsdf);
253 }
254 #endif
255 #if 1 /* output continuous surface */
256 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
257 fflush(stdout);
258 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1);
259 pfp = popen(buf, "w");
260 if (pfp == NULL) {
261 fprintf(stderr, "%s: cannot open '| %s'\n", argv[0], buf);
262 return(1);
263 }
264 for (i = 0; i < GRIDRES; i++)
265 for (j = 0; j < GRIDRES; j++) {
266 ovec_from_pos(dir, i, j);
267 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
268 bsdf = log(bsdf) - min_log;
269 fprintf(pfp, "%.8e %.8e %.8e\n",
270 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
271 }
272 if (pclose(pfp) != 0)
273 return(1);
274 #endif
275 return(0);
276 }
277 #endif
