root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.30
Committed: Tue May 16 20:41:03 2017 UTC (8 years, 2 months ago) by greg
CVS Tags: rad5R2, rad5R1
Changes since 2.29: +5 -2 lines
Fixed issue with theta=0 inputs
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.29 2016/02/02 00:42:11 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 * Assumes that surface-normal (Z-axis) faces into room unless -t option given.
7 *
8 * G. Ward
9 */
10
11 #define _USE_MATH_DEFINES
12 #include <stdio.h>
13 #include <stdlib.h>
14 #include <string.h>
15 #include <ctype.h>
16 #include <math.h>
17 #include "platform.h"
18 #include "bsdfrep.h"
19 #include "resolu.h"
20 /* global argv[0] */
21 char *progname;
22
23 typedef struct {
24 const char *fname; /* input file path */
25 double theta, phi; /* input angles (degrees) */
26 double up_phi; /* azimuth for "up" direction */
27 int igp[2]; /* input grid position */
28 int isDSF; /* data is DSF (rather than BSDF)? */
29 int nspec; /* number of spectral samples */
30 long dstart; /* data start offset in file */
31 } PGINPUT;
32
33 PGINPUT *inpfile; /* input files sorted by incidence */
34 int ninpfiles; /* number of input files */
35
36 int rev_orient = 0; /* shall we reverse surface orientation? */
37
38 /* Compare incident angles */
39 static int
40 cmp_indir(const void *p1, const void *p2)
41 {
42 const PGINPUT *inp1 = (const PGINPUT *)p1;
43 const PGINPUT *inp2 = (const PGINPUT *)p2;
44 int ydif = inp1->igp[1] - inp2->igp[1];
45
46 if (ydif)
47 return(ydif);
48
49 return(inp1->igp[0] - inp2->igp[0]);
50 }
51
52 /* Prepare a PAB-Opto input file by reading its header */
53 static int
54 init_pabopto_inp(const int i, const char *fname)
55 {
56 FILE *fp = fopen(fname, "r");
57 FVECT dv;
58 char buf[2048];
59 int c;
60
61 if (fp == NULL) {
62 fputs(fname, stderr);
63 fputs(": cannot open\n", stderr);
64 return(0);
65 }
66 inpfile[i].fname = fname;
67 inpfile[i].isDSF = -1;
68 inpfile[i].nspec = 0;
69 inpfile[i].up_phi = 0;
70 inpfile[i].theta = inpfile[i].phi = -10001.;
71 /* read header information */
72 while ((c = getc(fp)) == '#' || c == EOF) {
73 char typ[64];
74 if (fgets(buf, sizeof(buf), fp) == NULL) {
75 fputs(fname, stderr);
76 fputs(": unexpected EOF\n", stderr);
77 fclose(fp);
78 return(0);
79 }
80 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
81 continue;
82 if (sscanf(buf, "colorimetry: %s", typ) == 1) {
83 if (!strcasecmp(typ, "CIE-XYZ"))
84 inpfile[i].nspec = 3;
85 else if (!strcasecmp(typ, "CIE-Y"))
86 inpfile[i].nspec = 1;
87 continue;
88 }
89 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
90 if (!strcasecmp(typ, "DSF"))
91 inpfile[i].isDSF = 1;
92 else if (!strcasecmp(typ, "BSDF") ||
93 !strcasecmp(typ, "BRDF") ||
94 !strcasecmp(typ, "BTDF"))
95 inpfile[i].isDSF = 0;
96 continue;
97 }
98 if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1)
99 continue;
100 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
101 continue;
102 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
103 continue;
104 if (sscanf(buf, "incident_angle %lf %lf",
105 &inpfile[i].theta, &inpfile[i].phi) == 2)
106 continue;
107 }
108 inpfile[i].dstart = ftell(fp) - 1;
109 fclose(fp);
110 if (inpfile[i].isDSF < 0) {
111 fputs(fname, stderr);
112 fputs(": unknown format\n", stderr);
113 return(0);
114 }
115 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
116 fputs(fname, stderr);
117 fputs(": unknown incident angle\n", stderr);
118 return(0);
119 }
120 if (rev_orient) { /* reverse Z-axis to face outside */
121 inpfile[i].theta = 180. - inpfile[i].theta;
122 inpfile[i].phi = 360. - inpfile[i].phi;
123 }
124 /* convert to Y-up orientation */
125 inpfile[i].phi += 90.-inpfile[i].up_phi;
126 /* convert angle to grid position */
127 dv[2] = sin(M_PI/180.*inpfile[i].theta);
128 dv[0] = cos(M_PI/180.*inpfile[i].phi)*dv[2];
129 dv[1] = sin(M_PI/180.*inpfile[i].phi)*dv[2];
130 dv[2] = sqrt(1. - dv[2]*dv[2]);
131 if (inpfile[i].theta <= FTINY)
132 inpfile[i].igp[0] = inpfile[i].igp[1] = grid_res/2 - 1;
133 else
134 pos_from_vec(inpfile[i].igp, dv);
135 return(1);
136 }
137
138 /* Load a set of measurements corresponding to a particular incident angle */
139 static int
140 add_pabopto_inp(const int i)
141 {
142 FILE *fp = fopen(inpfile[i].fname, "r");
143 double theta_out, phi_out, val[3];
144 int n, c;
145
146 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
147 fputs(inpfile[i].fname, stderr);
148 fputs(": cannot open\n", stderr);
149 return(0);
150 }
151 /* prepare input grid */
152 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
153 if (i) /* process previous incidence */
154 make_rbfrep();
155 #ifdef DEBUG
156 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
157 inpfile[i].theta, inpfile[i].phi);
158 #endif
159 if (inpfile[i].nspec)
160 set_spectral_samples(inpfile[i].nspec);
161 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
162 }
163 #ifdef DEBUG
164 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
165 #endif
166 /* read scattering data */
167 while (fscanf(fp, "%lf %lf %lf", &theta_out, &phi_out, val) == 3) {
168 for (n = 1; n < inpfile[i].nspec; n++)
169 if (fscanf(fp, "%lf", val+n) != 1) {
170 fprintf(stderr, "%s: warning: unexpected EOF\n",
171 inpfile[i].fname);
172 fclose(fp);
173 return(1);
174 }
175 if (rev_orient) { /* reverse Z-axis to face outside */
176 theta_out = 180. - theta_out;
177 phi_out = 360. - phi_out;
178 }
179 add_bsdf_data(theta_out, phi_out+90.-inpfile[i].up_phi,
180 val, inpfile[i].isDSF);
181 }
182 n = 0;
183 while ((c = getc(fp)) != EOF)
184 n += !isspace(c);
185 if (n)
186 fprintf(stderr,
187 "%s: warning: %d unexpected characters past EOD\n",
188 inpfile[i].fname, n);
189 fclose(fp);
190 return(1);
191 }
192
193 #ifndef TEST_MAIN
194 /* Read in PAB-Opto BSDF files and output RBF interpolant */
195 int
196 main(int argc, char *argv[])
197 {
198 extern int nprocs;
199 int i;
200 /* start header */
201 SET_FILE_BINARY(stdout);
202 newheader("RADIANCE", stdout);
203 printargs(argc, argv, stdout);
204 fputnow(stdout);
205 progname = argv[0]; /* get options */
206 while (argc > 2 && argv[1][0] == '-') {
207 switch (argv[1][1]) {
208 case 't':
209 rev_orient = !rev_orient;
210 break;
211 case 'n':
212 nprocs = atoi(argv[2]);
213 argv++; argc--;
214 break;
215 default:
216 goto userr;
217 }
218 argv++; argc--;
219 }
220 /* initialize & sort inputs */
221 ninpfiles = argc - 1;
222 if (ninpfiles < 2)
223 goto userr;
224 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
225 if (inpfile == NULL)
226 return(1);
227 for (i = 0; i < ninpfiles; i++)
228 if (!init_pabopto_inp(i, argv[i+1]))
229 return(1);
230 qsort(inpfile, ninpfiles, sizeof(PGINPUT), cmp_indir);
231 /* compile measurements */
232 for (i = 0; i < ninpfiles; i++)
233 if (!add_pabopto_inp(i))
234 return(1);
235 make_rbfrep(); /* process last data set */
236 build_mesh(); /* create interpolation */
237 save_bsdf_rep(stdout); /* write it out */
238 return(0);
239 userr:
240 fprintf(stderr, "Usage: %s [-t][-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
241 progname);
242 return(1);
243 }
244 #else
245 /* Test main produces a Radiance model from the given input file */
246 int
247 main(int argc, char *argv[])
248 {
249 PGINPUT pginp;
250 char buf[128];
251 FILE *pfp;
252 double bsdf, min_log;
253 FVECT dir;
254 int i, j, n;
255
256 progname = argv[0];
257 if (argc != 2) {
258 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
259 return(1);
260 }
261 ninpfiles = 1;
262 inpfile = &pginp;
263 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
264 return(1);
265 /* reduce data set */
266 if (make_rbfrep() == NULL) {
267 fprintf(stderr, "%s: nothing to plot!\n", progname);
268 exit(1);
269 }
270 #ifdef DEBUG
271 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
272 #endif
273 min_log = log(bsdf_min*.5 + 1e-5);
274 #if 1 /* produce spheres at meas. */
275 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
276 n = 0;
277 for (i = 0; i < grid_res; i++)
278 for (j = 0; j < grid_res; j++)
279 if (dsf_grid[i][j].sum.n > 0) {
280 ovec_from_pos(dir, i, j);
281 bsdf = dsf_grid[i][j].sum.v /
282 ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]);
283 if (bsdf <= bsdf_min*.6)
284 continue;
285 bsdf = log(bsdf + 1e-5) - min_log;
286 ovec_from_pos(dir, i, j);
287 printf("yellow sphere s%04d\n0\n0\n", ++n);
288 printf("4 %.6g %.6g %.6g %.6g\n\n",
289 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
290 .007*bsdf);
291 }
292 #endif
293 #if 1 /* spheres at RBF peaks */
294 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
295 for (n = 0; n < dsf_list->nrbf; n++) {
296 RBFVAL *rbf = &dsf_list->rbfa[n];
297 ovec_from_pos(dir, rbf->gx, rbf->gy);
298 bsdf = eval_rbfrep(dsf_list, dir);
299 bsdf = log(bsdf + 1e-5) - min_log;
300 printf("red sphere p%04d\n0\n0\n", ++n);
301 printf("4 %.6g %.6g %.6g %.6g\n\n",
302 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
303 .011*bsdf);
304 }
305 #endif
306 #if 1 /* output continuous surface */
307 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
308 fflush(stdout);
309 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", grid_res-1, grid_res-1);
310 pfp = popen(buf, "w");
311 if (pfp == NULL) {
312 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
313 return(1);
314 }
315 for (i = 0; i < grid_res; i++)
316 for (j = 0; j < grid_res; j++) {
317 ovec_from_pos(dir, i, j);
318 bsdf = eval_rbfrep(dsf_list, dir);
319 bsdf = log(bsdf + 1e-5) - min_log;
320 fprintf(pfp, "%.8e %.8e %.8e\n",
321 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
322 }
323 if (pclose(pfp) != 0)
324 return(1);
325 #endif
326 return(0);
327 }
328 #endif
