root/radiance/ray/src/cv/optics2rad.csh
Revision: 2.2
Committed: Fri May 19 21:33:12 2006 UTC (17 years, 11 months ago) by greg
Content type: application/x-csh
CVS Tags: rad3R8, rad3R9
Preserve comments and ignore DOS carriage returns
1 #!/bin/csh -f
2 # RCSid $Id: optics2rad.csh,v 2.1 2006/05/19 03:50:13 greg Exp $
3 #
4 # Convert Optics 5 output to correct Radiance input
5 #
6 if ($#argv < 1) then
7 echo "Usage: $0 optics.mat .."
8 exit 1
9 endif
10 cat > /tmp/opt.fmt << '_EOF_'
11 void glass $(name)_glass
12 0
13 0
14 3 ${Rtn} ${Gtn} ${Btn}
15
16 void BRTDfunc $(name)_front
17 10
18 ${fRrho} ${fGrho} ${fBrho}
19 ${Rtau} ${Gtau} ${Btau}
20 0 0 0
21 .
22 0
23 9 0 0 0 0 0 0 0 0 0
24
25 void BRTDfunc $(name)_back
26 10
27 ${bRrho} ${bGrho} ${bBrho}
28 ${Rtau} ${Gtau} ${Btau}
29 0 0 0
30 .
31 0
32 9 0 0 0 0 0 0 0 0 0
33 '_EOF_'
34
35 echo "# Output generated by $0 from $*"
36 sed -e '/^[^#]/d' -e '/^$/d' $*
37
38 cat > /tmp/out$$.fmt << '_EOF_'
39
40 void glass $(name)
41 0
42 0
43 3 ${Rtn} ${Gtn} ${Btn}
44 '_EOF_'
45
46 rcalc -l -e 'abs(x):if(x,x,-x);and(a,b):if(a,b,a);not(x):if(x,-1,1)' \
47 -e 'lum(r,g,b):.265*r+.670*g+.065*b' \
48 -e 'trans=lum(Rtau,Gtau,Btau)' \
49 -e 'rfront=lum(fRrho,fGrho,fBrho);rback=lum(bRrho,bGrho,bBrho)' \
50 -e 'cond=0.005-abs(rfront-rback)' \
51 -i /tmp/opt.fmt -o /tmp/out$$.fmt $*
52
53 cat > /tmp/out$$.fmt << '_EOF_'
54
55 void BRTDfunc $(name)
56 10
57 rR_clear rG_clear rB_clear
58 ${Rtau}*tR_clear ${Gtau}*tG_clear ${Btau}*tB_clear
59 0 0 0
60 window.cal
61 0
62 15 0 0 0 0 0 0 0 0 0
63 ${fRrho} ${fGrho} ${fBrho}
64 ${bRrho} ${bGrho} ${bBrho}
65 '_EOF_'
66
67 rcalc -l -e 'abs(x):if(x,x,-x);and(a,b):if(a,b,a);not(x):if(x,-1,1)' \
68 -e 'lum(r,g,b):.265*r+.670*g+.065*b' \
69 -e 'trans=lum(Rtau,Gtau,Btau)' \
70 -e 'rfront=lum(fRrho,fGrho,fBrho);rback=lum(bRrho,bGrho,bBrho)' \
71 -e 'cond=and(trans-.645, not(0.005-abs(rfront-rback)))' \
72 -i /tmp/opt.fmt -o /tmp/out$$.fmt $*
73
74 cat > /tmp/out$$.fmt << '_EOF_'
75
76 void BRTDfunc $(name)
77 10
78 rR_bronze rG_bronze rB_bronze
79 ${Rtau}*tR_bronze ${Gtau}*tG_bronze ${Btau}*tB_bronze
80 0 0 0
81 window.cal
82 0
83 15 0 0 0 0 0 0 0 0 0
84 ${fRrho} ${fGrho} ${fBrho}
85 ${bRrho} ${bGrho} ${bBrho}
86 '_EOF_'
87
88 rcalc -l -e 'abs(x):if(x,x,-x);and(a,b):if(a,b,a);not(x):if(x,-1,1)' \
89 -e 'lum(r,g,b):.265*r+.670*g+.065*b' \
90 -e 'trans=lum(Rtau,Gtau,Btau)' \
91 -e 'rfront=lum(fRrho,fGrho,fBrho);rback=lum(bRrho,bGrho,bBrho)' \
92 -e 'cond=and(not(trans-.645), not(0.005-abs(rfront-rback)))' \
93 -i /tmp/opt.fmt -o /tmp/out$$.fmt $*
94
95 rm -f /tmp/opt.fmt /tmp/out$$.fmt
