Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Fixed problems with normals and orientations that disagree.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added check for flat triangles with normals
cosmetic fix to parameters of put_baryc
further reduced complexity and size of barycentric calculation
added check for flatten in nonplanar()
eliminated gensurf.c putquad() code for better normal interpolation
changed to more compact barycentric coordinate calculation
minor non-essential changes
added -f option to flatten faces
took out use of Wavefront texture maps and indices fixed bug introduced last time in conversion of non-planar polygons
slight enhancement in conversion of non-planar polygons now uses group name as default material if no usemtl and no -m option
added sloppy division of non-planar faces into triangles
fixed nasty bug in ordering of parameters to putquad()
added mapping file to obj2rad
made zero-area faces non-fatal
