root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.29
Committed: Tue Feb 2 00:42:11 2016 UTC (9 years, 4 months ago) by greg
Changes since 2.28: +18 -3 lines
Added -t option to reverse coordinate orientation
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.28 2016/01/29 16:21:56 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 * Assumes that surface-normal (Z-axis) faces into room unless -t option given.
7 *
8 * G. Ward
9 */
10
11 #define _USE_MATH_DEFINES
12 #include <stdio.h>
13 #include <stdlib.h>
14 #include <string.h>
15 #include <ctype.h>
16 #include <math.h>
17 #include "platform.h"
18 #include "bsdfrep.h"
19 #include "resolu.h"
20 /* global argv[0] */
21 char *progname;
22
23 typedef struct {
24 const char *fname; /* input file path */
25 double theta, phi; /* input angles (degrees) */
26 double up_phi; /* azimuth for "up" direction */
27 int igp[2]; /* input grid position */
28 int isDSF; /* data is DSF (rather than BSDF)? */
29 int nspec; /* number of spectral samples */
30 long dstart; /* data start offset in file */
31 } PGINPUT;
32
33 PGINPUT *inpfile; /* input files sorted by incidence */
34 int ninpfiles; /* number of input files */
35
36 int rev_orient = 0; /* shall we reverse surface orientation? */
37
38 /* Compare incident angles */
39 static int
40 cmp_indir(const void *p1, const void *p2)
41 {
42 const PGINPUT *inp1 = (const PGINPUT *)p1;
43 const PGINPUT *inp2 = (const PGINPUT *)p2;
44 int ydif = inp1->igp[1] - inp2->igp[1];
45
46 if (ydif)
47 return(ydif);
48
49 return(inp1->igp[0] - inp2->igp[0]);
50 }
51
52 /* Prepare a PAB-Opto input file by reading its header */
53 static int
54 init_pabopto_inp(const int i, const char *fname)
55 {
56 FILE *fp = fopen(fname, "r");
57 FVECT dv;
58 char buf[2048];
59 int c;
60
61 if (fp == NULL) {
62 fputs(fname, stderr);
63 fputs(": cannot open\n", stderr);
64 return(0);
65 }
66 inpfile[i].fname = fname;
67 inpfile[i].isDSF = -1;
68 inpfile[i].nspec = 0;
69 inpfile[i].up_phi = 0;
70 inpfile[i].theta = inpfile[i].phi = -10001.;
71 /* read header information */
72 while ((c = getc(fp)) == '#' || c == EOF) {
73 char typ[64];
74 if (fgets(buf, sizeof(buf), fp) == NULL) {
75 fputs(fname, stderr);
76 fputs(": unexpected EOF\n", stderr);
77 fclose(fp);
78 return(0);
79 }
80 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
81 continue;
82 if (sscanf(buf, "colorimetry: %s", typ) == 1) {
83 if (!strcasecmp(typ, "CIE-XYZ"))
84 inpfile[i].nspec = 3;
85 else if (!strcasecmp(typ, "CIE-Y"))
86 inpfile[i].nspec = 1;
87 continue;
88 }
89 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
90 if (!strcasecmp(typ, "DSF"))
91 inpfile[i].isDSF = 1;
92 else if (!strcasecmp(typ, "BSDF") ||
93 !strcasecmp(typ, "BRDF") ||
94 !strcasecmp(typ, "BTDF"))
95 inpfile[i].isDSF = 0;
96 continue;
97 }
98 if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1)
99 continue;
100 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
101 continue;
102 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
103 continue;
104 if (sscanf(buf, "incident_angle %lf %lf",
105 &inpfile[i].theta, &inpfile[i].phi) == 2)
106 continue;
107 }
108 inpfile[i].dstart = ftell(fp) - 1;
109 fclose(fp);
110 if (inpfile[i].isDSF < 0) {
111 fputs(fname, stderr);
112 fputs(": unknown format\n", stderr);
113 return(0);
114 }
115 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
116 fputs(fname, stderr);
117 fputs(": unknown incident angle\n", stderr);
118 return(0);
119 }
120 if (rev_orient) { /* reverse Z-axis to face outside */
121 inpfile[i].theta = 180. - inpfile[i].theta;
122 inpfile[i].phi = 360. - inpfile[i].phi;
123 }
124 /* convert to Y-up orientation */
125 inpfile[i].phi += 90.-inpfile[i].up_phi;
126 /* convert angle to grid position */
127 dv[2] = sin(M_PI/180.*inpfile[i].theta);
128 dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2];
129 dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2];
130 dv[2] = sqrt(1. - dv[2]*dv[2]);
131 pos_from_vec(inpfile[i].igp, dv);
132 return(1);
133 }
134
135 /* Load a set of measurements corresponding to a particular incident angle */
136 static int
137 add_pabopto_inp(const int i)
138 {
139 FILE *fp = fopen(inpfile[i].fname, "r");
140 double theta_out, phi_out, val[3];
141 int n, c;
142
143 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
144 fputs(inpfile[i].fname, stderr);
145 fputs(": cannot open\n", stderr);
146 return(0);
147 }
148 /* prepare input grid */
149 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
150 if (i) /* process previous incidence */
151 make_rbfrep();
152 #ifdef DEBUG
153 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
154 inpfile[i].theta, inpfile[i].phi);
155 #endif
156 if (inpfile[i].nspec)
157 set_spectral_samples(inpfile[i].nspec);
158 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
159 }
160 #ifdef DEBUG
161 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
162 #endif
163 /* read scattering data */
164 while (fscanf(fp, "%lf %lf %lf", &theta_out, &phi_out, val) == 3) {
165 for (n = 1; n < inpfile[i].nspec; n++)
166 if (fscanf(fp, "%lf", val+n) != 1) {
167 fprintf(stderr, "%s: warning: unexpected EOF\n",
168 inpfile[i].fname);
169 fclose(fp);
170 return(1);
171 }
172 if (rev_orient) { /* reverse Z-axis to face outside */
173 theta_out = 180. - theta_out;
174 phi_out = 360. - phi_out;
175 }
176 add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi,
177 val, inpfile[i].isDSF);
178 }
179 n = 0;
180 while ((c = getc(fp)) != EOF)
181 n += !isspace(c);
182 if (n)
183 fprintf(stderr,
184 "%s: warning: %d unexpected characters past EOD\n",
185 inpfile[i].fname, n);
186 fclose(fp);
187 return(1);
188 }
189
190 #ifndef TEST_MAIN
191 /* Read in PAB-Opto BSDF files and output RBF interpolant */
192 int
193 main(int argc, char *argv[])
194 {
195 extern int nprocs;
196 int i;
197 /* start header */
198 SET_FILE_BINARY(stdout);
199 newheader("RADIANCE", stdout);
200 printargs(argc, argv, stdout);
201 fputnow(stdout);
202 progname = argv[0]; /* get options */
203 while (argc > 2 && argv[1][0] == '-') {
204 switch (argv[1][1]) {
205 case 't':
206 rev_orient = !rev_orient;
207 break;
208 case 'n':
209 nprocs = atoi(argv[2]);
210 argv++; argc--;
211 break;
212 default:
213 goto userr;
214 }
215 argv++; argc--;
216 }
217 /* initialize & sort inputs */
218 ninpfiles = argc - 1;
219 if (ninpfiles < 2)
220 goto userr;
221 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
222 if (inpfile == NULL)
223 return(1);
224 for (i = 0; i < ninpfiles; i++)
225 if (!init_pabopto_inp(i, argv[i+1]))
226 return(1);
227 qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir);
228 /* compile measurements */
229 for (i = 0; i < ninpfiles; i++)
230 if (!add_pabopto_inp(i))
231 return(1);
232 make_rbfrep(); /* process last data set */
233 build_mesh(); /* create interpolation */
234 save_bsdf_rep(stdout); /* write it out */
235 return(0);
236 userr:
237 fprintf(stderr, "Usage: %s [-t][-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
238 progname);
239 return(1);
240 }
241 #else
242 /* Test main produces a Radiance model from the given input file */
243 int
244 main(int argc, char *argv[])
245 {
246 PGINPUT pginp;
247 char buf[128];
248 FILE *pfp;
249 double bsdf, min_log;
250 FVECT dir;
251 int i, j, n;
252
253 progname = argv[0];
254 if (argc != 2) {
255 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
256 return(1);
257 }
258 ninpfiles = 1;
259 inpfile = &pginp;
260 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
261 return(1);
262 /* reduce data set */
263 if (make_rbfrep() == NULL) {
264 fprintf(stderr, "%s: nothing to plot!\n", progname);
265 exit(1);
266 }
267 #ifdef DEBUG
268 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
269 #endif
270 min_log = log(bsdf_min*.5 + 1e-5);
271 #if 1 /* produce spheres at meas. */
272 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
273 n = 0;
274 for (i = 0; i < grid_res; i++)
275 for (j = 0; j < grid_res; j++)
276 if (dsf_grid[i][j].sum.n > 0) {
277 ovec_from_pos(dir, i, j);
278 bsdf = dsf_grid[i][j].sum.v /
279 ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]);
280 if (bsdf <= bsdf_min*.6)
281 continue;
282 bsdf = log(bsdf + 1e-5) - min_log;
283 ovec_from_pos(dir, i, j);
284 printf("yellow sphere s%04d\n0\n0\n", ++n);
285 printf("4 %.6g %.6g %.6g %.6g\n\n",
286 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
287 .007*bsdf);
288 }
289 #endif
290 #if 1 /* spheres at RBF peaks */
291 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
292 for (n = 0; n < dsf_list->nrbf; n++) {
293 RBFVAL *rbf = &dsf_list->rbfa[n];
294 ovec_from_pos(dir, rbf->gx, rbf->gy);
295 bsdf = eval_rbfrep(dsf_list, dir);
296 bsdf = log(bsdf + 1e-5) - min_log;
297 printf("red sphere p%04d\n0\n0\n", ++n);
298 printf("4 %.6g %.6g %.6g %.6g\n\n",
299 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
300 .011*bsdf);
301 }
302 #endif
303 #if 1 /* output continuous surface */
304 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
305 fflush(stdout);
306 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", grid_res-1, grid_res-1);
307 pfp = popen(buf, "w");
308 if (pfp == NULL) {
309 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
310 return(1);
311 }
312 for (i = 0; i < grid_res; i++)
313 for (j = 0; j < grid_res; j++) {
314 ovec_from_pos(dir, i, j);
315 bsdf = eval_rbfrep(dsf_list, dir);
316 bsdf = log(bsdf + 1e-5) - min_log;
317 fprintf(pfp, "%.8e %.8e %.8e\n",
318 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
319 }
320 if (pclose(pfp) != 0)
321 return(1);
322 #endif
323 return(0);
324 }
325 #endif
