root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.17
Committed: Tue Mar 18 19:08:24 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.16: +7 -5 lines
Increased epsilon for incident angle equivalence test
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.16 2014/03/17 01:52:51 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 *
7 * G. Ward
8 */
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <string.h>
13 #include <ctype.h>
14 #include <math.h>
15 #include "platform.h"
16 #include "bsdfrep.h"
17 #include "resolu.h"
18 /* global argv[0] */
19 char *progname;
20
21 typedef struct {
22 const char *fname; /* input file path */
23 double theta, phi; /* incident angles (in degrees) */
24 int isDSF; /* data is DSF (rather than BSDF)? */
25 long dstart; /* data start offset in file */
26 } PGINPUT;
27
28 const double ANGLE_EPS = 180./2./GRIDRES;
29
30 PGINPUT *inpfile; /* input files sorted by incidence */
31 int ninpfiles; /* number of input files */
32
33 /* Compare incident angles */
34 static int
35 cmp_inang(const void *p1, const void *p2)
36 {
37 const PGINPUT *inp1 = (const PGINPUT *)p1;
38 const PGINPUT *inp2 = (const PGINPUT *)p2;
39
40 if (inp1->theta > inp2->theta+ANGLE_EPS)
41 return(1);
42 if (inp1->theta < inp2->theta-ANGLE_EPS)
43 return(-1);
44 if (inp1->phi > inp2->phi+ANGLE_EPS)
45 return(1);
46 if (inp1->phi < inp2->phi-ANGLE_EPS)
47 return(-1);
48 return(0);
49 }
50
51 /* Prepare a PAB-Opto input file by reading its header */
52 static int
53 init_pabopto_inp(const int i, const char *fname)
54 {
55 FILE *fp = fopen(fname, "r");
56 char buf[2048];
57 int c;
58
59 if (fp == NULL) {
60 fputs(fname, stderr);
61 fputs(": cannot open\n", stderr);
62 return(0);
63 }
64 inpfile[i].fname = fname;
65 inpfile[i].isDSF = -1;
66 inpfile[i].theta = inpfile[i].phi = -10001.;
67 /* read header information */
68 while ((c = getc(fp)) == '#' || c == EOF) {
69 char typ[32];
70 if (fgets(buf, sizeof(buf), fp) == NULL) {
71 fputs(fname, stderr);
72 fputs(": unexpected EOF\n", stderr);
73 fclose(fp);
74 return(0);
75 }
76 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
77 continue;
78 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
79 if (!strcasecmp(typ, "DSF")) {
80 inpfile[i].isDSF = 1;
81 continue;
82 }
83 if (!strcasecmp(typ, "BSDF")) {
84 inpfile[i].isDSF = 0;
85 continue;
86 }
87 }
88 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
89 continue;
90 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
91 continue;
92 if (sscanf(buf, "incident_angle %lf %lf",
93 &inpfile[i].theta, &inpfile[i].phi) == 2)
94 continue;
95 }
96 inpfile[i].dstart = ftell(fp) - 1;
97 fclose(fp);
98 if (inpfile[i].isDSF < 0) {
99 fputs(fname, stderr);
100 fputs(": unknown format\n", stderr);
101 return(0);
102 }
103 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
104 fputs(fname, stderr);
105 fputs(": unknown incident angle\n", stderr);
106 return(0);
107 }
108 while (inpfile[i].phi < 0) /* normalize phi direction */
109 inpfile[i].phi += 360.;
110 return(1);
111 }
112
113 /* Load a set of measurements corresponding to a particular incident angle */
114 static int
115 add_pabopto_inp(const int i)
116 {
117 FILE *fp = fopen(inpfile[i].fname, "r");
118 double theta_out, phi_out, val;
119 int n, c;
120
121 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
122 fputs(inpfile[i].fname, stderr);
123 fputs(": cannot open\n", stderr);
124 return(0);
125 }
126 /* prepare input grid */
127 if (!i || cmp_inang(&inpfile[i-1], &inpfile[i])) {
128 if (i) /* need to process previous incidence */
129 make_rbfrep();
130 #ifdef DEBUG
131 fprintf(stderr, "New incident (theta,phi)=(%f,%f)\n",
132 inpfile[i].theta, inpfile[i].phi);
133 #endif
134 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
135 }
136 #ifdef DEBUG
137 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
138 #endif
139 /* read scattering data */
140 while (fscanf(fp, "%lf %lf %lf\n", &theta_out, &phi_out, &val) == 3)
141 add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
142 n = 0;
143 while ((c = getc(fp)) != EOF)
144 n += !isspace(c);
145 if (n)
146 fprintf(stderr,
147 "%s: warning: %d unexpected characters past EOD\n",
148 inpfile[i].fname, n);
149 fclose(fp);
150 return(1);
151 }
152
153 #ifndef TEST_MAIN
154 /* Read in PAB-Opto BSDF files and output RBF interpolant */
155 int
156 main(int argc, char *argv[])
157 {
158 extern int nprocs;
159 int i;
160 /* start header */
161 SET_FILE_BINARY(stdout);
162 newheader("RADIANCE", stdout);
163 printargs(argc, argv, stdout);
164 fputnow(stdout);
165 progname = argv[0]; /* get options */
166 while (argc > 2 && argv[1][0] == '-') {
167 switch (argv[1][1]) {
168 case 'n':
169 nprocs = atoi(argv[2]);
170 break;
171 default:
172 goto userr;
173 }
174 argv += 2; argc -= 2;
175 }
176 /* initialize & sort inputs */
177 ninpfiles = argc - 1;
178 if (ninpfiles < 2)
179 goto userr;
180 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*ninpfiles);
181 if (inpfile == NULL)
182 return(1);
183 for (i = 0; i < ninpfiles; i++)
184 if (!init_pabopto_inp(i, argv[i+1]))
185 return(1);
186 qsort(inpfile, ninpfiles, sizeof(PGINPUT), &cmp_inang);
187 /* compile measurements */
188 for (i = 0; i < ninpfiles; i++)
189 if (!add_pabopto_inp(i))
190 return(1);
191 make_rbfrep(); /* process last data set */
192 build_mesh(); /* create interpolation */
193 save_bsdf_rep(stdout); /* write it out */
194 return(0);
195 userr:
196 fprintf(stderr, "Usage: %s [-n nproc] meas1.dat meas2.dat .. > bsdf.sir\n",
197 progname);
198 return(1);
199 }
200 #else
201 /* Test main produces a Radiance model from the given input file */
202 int
203 main(int argc, char *argv[])
204 {
205 PGINPUT pginp;
206 char buf[128];
207 FILE *pfp;
208 double bsdf, min_log;
209 FVECT dir;
210 int i, j, n;
211
212 if (argc != 2) {
213 fprintf(stderr, "Usage: %s input.dat > output.rad\n", argv[0]);
214 return(1);
215 }
216 ninpfiles = 1;
217 inpfile = &pginp;
218 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
219 return(1);
220 /* reduce data set */
221 make_rbfrep();
222 #ifdef DEBUG
223 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
224 #endif
225 min_log = log(bsdf_min*.5 + 1e-5);
226 #if 1 /* produce spheres at meas. */
227 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
228 n = 0;
229 for (i = 0; i < GRIDRES; i++)
230 for (j = 0; j < GRIDRES; j++)
231 if (dsf_grid[i][j].sum.n > 0) {
232 ovec_from_pos(dir, i, j);
233 bsdf = dsf_grid[i][j].sum.v /
234 (dsf_grid[i][j].sum.n*output_orient*dir[2]);
235 if (bsdf <= bsdf_min*.6)
236 continue;
237 bsdf = log(bsdf + 1e-5) - min_log;
238 ovec_from_pos(dir, i, j);
239 printf("yellow sphere s%04d\n0\n0\n", ++n);
240 printf("4 %.6g %.6g %.6g %.6g\n\n",
241 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
242 .007*bsdf);
243 }
244 #endif
245 #if 1 /* spheres at RBF peaks */
246 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
247 for (n = 0; n < dsf_list->nrbf; n++) {
248 RBFVAL *rbf = &dsf_list->rbfa[n];
249 ovec_from_pos(dir, rbf->gx, rbf->gy);
250 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
251 bsdf = log(bsdf + 1e-5) - min_log;
252 printf("red sphere p%04d\n0\n0\n", ++n);
253 printf("4 %.6g %.6g %.6g %.6g\n\n",
254 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
255 .011*bsdf);
256 }
257 #endif
258 #if 1 /* output continuous surface */
259 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
260 fflush(stdout);
261 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", GRIDRES-1, GRIDRES-1);
262 pfp = popen(buf, "w");
263 if (pfp == NULL) {
264 fprintf(stderr, "%s: cannot open '| %s'\n", argv[0], buf);
265 return(1);
266 }
267 for (i = 0; i < GRIDRES; i++)
268 for (j = 0; j < GRIDRES; j++) {
269 ovec_from_pos(dir, i, j);
270 bsdf = eval_rbfrep(dsf_list, dir) / (output_orient*dir[2]);
271 bsdf = log(bsdf + 1e-5) - min_log;
272 fprintf(pfp, "%.8e %.8e %.8e\n",
273 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
274 }
275 if (pclose(pfp) != 0)
276 return(1);
277 #endif
278 return(0);
279 }
280 #endif
