| 1 |
/* Copyright (c) 1994 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Convert a Wavefront .obj file to Radiance format.
| 9 |
| 10 |
* Currently, we support only polygonal geometry. Non-planar
| 11 |
* faces are broken rather haphazardly into triangles.
| 12 |
* Also, texture map indices only work for triangles, though
| 13 |
* I'm not sure they work correctly. (Taken out -- see TEXMAPS defines.)
| 14 |
| 15 |
| 16 |
#include "standard.h"
| 17 |
| 18 |
#include "trans.h"
| 19 |
| 20 |
#include <ctype.h>
| 21 |
| 22 |
#define TCALNAME "tmesh.cal" /* triangle interp. file */
| 23 |
#define QCALNAME "surf.cal" /* quad interp. file */
| 24 |
#define PATNAME "M-pat" /* mesh pattern name (reused) */
| 25 |
#define TEXNAME "M-nor" /* mesh texture name (reused) */
| 26 |
#define DEFOBJ "unnamed" /* default object name */
| 27 |
#define DEFMAT "white" /* default material name */
| 28 |
| 29 |
#define ABS(x) ((x)>=0 ? (x) : -(x))
| 30 |
| 31 |
#define pvect(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2])
| 32 |
| 33 |
FVECT *vlist; /* our vertex list */
| 34 |
int nvs; /* number of vertices in our list */
| 35 |
FVECT *vnlist; /* vertex normal list */
| 36 |
int nvns;
| 37 |
FLOAT (*vtlist)[2]; /* map vertex list */
| 38 |
int nvts;
| 39 |
| 40 |
typedef FLOAT BARYCCM[3][4]; /* barycentric coordinate system */
| 41 |
| 42 |
typedef int VNDX[3]; /* vertex index (point,map,normal) */
| 43 |
| 44 |
#define CHUNKSIZ 256 /* vertex allocation chunk size */
| 45 |
| 46 |
#define MAXARG 64 /* maximum # arguments in a statement */
| 47 |
| 48 |
/* qualifiers */
| 49 |
#define Q_MTL 0
| 50 |
#define Q_MAP 1
| 51 |
#define Q_GRP 2
| 52 |
#define Q_OBJ 3
| 53 |
#define Q_FAC 4
| 54 |
#define NQUALS 5
| 55 |
| 56 |
char *qname[NQUALS] = {
| 57 |
"Material",
| 58 |
"Map",
| 59 |
"Group",
| 60 |
"Object",
| 61 |
"Face",
| 62 |
| 63 |
| 64 |
QLIST qlist = {NQUALS, qname};
| 65 |
/* valid qualifier ids */
| 66 |
IDLIST qual[NQUALS];
| 67 |
/* mapping rules */
| 68 |
RULEHD *ourmapping = NULL;
| 69 |
| 70 |
char *defmat = DEFMAT; /* default (starting) material name */
| 71 |
char *defobj = DEFOBJ; /* default (starting) object name */
| 72 |
| 73 |
char *getmtl(), *getonm();
| 74 |
| 75 |
char mapname[128]; /* current picture file */
| 76 |
char matname[64]; /* current material name */
| 77 |
char group[16][32]; /* current group names */
| 78 |
char objname[128]; /* current object name */
| 79 |
char *inpfile; /* input file name */
| 80 |
int lineno; /* current line number */
| 81 |
int faceno; /* current face number */
| 82 |
| 83 |
| 84 |
main(argc, argv) /* read in .obj file and convert */
| 85 |
int argc;
| 86 |
char *argv[];
| 87 |
| 88 |
int donames = 0;
| 89 |
int i;
| 90 |
| 91 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 92 |
switch (argv[i][1]) {
| 93 |
case 'o': /* object name */
| 94 |
defobj = argv[++i];
| 95 |
break;
| 96 |
case 'n': /* just produce name list */
| 97 |
donames++;
| 98 |
break;
| 99 |
case 'm': /* use custom mapfile */
| 100 |
ourmapping = getmapping(argv[++i], &qlist);
| 101 |
break;
| 102 |
default:
| 103 |
goto userr;
| 104 |
| 105 |
if (i > argc | i < argc-1)
| 106 |
goto userr;
| 107 |
if (i == argc)
| 108 |
inpfile = "<stdin>";
| 109 |
else if (freopen(inpfile=argv[i], "r", stdin) == NULL) {
| 110 |
fprintf(stderr, "%s: cannot open\n", inpfile);
| 111 |
exit(1);
| 112 |
| 113 |
if (donames) { /* scan for ids */
| 114 |
getnames(stdin);
| 115 |
printf("filename \"%s\"\n", inpfile);
| 116 |
printf("filetype \"Wavefront\"\n");
| 117 |
write_quals(&qlist, qual, stdout);
| 118 |
printf("qualifier %s begin\n", qlist.qual[Q_FAC]);
| 119 |
printf("[%d:%d]\n", 1, faceno);
| 120 |
printf("end\n");
| 121 |
} else { /* translate file */
| 122 |
printf("# ");
| 123 |
printargs(argc, argv, stdout);
| 124 |
convert(stdin);
| 125 |
| 126 |
exit(0);
| 127 |
userr:
| 128 |
fprintf(stderr, "Usage: %s [-o obj][-m mapping][-n] [file.obj]\n",
| 129 |
argv[0]);
| 130 |
exit(1);
| 131 |
| 132 |
| 133 |
| 134 |
getnames(fp) /* get valid qualifier names */
| 135 |
FILE *fp;
| 136 |
| 137 |
char *argv[MAXARG];
| 138 |
int argc;
| 139 |
ID tmpid;
| 140 |
register int i;
| 141 |
| 142 |
while (argc = getstmt(argv, fp))
| 143 |
switch (argv[0][0]) {
| 144 |
case 'f': /* face */
| 145 |
if (!argv[0][1])
| 146 |
faceno++;
| 147 |
break;
| 148 |
case 'u':
| 149 |
if (!strcmp(argv[0], "usemtl")) { /* material */
| 150 |
if (argc < 2)
| 151 |
break; /* not fatal */
| 152 |
tmpid.number = 0;
| 153 |
tmpid.name = argv[1];
| 154 |
findid(&qual[Q_MTL], &tmpid, 1);
| 155 |
} else if (!strcmp(argv[0], "usemap")) {/* map */
| 156 |
if (argc < 2 || !strcmp(argv[1], "off"))
| 157 |
| 158 |
tmpid.number = 0;
| 159 |
| 160 |
findid(&qual[Q_MAP], &tmpid, 1);
| 161 |
| 162 |
break;
| 163 |
| 164 |
if (argv[0][1] || argc < 2)
| 165 |
break;
| 166 |
tmpid.number = 0;
| 167 |
| 168 |
findid(&qual[Q_OBJ], &tmpid, 1);
| 169 |
break;
| 170 |
case 'g': /* group name(s) */
| 171 |
if (argv[0][1])
| 172 |
break;
| 173 |
tmpid.number = 0;
| 174 |
for (i = 1; i < argc; i++) {
| 175 |
tmpid.name = argv[i];
| 176 |
findid(&qual[Q_GRP], &tmpid, 1);
| 177 |
| 178 |
break;
| 179 |
| 180 |
| 181 |
| 182 |
| 183 |
convert(fp) /* convert a T-mesh */
| 184 |
FILE *fp;
| 185 |
| 186 |
char *argv[MAXARG];
| 187 |
int argc;
| 188 |
int nstats, nunknown;
| 189 |
register int i;
| 190 |
| 191 |
nstats = nunknown = 0;
| 192 |
/* scan until EOF */
| 193 |
while (argc = getstmt(argv, fp)) {
| 194 |
| 195 |
case 'v': /* vertex */
| 196 |
switch (argv[0][1]) {
| 197 |
case '\0': /* point */
| 198 |
if (badarg(argc-1,argv+1,"fff"))
| 199 |
syntax("Bad vertex");
| 200 |
newv(atof(argv[1]), atof(argv[2]),
| 201 |
atof(argv[3]));
| 202 |
break;
| 203 |
case 'n': /* normal */
| 204 |
if (argv[0][2])
| 205 |
goto unknown;
| 206 |
| 207 |
syntax("Bad normal");
| 208 |
if (!newvn(atof(argv[1]), atof(argv[2]),
| 209 |
atof(argv[3])))
| 210 |
syntax("Zero normal");
| 211 |
break;
| 212 |
case 't': /* texture map */
| 213 |
if (argv[0][2])
| 214 |
goto unknown;
| 215 |
if (badarg(argc-1,argv+1,"ff"))
| 216 |
goto unknown;
| 217 |
newvt(atof(argv[1]), atof(argv[2]));
| 218 |
break;
| 219 |
default:
| 220 |
goto unknown;
| 221 |
| 222 |
break;
| 223 |
| 224 |
if (argv[0][1])
| 225 |
goto unknown;
| 226 |
faceno++;
| 227 |
switch (argc-1) {
| 228 |
case 0: case 1: case 2:
| 229 |
syntax("Too few vertices");
| 230 |
break;
| 231 |
case 3:
| 232 |
if (!puttri(argv[1], argv[2], argv[3]))
| 233 |
syntax("Bad triangle");
| 234 |
break;
| 235 |
case 4:
| 236 |
if (!putquad(argv[1], argv[2],
| 237 |
argv[3], argv[4]))
| 238 |
syntax("Bad quad");
| 239 |
break;
| 240 |
default:
| 241 |
if (!putface(argc-1, argv+1))
| 242 |
syntax("Bad face");
| 243 |
break;
| 244 |
| 245 |
break;
| 246 |
case 'u':
| 247 |
| 248 |
if (argc < 2)
| 249 |
| 250 |
strcpy(matname, argv[1]);
| 251 |
| 252 |
if (argc < 2)
| 253 |
| 254 |
if (!strcmp(argv[1], "off"))
| 255 |
mapname[0] = '\0';
| 256 |
else
| 257 |
sprintf(mapname, "%s.pic", argv[1]);
| 258 |
} else
| 259 |
goto unknown;
| 260 |
break;
| 261 |
| 262 |
if (argv[0][1])
| 263 |
goto unknown;
| 264 |
if (argc < 2)
| 265 |
| 266 |
strcpy(objname, argv[1]);
| 267 |
break;
| 268 |
| 269 |
if (argv[0][1])
| 270 |
goto unknown;
| 271 |
| 272 |
strcpy(group[i-1], argv[i]);
| 273 |
group[i-1][0] = '\0';
| 274 |
break;
| 275 |
case '#': /* comment */
| 276 |
| 277 |
break;
| 278 |
default:; /* something we don't deal with */
| 279 |
unknown:
| 280 |
nunknown++;
| 281 |
break;
| 282 |
| 283 |
nstats++;
| 284 |
| 285 |
printf("\n# Done processing file: %s\n", inpfile);
| 286 |
printf("# %d lines, %d statements, %d unrecognized\n",
| 287 |
lineno, nstats, nunknown);
| 288 |
| 289 |
| 290 |
| 291 |
int
| 292 |
getstmt(av, fp) /* read the next statement from fp */
| 293 |
register char *av[MAXARG];
| 294 |
FILE *fp;
| 295 |
| 296 |
extern char *fgetline();
| 297 |
static char sbuf[MAXARG*10];
| 298 |
register char *cp;
| 299 |
register int i;
| 300 |
| 301 |
do {
| 302 |
if (fgetline(cp=sbuf, sizeof(sbuf), fp) == NULL)
| 303 |
return(0);
| 304 |
i = 0;
| 305 |
for ( ; ; ) {
| 306 |
while (isspace(*cp) || *cp == '\\') {
| 307 |
if (*cp == '\n')
| 308 |
lineno++;
| 309 |
*cp++ = '\0';
| 310 |
| 311 |
if (!*cp || i >= MAXARG-1)
| 312 |
break;
| 313 |
av[i++] = cp;
| 314 |
while (*++cp && !isspace(*cp))
| 315 |
| 316 |
| 317 |
av[i] = NULL;
| 318 |
lineno++;
| 319 |
} while (!i);
| 320 |
| 321 |
return(i);
| 322 |
| 323 |
| 324 |
| 325 |
char *
| 326 |
getmtl() /* figure material for this face */
| 327 |
| 328 |
register RULEHD *rp = ourmapping;
| 329 |
| 330 |
if (rp == NULL) { /* no rule set */
| 331 |
if (matname[0])
| 332 |
return(matname);
| 333 |
if (group[0][0])
| 334 |
return(group[0]);
| 335 |
return(defmat);
| 336 |
| 337 |
/* check for match */
| 338 |
do {
| 339 |
if (matchrule(rp)) {
| 340 |
if (!strcmp(rp->mnam, VOIDID))
| 341 |
return(NULL); /* match is null */
| 342 |
return(rp->mnam);
| 343 |
| 344 |
rp = rp->next;
| 345 |
} while (rp != NULL);
| 346 |
/* no match found */
| 347 |
return(NULL);
| 348 |
| 349 |
| 350 |
| 351 |
char *
| 352 |
getonm() /* invent a good name for object */
| 353 |
| 354 |
static char name[64];
| 355 |
register char *cp1, *cp2;
| 356 |
register int i;
| 357 |
/* check for preset */
| 358 |
if (objname[0])
| 359 |
return(objname);
| 360 |
if (!group[0][0])
| 361 |
return(defobj);
| 362 |
cp1 = name; /* else make name out of groups */
| 363 |
for (i = 0; group[i][0]; i++) {
| 364 |
cp2 = group[i];
| 365 |
if (cp1 > name)
| 366 |
*cp1++ = '.';
| 367 |
while (*cp1 = *cp2++)
| 368 |
if (++cp1 >= name+sizeof(name)-2) {
| 369 |
*cp1 = '\0';
| 370 |
return(name);
| 371 |
| 372 |
| 373 |
return(name);
| 374 |
| 375 |
| 376 |
| 377 |
matchrule(rp) /* check for a match on this rule */
| 378 |
register RULEHD *rp;
| 379 |
| 380 |
ID tmpid;
| 381 |
int gotmatch;
| 382 |
register int i;
| 383 |
| 384 |
if (rp->qflg & FL(Q_MTL)) {
| 385 |
if (!matname[0])
| 386 |
return(0);
| 387 |
tmpid.number = 0;
| 388 |
tmpid.name = matname;
| 389 |
if (!matchid(&tmpid, &idm(rp)[Q_MTL]))
| 390 |
return(0);
| 391 |
| 392 |
if (rp->qflg & FL(Q_MAP)) {
| 393 |
if (!mapname[0])
| 394 |
return(0);
| 395 |
tmpid.number = 0;
| 396 |
tmpid.name = mapname;
| 397 |
if (!matchid(&tmpid, &idm(rp)[Q_MAP]))
| 398 |
return(0);
| 399 |
| 400 |
if (rp->qflg & FL(Q_GRP)) {
| 401 |
tmpid.number = 0;
| 402 |
gotmatch = 0;
| 403 |
| 404 |
tmpid.name = group[i];
| 405 |
gotmatch |= matchid(&tmpid, &idm(rp)[Q_GRP]);
| 406 |
| 407 |
if (!gotmatch)
| 408 |
return(0);
| 409 |
| 410 |
if (rp->qflg & FL(Q_OBJ)) {
| 411 |
if (!objname[0])
| 412 |
return(0);
| 413 |
tmpid.number = 0;
| 414 |
tmpid.name = objname;
| 415 |
if (!matchid(&tmpid, &idm(rp)[Q_OBJ]))
| 416 |
return(0);
| 417 |
| 418 |
if (rp->qflg & FL(Q_FAC)) {
| 419 |
tmpid.name = NULL;
| 420 |
tmpid.number = faceno;
| 421 |
if (!matchid(&tmpid, &idm(rp)[Q_FAC]))
| 422 |
return(0);
| 423 |
| 424 |
return(1);
| 425 |
| 426 |
| 427 |
| 428 |
cvtndx(vi, vs) /* convert vertex string to index */
| 429 |
register VNDX vi;
| 430 |
register char *vs;
| 431 |
| 432 |
/* get point */
| 433 |
vi[0] = atoi(vs);
| 434 |
if (vi[0] > 0) {
| 435 |
if (vi[0]-- > nvs)
| 436 |
return(0);
| 437 |
} else if (vi[0] < 0) {
| 438 |
vi[0] = nvs + vi[0];
| 439 |
if (vi[0] < 0)
| 440 |
return(0);
| 441 |
} else
| 442 |
return(0);
| 443 |
/* get map */
| 444 |
while (*vs)
| 445 |
if (*vs++ == '/')
| 446 |
break;
| 447 |
vi[1] = atoi(vs);
| 448 |
if (vi[1] > 0) {
| 449 |
if (vi[1]-- > nvts)
| 450 |
return(0);
| 451 |
} else if (vi[1] < 0) {
| 452 |
vi[1] = nvts + vi[1];
| 453 |
if (vi[1] < 0)
| 454 |
return(0);
| 455 |
} else
| 456 |
vi[1] = -1;
| 457 |
/* get normal */
| 458 |
while (*vs)
| 459 |
if (*vs++ == '/')
| 460 |
break;
| 461 |
vi[2] = atoi(vs);
| 462 |
if (vi[2] > 0) {
| 463 |
if (vi[2]-- > nvns)
| 464 |
return(0);
| 465 |
} else if (vi[2] < 0) {
| 466 |
vi[2] = nvns + vi[2];
| 467 |
if (vi[2] < 0)
| 468 |
return(0);
| 469 |
} else
| 470 |
vi[2] = -1;
| 471 |
return(1);
| 472 |
| 473 |
| 474 |
| 475 |
nonplanar(ac, av) /* are vertices are non-planar? */
| 476 |
register int ac;
| 477 |
register char **av;
| 478 |
| 479 |
VNDX vi;
| 480 |
FLOAT *p0, *p1;
| 481 |
FVECT v1, v2, nsum, newn;
| 482 |
double d;
| 483 |
register int i;
| 484 |
| 485 |
if (!cvtndx(vi, av[0]))
| 486 |
return(0);
| 487 |
if (vi[2] >= 0)
| 488 |
return(1); /* has interpolated normals */
| 489 |
if (ac < 4)
| 490 |
return(0); /* it's a triangle! */
| 491 |
/* set up */
| 492 |
p0 = vlist[vi[0]];
| 493 |
if (!cvtndx(vi, av[1]))
| 494 |
return(0); /* error gets caught later */
| 495 |
nsum[0] = nsum[1] = nsum[2] = 0.;
| 496 |
p1 = vlist[vi[0]];
| 497 |
fvsum(v2, p1, p0, -1.0);
| 498 |
for (i = 2; i < ac; i++) {
| 499 |
VCOPY(v1, v2);
| 500 |
if (!cvtndx(vi, av[i]))
| 501 |
return(0);
| 502 |
p1 = vlist[vi[0]];
| 503 |
| 504 |
fcross(newn, v1, v2);
| 505 |
if (normalize(newn) == 0.0) {
| 506 |
if (i < 3)
| 507 |
return(1); /* can't deal with this */
| 508 |
fvsum(nsum, nsum, nsum, 1./(i-2));
| 509 |
continue;
| 510 |
| 511 |
d = fdot(newn,nsum);
| 512 |
if (d >= 0) {
| 513 |
if (d < (1.0-FTINY)*(i-2))
| 514 |
return(1);
| 515 |
fvsum(nsum, nsum, newn, 1.0);
| 516 |
} else {
| 517 |
if (d > -(1.0-FTINY)*(i-2))
| 518 |
return(1);
| 519 |
fvsum(nsum, nsum, newn, -1.0);
| 520 |
| 521 |
| 522 |
return(0);
| 523 |
| 524 |
| 525 |
| 526 |
putface(ac, av) /* put out an N-sided polygon */
| 527 |
int ac;
| 528 |
register char **av;
| 529 |
| 530 |
VNDX vi;
| 531 |
char *cp;
| 532 |
register int i;
| 533 |
| 534 |
if (nonplanar(ac, av)) { /* break into quads and triangles */
| 535 |
while (ac > 3) {
| 536 |
if (!putquad(av[0], av[1], av[2], av[3]))
| 537 |
return(0);
| 538 |
ac -= 2; /* remove two vertices & rotate */
| 539 |
cp = av[0];
| 540 |
for (i = 0; i < ac-1; i++)
| 541 |
av[i] = av[i+3];
| 542 |
av[i] = cp;
| 543 |
| 544 |
if (ac == 3 && !puttri(av[0], av[1], av[2]))
| 545 |
return(0);
| 546 |
return(1);
| 547 |
| 548 |
if ((cp = getmtl()) == NULL)
| 549 |
return(-1);
| 550 |
printf("\n%s polygon %s.%d\n", cp, getonm(), faceno);
| 551 |
printf("0\n0\n%d\n", 3*ac);
| 552 |
for (i = 0; i < ac; i++) {
| 553 |
| 554 |
return(0);
| 555 |
pvect(vlist[vi[0]]);
| 556 |
| 557 |
return(1);
| 558 |
| 559 |
| 560 |
| 561 |
puttri(v1, v2, v3) /* put out a triangle */
| 562 |
char *v1, *v2, *v3;
| 563 |
| 564 |
char *mod;
| 565 |
VNDX v1i, v2i, v3i;
| 566 |
BARYCCM bvecs;
| 567 |
int texOK, patOK;
| 568 |
| 569 |
if ((mod = getmtl()) == NULL)
| 570 |
return(-1);
| 571 |
| 572 |
if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3))
| 573 |
return(0);
| 574 |
/* compute barycentric coordinates */
| 575 |
texOK = (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0);
| 576 |
#ifdef TEXMAPS
| 577 |
patOK = mapname[0] && (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0);
| 578 |
#else
| 579 |
patOK = 0;
| 580 |
#endif
| 581 |
if (texOK | patOK)
| 582 |
if (comp_baryc(bvecs, vlist[v1i[0]], vlist[v2i[0]],
| 583 |
vlist[v3i[0]]) < 0)
| 584 |
return(-1);
| 585 |
/* put out texture (if any) */
| 586 |
if (texOK) {
| 587 |
printf("\n%s texfunc %s\n", mod, TEXNAME);
| 588 |
mod = TEXNAME;
| 589 |
printf("4 dx dy dz %s\n", TCALNAME);
| 590 |
printf("0\n21\n");
| 591 |
put_baryc(bvecs);
| 592 |
printf("\t%14.12g %14.12g %14.12g\n",
| 593 |
vnlist[v1i[2]][0], vnlist[v2i[2]][0],
| 594 |
vnlist[v3i[2]][0]);
| 595 |
| 596 |
vnlist[v1i[2]][1], vnlist[v2i[2]][1],
| 597 |
vnlist[v3i[2]][1]);
| 598 |
| 599 |
vnlist[v1i[2]][2], vnlist[v2i[2]][2],
| 600 |
vnlist[v3i[2]][2]);
| 601 |
| 602 |
#ifdef TEXMAPS
| 603 |
/* put out pattern (if any) */
| 604 |
if (patOK) {
| 605 |
printf("\n%s colorpict %s\n", mod, PATNAME);
| 606 |
mod = PATNAME;
| 607 |
printf("7 noneg noneg noneg %s %s u v\n", mapname, TCALNAME);
| 608 |
printf("0\n18\n");
| 609 |
put_baryc(bvecs);
| 610 |
printf("\t%f %f %f\n", vtlist[v1i[1]][0],
| 611 |
vtlist[v2i[1]][0], vtlist[v3i[1]][0]);
| 612 |
printf("\t%f %f %f\n", vtlist[v1i[1]][1],
| 613 |
vtlist[v2i[1]][1], vtlist[v3i[1]][1]);
| 614 |
| 615 |
#endif
| 616 |
/* put out triangle */
| 617 |
printf("\n%s polygon %s.%d\n", mod, getonm(), faceno);
| 618 |
printf("0\n0\n9\n");
| 619 |
pvect(vlist[v1i[0]]);
| 620 |
pvect(vlist[v2i[0]]);
| 621 |
pvect(vlist[v3i[0]]);
| 622 |
| 623 |
return(1);
| 624 |
| 625 |
| 626 |
| 627 |
int
| 628 |
comp_baryc(bcm, v1, v2, v3) /* compute barycentric vectors */
| 629 |
register BARYCCM bcm;
| 630 |
FLOAT *v1, *v2, *v3;
| 631 |
| 632 |
FLOAT *vt;
| 633 |
FVECT va, vab, vcb;
| 634 |
double d;
| 635 |
register int i, j;
| 636 |
| 637 |
for (j = 0; j < 3; j++) {
| 638 |
for (i = 0; i < 3; i++) {
| 639 |
vab[i] = v1[i] - v2[i];
| 640 |
vcb[i] = v3[i] - v2[i];
| 641 |
| 642 |
d = DOT(vcb,vcb);
| 643 |
if (d <= FTINY)
| 644 |
return(-1);
| 645 |
d = DOT(vcb,vab)/d;
| 646 |
| 647 |
va[i] = vab[i] - vcb[i]*d;
| 648 |
d = DOT(va,va);
| 649 |
if (d <= FTINY)
| 650 |
return(-1);
| 651 |
| 652 |
va[i] /= d;
| 653 |
bcm[j][i] = va[i];
| 654 |
| 655 |
bcm[j][3] = -DOT(v2,va);
| 656 |
/* rotate vertices */
| 657 |
vt = v1;
| 658 |
v1 = v2;
| 659 |
v2 = v3;
| 660 |
v3 = vt;
| 661 |
| 662 |
return(0);
| 663 |
| 664 |
| 665 |
| 666 |
put_baryc(bcm) /* put barycentric coord. vectors */
| 667 |
| 668 |
| 669 |
register int i;
| 670 |
| 671 |
| 672 |
printf("%14.8f %14.8f %14.8f %14.8f\n",
| 673 |
bcm[i][0], bcm[i][1], bcm[i][2], bcm[i][3]);
| 674 |
| 675 |
| 676 |
| 677 |
putquad(p0, p1, p3, p2) /* put out a quadrilateral */
| 678 |
char *p0, *p1, *p3, *p2; /* names correspond to binary pos. */
| 679 |
| 680 |
VNDX p0i, p1i, p2i, p3i;
| 681 |
FVECT norm[4];
| 682 |
char *mod, *name;
| 683 |
int axis;
| 684 |
FVECT v1, v2, vc1, vc2;
| 685 |
int ok1, ok2;
| 686 |
| 687 |
#ifdef TEXMAPS
| 688 |
/* also should output texture index coordinates,
| 689 |
* which will require new .cal file
| 690 |
| 691 |
#endif
| 692 |
| 693 |
return(-1);
| 694 |
name = getonm();
| 695 |
/* get actual indices */
| 696 |
if (!cvtndx(p0i,p0) || !cvtndx(p1i,p1) ||
| 697 |
!cvtndx(p2i,p2) || !cvtndx(p3i,p3))
| 698 |
return(0);
| 699 |
/* compute exact normals */
| 700 |
fvsum(v1, vlist[p1i[0]], vlist[p0i[0]], -1.0);
| 701 |
fvsum(v2, vlist[p2i[0]], vlist[p0i[0]], -1.0);
| 702 |
fcross(vc1, v1, v2);
| 703 |
ok1 = normalize(vc1) != 0.0;
| 704 |
fvsum(v1, vlist[p2i[0]], vlist[p3i[0]], -1.0);
| 705 |
fvsum(v2, vlist[p1i[0]], vlist[p3i[0]], -1.0);
| 706 |
fcross(vc2, v1, v2);
| 707 |
ok2 = normalize(vc2) != 0.0;
| 708 |
if (!(ok1 | ok2))
| 709 |
return(-1);
| 710 |
/* compute normal interpolation */
| 711 |
axis = norminterp(norm, p0i, p1i, p2i, p3i);
| 712 |
| 713 |
/* put out quadrilateral? */
| 714 |
if (ok1 & ok2 && fabs(fdot(vc1,vc2)) >= 1.0-FTINY) {
| 715 |
printf("\n%s ", mod);
| 716 |
if (axis != -1) {
| 717 |
printf("texfunc %s\n", TEXNAME);
| 718 |
printf("4 surf_dx surf_dy surf_dz %s\n", QCALNAME);
| 719 |
printf("0\n13\t%d\n", axis);
| 720 |
pvect(norm[0]);
| 721 |
pvect(norm[1]);
| 722 |
pvect(norm[2]);
| 723 |
fvsum(v1, norm[3], vc1, -0.5);
| 724 |
fvsum(v1, v1, vc2, -0.5);
| 725 |
pvect(v1);
| 726 |
printf("\n%s ", TEXNAME);
| 727 |
| 728 |
printf("polygon %s.%d\n", name, faceno);
| 729 |
printf("0\n0\n12\n");
| 730 |
pvect(vlist[p0i[0]]);
| 731 |
pvect(vlist[p1i[0]]);
| 732 |
pvect(vlist[p3i[0]]);
| 733 |
pvect(vlist[p2i[0]]);
| 734 |
return(1);
| 735 |
| 736 |
/* put out triangles? */
| 737 |
if (ok1) {
| 738 |
| 739 |
if (axis != -1) {
| 740 |
| 741 |
| 742 |
| 743 |
pvect(norm[0]);
| 744 |
pvect(norm[1]);
| 745 |
pvect(norm[2]);
| 746 |
fvsum(v1, norm[3], vc1, -1.0);
| 747 |
pvect(v1);
| 748 |
| 749 |
| 750 |
printf("polygon %s.%da\n", name, faceno);
| 751 |
| 752 |
| 753 |
| 754 |
| 755 |
| 756 |
if (ok2) {
| 757 |
| 758 |
if (axis != -1) {
| 759 |
| 760 |
| 761 |
| 762 |
pvect(norm[0]);
| 763 |
pvect(norm[1]);
| 764 |
pvect(norm[2]);
| 765 |
fvsum(v2, norm[3], vc2, -1.0);
| 766 |
pvect(v2);
| 767 |
| 768 |
| 769 |
printf("polygon %s.%db\n", name, faceno);
| 770 |
| 771 |
| 772 |
| 773 |
| 774 |
| 775 |
return(1);
| 776 |
| 777 |
| 778 |
| 779 |
int
| 780 |
norminterp(resmat, p0i, p1i, p2i, p3i) /* compute normal interpolation */
| 781 |
register FVECT resmat[4];
| 782 |
register VNDX p0i, p1i, p2i, p3i;
| 783 |
| 784 |
#define u ((ax+1)%3)
| 785 |
#define v ((ax+2)%3)
| 786 |
| 787 |
register int ax;
| 788 |
MAT4 eqnmat;
| 789 |
FVECT v1;
| 790 |
register int i, j;
| 791 |
| 792 |
#ifdef TEXMAPS
| 793 |
/* also check for texture indices */
| 794 |
#endif
| 795 |
if (!(p0i[2]>=0 && p1i[2]>=0 && p2i[2]>=0 && p3i[2]>=0))
| 796 |
return(-1);
| 797 |
/* find dominant axis */
| 798 |
VCOPY(v1, vnlist[p0i[2]]);
| 799 |
fvsum(v1, v1, vnlist[p1i[2]], 1.0);
| 800 |
fvsum(v1, v1, vnlist[p2i[2]], 1.0);
| 801 |
fvsum(v1, v1, vnlist[p3i[2]], 1.0);
| 802 |
ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
| 803 |
ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
| 804 |
/* assign equation matrix */
| 805 |
eqnmat[0][0] = vlist[p0i[0]][u]*vlist[p0i[0]][v];
| 806 |
eqnmat[0][1] = vlist[p0i[0]][u];
| 807 |
eqnmat[0][2] = vlist[p0i[0]][v];
| 808 |
eqnmat[0][3] = 1.0;
| 809 |
eqnmat[1][0] = vlist[p1i[0]][u]*vlist[p1i[0]][v];
| 810 |
eqnmat[1][1] = vlist[p1i[0]][u];
| 811 |
eqnmat[1][2] = vlist[p1i[0]][v];
| 812 |
eqnmat[1][3] = 1.0;
| 813 |
eqnmat[2][0] = vlist[p2i[0]][u]*vlist[p2i[0]][v];
| 814 |
eqnmat[2][1] = vlist[p2i[0]][u];
| 815 |
eqnmat[2][2] = vlist[p2i[0]][v];
| 816 |
eqnmat[2][3] = 1.0;
| 817 |
eqnmat[3][0] = vlist[p3i[0]][u]*vlist[p3i[0]][v];
| 818 |
eqnmat[3][1] = vlist[p3i[0]][u];
| 819 |
eqnmat[3][2] = vlist[p3i[0]][v];
| 820 |
eqnmat[3][3] = 1.0;
| 821 |
/* invert matrix (solve system) */
| 822 |
if (!invmat4(eqnmat, eqnmat))
| 823 |
return(-1); /* no solution */
| 824 |
/* compute result matrix */
| 825 |
for (j = 0; j < 4; j++)
| 826 |
| 827 |
resmat[j][i] = eqnmat[j][0]*vnlist[p0i[2]][i] +
| 828 |
eqnmat[j][1]*vnlist[p1i[2]][i] +
| 829 |
eqnmat[j][2]*vnlist[p2i[2]][i] +
| 830 |
eqnmat[j][3]*vnlist[p3i[2]][i];
| 831 |
#ifdef TEXMAPS
| 832 |
/* compute result matrix for texture indices */
| 833 |
#endif
| 834 |
return(ax);
| 835 |
| 836 |
#undef u
| 837 |
#undef v
| 838 |
| 839 |
| 840 |
| 841 |
freeverts() /* free all vertices */
| 842 |
| 843 |
if (nvs) {
| 844 |
free((char *)vlist);
| 845 |
nvs = 0;
| 846 |
| 847 |
if (nvts) {
| 848 |
free((char *)vtlist);
| 849 |
nvts = 0;
| 850 |
| 851 |
if (nvns) {
| 852 |
free((char *)vnlist);
| 853 |
nvns = 0;
| 854 |
| 855 |
| 856 |
| 857 |
| 858 |
int
| 859 |
newv(x, y, z) /* create a new vertex */
| 860 |
double x, y, z;
| 861 |
| 862 |
if (!(nvs%CHUNKSIZ)) { /* allocate next block */
| 863 |
if (nvs == 0)
| 864 |
vlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT));
| 865 |
else
| 866 |
vlist = (FVECT *)realloc((char *)vlist,
| 867 |
(nvs+CHUNKSIZ)*sizeof(FVECT));
| 868 |
if (vlist == NULL) {
| 869 |
fprintf(stderr,
| 870 |
"Out of memory while allocating vertex %d\n", nvs);
| 871 |
exit(1);
| 872 |
| 873 |
| 874 |
/* assign new vertex */
| 875 |
vlist[nvs][0] = x;
| 876 |
vlist[nvs][1] = y;
| 877 |
vlist[nvs][2] = z;
| 878 |
return(++nvs);
| 879 |
| 880 |
| 881 |
| 882 |
int
| 883 |
newvn(x, y, z) /* create a new vertex normal */
| 884 |
double x, y, z;
| 885 |
| 886 |
if (!(nvns%CHUNKSIZ)) { /* allocate next block */
| 887 |
if (nvns == 0)
| 888 |
vnlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT));
| 889 |
else
| 890 |
vnlist = (FVECT *)realloc((char *)vnlist,
| 891 |
(nvns+CHUNKSIZ)*sizeof(FVECT));
| 892 |
if (vnlist == NULL) {
| 893 |
fprintf(stderr,
| 894 |
"Out of memory while allocating normal %d\n", nvns);
| 895 |
exit(1);
| 896 |
| 897 |
| 898 |
/* assign new normal */
| 899 |
vnlist[nvns][0] = x;
| 900 |
vnlist[nvns][1] = y;
| 901 |
vnlist[nvns][2] = z;
| 902 |
if (normalize(vnlist[nvns]) == 0.0)
| 903 |
return(0);
| 904 |
return(++nvns);
| 905 |
| 906 |
| 907 |
| 908 |
int
| 909 |
newvt(x, y) /* create a new texture map vertex */
| 910 |
double x, y;
| 911 |
| 912 |
if (!(nvts%CHUNKSIZ)) { /* allocate next block */
| 913 |
if (nvts == 0)
| 914 |
vtlist = (FLOAT (*)[2])malloc(CHUNKSIZ*2*sizeof(FLOAT));
| 915 |
else
| 916 |
vtlist = (FLOAT (*)[2])realloc((char *)vtlist,
| 917 |
(nvts+CHUNKSIZ)*2*sizeof(FLOAT));
| 918 |
if (vtlist == NULL) {
| 919 |
fprintf(stderr,
| 920 |
"Out of memory while allocating texture vertex %d\n",
| 921 |
nvts);
| 922 |
exit(1);
| 923 |
| 924 |
| 925 |
| 926 |
vtlist[nvts][0] = x;
| 927 |
vtlist[nvts][1] = y;
| 928 |
return(++nvts);
| 929 |
| 930 |
| 931 |
| 932 |
syntax(er) /* report syntax error and exit */
| 933 |
char *er;
| 934 |
| 935 |
fprintf(stderr, "%s: Wavefront syntax error near line %d: %s\n",
| 936 |
inpfile, lineno, er);
| 937 |
exit(1);
| 938 |
