| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: obj2rad.c,v 2.21 2003/07/27 22:12:02 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Convert a Wavefront .obj file to Radiance format.
| 6 |
| 7 |
* Currently, we support only polygonal geometry. Non-planar
| 8 |
* faces are broken rather haphazardly into triangles.
| 9 |
* Also, texture map indices only work for triangles, though
| 10 |
* I'm not sure they work correctly. (Taken out -- see TEXMAPS defines.)
| 11 |
| 12 |
| 13 |
#include <stdlib.h>
| 14 |
#include <stdio.h>
| 15 |
#include <ctype.h>
| 16 |
| 17 |
#include "rtmath.h"
| 18 |
#include "rtio.h"
| 19 |
#include "resolu.h"
| 20 |
#include "trans.h"
| 21 |
#include "tmesh.h"
| 22 |
| 23 |
| 24 |
#define PATNAME "M-pat" /* mesh pattern name (reused) */
| 25 |
#define TEXNAME "M-nor" /* mesh texture name (reused) */
| 26 |
#define DEFOBJ "unnamed" /* default object name */
| 27 |
#define DEFMAT "white" /* default material name */
| 28 |
| 29 |
#define pvect(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2])
| 30 |
| 31 |
FVECT *vlist; /* our vertex list */
| 32 |
int nvs; /* number of vertices in our list */
| 33 |
FVECT *vnlist; /* vertex normal list */
| 34 |
int nvns;
| 35 |
RREAL (*vtlist)[2]; /* map vertex list */
| 36 |
int nvts;
| 37 |
| 38 |
typedef int VNDX[3]; /* vertex index (point,map,normal) */
| 39 |
| 40 |
#define CHUNKSIZ 256 /* vertex allocation chunk size */
| 41 |
| 42 |
#define MAXARG 64 /* maximum # arguments in a statement */
| 43 |
| 44 |
/* qualifiers */
| 45 |
#define Q_MTL 0
| 46 |
#define Q_MAP 1
| 47 |
#define Q_GRP 2
| 48 |
#define Q_OBJ 3
| 49 |
#define Q_FAC 4
| 50 |
#define NQUALS 5
| 51 |
| 52 |
char *qname[NQUALS] = {
| 53 |
"Material",
| 54 |
"Map",
| 55 |
"Group",
| 56 |
"Object",
| 57 |
"Face",
| 58 |
| 59 |
| 60 |
QLIST qlist = {NQUALS, qname};
| 61 |
/* valid qualifier ids */
| 62 |
IDLIST qual[NQUALS];
| 63 |
/* mapping rules */
| 64 |
RULEHD *ourmapping = NULL;
| 65 |
| 66 |
char *defmat = DEFMAT; /* default (starting) material name */
| 67 |
char *defobj = DEFOBJ; /* default (starting) object name */
| 68 |
| 69 |
int flatten = 0; /* discard surface normal information */
| 70 |
| 71 |
char mapname[128]; /* current picture file */
| 72 |
char matname[64]; /* current material name */
| 73 |
char group[16][32]; /* current group names */
| 74 |
char objname[128]; /* current object name */
| 75 |
char *inpfile; /* input file name */
| 76 |
int lineno; /* current line number */
| 77 |
int faceno; /* current face number */
| 78 |
| 79 |
static void getnames(FILE *fp);
| 80 |
static void convert(FILE *fp);
| 81 |
static int getstmt(char *av[MAXARG], FILE *fp);
| 82 |
static char * getmtl(void);
| 83 |
static char * getonm(void);
| 84 |
static int matchrule(RULEHD *rp);
| 85 |
static int cvtndx(VNDX vi, char *vs);
| 86 |
static int nonplanar(int ac, char **av);
| 87 |
static int putface(int ac, char **av);
| 88 |
static int puttri(char *v1, char *v2, char *v3);
| 89 |
static void freeverts(void);
| 90 |
static int newv(double x, double y, double z);
| 91 |
static int newvn(double x, double y, double z);
| 92 |
static int newvt(double x, double y);
| 93 |
static void syntax(char *er);
| 94 |
| 95 |
| 96 |
int
| 97 |
main( /* read in .obj file and convert */
| 98 |
int argc,
| 99 |
char *argv[]
| 100 |
| 101 |
| 102 |
int donames = 0;
| 103 |
int i;
| 104 |
| 105 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 106 |
switch (argv[i][1]) {
| 107 |
case 'o': /* object name */
| 108 |
defobj = argv[++i];
| 109 |
break;
| 110 |
case 'n': /* just produce name list */
| 111 |
donames++;
| 112 |
break;
| 113 |
case 'm': /* use custom mapfile */
| 114 |
ourmapping = getmapping(argv[++i], &qlist);
| 115 |
break;
| 116 |
case 'f': /* flatten surfaces */
| 117 |
flatten++;
| 118 |
break;
| 119 |
default:
| 120 |
goto userr;
| 121 |
| 122 |
if ((i > argc) | (i < argc-1))
| 123 |
goto userr;
| 124 |
if (i == argc)
| 125 |
inpfile = "<stdin>";
| 126 |
else if (freopen(inpfile=argv[i], "r", stdin) == NULL) {
| 127 |
fprintf(stderr, "%s: cannot open\n", inpfile);
| 128 |
exit(1);
| 129 |
| 130 |
if (donames) { /* scan for ids */
| 131 |
getnames(stdin);
| 132 |
printf("filename \"%s\"\n", inpfile);
| 133 |
printf("filetype \"Wavefront\"\n");
| 134 |
write_quals(&qlist, qual, stdout);
| 135 |
printf("qualifier %s begin\n", qlist.qual[Q_FAC]);
| 136 |
printf("[%d:%d]\n", 1, faceno);
| 137 |
printf("end\n");
| 138 |
} else { /* translate file */
| 139 |
printf("# ");
| 140 |
printargs(argc, argv, stdout);
| 141 |
convert(stdin);
| 142 |
| 143 |
exit(0);
| 144 |
userr:
| 145 |
fprintf(stderr, "Usage: %s [-o obj][-m mapping][-n][-f] [file.obj]\n",
| 146 |
argv[0]);
| 147 |
exit(1);
| 148 |
| 149 |
| 150 |
| 151 |
void
| 152 |
getnames( /* get valid qualifier names */
| 153 |
FILE *fp
| 154 |
| 155 |
| 156 |
char *argv[MAXARG];
| 157 |
int argc;
| 158 |
ID tmpid;
| 159 |
register int i;
| 160 |
| 161 |
while ( (argc = getstmt(argv, fp)) )
| 162 |
switch (argv[0][0]) {
| 163 |
case 'f': /* face */
| 164 |
if (!argv[0][1])
| 165 |
faceno++;
| 166 |
break;
| 167 |
case 'u':
| 168 |
if (!strcmp(argv[0], "usemtl")) { /* material */
| 169 |
if (argc < 2)
| 170 |
break; /* not fatal */
| 171 |
tmpid.number = 0;
| 172 |
tmpid.name = argv[1];
| 173 |
findid(&qual[Q_MTL], &tmpid, 1);
| 174 |
} else if (!strcmp(argv[0], "usemap")) {/* map */
| 175 |
if (argc < 2 || !strcmp(argv[1], "off"))
| 176 |
| 177 |
tmpid.number = 0;
| 178 |
| 179 |
findid(&qual[Q_MAP], &tmpid, 1);
| 180 |
| 181 |
break;
| 182 |
| 183 |
if (argv[0][1] || argc < 2)
| 184 |
break;
| 185 |
tmpid.number = 0;
| 186 |
| 187 |
findid(&qual[Q_OBJ], &tmpid, 1);
| 188 |
break;
| 189 |
case 'g': /* group name(s) */
| 190 |
if (argv[0][1])
| 191 |
break;
| 192 |
tmpid.number = 0;
| 193 |
for (i = 1; i < argc; i++) {
| 194 |
tmpid.name = argv[i];
| 195 |
findid(&qual[Q_GRP], &tmpid, 1);
| 196 |
| 197 |
break;
| 198 |
| 199 |
| 200 |
| 201 |
| 202 |
void
| 203 |
convert( /* convert a T-mesh */
| 204 |
FILE *fp
| 205 |
| 206 |
| 207 |
char *argv[MAXARG];
| 208 |
int argc;
| 209 |
int nstats, nunknown;
| 210 |
register int i;
| 211 |
| 212 |
nstats = nunknown = 0;
| 213 |
/* scan until EOF */
| 214 |
while ( (argc = getstmt(argv, fp)) ) {
| 215 |
| 216 |
case 'v': /* vertex */
| 217 |
switch (argv[0][1]) {
| 218 |
case '\0': /* point */
| 219 |
if (badarg(argc-1,argv+1,"fff"))
| 220 |
syntax("Bad vertex");
| 221 |
newv(atof(argv[1]), atof(argv[2]),
| 222 |
atof(argv[3]));
| 223 |
break;
| 224 |
case 'n': /* normal */
| 225 |
if (argv[0][2])
| 226 |
goto unknown;
| 227 |
| 228 |
syntax("Bad normal");
| 229 |
if (!newvn(atof(argv[1]), atof(argv[2]),
| 230 |
atof(argv[3])))
| 231 |
syntax("Zero normal");
| 232 |
break;
| 233 |
case 't': /* texture map */
| 234 |
if (argv[0][2])
| 235 |
goto unknown;
| 236 |
if (badarg(argc-1,argv+1,"ff"))
| 237 |
goto unknown;
| 238 |
newvt(atof(argv[1]), atof(argv[2]));
| 239 |
break;
| 240 |
default:
| 241 |
goto unknown;
| 242 |
| 243 |
break;
| 244 |
| 245 |
if (argv[0][1])
| 246 |
goto unknown;
| 247 |
faceno++;
| 248 |
switch (argc-1) {
| 249 |
case 0: case 1: case 2:
| 250 |
syntax("Too few vertices");
| 251 |
break;
| 252 |
case 3:
| 253 |
if (!puttri(argv[1], argv[2], argv[3]))
| 254 |
syntax("Bad triangle");
| 255 |
break;
| 256 |
default:
| 257 |
if (!putface(argc-1, argv+1))
| 258 |
syntax("Bad face");
| 259 |
break;
| 260 |
| 261 |
break;
| 262 |
case 'u':
| 263 |
| 264 |
if (argc < 2)
| 265 |
| 266 |
strcpy(matname, argv[1]);
| 267 |
| 268 |
if (argc < 2)
| 269 |
| 270 |
if (!strcmp(argv[1], "off"))
| 271 |
mapname[0] = '\0';
| 272 |
else
| 273 |
sprintf(mapname, "%s.pic", argv[1]);
| 274 |
} else
| 275 |
goto unknown;
| 276 |
break;
| 277 |
| 278 |
if (argv[0][1])
| 279 |
goto unknown;
| 280 |
if (argc < 2)
| 281 |
| 282 |
strcpy(objname, argv[1]);
| 283 |
break;
| 284 |
| 285 |
if (argv[0][1])
| 286 |
goto unknown;
| 287 |
| 288 |
strcpy(group[i-1], argv[i]);
| 289 |
group[i-1][0] = '\0';
| 290 |
break;
| 291 |
case '#': /* comment */
| 292 |
| 293 |
break;
| 294 |
default:; /* something we don't deal with */
| 295 |
unknown:
| 296 |
nunknown++;
| 297 |
break;
| 298 |
| 299 |
nstats++;
| 300 |
| 301 |
printf("\n# Done processing file: %s\n", inpfile);
| 302 |
printf("# %d lines, %d statements, %d unrecognized\n",
| 303 |
lineno, nstats, nunknown);
| 304 |
| 305 |
| 306 |
| 307 |
int
| 308 |
getstmt( /* read the next statement from fp */
| 309 |
register char *av[MAXARG],
| 310 |
FILE *fp
| 311 |
| 312 |
| 313 |
extern char *fgetline();
| 314 |
static char sbuf[MAXARG*10];
| 315 |
register char *cp;
| 316 |
register int i;
| 317 |
| 318 |
do {
| 319 |
if (fgetline(cp=sbuf, sizeof(sbuf), fp) == NULL)
| 320 |
return(0);
| 321 |
i = 0;
| 322 |
for ( ; ; ) {
| 323 |
while (isspace(*cp) || *cp == '\\') {
| 324 |
if (*cp == '\n')
| 325 |
lineno++;
| 326 |
*cp++ = '\0';
| 327 |
| 328 |
if (!*cp || i >= MAXARG-1)
| 329 |
break;
| 330 |
av[i++] = cp;
| 331 |
while (*++cp && !isspace(*cp))
| 332 |
| 333 |
| 334 |
av[i] = NULL;
| 335 |
lineno++;
| 336 |
} while (!i);
| 337 |
| 338 |
return(i);
| 339 |
| 340 |
| 341 |
| 342 |
char *
| 343 |
getmtl(void) /* figure material for this face */
| 344 |
| 345 |
register RULEHD *rp = ourmapping;
| 346 |
| 347 |
if (rp == NULL) { /* no rule set */
| 348 |
if (matname[0])
| 349 |
return(matname);
| 350 |
if (group[0][0])
| 351 |
return(group[0]);
| 352 |
return(defmat);
| 353 |
| 354 |
/* check for match */
| 355 |
do {
| 356 |
if (matchrule(rp)) {
| 357 |
if (!strcmp(rp->mnam, VOIDID))
| 358 |
return(NULL); /* match is null */
| 359 |
return(rp->mnam);
| 360 |
| 361 |
rp = rp->next;
| 362 |
} while (rp != NULL);
| 363 |
/* no match found */
| 364 |
return(NULL);
| 365 |
| 366 |
| 367 |
| 368 |
char *
| 369 |
getonm(void) /* invent a good name for object */
| 370 |
| 371 |
static char name[64];
| 372 |
register char *cp1, *cp2;
| 373 |
register int i;
| 374 |
/* check for preset */
| 375 |
if (objname[0])
| 376 |
return(objname);
| 377 |
if (!group[0][0])
| 378 |
return(defobj);
| 379 |
cp1 = name; /* else make name out of groups */
| 380 |
for (i = 0; group[i][0]; i++) {
| 381 |
cp2 = group[i];
| 382 |
if (cp1 > name)
| 383 |
*cp1++ = '.';
| 384 |
while ( (*cp1 = *cp2++) )
| 385 |
if (++cp1 >= name+sizeof(name)-2) {
| 386 |
*cp1 = '\0';
| 387 |
return(name);
| 388 |
| 389 |
| 390 |
return(name);
| 391 |
| 392 |
| 393 |
| 394 |
int
| 395 |
matchrule( /* check for a match on this rule */
| 396 |
register RULEHD *rp
| 397 |
| 398 |
| 399 |
ID tmpid;
| 400 |
int gotmatch;
| 401 |
register int i;
| 402 |
| 403 |
if (rp->qflg & FL(Q_MTL)) {
| 404 |
if (!matname[0])
| 405 |
return(0);
| 406 |
tmpid.number = 0;
| 407 |
tmpid.name = matname;
| 408 |
if (!matchid(&tmpid, &idm(rp)[Q_MTL]))
| 409 |
return(0);
| 410 |
| 411 |
if (rp->qflg & FL(Q_MAP)) {
| 412 |
if (!mapname[0])
| 413 |
return(0);
| 414 |
tmpid.number = 0;
| 415 |
tmpid.name = mapname;
| 416 |
if (!matchid(&tmpid, &idm(rp)[Q_MAP]))
| 417 |
return(0);
| 418 |
| 419 |
if (rp->qflg & FL(Q_GRP)) {
| 420 |
tmpid.number = 0;
| 421 |
gotmatch = 0;
| 422 |
| 423 |
tmpid.name = group[i];
| 424 |
gotmatch |= matchid(&tmpid, &idm(rp)[Q_GRP]);
| 425 |
| 426 |
if (!gotmatch)
| 427 |
return(0);
| 428 |
| 429 |
if (rp->qflg & FL(Q_OBJ)) {
| 430 |
if (!objname[0])
| 431 |
return(0);
| 432 |
tmpid.number = 0;
| 433 |
tmpid.name = objname;
| 434 |
if (!matchid(&tmpid, &idm(rp)[Q_OBJ]))
| 435 |
return(0);
| 436 |
| 437 |
if (rp->qflg & FL(Q_FAC)) {
| 438 |
tmpid.name = NULL;
| 439 |
tmpid.number = faceno;
| 440 |
if (!matchid(&tmpid, &idm(rp)[Q_FAC]))
| 441 |
return(0);
| 442 |
| 443 |
return(1);
| 444 |
| 445 |
| 446 |
| 447 |
int
| 448 |
cvtndx( /* convert vertex string to index */
| 449 |
register VNDX vi,
| 450 |
register char *vs
| 451 |
| 452 |
| 453 |
/* get point */
| 454 |
vi[0] = atoi(vs);
| 455 |
if (vi[0] > 0) {
| 456 |
if (vi[0]-- > nvs)
| 457 |
return(0);
| 458 |
} else if (vi[0] < 0) {
| 459 |
vi[0] += nvs;
| 460 |
if (vi[0] < 0)
| 461 |
return(0);
| 462 |
} else
| 463 |
return(0);
| 464 |
/* get map */
| 465 |
while (*vs)
| 466 |
if (*vs++ == '/')
| 467 |
break;
| 468 |
vi[1] = atoi(vs);
| 469 |
if (vi[1] > 0) {
| 470 |
if (vi[1]-- > nvts)
| 471 |
return(0);
| 472 |
} else if (vi[1] < 0) {
| 473 |
vi[1] += nvts;
| 474 |
if (vi[1] < 0)
| 475 |
return(0);
| 476 |
} else
| 477 |
vi[1] = -1;
| 478 |
/* get normal */
| 479 |
while (*vs)
| 480 |
if (*vs++ == '/')
| 481 |
break;
| 482 |
vi[2] = atoi(vs);
| 483 |
if (vi[2] > 0) {
| 484 |
if (vi[2]-- > nvns)
| 485 |
return(0);
| 486 |
} else if (vi[2] < 0) {
| 487 |
vi[2] += nvns;
| 488 |
if (vi[2] < 0)
| 489 |
return(0);
| 490 |
} else
| 491 |
vi[2] = -1;
| 492 |
return(1);
| 493 |
| 494 |
| 495 |
| 496 |
int
| 497 |
nonplanar( /* are vertices non-planar? */
| 498 |
register int ac,
| 499 |
register char **av
| 500 |
| 501 |
| 502 |
VNDX vi;
| 503 |
RREAL *p0, *p1;
| 504 |
FVECT v1, v2, nsum, newn;
| 505 |
double d;
| 506 |
register int i;
| 507 |
| 508 |
if (!cvtndx(vi, av[0]))
| 509 |
return(0);
| 510 |
if (!flatten && vi[2] >= 0)
| 511 |
return(1); /* has interpolated normals */
| 512 |
if (ac < 4)
| 513 |
return(0); /* it's a triangle! */
| 514 |
/* set up */
| 515 |
p0 = vlist[vi[0]];
| 516 |
if (!cvtndx(vi, av[1]))
| 517 |
return(0); /* error gets caught later */
| 518 |
nsum[0] = nsum[1] = nsum[2] = 0.;
| 519 |
p1 = vlist[vi[0]];
| 520 |
fvsum(v2, p1, p0, -1.0);
| 521 |
for (i = 2; i < ac; i++) {
| 522 |
VCOPY(v1, v2);
| 523 |
if (!cvtndx(vi, av[i]))
| 524 |
return(0);
| 525 |
p1 = vlist[vi[0]];
| 526 |
| 527 |
fcross(newn, v1, v2);
| 528 |
if (normalize(newn) == 0.0) {
| 529 |
if (i < 3)
| 530 |
return(1); /* can't deal with this */
| 531 |
fvsum(nsum, nsum, nsum, 1./(i-2));
| 532 |
continue;
| 533 |
| 534 |
d = fdot(newn,nsum);
| 535 |
if (d >= 0) {
| 536 |
if (d < (1.0-FTINY)*(i-2))
| 537 |
return(1);
| 538 |
fvsum(nsum, nsum, newn, 1.0);
| 539 |
} else {
| 540 |
if (d > -(1.0-FTINY)*(i-2))
| 541 |
return(1);
| 542 |
fvsum(nsum, nsum, newn, -1.0);
| 543 |
| 544 |
| 545 |
return(0);
| 546 |
| 547 |
| 548 |
| 549 |
int
| 550 |
putface( /* put out an N-sided polygon */
| 551 |
int ac,
| 552 |
register char **av
| 553 |
| 554 |
| 555 |
VNDX vi;
| 556 |
char *cp;
| 557 |
register int i;
| 558 |
| 559 |
if (nonplanar(ac, av)) { /* break into triangles */
| 560 |
while (ac > 2) {
| 561 |
if (!puttri(av[0], av[1], av[2]))
| 562 |
return(0);
| 563 |
ac--; /* remove vertex & rotate */
| 564 |
cp = av[0];
| 565 |
for (i = 0; i < ac-1; i++)
| 566 |
av[i] = av[i+2];
| 567 |
av[i] = cp;
| 568 |
| 569 |
return(1);
| 570 |
| 571 |
if ((cp = getmtl()) == NULL)
| 572 |
return(-1);
| 573 |
printf("\n%s polygon %s.%d\n", cp, getonm(), faceno);
| 574 |
printf("0\n0\n%d\n", 3*ac);
| 575 |
for (i = 0; i < ac; i++) {
| 576 |
| 577 |
return(0);
| 578 |
pvect(vlist[vi[0]]);
| 579 |
| 580 |
return(1);
| 581 |
| 582 |
| 583 |
| 584 |
int
| 585 |
puttri( /* put out a triangle */
| 586 |
char *v1,
| 587 |
char *v2,
| 588 |
char *v3
| 589 |
| 590 |
| 591 |
char *mod;
| 592 |
VNDX v1i, v2i, v3i;
| 593 |
BARYCCM bvecs;
| 594 |
RREAL bcoor[3][3];
| 595 |
int texOK = 0, patOK;
| 596 |
int flatness;
| 597 |
register int i;
| 598 |
| 599 |
if ((mod = getmtl()) == NULL)
| 600 |
return(-1);
| 601 |
| 602 |
if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3))
| 603 |
return(0);
| 604 |
/* compute barycentric coordinates */
| 605 |
if (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0)
| 606 |
flatness = flat_tri(vlist[v1i[0]], vlist[v2i[0]], vlist[v3i[0]],
| 607 |
vnlist[v1i[2]], vnlist[v2i[2]], vnlist[v3i[2]]);
| 608 |
else
| 609 |
flatness = ISFLAT;
| 610 |
| 611 |
switch (flatness) {
| 612 |
case DEGEN: /* zero area */
| 613 |
return(-1);
| 614 |
case RVFLAT: /* reversed normals, but flat */
| 615 |
case ISFLAT: /* smoothing unnecessary */
| 616 |
texOK = 0;
| 617 |
break;
| 618 |
case RVBENT: /* reversed normals with smoothing */
| 619 |
case ISBENT: /* proper smoothing */
| 620 |
texOK = 1;
| 621 |
break;
| 622 |
| 623 |
if (flatten)
| 624 |
texOK = 0;
| 625 |
#ifdef TEXMAPS
| 626 |
patOK = mapname[0] && (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0);
| 627 |
#else
| 628 |
patOK = 0;
| 629 |
#endif
| 630 |
if (texOK | patOK)
| 631 |
if (comp_baryc(&bvecs, vlist[v1i[0]], vlist[v2i[0]],
| 632 |
vlist[v3i[0]]) < 0)
| 633 |
return(-1);
| 634 |
/* put out texture (if any) */
| 635 |
if (texOK) {
| 636 |
printf("\n%s texfunc %s\n", mod, TEXNAME);
| 637 |
mod = TEXNAME;
| 638 |
printf("4 dx dy dz %s\n", TCALNAME);
| 639 |
printf("0\n");
| 640 |
for (i = 0; i < 3; i++) {
| 641 |
bcoor[i][0] = vnlist[v1i[2]][i];
| 642 |
bcoor[i][1] = vnlist[v2i[2]][i];
| 643 |
bcoor[i][2] = vnlist[v3i[2]][i];
| 644 |
| 645 |
put_baryc(&bvecs, bcoor, 3);
| 646 |
| 647 |
#ifdef TEXMAPS
| 648 |
/* put out pattern (if any) */
| 649 |
if (patOK) {
| 650 |
printf("\n%s colorpict %s\n", mod, PATNAME);
| 651 |
mod = PATNAME;
| 652 |
printf("7 noneg noneg noneg %s %s u v\n", mapname, TCALNAME);
| 653 |
printf("0\n");
| 654 |
for (i = 0; i < 2; i++) {
| 655 |
bcoor[i][0] = vtlist[v1i[1]][i];
| 656 |
bcoor[i][1] = vtlist[v2i[1]][i];
| 657 |
bcoor[i][2] = vtlist[v3i[1]][i];
| 658 |
| 659 |
put_baryc(&bvecs, bcoor, 2);
| 660 |
| 661 |
#endif
| 662 |
/* put out (reversed) triangle */
| 663 |
printf("\n%s polygon %s.%d\n", mod, getonm(), faceno);
| 664 |
printf("0\n0\n9\n");
| 665 |
if (flatness == RVFLAT || flatness == RVBENT) {
| 666 |
pvect(vlist[v3i[0]]);
| 667 |
pvect(vlist[v2i[0]]);
| 668 |
pvect(vlist[v1i[0]]);
| 669 |
} else {
| 670 |
| 671 |
| 672 |
| 673 |
| 674 |
return(1);
| 675 |
| 676 |
| 677 |
| 678 |
void
| 679 |
freeverts(void) /* free all vertices */
| 680 |
| 681 |
if (nvs) {
| 682 |
free((void *)vlist);
| 683 |
nvs = 0;
| 684 |
| 685 |
if (nvts) {
| 686 |
free((void *)vtlist);
| 687 |
nvts = 0;
| 688 |
| 689 |
if (nvns) {
| 690 |
free((void *)vnlist);
| 691 |
nvns = 0;
| 692 |
| 693 |
| 694 |
| 695 |
| 696 |
int
| 697 |
newv( /* create a new vertex */
| 698 |
double x,
| 699 |
double y,
| 700 |
double z
| 701 |
| 702 |
| 703 |
if (!(nvs%CHUNKSIZ)) { /* allocate next block */
| 704 |
if (nvs == 0)
| 705 |
vlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT));
| 706 |
else
| 707 |
vlist = (FVECT *)realloc((void *)vlist,
| 708 |
(nvs+CHUNKSIZ)*sizeof(FVECT));
| 709 |
if (vlist == NULL) {
| 710 |
fprintf(stderr,
| 711 |
"Out of memory while allocating vertex %d\n", nvs);
| 712 |
exit(1);
| 713 |
| 714 |
| 715 |
/* assign new vertex */
| 716 |
vlist[nvs][0] = x;
| 717 |
vlist[nvs][1] = y;
| 718 |
vlist[nvs][2] = z;
| 719 |
return(++nvs);
| 720 |
| 721 |
| 722 |
| 723 |
int
| 724 |
newvn( /* create a new vertex normal */
| 725 |
double x,
| 726 |
double y,
| 727 |
double z
| 728 |
| 729 |
| 730 |
if (!(nvns%CHUNKSIZ)) { /* allocate next block */
| 731 |
if (nvns == 0)
| 732 |
vnlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT));
| 733 |
else
| 734 |
vnlist = (FVECT *)realloc((void *)vnlist,
| 735 |
(nvns+CHUNKSIZ)*sizeof(FVECT));
| 736 |
if (vnlist == NULL) {
| 737 |
fprintf(stderr,
| 738 |
"Out of memory while allocating normal %d\n", nvns);
| 739 |
exit(1);
| 740 |
| 741 |
| 742 |
/* assign new normal */
| 743 |
vnlist[nvns][0] = x;
| 744 |
vnlist[nvns][1] = y;
| 745 |
vnlist[nvns][2] = z;
| 746 |
if (normalize(vnlist[nvns]) == 0.0)
| 747 |
return(0);
| 748 |
return(++nvns);
| 749 |
| 750 |
| 751 |
| 752 |
int
| 753 |
newvt( /* create a new texture map vertex */
| 754 |
double x,
| 755 |
double y
| 756 |
| 757 |
| 758 |
if (!(nvts%CHUNKSIZ)) { /* allocate next block */
| 759 |
if (nvts == 0)
| 760 |
vtlist = (RREAL (*)[2])malloc(CHUNKSIZ*2*sizeof(RREAL));
| 761 |
else
| 762 |
vtlist = (RREAL (*)[2])realloc((void *)vtlist,
| 763 |
(nvts+CHUNKSIZ)*2*sizeof(RREAL));
| 764 |
if (vtlist == NULL) {
| 765 |
fprintf(stderr,
| 766 |
"Out of memory while allocating texture vertex %d\n",
| 767 |
nvts);
| 768 |
exit(1);
| 769 |
| 770 |
| 771 |
| 772 |
vtlist[nvts][0] = x;
| 773 |
vtlist[nvts][1] = y;
| 774 |
return(++nvts);
| 775 |
| 776 |
| 777 |
| 778 |
void
| 779 |
syntax( /* report syntax error and exit */
| 780 |
char *er
| 781 |
| 782 |
| 783 |
fprintf(stderr, "%s: Wavefront syntax error near line %d: %s\n",
| 784 |
inpfile, lineno, er);
| 785 |
exit(1);
| 786 |
