--- ray/src/cv/pabopto2bsdf.c 2019/07/19 17:37:56 2.36 +++ ray/src/cv/pabopto2bsdf.c 2021/02/15 23:20:22 2.37 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.36 2019/07/19 17:37:56 greg Exp $"; +static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.37 2021/02/15 23:20:22 greg Exp $"; #endif /* * Load measured BSDF data in PAB-Opto format. @@ -29,7 +29,6 @@ typedef struct { } PGINPUT; PGINPUT *inpfile; /* input files sorted by incidence */ -int ninpfiles; /* number of input files */ int rev_orient = 0; /* shall we reverse surface orientation? */ @@ -47,12 +46,28 @@ cmp_indir(const void *p1, const void *p2) return(inp1->igp[0] - inp2->igp[0]); } +/* Assign grid position from theta and phi */ +static void +set_grid_pos(PGINPUT *pip) +{ + FVECT dv; + + if (pip->theta <= FTINY) { + pip->igp[0] = pip->igp[1] = grid_res/2 - 1; + return; + } + dv[2] = sin(M_PI/180.*pip->theta); + dv[0] = cos(M_PI/180.*pip->phi)*dv[2]; + dv[1] = sin(M_PI/180.*pip->phi)*dv[2]; + dv[2] = sqrt(1. - dv[2]*dv[2]); + pos_from_vec(pip->igp, dv); +} + /* Prepare a PAB-Opto input file by reading its header */ static int init_pabopto_inp(const int i, const char *fname) { FILE *fp = fopen(fname, "r"); - FVECT dv; char buf[2048]; int c; @@ -122,14 +137,7 @@ init_pabopto_inp(const int i, const char *fname) /* convert to Y-up orientation */ inpfile[i].phi += 90.-inpfile[i].up_phi; /* convert angle to grid position */ - dv[2] = sin(M_PI/180.*inpfile[i].theta); - dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2]; - dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2]; - dv[2] = sqrt(1. - dv[2]*dv[2]); - if (inpfile[i].theta <= FTINY) - inpfile[i].igp[0] = inpfile[i].igp[1] = grid_res/2 - 1; - else - pos_from_vec(inpfile[i].igp, dv); + set_grid_pos(&inpfile[i]); return(1); } @@ -174,8 +182,8 @@ add_pabopto_inp(const int i) theta_out = 180. - theta_out; phi_out = 360. - phi_out; } - add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi, - val, inpfile[i].isDSF); + phi_out += 90.-inpfile[i].up_phi; + add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF); } n = 0; while ((c = getc(fp)) != EOF) @@ -195,6 +203,7 @@ add_pabopto_inp(const int i) #define SYM_QUAD 'Q' /* quadrilateral symmetry */ #define SYM_BILAT 'B' /* bilateral symmetry */ #define SYM_ANISO 'A' /* anisotropic */ +#define SYM_UP 'U' /* "up-down" (180°) symmetry */ static const char quadrant_rep[16][16] = { "in-plane","0-90","90-180","0-180", @@ -215,57 +224,66 @@ int main(int argc, char *argv[]) { extern int nprocs; - const char *symmetry = "U"; - int i; + const char *symmetry = "0"; + int ninpfiles, totinc; + int a, i; /* start header */ SET_FILE_BINARY(stdout); newheader("RADIANCE", stdout); printargs(argc, argv, stdout); fputnow(stdout); progname = argv[0]; /* get options */ - while (argc > 2 && argv[1][0] == '-') { - switch (argv[1][1]) { + for (a = 1; a < argc && argv[a][0] == '-'; a++) + switch (argv[a][1]) { case 't': rev_orient = !rev_orient; break; case 'n': - nprocs = atoi(argv[2]); - argv++; argc--; + nprocs = atoi(argv[++a]); break; case 's': - symmetry = argv[2]; - argv++; argc--; + symmetry = argv[++a]; break; default: goto userr; } - argv++; argc--; - } - /* initialize & sort inputs */ - ninpfiles = argc - 1; + totinc = ninpfiles = argc - a; /* initialize & sort inputs */ if (ninpfiles < 2) goto userr; - inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles); + if (toupper(symmetry[0]) == SYM_UP) /* special case for "up" symmetry */ + totinc += ninpfiles; + inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*totinc); if (inpfile == NULL) return(1); for (i = 0; i < ninpfiles; i++) - if (!init_pabopto_inp(i, argv[i+1])) + if (!init_pabopto_inp(i, argv[a+i])) return(1); + + for (i = ninpfiles; i < totinc; i++) { /* copy for "up" symmetry */ + inpfile[i] = inpfile[i-ninpfiles]; + inpfile[i].phi += 180.; /* invert duplicate data */ + inpfile[i].up_phi -= 180.; + set_grid_pos(&inpfile[i]); /* grid location for sorting */ + } qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir); /* compile measurements */ - for (i = 0; i < ninpfiles; i++) + for (i = 0; i < totinc; i++) if (!add_pabopto_inp(i)) return(1); make_rbfrep(); /* process last data set */ /* check input symmetry */ switch (toupper(symmetry[0])) { - case 'U': /* unspecified symmetry */ + case '0': /* unspecified symmetry */ if (quadrant_sym[inp_coverage] != SYM_ILL) break; /* anything legal goes */ fprintf(stderr, "%s: unsupported phi coverage (%s)\n", progname, quadrant_rep[inp_coverage]); return(1); - case SYM_ISO: /* legal symmetry types */ + case SYM_UP: /* faux "up" symmetry */ + if (quadrant_sym[inp_coverage] == SYM_ANISO) + break; + /* fall through */ + case SYM_ISO: /* usual symmetry types */ case SYM_QUAD: case SYM_BILAT: case SYM_ANISO: @@ -277,7 +295,7 @@ main(int argc, char *argv[]) return(1); default: fprintf(stderr, - "%s: -s option must be Isotropic, Quadrilateral, Bilateral, or Anisotropic\n", + "%s: -s option must be Isotropic, Quadrilateral, Bilateral, Up, or Anisotropic\n", progname); return(1); } @@ -313,7 +331,6 @@ main(int argc, char *argv[]) fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname); return(1); } - ninpfiles = 1; inpfile = &pginp; if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0)) return(1);
