--- ray/src/cv/obj2rad.c 1994/04/14 04:29:10 2.6 +++ ray/src/cv/obj2rad.c 1994/06/15 09:51:31 2.9 @@ -10,7 +10,7 @@ static char SCCSid[] = "$SunId$ LBL"; * Currently, we support only polygonal geometry. Non-planar * faces are broken rather haphazardly into triangles. * Also, texture map indices only work for triangles, though - * I'm not sure they work correctly. + * I'm not sure they work correctly. (Taken out -- see TEXMAPS defines.) */ #include "standard.h" @@ -70,6 +70,8 @@ RULEHD *ourmapping = NULL; char *defmat = DEFMAT; /* default (starting) material name */ char *defobj = DEFOBJ; /* default (starting) object name */ +int flatten = 0; /* discard surface normal information */ + char *getmtl(), *getonm(); char mapname[128]; /* current picture file */ @@ -99,6 +101,9 @@ char *argv[]; case 'm': /* use custom mapfile */ ourmapping = getmapping(argv[++i], &qlist); break; + case 'f': /* flatten surfaces */ + flatten++; + break; default: goto userr; } @@ -125,7 +130,7 @@ char *argv[]; } exit(0); userr: - fprintf(stderr, "Usage: %s [-o obj][-m mapping][-n] [file.obj]\n", + fprintf(stderr, "Usage: %s [-o obj][-m mapping][-n][-f] [file.obj]\n", argv[0]); exit(1); } @@ -254,7 +259,7 @@ FILE *fp; if (!strcmp(argv[1], "off")) mapname[0] = '\0'; else - strcpy(mapname, argv[1]); + sprintf(mapname, "%s.pic", argv[1]); } else goto unknown; break; @@ -273,6 +278,7 @@ FILE *fp; group[i-1][0] = '\0'; break; case '#': /* comment */ + printargs(argc, argv, stdout); break; default:; /* something we don't deal with */ unknown: @@ -434,7 +440,7 @@ register char *vs; if (vi[0]-- > nvs) return(0); } else if (vi[0] < 0) { - vi[0] = nvs + vi[0]; + vi[0] += nvs; if (vi[0] < 0) return(0); } else @@ -448,7 +454,7 @@ register char *vs; if (vi[1]-- > nvts) return(0); } else if (vi[1] < 0) { - vi[1] = nvts + vi[1]; + vi[1] += nvts; if (vi[1] < 0) return(0); } else @@ -462,7 +468,7 @@ register char *vs; if (vi[2]-- > nvns) return(0); } else if (vi[2] < 0) { - vi[2] = nvns + vi[2]; + vi[2] += nvns; if (vi[2] < 0) return(0); } else @@ -471,7 +477,7 @@ register char *vs; } -nonplanar(ac, av) /* are vertices are non-planar? */ +nonplanar(ac, av) /* are vertices non-planar? */ register int ac; register char **av; { @@ -527,25 +533,26 @@ int ac; register char **av; { VNDX vi; - char *mod; + char *cp; register int i; if (nonplanar(ac, av)) { /* break into quads and triangles */ while (ac > 3) { if (!putquad(av[0], av[1], av[2], av[3])) return(0); - /* remove two vertices & rotate */ - av[ac -= 2] = av[0]; - for (i = 0; i <= ac; i++) - av[i] = av[i+2]; + ac -= 2; /* remove two vertices & rotate */ + cp = av[0]; + for (i = 0; i < ac-1; i++) + av[i] = av[i+3]; + av[i] = cp; } if (ac == 3 && !puttri(av[0], av[1], av[2])) return(0); return(1); } - if ((mod = getmtl()) == NULL) + if ((cp = getmtl()) == NULL) return(-1); - printf("\n%s polygon %s.%d\n", mod, getonm(), faceno); + printf("\n%s polygon %s.%d\n", cp, getonm(), faceno); printf("0\n0\n%d\n", 3*ac); for (i = 0; i < ac; i++) { if (!cvtndx(vi, av[i])) @@ -570,8 +577,12 @@ char *v1, *v2, *v3; if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) return(0); /* compute barycentric coordinates */ - texOK = (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0); + texOK = !flatten && (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0); +#ifdef TEXMAPS patOK = mapname[0] && (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0); +#else + patOK = 0; +#endif if (texOK | patOK) if (comp_baryc(bvecs, vlist[v1i[0]], vlist[v2i[0]], vlist[v3i[0]]) < 0) @@ -593,6 +604,7 @@ char *v1, *v2, *v3; vnlist[v1i[2]][2], vnlist[v2i[2]][2], vnlist[v3i[2]][2]); } +#ifdef TEXMAPS /* put out pattern (if any) */ if (patOK) { printf("\n%s colorpict %s\n", mod, PATNAME); @@ -605,6 +617,7 @@ char *v1, *v2, *v3; printf("\t%f %f %f\n", vtlist[v1i[1]][1], vtlist[v2i[1]][1], vtlist[v3i[1]][1]); } +#endif /* put out triangle */ printf("\n%s polygon %s.%d\n", mod, getonm(), faceno); printf("0\n0\n9\n"); @@ -676,6 +689,11 @@ char *p0, *p1, *p3, *p2; /* names correspond to bina FVECT v1, v2, vc1, vc2; int ok1, ok2; +#ifdef TEXMAPS + /* also should output texture index coordinates, + * which will require new .cal file + */ +#endif if ((mod = getmtl()) == NULL) return(-1); name = getonm(); @@ -776,7 +794,10 @@ register VNDX p0i, p1i, p2i, p3i; FVECT v1; register int i, j; - if (!(p0i[2]>=0 && p1i[2]>=0 && p2i[2]>=0 && p3i[2]>=0)) +#ifdef TEXMAPS + /* also check for texture indices */ +#endif + if (flatten || !(p0i[2]>=0 && p1i[2]>=0 && p2i[2]>=0 && p3i[2]>=0)) return(-1); /* find dominant axis */ VCOPY(v1, vnlist[p0i[2]]); @@ -812,6 +833,9 @@ register VNDX p0i, p1i, p2i, p3i; eqnmat[j][1]*vnlist[p1i[2]][i] + eqnmat[j][2]*vnlist[p2i[2]][i] + eqnmat[j][3]*vnlist[p3i[2]][i]; +#ifdef TEXMAPS + /* compute result matrix for texture indices */ +#endif return(ax); #undef u
