--- ray/src/cv/obj2rad.c 2008/11/10 19:08:18 2.25 +++ ray/src/cv/obj2rad.c 2010/09/28 21:28:23 2.27 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: obj2rad.c,v 2.25 2008/11/10 19:08:18 greg Exp $"; +static const char RCSid[] = "$Id: obj2rad.c,v 2.27 2010/09/28 21:28:23 greg Exp $"; #endif /* * Convert a Wavefront .obj file to Radiance format. @@ -36,6 +36,7 @@ RREAL (*vtlist)[2]; /* map vertex list */ int nvts; int ndegen = 0; /* count of degenerate faces */ +int n0norm = 0; /* count of zero normals */ typedef int VNDX[3]; /* vertex index (point,map,normal) */ @@ -144,6 +145,8 @@ main( /* read in .obj file and convert */ } if (ndegen) printf("# %d degenerate faces\n", ndegen); + if (n0norm) + printf("# %d invalid (zero) normals\n", n0norm); exit(0); userr: fprintf(stderr, "Usage: %s [-o obj][-m mapping][-n][-f] [file.obj]\n", @@ -498,6 +501,9 @@ cvtndx( /* convert vertex string to index */ return(0); } else vi[2] = -1; + /* zero normal is not normal */ + if (vi[2] >= 0 && DOT(vnlist[vi[2]],vnlist[vi[2]]) <= FTINY) + vi[2] = -1; return(1); } @@ -578,7 +584,7 @@ putface( /* put out an N-sided polygon */ return(1); } if ((cp = getmtl()) == NULL) - return(0); + return(-1); printf("\n%s polygon %s.%d\n", cp, getonm(), faceno); printf("0\n0\n%d\n", 3*ac); for (i = 0; i < ac; i++) { @@ -606,7 +612,7 @@ puttri( /* put out a triangle */ register int i; if ((mod = getmtl()) == NULL) - return(0); + return(-1); if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) return(0); @@ -753,8 +759,7 @@ newvn( /* create a new vertex normal */ vnlist[nvns][0] = x; vnlist[nvns][1] = y; vnlist[nvns][2] = z; - if (normalize(vnlist[nvns]) == 0.0) - return(0); + n0norm += (normalize(vnlist[nvns]) == 0.0); return(++nvns); }
