fix(pabopto2bsdf): Added declaration of popen() needed for Windows
feat(pabopto2bsdf): Made it so "-g auto" writes out minimum angle used in header
feat(pabopto2bsdf): Added -g option to cull grazing measurements from input
fix: hold off producing header until work is finished
fix: correction to last feature add
feat: Added "up" symmetry for duplicating data @ phi += 180 degrees
Simplified and improved last change
Added checks for other illegal phi coverage flags
Added -s option to specify input symmetry
Removed redundant debug output (already in bsdfrbf.c)
Added debug output of integrated scattering to pabopto2rad
Fixed issue with theta=0 inputs
Added -t option to reverse coordinate orientation
Removed redundant address operator
Bug fix for BTDF sample point plotting in debug version (pabopto2rad)
Made more accepting of older Mountain formats
Fixed format on debug statement
Changed behavior so bad incident directions are skipped rather than dying
Hopefully final change to angle collusion method
Fixed potential bug due with closely-spaced incident angles
Rejiggered epsilon tests so as not to confuse qsort()
Increased epsilon for incident angle equivalence test
Fixed pabopto2rad for new grid union
Fixed compiler warnings
Moved misplaced assignment
Added RBF peak locations to Radiance output (-DTEST_MAIN)
Added debugging output for pabopto2rad test module
Fixed brittle parser that was not recognizing format from different systems
Added normalization step for azimuth angle
Fixed debug output a bit
Added handling of multiple input files with identical incident angles
