1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Convert a Wavefront .obj file to Radiance format. |
9 |
10 |
* Currently, we support only polygonal geometry. Non-planar |
11 |
* faces are broken rather haphazardly into triangles. |
12 |
* Also, texture map indices only work for triangles, though |
13 |
* I'm not sure they work correctly. (Taken out -- see TEXMAPS defines.) |
14 |
15 |
16 |
#include "standard.h" |
17 |
18 |
#include "trans.h" |
19 |
20 |
#include "tmesh.h" |
21 |
22 |
#include <ctype.h> |
23 |
24 |
#define PATNAME "M-pat" /* mesh pattern name (reused) */ |
25 |
#define TEXNAME "M-nor" /* mesh texture name (reused) */ |
26 |
#define DEFOBJ "unnamed" /* default object name */ |
27 |
#define DEFMAT "white" /* default material name */ |
28 |
29 |
#define pvect(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2]) |
30 |
31 |
FVECT *vlist; /* our vertex list */ |
32 |
int nvs; /* number of vertices in our list */ |
33 |
FVECT *vnlist; /* vertex normal list */ |
34 |
int nvns; |
35 |
FLOAT (*vtlist)[2]; /* map vertex list */ |
36 |
int nvts; |
37 |
38 |
typedef int VNDX[3]; /* vertex index (point,map,normal) */ |
39 |
40 |
#define CHUNKSIZ 256 /* vertex allocation chunk size */ |
41 |
42 |
#define MAXARG 64 /* maximum # arguments in a statement */ |
43 |
44 |
/* qualifiers */ |
45 |
#define Q_MTL 0 |
46 |
#define Q_MAP 1 |
47 |
#define Q_GRP 2 |
48 |
#define Q_OBJ 3 |
49 |
#define Q_FAC 4 |
50 |
#define NQUALS 5 |
51 |
52 |
char *qname[NQUALS] = { |
53 |
"Material", |
54 |
"Map", |
55 |
"Group", |
56 |
"Object", |
57 |
"Face", |
58 |
59 |
60 |
QLIST qlist = {NQUALS, qname}; |
61 |
/* valid qualifier ids */ |
62 |
IDLIST qual[NQUALS]; |
63 |
/* mapping rules */ |
64 |
RULEHD *ourmapping = NULL; |
65 |
66 |
char *defmat = DEFMAT; /* default (starting) material name */ |
67 |
char *defobj = DEFOBJ; /* default (starting) object name */ |
68 |
69 |
int flatten = 0; /* discard surface normal information */ |
70 |
71 |
char *getmtl(), *getonm(); |
72 |
73 |
char mapname[128]; /* current picture file */ |
74 |
char matname[64]; /* current material name */ |
75 |
char group[16][32]; /* current group names */ |
76 |
char objname[128]; /* current object name */ |
77 |
char *inpfile; /* input file name */ |
78 |
int lineno; /* current line number */ |
79 |
int faceno; /* current face number */ |
80 |
81 |
82 |
main(argc, argv) /* read in .obj file and convert */ |
83 |
int argc; |
84 |
char *argv[]; |
85 |
86 |
int donames = 0; |
87 |
int i; |
88 |
89 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
90 |
switch (argv[i][1]) { |
91 |
case 'o': /* object name */ |
92 |
defobj = argv[++i]; |
93 |
break; |
94 |
case 'n': /* just produce name list */ |
95 |
donames++; |
96 |
break; |
97 |
case 'm': /* use custom mapfile */ |
98 |
ourmapping = getmapping(argv[++i], &qlist); |
99 |
break; |
100 |
case 'f': /* flatten surfaces */ |
101 |
flatten++; |
102 |
break; |
103 |
default: |
104 |
goto userr; |
105 |
106 |
if (i > argc | i < argc-1) |
107 |
goto userr; |
108 |
if (i == argc) |
109 |
inpfile = "<stdin>"; |
110 |
else if (freopen(inpfile=argv[i], "r", stdin) == NULL) { |
111 |
fprintf(stderr, "%s: cannot open\n", inpfile); |
112 |
exit(1); |
113 |
114 |
if (donames) { /* scan for ids */ |
115 |
getnames(stdin); |
116 |
printf("filename \"%s\"\n", inpfile); |
117 |
printf("filetype \"Wavefront\"\n"); |
118 |
write_quals(&qlist, qual, stdout); |
119 |
printf("qualifier %s begin\n", qlist.qual[Q_FAC]); |
120 |
printf("[%d:%d]\n", 1, faceno); |
121 |
printf("end\n"); |
122 |
} else { /* translate file */ |
123 |
printf("# "); |
124 |
printargs(argc, argv, stdout); |
125 |
convert(stdin); |
126 |
127 |
exit(0); |
128 |
userr: |
129 |
fprintf(stderr, "Usage: %s [-o obj][-m mapping][-n][-f] [file.obj]\n", |
130 |
argv[0]); |
131 |
exit(1); |
132 |
133 |
134 |
135 |
getnames(fp) /* get valid qualifier names */ |
136 |
FILE *fp; |
137 |
138 |
char *argv[MAXARG]; |
139 |
int argc; |
140 |
ID tmpid; |
141 |
register int i; |
142 |
143 |
while (argc = getstmt(argv, fp)) |
144 |
switch (argv[0][0]) { |
145 |
case 'f': /* face */ |
146 |
if (!argv[0][1]) |
147 |
faceno++; |
148 |
break; |
149 |
case 'u': |
150 |
if (!strcmp(argv[0], "usemtl")) { /* material */ |
151 |
if (argc < 2) |
152 |
break; /* not fatal */ |
153 |
tmpid.number = 0; |
154 |
tmpid.name = argv[1]; |
155 |
findid(&qual[Q_MTL], &tmpid, 1); |
156 |
} else if (!strcmp(argv[0], "usemap")) {/* map */ |
157 |
if (argc < 2 || !strcmp(argv[1], "off")) |
158 |
159 |
tmpid.number = 0; |
160 |
161 |
findid(&qual[Q_MAP], &tmpid, 1); |
162 |
163 |
break; |
164 |
165 |
if (argv[0][1] || argc < 2) |
166 |
break; |
167 |
tmpid.number = 0; |
168 |
169 |
findid(&qual[Q_OBJ], &tmpid, 1); |
170 |
break; |
171 |
case 'g': /* group name(s) */ |
172 |
if (argv[0][1]) |
173 |
break; |
174 |
tmpid.number = 0; |
175 |
for (i = 1; i < argc; i++) { |
176 |
tmpid.name = argv[i]; |
177 |
findid(&qual[Q_GRP], &tmpid, 1); |
178 |
179 |
break; |
180 |
181 |
182 |
183 |
184 |
convert(fp) /* convert a T-mesh */ |
185 |
FILE *fp; |
186 |
187 |
188 |
int argc; |
189 |
int nstats, nunknown; |
190 |
register int i; |
191 |
192 |
nstats = nunknown = 0; |
193 |
/* scan until EOF */ |
194 |
while (argc = getstmt(argv, fp)) { |
195 |
196 |
case 'v': /* vertex */ |
197 |
switch (argv[0][1]) { |
198 |
case '\0': /* point */ |
199 |
if (badarg(argc-1,argv+1,"fff")) |
200 |
syntax("Bad vertex"); |
201 |
newv(atof(argv[1]), atof(argv[2]), |
202 |
atof(argv[3])); |
203 |
break; |
204 |
case 'n': /* normal */ |
205 |
if (argv[0][2]) |
206 |
goto unknown; |
207 |
208 |
syntax("Bad normal"); |
209 |
if (!newvn(atof(argv[1]), atof(argv[2]), |
210 |
atof(argv[3]))) |
211 |
syntax("Zero normal"); |
212 |
break; |
213 |
case 't': /* texture map */ |
214 |
if (argv[0][2]) |
215 |
goto unknown; |
216 |
if (badarg(argc-1,argv+1,"ff")) |
217 |
goto unknown; |
218 |
newvt(atof(argv[1]), atof(argv[2])); |
219 |
break; |
220 |
default: |
221 |
goto unknown; |
222 |
223 |
break; |
224 |
225 |
if (argv[0][1]) |
226 |
goto unknown; |
227 |
faceno++; |
228 |
switch (argc-1) { |
229 |
case 0: case 1: case 2: |
230 |
syntax("Too few vertices"); |
231 |
break; |
232 |
case 3: |
233 |
if (!puttri(argv[1], argv[2], argv[3])) |
234 |
syntax("Bad triangle"); |
235 |
break; |
236 |
default: |
237 |
if (!putface(argc-1, argv+1)) |
238 |
syntax("Bad face"); |
239 |
break; |
240 |
241 |
break; |
242 |
case 'u': |
243 |
244 |
if (argc < 2) |
245 |
246 |
strcpy(matname, argv[1]); |
247 |
248 |
if (argc < 2) |
249 |
250 |
if (!strcmp(argv[1], "off")) |
251 |
mapname[0] = '\0'; |
252 |
else |
253 |
sprintf(mapname, "%s.pic", argv[1]); |
254 |
} else |
255 |
goto unknown; |
256 |
break; |
257 |
258 |
if (argv[0][1]) |
259 |
goto unknown; |
260 |
if (argc < 2) |
261 |
262 |
strcpy(objname, argv[1]); |
263 |
break; |
264 |
265 |
if (argv[0][1]) |
266 |
goto unknown; |
267 |
for (i = 1; i < argc; i++) |
268 |
strcpy(group[i-1], argv[i]); |
269 |
group[i-1][0] = '\0'; |
270 |
break; |
271 |
case '#': /* comment */ |
272 |
273 |
break; |
274 |
default:; /* something we don't deal with */ |
275 |
unknown: |
276 |
nunknown++; |
277 |
break; |
278 |
279 |
nstats++; |
280 |
281 |
printf("\n# Done processing file: %s\n", inpfile); |
282 |
printf("# %d lines, %d statements, %d unrecognized\n", |
283 |
lineno, nstats, nunknown); |
284 |
285 |
286 |
287 |
int |
288 |
getstmt(av, fp) /* read the next statement from fp */ |
289 |
register char *av[MAXARG]; |
290 |
FILE *fp; |
291 |
292 |
extern char *fgetline(); |
293 |
static char sbuf[MAXARG*10]; |
294 |
register char *cp; |
295 |
register int i; |
296 |
297 |
do { |
298 |
if (fgetline(cp=sbuf, sizeof(sbuf), fp) == NULL) |
299 |
return(0); |
300 |
i = 0; |
301 |
for ( ; ; ) { |
302 |
while (isspace(*cp) || *cp == '\\') { |
303 |
if (*cp == '\n') |
304 |
lineno++; |
305 |
*cp++ = '\0'; |
306 |
307 |
if (!*cp || i >= MAXARG-1) |
308 |
break; |
309 |
av[i++] = cp; |
310 |
while (*++cp && !isspace(*cp)) |
311 |
312 |
313 |
av[i] = NULL; |
314 |
lineno++; |
315 |
} while (!i); |
316 |
317 |
return(i); |
318 |
319 |
320 |
321 |
char * |
322 |
getmtl() /* figure material for this face */ |
323 |
324 |
register RULEHD *rp = ourmapping; |
325 |
326 |
if (rp == NULL) { /* no rule set */ |
327 |
if (matname[0]) |
328 |
return(matname); |
329 |
if (group[0][0]) |
330 |
return(group[0]); |
331 |
return(defmat); |
332 |
333 |
/* check for match */ |
334 |
do { |
335 |
if (matchrule(rp)) { |
336 |
if (!strcmp(rp->mnam, VOIDID)) |
337 |
return(NULL); /* match is null */ |
338 |
return(rp->mnam); |
339 |
340 |
rp = rp->next; |
341 |
} while (rp != NULL); |
342 |
/* no match found */ |
343 |
return(NULL); |
344 |
345 |
346 |
347 |
char * |
348 |
getonm() /* invent a good name for object */ |
349 |
350 |
static char name[64]; |
351 |
register char *cp1, *cp2; |
352 |
register int i; |
353 |
/* check for preset */ |
354 |
if (objname[0]) |
355 |
return(objname); |
356 |
if (!group[0][0]) |
357 |
return(defobj); |
358 |
cp1 = name; /* else make name out of groups */ |
359 |
for (i = 0; group[i][0]; i++) { |
360 |
cp2 = group[i]; |
361 |
if (cp1 > name) |
362 |
*cp1++ = '.'; |
363 |
while (*cp1 = *cp2++) |
364 |
if (++cp1 >= name+sizeof(name)-2) { |
365 |
*cp1 = '\0'; |
366 |
return(name); |
367 |
368 |
369 |
return(name); |
370 |
371 |
372 |
373 |
matchrule(rp) /* check for a match on this rule */ |
374 |
register RULEHD *rp; |
375 |
376 |
ID tmpid; |
377 |
int gotmatch; |
378 |
register int i; |
379 |
380 |
if (rp->qflg & FL(Q_MTL)) { |
381 |
if (!matname[0]) |
382 |
return(0); |
383 |
tmpid.number = 0; |
384 |
tmpid.name = matname; |
385 |
if (!matchid(&tmpid, &idm(rp)[Q_MTL])) |
386 |
return(0); |
387 |
388 |
if (rp->qflg & FL(Q_MAP)) { |
389 |
if (!mapname[0]) |
390 |
return(0); |
391 |
tmpid.number = 0; |
392 |
tmpid.name = mapname; |
393 |
if (!matchid(&tmpid, &idm(rp)[Q_MAP])) |
394 |
return(0); |
395 |
396 |
if (rp->qflg & FL(Q_GRP)) { |
397 |
tmpid.number = 0; |
398 |
gotmatch = 0; |
399 |
400 |
tmpid.name = group[i]; |
401 |
gotmatch |= matchid(&tmpid, &idm(rp)[Q_GRP]); |
402 |
403 |
if (!gotmatch) |
404 |
return(0); |
405 |
406 |
if (rp->qflg & FL(Q_OBJ)) { |
407 |
if (!objname[0]) |
408 |
return(0); |
409 |
tmpid.number = 0; |
410 |
tmpid.name = objname; |
411 |
if (!matchid(&tmpid, &idm(rp)[Q_OBJ])) |
412 |
return(0); |
413 |
414 |
if (rp->qflg & FL(Q_FAC)) { |
415 |
tmpid.name = NULL; |
416 |
tmpid.number = faceno; |
417 |
if (!matchid(&tmpid, &idm(rp)[Q_FAC])) |
418 |
return(0); |
419 |
420 |
return(1); |
421 |
422 |
423 |
424 |
cvtndx(vi, vs) /* convert vertex string to index */ |
425 |
register VNDX vi; |
426 |
register char *vs; |
427 |
428 |
/* get point */ |
429 |
vi[0] = atoi(vs); |
430 |
if (vi[0] > 0) { |
431 |
if (vi[0]-- > nvs) |
432 |
return(0); |
433 |
} else if (vi[0] < 0) { |
434 |
vi[0] += nvs; |
435 |
if (vi[0] < 0) |
436 |
return(0); |
437 |
} else |
438 |
return(0); |
439 |
/* get map */ |
440 |
while (*vs) |
441 |
if (*vs++ == '/') |
442 |
break; |
443 |
vi[1] = atoi(vs); |
444 |
if (vi[1] > 0) { |
445 |
if (vi[1]-- > nvts) |
446 |
return(0); |
447 |
} else if (vi[1] < 0) { |
448 |
vi[1] += nvts; |
449 |
if (vi[1] < 0) |
450 |
return(0); |
451 |
} else |
452 |
vi[1] = -1; |
453 |
/* get normal */ |
454 |
while (*vs) |
455 |
if (*vs++ == '/') |
456 |
break; |
457 |
vi[2] = atoi(vs); |
458 |
if (vi[2] > 0) { |
459 |
if (vi[2]-- > nvns) |
460 |
return(0); |
461 |
} else if (vi[2] < 0) { |
462 |
vi[2] += nvns; |
463 |
if (vi[2] < 0) |
464 |
return(0); |
465 |
} else |
466 |
vi[2] = -1; |
467 |
return(1); |
468 |
469 |
470 |
471 |
nonplanar(ac, av) /* are vertices non-planar? */ |
472 |
register int ac; |
473 |
register char **av; |
474 |
475 |
VNDX vi; |
476 |
FLOAT *p0, *p1; |
477 |
FVECT v1, v2, nsum, newn; |
478 |
double d; |
479 |
register int i; |
480 |
481 |
if (!cvtndx(vi, av[0])) |
482 |
return(0); |
483 |
if (!flatten && vi[2] >= 0) |
484 |
return(1); /* has interpolated normals */ |
485 |
if (ac < 4) |
486 |
return(0); /* it's a triangle! */ |
487 |
/* set up */ |
488 |
p0 = vlist[vi[0]]; |
489 |
if (!cvtndx(vi, av[1])) |
490 |
return(0); /* error gets caught later */ |
491 |
nsum[0] = nsum[1] = nsum[2] = 0.; |
492 |
p1 = vlist[vi[0]]; |
493 |
fvsum(v2, p1, p0, -1.0); |
494 |
for (i = 2; i < ac; i++) { |
495 |
VCOPY(v1, v2); |
496 |
if (!cvtndx(vi, av[i])) |
497 |
return(0); |
498 |
499 |
500 |
fcross(newn, v1, v2); |
501 |
if (normalize(newn) == 0.0) { |
502 |
if (i < 3) |
503 |
return(1); /* can't deal with this */ |
504 |
fvsum(nsum, nsum, nsum, 1./(i-2)); |
505 |
continue; |
506 |
507 |
d = fdot(newn,nsum); |
508 |
if (d >= 0) { |
509 |
if (d < (1.0-FTINY)*(i-2)) |
510 |
return(1); |
511 |
fvsum(nsum, nsum, newn, 1.0); |
512 |
} else { |
513 |
if (d > -(1.0-FTINY)*(i-2)) |
514 |
return(1); |
515 |
fvsum(nsum, nsum, newn, -1.0); |
516 |
517 |
518 |
return(0); |
519 |
520 |
521 |
522 |
putface(ac, av) /* put out an N-sided polygon */ |
523 |
int ac; |
524 |
525 |
526 |
VNDX vi; |
527 |
char *cp; |
528 |
register int i; |
529 |
530 |
if (nonplanar(ac, av)) { /* break into triangles */ |
531 |
while (ac > 2) { |
532 |
if (!puttri(av[0], av[1], av[2])) |
533 |
return(0); |
534 |
ac--; /* remove vertex & rotate */ |
535 |
cp = av[0]; |
536 |
for (i = 0; i < ac-1; i++) |
537 |
av[i] = av[i+2]; |
538 |
av[i] = cp; |
539 |
540 |
return(1); |
541 |
542 |
if ((cp = getmtl()) == NULL) |
543 |
return(-1); |
544 |
printf("\n%s polygon %s.%d\n", cp, getonm(), faceno); |
545 |
printf("0\n0\n%d\n", 3*ac); |
546 |
for (i = 0; i < ac; i++) { |
547 |
548 |
return(0); |
549 |
pvect(vlist[vi[0]]); |
550 |
551 |
return(1); |
552 |
553 |
554 |
555 |
puttri(v1, v2, v3) /* put out a triangle */ |
556 |
char *v1, *v2, *v3; |
557 |
558 |
char *mod; |
559 |
VNDX v1i, v2i, v3i; |
560 |
BARYCCM bvecs; |
561 |
FLOAT bcoor[3][3]; |
562 |
int texOK, patOK; |
563 |
register int i; |
564 |
565 |
if ((mod = getmtl()) == NULL) |
566 |
return(-1); |
567 |
568 |
if (!cvtndx(v1i, v1) || !cvtndx(v2i, v2) || !cvtndx(v3i, v3)) |
569 |
return(0); |
570 |
/* compute barycentric coordinates */ |
571 |
if (!flatten && v1i[2]>=0 && v2i[2]>=0 && v3i[2]>=0) |
572 |
switch (flat_tri(vlist[v1i[0]], vlist[v2i[0]], vlist[v3i[0]], |
573 |
vnlist[v1i[2]], vnlist[v2i[2]], vnlist[v3i[2]])) { |
574 |
case DEGEN: /* zero area */ |
575 |
return(-1); |
576 |
case RVFLAT: /* reversed normals, but flat */ |
577 |
case ISFLAT: /* smoothing unnecessary */ |
578 |
texOK = 0; |
579 |
break; |
580 |
case RVBENT: /* reversed normals with smoothing */ |
581 |
case ISBENT: /* proper smoothing */ |
582 |
texOK = 1; |
583 |
break; |
584 |
585 |
else |
586 |
texOK = 0; |
587 |
#ifdef TEXMAPS |
588 |
patOK = mapname[0] && (v1i[1]>=0 && v2i[1]>=0 && v3i[1]>=0); |
589 |
#else |
590 |
patOK = 0; |
591 |
#endif |
592 |
if (texOK | patOK) |
593 |
if (comp_baryc(&bvecs, vlist[v1i[0]], vlist[v2i[0]], |
594 |
vlist[v3i[0]]) < 0) |
595 |
return(-1); |
596 |
/* put out texture (if any) */ |
597 |
if (texOK) { |
598 |
printf("\n%s texfunc %s\n", mod, TEXNAME); |
599 |
mod = TEXNAME; |
600 |
printf("4 dx dy dz %s\n", TCALNAME); |
601 |
printf("0\n"); |
602 |
for (i = 0; i < 3; i++) { |
603 |
bcoor[i][0] = vnlist[v1i[2]][i]; |
604 |
bcoor[i][1] = vnlist[v2i[2]][i]; |
605 |
bcoor[i][2] = vnlist[v3i[2]][i]; |
606 |
607 |
put_baryc(&bvecs, bcoor, 3); |
608 |
609 |
#ifdef TEXMAPS |
610 |
/* put out pattern (if any) */ |
611 |
if (patOK) { |
612 |
printf("\n%s colorpict %s\n", mod, PATNAME); |
613 |
mod = PATNAME; |
614 |
printf("7 noneg noneg noneg %s %s u v\n", mapname, TCALNAME); |
615 |
printf("0\n"); |
616 |
for (i = 0; i < 2; i++) { |
617 |
bcoor[i][0] = vtlist[v1i[1]][i]; |
618 |
bcoor[i][1] = vtlist[v2i[1]][i]; |
619 |
bcoor[i][2] = vtlist[v3i[1]][i]; |
620 |
621 |
put_baryc(&bvecs, bcoor, 2); |
622 |
623 |
#endif |
624 |
/* put out triangle */ |
625 |
printf("\n%s polygon %s.%d\n", mod, getonm(), faceno); |
626 |
printf("0\n0\n9\n"); |
627 |
pvect(vlist[v1i[0]]); |
628 |
pvect(vlist[v2i[0]]); |
629 |
pvect(vlist[v3i[0]]); |
630 |
631 |
return(1); |
632 |
633 |
634 |
635 |
freeverts() /* free all vertices */ |
636 |
637 |
if (nvs) { |
638 |
free((char *)vlist); |
639 |
nvs = 0; |
640 |
641 |
if (nvts) { |
642 |
free((char *)vtlist); |
643 |
nvts = 0; |
644 |
645 |
if (nvns) { |
646 |
free((char *)vnlist); |
647 |
nvns = 0; |
648 |
649 |
650 |
651 |
652 |
int |
653 |
newv(x, y, z) /* create a new vertex */ |
654 |
double x, y, z; |
655 |
656 |
if (!(nvs%CHUNKSIZ)) { /* allocate next block */ |
657 |
if (nvs == 0) |
658 |
vlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT)); |
659 |
else |
660 |
vlist = (FVECT *)realloc((char *)vlist, |
661 |
(nvs+CHUNKSIZ)*sizeof(FVECT)); |
662 |
if (vlist == NULL) { |
663 |
fprintf(stderr, |
664 |
"Out of memory while allocating vertex %d\n", nvs); |
665 |
exit(1); |
666 |
667 |
668 |
/* assign new vertex */ |
669 |
vlist[nvs][0] = x; |
670 |
vlist[nvs][1] = y; |
671 |
vlist[nvs][2] = z; |
672 |
return(++nvs); |
673 |
674 |
675 |
676 |
int |
677 |
newvn(x, y, z) /* create a new vertex normal */ |
678 |
double x, y, z; |
679 |
680 |
if (!(nvns%CHUNKSIZ)) { /* allocate next block */ |
681 |
if (nvns == 0) |
682 |
vnlist = (FVECT *)malloc(CHUNKSIZ*sizeof(FVECT)); |
683 |
else |
684 |
vnlist = (FVECT *)realloc((char *)vnlist, |
685 |
(nvns+CHUNKSIZ)*sizeof(FVECT)); |
686 |
if (vnlist == NULL) { |
687 |
fprintf(stderr, |
688 |
"Out of memory while allocating normal %d\n", nvns); |
689 |
exit(1); |
690 |
691 |
692 |
/* assign new normal */ |
693 |
vnlist[nvns][0] = x; |
694 |
vnlist[nvns][1] = y; |
695 |
vnlist[nvns][2] = z; |
696 |
if (normalize(vnlist[nvns]) == 0.0) |
697 |
return(0); |
698 |
return(++nvns); |
699 |
700 |
701 |
702 |
int |
703 |
newvt(x, y) /* create a new texture map vertex */ |
704 |
double x, y; |
705 |
706 |
if (!(nvts%CHUNKSIZ)) { /* allocate next block */ |
707 |
if (nvts == 0) |
708 |
vtlist = (FLOAT (*)[2])malloc(CHUNKSIZ*2*sizeof(FLOAT)); |
709 |
else |
710 |
vtlist = (FLOAT (*)[2])realloc((char *)vtlist, |
711 |
(nvts+CHUNKSIZ)*2*sizeof(FLOAT)); |
712 |
if (vtlist == NULL) { |
713 |
fprintf(stderr, |
714 |
"Out of memory while allocating texture vertex %d\n", |
715 |
nvts); |
716 |
exit(1); |
717 |
718 |
719 |
720 |
vtlist[nvts][0] = x; |
721 |
vtlist[nvts][1] = y; |
722 |
return(++nvts); |
723 |
724 |
725 |
726 |
syntax(er) /* report syntax error and exit */ |
727 |
char *er; |
728 |
729 |
fprintf(stderr, "%s: Wavefront syntax error near line %d: %s\n", |
730 |
inpfile, lineno, er); |
731 |
exit(1); |
732 |
