root/radiance/ray/src/cv/obj2rad.c
Fri Nov 8 16:49:04 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.28: +4 -4 lines
Diff to previous 2.28 , to selected 2.9
Increased maximum identifier name length from 64 to 256
Tue Aug 20 16:19:03 2013 UTC (10 years, 9 months ago) by greg
Changes since 2.27: +24 -24 lines
Diff to previous 2.27 , to selected 2.9
Increased max. group name size to 256
Tue Sep 28 21:28:23 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.26: +3 -3 lines
Diff to previous 2.26 , to selected 2.9
Fixed bug in "void" mapping of surfaces
Thu Sep 16 03:28:21 2010 UTC (13 years, 9 months ago) by greg
Changes since 2.25: +8 -3 lines
Diff to previous 2.25 , to selected 2.9
Changed obj2rad to accept illegal normals
Mon Nov 10 19:08:18 2008 UTC (15 years, 7 months ago) by greg
Diff to previous 2.24 , to selected 2.9
Tue Jun 24 02:01:19 2008 UTC (15 years, 11 months ago) by greg
Changes since 2.23: +9 -4 lines
Diff to previous 2.23 , to selected 2.9
Fri Apr 23 16:20:56 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.22: +11 -6 lines
Diff to previous 2.22 , to selected 2.9
Sat Nov 15 17:54:06 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 2.21: +88 -41 lines
Diff to previous 2.21 , to selected 2.9
Changes since 2.20: +5 -5 lines
Diff to previous 2.20 , to selected 2.9
Changes since 2.19: +7 -7 lines
Diff to previous 2.19 , to selected 2.9
Wed Apr 23 00:52:33 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.18 , to selected 2.9
Tue Mar 4 01:42:29 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.17: +29 -19 lines
Diff to previous 2.17 , to selected 2.9
Fixed problems with normals and orientations that disagree.
Changes since 2.16: +4 -7 lines
Diff to previous 2.16 , to selected 2.9
Wed Jul 24 13:07:41 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.15: +16 -1 lines
Diff to previous 2.15 , to selected 2.9
added check for flat triangles with normals
Wed Jun 22 12:35:59 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.14: +2 -75 lines
Wed Jun 15 19:06:04 1994 UTC (30 years ago) by greg
cosmetic fix to parameters of put_baryc
Wed Jun 15 15:07:08 1994 UTC (30 years ago) by greg
Changes since 2.12: +31 -23 lines
further reduced complexity and size of barycentric calculation
Wed Jun 15 12:52:19 1994 UTC (30 years ago) by greg
added check for flatten in nonplanar()
Wed Jun 15 12:50:37 1994 UTC (30 years ago) by greg
Changes since 2.10: +5 -177 lines
eliminated gensurf.c putquad() code for better normal interpolation
Wed Jun 15 12:29:55 1994 UTC (30 years ago) by greg
Changes since 2.9: +40 -29 lines
changed to more compact barycentric coordinate calculation
Wed Jun 15 09:51:31 1994 UTC (30 years ago) by greg
minor non-essential changes
Tue Jun 14 14:30:38 1994 UTC (30 years ago) by greg
Changes since 2.7: +7 -2 lines
added -f option to flatten faces
Thu Apr 14 13:36:18 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.6: +28 -9 lines
took out use of Wavefront texture maps and indices
fixed bug introduced last time in conversion of non-planar polygons
Thu Apr 14 04:29:10 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.5: +41 -36 lines
slight enhancement in conversion of non-planar polygons
now uses group name as default material if no usemtl and no -m option
Wed Apr 13 17:24:24 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.4: +70 -6 lines
added sloppy division of non-planar faces into triangles
Wed Apr 13 15:16:49 1994 UTC (30 years, 2 months ago) by greg
fixed nasty bug in ordering of parameters to putquad()
Wed Apr 13 14:08:55 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.2: +242 -61 lines
added mapping file to obj2rad
Tue Apr 12 17:28:52 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.1: +10 -8 lines
made zero-area faces non-fatal
Tue Apr 12 17:12:42 1994 UTC (30 years, 2 months ago) by greg
Diff to selected 2.9
