--- ray/src/cv/obj2rad.c 1994/04/14 04:29:10 2.6 +++ ray/src/cv/obj2rad.c 1994/04/14 13:36:18 2.7 @@ -10,7 +10,7 @@ static char SCCSid[] = "$SunId$ LBL"; * Currently, we support only polygonal geometry. Non-planar * faces are broken rather haphazardly into triangles. * Also, texture map indices only work for triangles, though - * I'm not sure they work correctly. + * I'm not sure they work correctly. (Taken out -- see TEXMAPS defines.) */ #include "standard.h" @@ -254,7 +254,7 @@ FILE *fp; if (!strcmp(argv[1], "off")) mapname[0] = '\0'; else - strcpy(mapname, argv[1]); + sprintf(mapname, "%s.pic", argv[1]); } else goto unknown; break; @@ -273,6 +273,7 @@ FILE *fp; group[i-1][0] = '\0'; break; case '#': /* comment */ + printargs(argc, argv, stdout); break; default:; /* something we don't deal with */ unknown: @@ -527,25 +528,26 @@ int ac; register char **av; { VNDX vi; - char *mod; + char *cp; register int i; if (nonplanar(ac, av)) { /* break into quads and triangles */ while (ac > 3) { if (!putquad(av[0], av[1], av[2], av[3])) return(0); - /* remove two vertices & rotate */ - av[ac -= 2] = av[0]; - for (i = 0; i <= ac; i++) - av[i] = av[i+2]; + ac -= 2; /* remove two vertices & rotate */ + cp = av[0]; + for (i = 0; i < ac-1; i++) + av[i] = av[i+3]; + av[i] = cp; } if (ac == 3 && !puttri(av[0], av[1], av[2])) return(0); return(1); } - if ((mod = getmtl()) == NULL) + if ((cp = getmtl()) == NULL) return(-1); - printf("\n%s polygon %s.%d\n", mod, getonm(), faceno); + printf("\n%s polygon %s.%d\n", cp, getonm(), faceno); printf("0\n0\n%d\n", 3*ac); for (i = 0; i < ac; i++) { if (!cvtndx(vi, av[i])) @@ -571,7 +573,11 @@ char *v1, *v2, *v3; return(0); /* compute barycentric coordinates */ texOK = (v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0); +#ifdef TEXMAPS patOK = mapname[0] && (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0); +#else + patOK = 0; +#endif if (texOK | patOK) if (comp_baryc(bvecs, vlist[v1i[0]], vlist[v2i[0]], vlist[v3i[0]]) < 0) @@ -593,6 +599,7 @@ char *v1, *v2, *v3; vnlist[v1i[2]][2], vnlist[v2i[2]][2], vnlist[v3i[2]][2]); } +#ifdef TEXMAPS /* put out pattern (if any) */ if (patOK) { printf("\n%s colorpict %s\n", mod, PATNAME); @@ -605,6 +612,7 @@ char *v1, *v2, *v3; printf("\t%f %f %f\n", vtlist[v1i[1]][1], vtlist[v2i[1]][1], vtlist[v3i[1]][1]); } +#endif /* put out triangle */ printf("\n%s polygon %s.%d\n", mod, getonm(), faceno); printf("0\n0\n9\n"); @@ -676,6 +684,11 @@ char *p0, *p1, *p3, *p2; /* names correspond to bina FVECT v1, v2, vc1, vc2; int ok1, ok2; +#ifdef TEXMAPS + /* also should output texture index coordinates, + * which will require new .cal file + */ +#endif if ((mod = getmtl()) == NULL) return(-1); name = getonm(); @@ -776,6 +789,9 @@ register VNDX p0i, p1i, p2i, p3i; FVECT v1; register int i, j; +#ifdef TEXMAPS + /* also check for texture indices */ +#endif if (!(p0i[2]>=0 && p1i[2]>=0 && p2i[2]>=0 && p3i[2]>=0)) return(-1); /* find dominant axis */ @@ -812,6 +828,9 @@ register VNDX p0i, p1i, p2i, p3i; eqnmat[j][1]*vnlist[p1i[2]][i] + eqnmat[j][2]*vnlist[p2i[2]][i] + eqnmat[j][3]*vnlist[p3i[2]][i]; +#ifdef TEXMAPS + /* compute result matrix for texture indices */ +#endif return(ax); #undef u
