root/radiance/ray/src/cv/optics2rad.csh
Revision: 2.1
Committed: Fri May 19 03:50:13 2006 UTC (19 years, 1 month ago) by greg
Content type: application/x-csh
1 #!/bin/csh -f
2 # RCSid $Id$
3 #
4 # Convert Optics 5 output to correct Radiance input
5 #
6 if ($#argv < 1) then
7 echo "Usage: $0 optics.mat .."
8 exit 1
9 endif
10 cat > /tmp/opt.fmt << '_EOF_'
11 void glass $(name)_glass
12 0
13 0
14 3 ${Rtn} ${Gtn} ${Btn}
15
16 void BRTDfunc $(name)_front
17 10
18 ${fRrho} ${fGrho} ${fBrho}
19 ${Rtau} ${Gtau} ${Btau}
20 0 0 0
21 .
22 0
23 9 0 0 0 0 0 0 0 0 0
24
25 void BRTDfunc $(name)_back
26 10
27 ${bRrho} ${bGrho} ${bBrho}
28 ${Rtau} ${Gtau} ${Btau}
29 0 0 0
30 .
31 0
32 9 0 0 0 0 0 0 0 0 0
33 '_EOF_'
34
35 echo "# Output generated by $0 from $*"
36
37 cat > /tmp/out$$.fmt << '_EOF_'
38
39 void glass $(name)
40 0
41 0
42 3 ${Rtn} ${Gtn} ${Btn}
43 '_EOF_'
44
45 rcalc -e 'abs(x):if(x,x,-x);and(a,b):if(a,b,a);not(x):if(x,-1,1)' \
46 -e 'lum(r,g,b):.265*r+.670*g+.065*b' \
47 -e 'trans=lum(Rtau,Gtau,Btau)' \
48 -e 'rfront=lum(fRrho,fGrho,fBrho);rback=lum(bRrho,bGrho,bBrho)' \
49 -e 'cond=0.005-abs(rfront-rback)' \
50 -i /tmp/opt.fmt -o /tmp/out$$.fmt $*
51
52 cat > /tmp/out$$.fmt << '_EOF_'
53
54 void BRTDfunc $(name)
55 10
56 rR_clear rG_clear rB_clear
57 ${Rtau}*tR_clear ${Gtau}*tG_clear ${Btau}*tB_clear
58 0 0 0
59 window.cal
60 0
61 15 0 0 0 0 0 0 0 0 0
62 ${fRrho} ${fGrho} ${fBrho}
63 ${bRrho} ${bGrho} ${bBrho}
64 '_EOF_'
65
66 rcalc -e 'abs(x):if(x,x,-x);and(a,b):if(a,b,a);not(x):if(x,-1,1)' \
67 -e 'lum(r,g,b):.265*r+.670*g+.065*b' \
68 -e 'trans=lum(Rtau,Gtau,Btau)' \
69 -e 'rfront=lum(fRrho,fGrho,fBrho);rback=lum(bRrho,bGrho,bBrho)' \
70 -e 'cond=and(trans-.645, not(0.005-abs(rfront-rback)))' \
71 -i /tmp/opt.fmt -o /tmp/out$$.fmt $*
72
73 cat > /tmp/out$$.fmt << '_EOF_'
74
75 void BRTDfunc $(name)
76 10
77 rR_bronze rG_bronze rB_bronze
78 ${Rtau}*tR_bronze ${Gtau}*tG_bronze ${Btau}*tB_bronze
79 0 0 0
80 window.cal
81 0
82 15 0 0 0 0 0 0 0 0 0
83 ${fRrho} ${fGrho} ${fBrho}
84 ${bRrho} ${bGrho} ${bBrho}
85 '_EOF_'
86
87 rcalc -e 'abs(x):if(x,x,-x);and(a,b):if(a,b,a);not(x):if(x,-1,1)' \
88 -e 'lum(r,g,b):.265*r+.670*g+.065*b' \
89 -e 'trans=lum(Rtau,Gtau,Btau)' \
90 -e 'rfront=lum(fRrho,fGrho,fBrho);rback=lum(bRrho,bGrho,bBrho)' \
91 -e 'cond=and(not(trans-.645), not(0.005-abs(rfront-rback)))' \
92 -i /tmp/opt.fmt -o /tmp/out$$.fmt $*
93
94 rm -f /tmp/opt.fmt /tmp/out$$.fmt
