root/Development/ray/src/cv/obj2rad.c
Sat Jun 7 05:09:45 2025 UTC (6 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.32 , to selected 2.24
Thu Apr 15 23:51:04 2021 UTC (4 years, 8 months ago) by greg
Diff to previous 2.31 , to selected 2.24
Tue Jan 28 21:18:02 2020 UTC (5 years, 11 months ago) by greg
Diff to previous 2.30 , to selected 2.24
Added space to beginning of line to help rcalc
Sat Dec 28 18:05:14 2019 UTC (6 years ago) by greg
Changes since 2.29: +1 -2 lines
Diff to previous 2.29 , to selected 2.24
Fri Nov 8 16:49:04 2013 UTC (12 years, 1 month ago) by greg
Changes since 2.28: +4 -4 lines
Diff to previous 2.28 , to selected 2.24
Increased maximum identifier name length from 64 to 256
Tue Aug 20 16:19:03 2013 UTC (12 years, 4 months ago) by greg
Changes since 2.27: +24 -24 lines
Diff to previous 2.27 , to selected 2.24
Increased max. group name size to 256
Tue Sep 28 21:28:23 2010 UTC (15 years, 3 months ago) by greg
Changes since 2.26: +3 -3 lines
Diff to previous 2.26 , to selected 2.24
Fixed bug in "void" mapping of surfaces
Thu Sep 16 03:28:21 2010 UTC (15 years, 3 months ago) by greg
Changes since 2.25: +8 -3 lines
Diff to previous 2.25 , to selected 2.24
Changed obj2rad to accept illegal normals
Mon Nov 10 19:08:18 2008 UTC (17 years, 1 month ago) by greg
Diff to previous 2.24
Revision 2.24 - (view) (download) (annotate) - [selected]
Tue Jun 24 02:01:19 2008 UTC (17 years, 6 months ago) by greg
Changes since 2.23: +9 -4 lines
Diff to previous 2.23
Fri Apr 23 16:20:56 2004 UTC (21 years, 8 months ago) by greg
Changes since 2.22: +11 -6 lines
Diff to previous 2.22 , to selected 2.24
Sat Nov 15 17:54:06 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.21: +88 -41 lines
Diff to previous 2.21 , to selected 2.24
Sun Jul 27 22:12:02 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.20: +5 -5 lines
Diff to previous 2.20 , to selected 2.24
Thu Jun 26 00:58:09 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 2.19: +7 -7 lines
Diff to previous 2.19 , to selected 2.24
Wed Apr 23 00:52:33 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.18 , to selected 2.24
Tue Mar 4 01:42:29 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.17: +29 -19 lines
Diff to previous 2.17 , to selected 2.24
Fixed problems with normals and orientations that disagree.
Sat Feb 22 02:07:23 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.16: +4 -7 lines
Diff to previous 2.16 , to selected 2.24
Wed Jul 24 13:07:41 1996 UTC (29 years, 5 months ago) by greg
Changes since 2.15: +16 -1 lines
Diff to previous 2.15 , to selected 2.24
added check for flat triangles with normals
Wed Jun 22 12:35:59 1994 UTC (31 years, 6 months ago) by greg
Changes since 2.14: +2 -75 lines
Diff to previous 2.14 , to selected 2.24
Wed Jun 15 19:06:04 1994 UTC (31 years, 6 months ago) by greg
Diff to previous 2.13 , to selected 2.24
cosmetic fix to parameters of put_baryc
Wed Jun 15 15:07:08 1994 UTC (31 years, 6 months ago) by greg
Changes since 2.12: +31 -23 lines
Diff to previous 2.12 , to selected 2.24
further reduced complexity and size of barycentric calculation
Wed Jun 15 12:52:19 1994 UTC (31 years, 6 months ago) by greg
Diff to previous 2.11 , to selected 2.24
added check for flatten in nonplanar()
Wed Jun 15 12:50:37 1994 UTC (31 years, 6 months ago) by greg
Changes since 2.10: +5 -177 lines
Diff to previous 2.10 , to selected 2.24
eliminated gensurf.c putquad() code for better normal interpolation
Wed Jun 15 12:29:55 1994 UTC (31 years, 6 months ago) by greg
Changes since 2.9: +40 -29 lines
Diff to previous 2.9 , to selected 2.24
changed to more compact barycentric coordinate calculation
Wed Jun 15 09:51:31 1994 UTC (31 years, 6 months ago) by greg
Diff to previous 2.8 , to selected 2.24
minor non-essential changes
Tue Jun 14 14:30:38 1994 UTC (31 years, 6 months ago) by greg
Changes since 2.7: +7 -2 lines
Diff to previous 2.7 , to selected 2.24
added -f option to flatten faces
Thu Apr 14 13:36:18 1994 UTC (31 years, 8 months ago) by greg
Changes since 2.6: +28 -9 lines
Diff to previous 2.6 , to selected 2.24
took out use of Wavefront texture maps and indices
fixed bug introduced last time in conversion of non-planar polygons
Thu Apr 14 04:29:10 1994 UTC (31 years, 8 months ago) by greg
Changes since 2.5: +41 -36 lines
Diff to previous 2.5 , to selected 2.24
slight enhancement in conversion of non-planar polygons
now uses group name as default material if no usemtl and no -m option
Wed Apr 13 17:24:24 1994 UTC (31 years, 8 months ago) by greg
Changes since 2.4: +70 -6 lines
Diff to previous 2.4 , to selected 2.24
added sloppy division of non-planar faces into triangles
Wed Apr 13 15:16:49 1994 UTC (31 years, 8 months ago) by greg
Diff to previous 2.3 , to selected 2.24
fixed nasty bug in ordering of parameters to putquad()
Wed Apr 13 14:08:55 1994 UTC (31 years, 8 months ago) by greg
Changes since 2.2: +242 -61 lines
Diff to previous 2.2 , to selected 2.24
added mapping file to obj2rad
Tue Apr 12 17:28:52 1994 UTC (31 years, 8 months ago) by greg
Changes since 2.1: +10 -8 lines
Diff to previous 2.1 , to selected 2.24
made zero-area faces non-fatal
Tue Apr 12 17:12:42 1994 UTC (31 years, 8 months ago) by greg
Diff to selected 2.24
