root/radiance/ray/src/cv/pabopto2bsdf.c
Revision: 2.42
Committed: Mon Nov 21 18:28:24 2022 UTC (2 years, 7 months ago) by greg
fix(pabopto2bsdf): Added declaration of popen() needed for Windows
2 static const char RCSid[] = "$Id: pabopto2bsdf.c,v 2.41 2021/04/05 21:06:32 greg Exp $";
5 * Load measured BSDF data in PAB-Opto format.
6 * Assumes that surface-normal (Z-axis) faces into room unless -t option given.
7 *
8 * G. Ward
9 */
10
11 #define _USE_MATH_DEFINES
12 #include <stdlib.h>
13 #include <ctype.h>
14 #include <math.h>
15 #include "rtio.h"
16 #include "platform.h"
17 #include "paths.h"
18 #include "bsdfrep.h"
19 /* global argv[0] */
20 char *progname;
21
22 typedef struct {
23 const char *fname; /* input file path */
24 double theta, phi; /* input angles (degrees) */
25 double up_phi; /* azimuth for "up" direction */
26 int igp[2]; /* input grid position */
27 int isDSF; /* data is DSF (rather than BSDF)? */
28 int nspec; /* number of spectral samples */
29 long dstart; /* data start offset in file */
30 } PGINPUT;
31
32 PGINPUT *inpfile; /* input files sorted by incidence */
33
34 int rev_orient = 0; /* shall we reverse surface orientation? */
35
36 double lim_graze = 0; /* limit scattering near grazing (deg above) */
37
38 /* Compare incident angles */
39 static int
40 cmp_indir(const void *p1, const void *p2)
41 {
42 const PGINPUT *inp1 = (const PGINPUT *)p1;
43 const PGINPUT *inp2 = (const PGINPUT *)p2;
44 int ydif = inp1->igp[1] - inp2->igp[1];
45
46 if (ydif)
47 return(ydif);
48
49 return(inp1->igp[0] - inp2->igp[0]);
50 }
51
52 /* Assign grid position from theta and phi */
53 static void
54 set_grid_pos(PGINPUT *pip)
55 {
56 FVECT dv;
57
58 if (pip->theta <= FTINY) {
59 pip->igp[0] = pip->igp[1] = grid_res/2 - 1;
60 return;
61 }
62 dv[2] = sin(M_PI/180.*pip->theta);
63 dv[0] = cos(M_PI/180.*pip->phi)*dv[2];
64 dv[1] = sin(M_PI/180.*pip->phi)*dv[2];
65 dv[2] = sqrt(1. - dv[2]*dv[2]);
66 pos_from_vec(pip->igp, dv);
67 }
68
69 /* Prepare a PAB-Opto input file by reading its header */
70 static int
71 init_pabopto_inp(const int i, const char *fname)
72 {
73 FILE *fp = fopen(fname, "r");
74 char buf[2048];
75 int c;
76
77 if (fp == NULL) {
78 fputs(fname, stderr);
79 fputs(": cannot open\n", stderr);
80 return(0);
81 }
82 inpfile[i].fname = fname;
83 inpfile[i].isDSF = -1;
84 inpfile[i].nspec = 0;
85 inpfile[i].up_phi = 0;
86 inpfile[i].theta = inpfile[i].phi = -10001.;
87 /* read header information */
88 while ((c = getc(fp)) == '#' || c == EOF) {
89 char typ[64];
90 if (fgets(buf, sizeof(buf), fp) == NULL) {
91 fputs(fname, stderr);
92 fputs(": unexpected EOF\n", stderr);
93 fclose(fp);
94 return(0);
95 }
96 if (sscanf(buf, "sample_name \"%[^\"]\"", bsdf_name) == 1)
97 continue;
98 if (sscanf(buf, "colorimetry: %s", typ) == 1) {
99 if (!strcasecmp(typ, "CIE-XYZ"))
100 inpfile[i].nspec = 3;
101 else if (!strcasecmp(typ, "CIE-Y"))
102 inpfile[i].nspec = 1;
103 continue;
104 }
105 if (sscanf(buf, "format: theta phi %s", typ) == 1) {
106 if (!strcasecmp(typ, "DSF"))
107 inpfile[i].isDSF = 1;
108 else if (!strcasecmp(typ, "BSDF") ||
109 !strcasecmp(typ, "BRDF") ||
110 !strcasecmp(typ, "BTDF"))
111 inpfile[i].isDSF = 0;
112 continue;
113 }
114 if (sscanf(buf, "upphi %lf", &inpfile[i].up_phi) == 1)
115 continue;
116 if (sscanf(buf, "intheta %lf", &inpfile[i].theta) == 1)
117 continue;
118 if (sscanf(buf, "inphi %lf", &inpfile[i].phi) == 1)
119 continue;
120 if (sscanf(buf, "incident_angle %lf %lf",
121 &inpfile[i].theta, &inpfile[i].phi) == 2)
122 continue;
123 }
124 inpfile[i].dstart = ftell(fp) - 1;
125 fclose(fp);
126 if (inpfile[i].isDSF < 0) {
127 fputs(fname, stderr);
128 fputs(": unknown format\n", stderr);
129 return(0);
130 }
131 if ((inpfile[i].theta < -10000.) | (inpfile[i].phi < -10000.)) {
132 fputs(fname, stderr);
133 fputs(": unknown incident angle\n", stderr);
134 return(0);
135 }
136 if (rev_orient) { /* reverse Z-axis to face outside */
137 inpfile[i].theta = 180. - inpfile[i].theta;
138 inpfile[i].phi = 360. - inpfile[i].phi;
139 }
140 /* convert to Y-up orientation */
141 inpfile[i].phi += 90.-inpfile[i].up_phi;
142 /* convert angle to grid position */
143 set_grid_pos(&inpfile[i]);
144 return(1);
145 }
146
147 /* Load a set of measurements corresponding to a particular incident angle */
148 static int
149 add_pabopto_inp(const int i)
150 {
151 FILE *fp = fopen(inpfile[i].fname, "r");
152 double theta_out, phi_out, val[3];
153 int n, c;
154
155 if (fp == NULL || fseek(fp, inpfile[i].dstart, 0) == EOF) {
156 fputs(inpfile[i].fname, stderr);
157 fputs(": cannot open\n", stderr);
158 return(0);
159 }
160 /* prepare input grid */
161 if (!i || cmp_indir(&inpfile[i-1], &inpfile[i])) {
162 if (i) /* process previous incidence */
163 make_rbfrep();
164 #ifdef DEBUG
165 fprintf(stderr, "New incident (theta,phi)=(%.1f,%.1f)\n",
166 inpfile[i].theta, inpfile[i].phi);
167 #endif
168 if (inpfile[i].nspec)
169 set_spectral_samples(inpfile[i].nspec);
170 new_bsdf_data(inpfile[i].theta, inpfile[i].phi);
171 }
172 #ifdef DEBUG
173 fprintf(stderr, "Loading measurements from '%s'...\n", inpfile[i].fname);
174 #endif
175 /* read scattering data */
176 while (fscanf(fp, "%lf %lf %lf", &theta_out, &phi_out, val) == 3) {
177 for (n = 1; n < inpfile[i].nspec; n++)
178 if (fscanf(fp, "%lf", val+n) != 1) {
179 fprintf(stderr, "%s: warning: unexpected EOF\n",
180 inpfile[i].fname);
181 fclose(fp);
182 return(1);
183 }
184 /* check if scatter angle is too low */
185 if (fabs(theta_out - 90.) < lim_graze-FTINY)
186 continue;
187 if (rev_orient) { /* reverse Z-axis to face outside? */
188 theta_out = 180. - theta_out;
189 phi_out = 360. - phi_out;
190 }
191 phi_out += 90.-inpfile[i].up_phi;
192 add_bsdf_data(theta_out, phi_out, val, inpfile[i].isDSF);
193 }
194 n = 0;
195 while ((c = getc(fp)) != EOF)
196 n += !isspace(c);
197 if (n)
198 fprintf(stderr,
199 "%s: warning: %d unexpected characters past EOD\n",
200 inpfile[i].fname, n);
201 fclose(fp);
202 return(1);
203 }
204
205 #ifndef TEST_MAIN
206
207 #define SYM_ILL '?' /* illegal symmetry value */
208 #define SYM_ISO 'I' /* isotropic */
209 #define SYM_QUAD 'Q' /* quadrilateral symmetry */
210 #define SYM_BILAT 'B' /* bilateral symmetry */
211 #define SYM_ANISO 'A' /* anisotropic */
212 #define SYM_UP 'U' /* "up-down" (180°) symmetry */
213
214 static const char quadrant_rep[16][16] = {
215 "in-plane","0-90","90-180","0-180",
216 "180-270","0-90+180-270","90-270",
217 "0-270","270-360","270-90",
218 "90-180+270-360","270-180","180-360",
219 "180-90","90-360","0-360"
220 };
221 static const char quadrant_sym[16] = {
222 SYM_ISO, SYM_QUAD, SYM_QUAD, SYM_BILAT,
223 SYM_QUAD, SYM_ILL, SYM_BILAT, SYM_ILL,
224 SYM_QUAD, SYM_BILAT, SYM_ILL, SYM_ILL,
225 SYM_BILAT, SYM_ILL, SYM_ILL, SYM_ANISO
226 };
227
228 /* Read in PAB-Opto BSDF files and output RBF interpolant */
229 int
230 main(int argc, char *argv[])
231 {
232 extern int nprocs;
233 static char gval_buf[16];
234 char * auto_grazing = NULL;
235 const char *symmetry = "0";
236 int ninpfiles, totinc;
237 int a, i;
238
239 progname = argv[0]; /* get options */
240 for (a = 1; a < argc && argv[a][0] == '-'; a++)
241 switch (argv[a][1]) {
242 case 't':
243 rev_orient = !rev_orient;
244 break;
245 case 'n':
246 nprocs = atoi(argv[++a]);
247 break;
248 case 's':
249 symmetry = argv[++a];
250 break;
251 case 'g':
252 if (toupper(argv[a+1][0]) == 'A')
253 auto_grazing = argv[a+1] = gval_buf;
254 else
255 lim_graze = atof(argv[a+1]);
256 ++a;
257 break;
258 default:
259 goto userr;
260 }
261 totinc = ninpfiles = argc - a; /* initialize & sort inputs */
262 if (ninpfiles < 2)
263 goto userr;
264 if (toupper(symmetry[0]) == SYM_UP) /* special case for "up" symmetry */
265 totinc += ninpfiles;
266 inpfile = (PGINPUT *)malloc(sizeof(PGINPUT)*totinc);
267 if (inpfile == NULL)
268 return(1);
269 if (auto_grazing)
270 lim_graze = 90.;
271 for (i = 0; i < ninpfiles; i++) {
272 if (!init_pabopto_inp(i, argv[a+i]))
273 return(1);
274 if (auto_grazing && fabs(inpfile[i].theta - 90.) < lim_graze)
275 lim_graze = fabs(inpfile[i].theta - 90.);
276 }
277 if (auto_grazing)
278 sprintf(auto_grazing, "%.2f", lim_graze);
279 for (i = ninpfiles; i < totinc; i++) { /* copy for "up" symmetry */
280 inpfile[i] = inpfile[i-ninpfiles];
281 inpfile[i].phi += 180.; /* invert duplicate data */
282 inpfile[i].up_phi -= 180.;
283 set_grid_pos(&inpfile[i]); /* grid location for sorting */
284 }
285 qsort(inpfile, totinc, sizeof(PGINPUT), cmp_indir);
286 /* compile measurements */
287 for (i = 0; i < totinc; i++)
288 if (!add_pabopto_inp(i))
289 return(1);
290 make_rbfrep(); /* process last data set */
291 /* check input symmetry */
292 switch (toupper(symmetry[0])) {
293 case '0': /* unspecified symmetry */
294 if (quadrant_sym[inp_coverage] != SYM_ILL)
295 break; /* anything legal goes */
296 fprintf(stderr, "%s: unsupported phi coverage (%s)\n",
297 progname, quadrant_rep[inp_coverage]);
298 return(1);
299 case SYM_UP: /* faux "up" symmetry */
300 if (quadrant_sym[inp_coverage] == SYM_ANISO)
301 break;
302 /* fall through */
303 case SYM_ISO: /* usual symmetry types */
304 case SYM_QUAD:
305 case SYM_BILAT:
306 case SYM_ANISO:
307 if (quadrant_sym[inp_coverage] == toupper(symmetry[0]))
308 break; /* matches spec */
309 fprintf(stderr,
310 "%s: phi coverage (%s) does not match requested '%s' symmetry\n",
311 progname, quadrant_rep[inp_coverage], symmetry);
312 return(1);
313 default:
314 fprintf(stderr,
315 "%s: -s option must be Isotropic, Quadrilateral, Bilateral, Up, or Anisotropic\n",
316 progname);
317 return(1);
318 }
319 #ifdef DEBUG
320 fprintf(stderr, "Input phi coverage (%s) has '%c' symmetry\n",
321 quadrant_rep[inp_coverage],
322 quadrant_sym[inp_coverage]);
323 #endif
324 build_mesh(); /* create interpolation */
325 SET_FILE_BINARY(stdout); /* start header */
326 newheader("RADIANCE", stdout);
327 printargs(argc, argv, stdout);
328 fputnow(stdout);
329 save_bsdf_rep(stdout); /* complete header + data */
330 return(0);
331 userr:
332 fprintf(stderr, "Usage: %s [-t][-n nproc][-s symmetry][-g angle|'A'] meas1.dat meas2.dat .. > bsdf.sir\n",
333 progname);
334 return(1);
335 }
336
337 #else /* TEST_MAIN */
338
339 /* Test main produces a Radiance model from the given input file */
340 int
341 main(int argc, char *argv[])
342 {
343 PGINPUT pginp;
344 char buf[128];
345 FILE *pfp;
346 double bsdf, min_log;
347 FVECT dir;
348 int i, j, n;
349
350 progname = argv[0];
351 if (argc != 2) {
352 fprintf(stderr, "Usage: %s input.dat > output.rad\n", progname);
353 return(1);
354 }
355 inpfile = &pginp;
356 if (!init_pabopto_inp(0, argv[1]) || !add_pabopto_inp(0))
357 return(1);
358 /* reduce data set */
359 if (make_rbfrep() == NULL) {
360 fprintf(stderr, "%s: nothing to plot!\n", progname);
361 exit(1);
362 }
363 #ifdef DEBUG
364 fprintf(stderr, "Minimum BSDF = %.4f\n", bsdf_min);
365 #endif
366 min_log = log(bsdf_min*.5 + 1e-5);
367 #if 1 /* produce spheres at meas. */
368 puts("void plastic yellow\n0\n0\n5 .6 .4 .01 .04 .08\n");
369 n = 0;
370 for (i = 0; i < grid_res; i++)
371 for (j = 0; j < grid_res; j++)
372 if (dsf_grid[i][j].sum.n > 0) {
373 ovec_from_pos(dir, i, j);
374 bsdf = dsf_grid[i][j].sum.v /
375 ((double)dsf_grid[i][j].sum.n*output_orient*dir[2]);
376 if (bsdf <= bsdf_min*.6)
377 continue;
378 bsdf = log(bsdf + 1e-5) - min_log;
379 ovec_from_pos(dir, i, j);
380 printf("yellow sphere s%04d\n0\n0\n", ++n);
381 printf("4 %.6g %.6g %.6g %.6g\n\n",
382 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
383 .007*bsdf);
384 }
385 #endif
386 #if 1 /* spheres at RBF peaks */
387 puts("void plastic red\n0\n0\n5 .8 .01 .01 .04 .08\n");
388 for (n = 0; n < dsf_list->nrbf; n++) {
389 RBFVAL *rbf = &dsf_list->rbfa[n];
390 ovec_from_pos(dir, rbf->gx, rbf->gy);
391 bsdf = eval_rbfrep(dsf_list, dir);
392 bsdf = log(bsdf + 1e-5) - min_log;
393 printf("red sphere p%04d\n0\n0\n", ++n);
394 printf("4 %.6g %.6g %.6g %.6g\n\n",
395 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf,
396 .011*bsdf);
397 }
398 #endif
399 #if 1 /* output continuous surface */
400 puts("void trans tgreen\n0\n0\n7 .7 1 .7 .04 .04 .9 1\n");
401 fflush(stdout);
402 sprintf(buf, "gensurf tgreen bsdf - - - %d %d", grid_res-1, grid_res-1);
403 pfp = popen(buf, "w");
404 if (pfp == NULL) {
405 fprintf(stderr, "%s: cannot open '| %s'\n", progname, buf);
406 return(1);
407 }
408 for (i = 0; i < grid_res; i++)
409 for (j = 0; j < grid_res; j++) {
410 ovec_from_pos(dir, i, j);
411 bsdf = eval_rbfrep(dsf_list, dir);
412 bsdf = log(bsdf + 1e-5) - min_log;
413 fprintf(pfp, "%.8e %.8e %.8e\n",
414 dir[0]*bsdf, dir[1]*bsdf, dir[2]*bsdf);
415 }
416 if (pclose(pfp) != 0)
417 return(1);
418 #endif
419 return(0);
420 }
421
422 #endif /* TEST_MAIN */
