--- ray/src/cv/obj2rad.c 1994/04/14 13:36:18 2.7 +++ ray/src/cv/obj2rad.c 1994/06/14 14:30:38 2.8 @@ -70,6 +70,8 @@ RULEHD *ourmapping = NULL; char *defmat = DEFMAT; /* default (starting) material name */ char *defobj = DEFOBJ; /* default (starting) object name */ +int flatten = 0; /* discard surface normal information */ + char *getmtl(), *getonm(); char mapname[128]; /* current picture file */ @@ -99,6 +101,9 @@ char *argv[]; case 'm': /* use custom mapfile */ ourmapping = getmapping(argv[++i], &qlist); break; + case 'f': /* flatten surfaces */ + flatten++; + break; default: goto userr; } @@ -572,7 +577,7 @@ char *v1, *v2, *v3; if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) return(0); /* compute barycentric coordinates */ - texOK = (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0); + texOK = !flatten && (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0); #ifdef TEXMAPS patOK = mapname[0] && (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0); #else @@ -792,7 +797,7 @@ register VNDX p0i, p1i, p2i, p3i; #ifdef TEXMAPS /* also check for texture indices */ #endif - if (!(p0i[2]>=0 && p1i[2]>=0 && p2i[2]>=0 && p3i[2]>=0)) + if (flatten || !(p0i[2]>=0 && p1i[2]>=0 && p2i[2]>=0 && p3i[2]>=0)) return(-1); /* find dominant axis */ VCOPY(v1, vnlist[p0i[2]]);
