root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.23
Committed: Sun Mar 23 17:46:25 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.22: +4 -2 lines
Made more accepting of older Mountain formats
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.22 2014/03/21 23:11:44 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 *
7 * G. Ward
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <string.h>
14 #include <ctype.h>
15 #include <math.h>
16 #include "platform.h"
17 #include "bsdfrep.h"
18 #include "resolu.h"
19 /* global argv[0] */
20 char *progname;
21
22 typedef struct {
23 const char *fname; /* input file path */
24 double theta, phi; /* input angles */
25 int igp[2]; /* input grid position */
26 int isDSF; /* data is DSF (rather than BSDF)? */
27 long dstart; /* data start offset in file */
28 } PGINPUT;
29
30 PGINPUT *inpfile; /* input files sorted by incidence */
31 int ninpfiles; /* number of input files */
32
33 /* Compare incident angles */
34 static int
35 cmp_indir(const void *p1, const void *p2)
36 {
37 const PGINPUT *inp1 = (const PGINPUT *)p1;
38 const PGINPUT *inp2 = (const PGINPUT *)p2;
39 int ydif = inp1->igp[1] - inp2->igp[1];
40
41 if (ydif)
42 return(ydif);
43
44 return(inp1->igp[0] - inp2->igp[0]);
45 }
46
47 /* Prepare a PAB-Opto input file by reading its header */
48 static int
49 init_pabopto_inp(const int i, const char *fname)
50 {
51 FILE *fp = fopen(fname, "r");
52 FVECT dv;
53 char buf[2048];
54 int c;
55
56 if (fp == NULL) {
57 fputs(fname, stderr);
58 fputs(": cannot open\n", stderr);
59 return(0);
60 }
61 inpfile[i].fname = fname;
62 inpfile[i].isDSF = -1;
63 inpfile[i].theta = inpfile[i].phi = -10001.;
64 /* read header information */
65 while ((c = getc(fp)) == '#' || c == EOF) {
66 char typ[32];
67 if (fgets(buf, sizeof(buf), fp) == NULL) {
68 fputs(fname, stderr);
69 fputs(": unexpected EOF\n", stderr);
70 fclose(fp);
71 return(0);
72 }
73 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
74 continue;
75 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
76 if (!strcasecmp(typ, "DSF")) {
77 inpfile[i].isDSF = 1;
78 continue;
79 }
80 if (!strcasecmp(typ, "BSDF") ||
81 !strcasecmp(typ, "BRDF") ||
82 !strcasecmp(typ, "BTDF")) {
83 inpfile[i].isDSF = 0;
84 continue;
85 }
86 }
87 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
88 continue;
89 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
90 continue;
91 if (sscanf(buf, "incident_angle %lf %lf",
92 &inpfile[i].theta, &inpfile[i].phi) == 2)
93 continue;
94 }
95 inpfile[i].dstart = ftell(fp) - 1;
96 fclose(fp);
97 if (inpfile[i].isDSF < 0) {
98 fputs(fname, stderr);
99 fputs(": unknown format\n", stderr);
100 return(0);
101 }
102 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
103 fputs(fname, stderr);
104 fputs(": unknown incident angle\n", stderr);
105 return(0);
106 }
107 /* convert angle to grid position */
108 dv[2] = sin(M_PI/180.*inpfile[i].theta);
109 dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2];
110 dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2];
111 dv[2] = sqrt(1. - dv[2]*dv[2]);
112 pos_from_vec(inpfile[i].igp, dv);
113 return(1);
114 }
115
116 /* Load a set of measurements corresponding to a particular incident angle */
117 static int
118 add_pabopto_inp(const int i)
119 {
120 FILE *fp = fopen(inpfile[i].fname, "r");
121 double theta_out, phi_out, val;
122 int n, c;
123
124 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
125 fputs(inpfile[i].fname, stderr);
126 fputs(": cannot open\n", stderr);
127 return(0);
128 }
129 /* prepare input grid */
130 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
131 if (i) /* process previous incidence */
132 make_rbfrep();
133 #ifdef DEBUG
134 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
135 inpfile[i].theta, inpfile[i].phi);
136 #endif
137 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
138 }
139 #ifdef DEBUG
140 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
141 #endif
142 /* read scattering data */
143 while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3)
144 add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
145 n = 0;
146 while ((c = getc(fp)) != EOF)
147 n += !isspace(c);
148 if (n)
149 fprintf(stderr,
150 "%s: warning: %d unexpected characters past EOD\n",
151 inpfile[i].fname, n);
152 fclose(fp);
153 return(1);
154 }
155
156 #ifndef TEST_MAIN
157 /* Read in PAB-Opto BSDF files and output RBF interpolant */
158 int
159 main(int argc, char *argv[])
160 {
161 extern int nprocs;
162 int i;
163 /* start header */
164 SET_FILE_BINARY(stdout);
165 newheader("RADIANCE", stdout);
166 printargs(argc, argv, stdout);
167 fputnow(stdout);
168 progname = argv[0]; /* get options */
169 while (argc > 2 && argv[1][0] == '-') {
170 switch (argv[1][1]) {
171 case 'n':
172 nprocs = atoi(argv[2]);
173 break;
174 default:
175 goto userr;
176 }
177 argv += 2; argc -= 2;
178 }
179 /* initialize & sort inputs */
180 ninpfiles = argc - 1;
181 if (ninpfiles < 2)
182 goto userr;
183 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
184 if (inpfile == NULL)
185 return(1);
186 for (i = 0; i < ninpfiles; i++)
187 if (!init_pabopto_inp(i, argv[i+1]))
188 return(1);
189 qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_indir);
190 /* compile measurements */
191 for (i = 0; i < ninpfiles; i++)
192 if (!add_pabopto_inp(i))
193 return(1);
194 make_rbfrep(); /* process last data set */
195 build_mesh(); /* create interpolation */
196 save_bsdf_rep(stdout); /* write it out */
197 return(0);
198 userr:
199 fprintf(stderr, "Usage: %s [-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
200 progname);
201 return(1);
202 }
203 #else
204 /* Test main produces a Radiance model from the given input file */
205 int
206 main(int argc, char *argv[])
207 {
208 PGINPUT pginp;
209 char buf[128];
210 FILE *pfp;
211 double bsdf, min_log;
212 FVECT dir;
213 int i, j, n;
214
215 progname = argv[0];
216 if (argc != 2) {
217 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
218 return(1);
219 }
220 ninpfiles = 1;
221 inpfile = &pginp;
222 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
223 return(1);
224 /* reduce data set */
225 if (make_rbfrep() == NULL) {
226 fprintf(stderr, "%s: nothing to plot!\n", progname);
227 exit(1);
228 }
229 #ifdef DEBUG
230 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
231 #endif
232 min_log = log(bsdf_min*.5 + 1e-5);
233 #if 1 /* produce spheres at meas. */
234 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
235 n = 0;
236 for (i = 0; i < GRIDRES; i++)
237 for (j = 0; j < GRIDRES; j++)
238 if (dsf_grid[i][j].sum.n > 0) {
239 ovec_from_pos(dir, i, j);
240 bsdf = dsf_grid[i][j].sum.v /
241 (dsf_grid[i][j].sum.n*output_orient*dir[2]);
242 if (bsdf <= bsdf_min*.6)
243 continue;
244 bsdf = log(bsdf + 1e-5) - min_log;
245 ovec_from_pos(dir, i, j);
246 printf("yellow sphere s%04d\n0\n0\n", ++n);
247 printf("4 %.6g %.6g %.6g %.6g\n\n",
248 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
249 .007*bsdf);
250 }
251 #endif
252 #if 1 /* spheres at RBF peaks */
253 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
254 for (n = 0; n < dsf_list->nrbf; n++) {
255 RBFVAL *rbf = &dsf_list->rbfa[n];
256 ovec_from_pos(dir, rbf->gx, rbf->gy);
257 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
258 bsdf = log(bsdf + 1e-5) - min_log;
259 printf("red sphere p%04d\n0\n0\n", ++n);
260 printf("4 %.6g %.6g %.6g %.6g\n\n",
261 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
262 .011*bsdf);
263 }
264 #endif
265 #if 1 /* output continuous surface */
266 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
267 fflush(stdout);
268 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1);
269 pfp = popen(buf, "w");
270 if (pfp == NULL) {
271 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
272 return(1);
273 }
274 for (i = 0; i < GRIDRES; i++)
275 for (j = 0; j < GRIDRES; j++) {
276 ovec_from_pos(dir, i, j);
277 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
278 bsdf = log(bsdf + 1e-5) - min_log;
279 fprintf(pfp, "%.8e %.8e %.8e\n",
280 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
281 }
282 if (pclose(pfp) != 0)
283 return(1);
284 #endif
285 return(0);
286 }
287 #endif
