--- ray/src/cv/nff2rad.c 1990/12/11 08:45:49 1.1 +++ ray/src/cv/nff2rad.c 1992/02/10 08:29:23 2.2 @@ -1,4 +1,4 @@ -/* Copyright (c) 1990 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -8,6 +8,9 @@ static char SCCSid[] = "$SunId$ LBL"; * Convert Neutral File Format input to Radiance scene description. * * 12/9/90 Greg Ward + * 02/7/92 Peter Averkamp added X11(MTV)color names & + * fixed some lf's for direct import of MTV + * source files */ /****************************************************************** @@ -83,11 +86,13 @@ char *argv[]; for (i = 1; i < argc; i++) if (argc-i > 1 && !strcmp(argv[i], "-vf")) viewfile = argv[++i]; + else if (!strncmp(argv[i], "-h",2)) + goto userr; else break; - if (i-argc > 1) + if (argc-i > 1) goto userr; - if (i-argc == 1 && freopen(argv[i], "r", stdin) == NULL) { + if (argc-i == 1 && freopen(argv[i], "r", stdin) == NULL) { perror(argv[i]); exit(1); } @@ -277,14 +282,14 @@ light() static int nlights = 0; register int c; float x, y, z; - - if (scanf("%f %f %f", &x, &y, &z) != 3) { - fprintf(stderr, "%s: light source syntax error\n", progname); - exit(1); + + if (scanf("%f %f %f",&x, &y, &z) != 3) { + fprintf(stderr, "%s: light source syntax error\n", progname); + exit(1); } while ((c = getchar()) != EOF && c != '\n') ; - printf("\nlight sphere l%d ", ++nlights); + printf("\nlight sphere l%d \n", ++nlights); printf("0\n0\n4 %g %g %g 1\n", x, y, z); } @@ -304,10 +309,20 @@ Format: background() { float r, g, b; - - if (scanf("%f %f %f", &r, &g, &b) != 3) { + char colname[50]; + double cvec[3]; + + if (scanf("%s", colname) != 1) { + fprintf(stderr,"%s: background syntax error\n",progname);exit(1); + } + if(LookupColorByName(colname,cvec)==1){ + r=cvec[0];g=cvec[1];b=cvec[2]; + }else{ + if(sscanf(colname,"%f",&r)!=1 || + scanf("%f %f", &g, &b) !=2) { fprintf(stderr, "%s: background syntax error\n", progname); exit(1); + } } printf("\nvoid glow backg_color\n"); printf("0\n0\n4 %g %g %g 0\n", r, g, b); @@ -341,9 +356,22 @@ Format: fill() { float r, g, b, d, s, p, t, n; - - if (scanf("%f %f %f %f %f %f %f %f", &r, &g, &b, - &d, &s, &p, &t, &n) != 8) { + char colname[50]; + double cvec[3]; + + if (scanf("%s", colname) != 1) { + fprintf(stderr,"%s: fill syntax error\n",progname);exit(1); + } + if(LookupColorByName(colname,cvec)==1){ + r=cvec[0];g=cvec[1];b=cvec[2]; + }else{ + if(sscanf(colname,"%f",&r)!=1 || + scanf("%f %f", &g, &b) !=2) { + fprintf(stderr, "%s: fill syntax error\n", progname); + exit(1); + } + } + if (scanf("%f %f %f %f %f", &d, &s, &p, &t, &n) != 5) { fprintf(stderr, "%s: fill material syntax error\n", progname); exit(1); } @@ -355,7 +383,7 @@ fill() p = 1./p; if (t > .001) { /* has transmission */ printf("\nvoid trans fill\n"); - printf("0\n0\n7 %g %g %g %g %g %g 1\n", r, g, b, s, p, t); + printf("0\n0\n7 %g %g %g %g 0 %g 1\n", r, g, b, s, t); } else { /* no transmission */ printf("\nvoid plastic fill\n"); printf("0\n0\n5 %g %g %g %g %g\n", r, g, b, s, p); @@ -405,13 +433,13 @@ cone() r1 = -r1; } if (r0-r1 < .001 && r1-r0 < .001) { /* cylinder */ - printf("\nfill %s c%d ", invert?"tube":"cylinder", ++ncs); + printf("\nfill %s c%d \n", invert?"tube":"cylinder", ++ncs); printf("0\n0\n7\n"); printf("\t%g\t%g\t%g\n", x0, y0, z0); printf("\t%g\t%g\t%g\n", x1, y1, z1); printf("\t%g\n", r0); } else { /* cone */ - printf("\nfill %s c%d ", invert?"cup":"cone", ++ncs); + printf("\nfill %s c%d \n", invert?"cup":"cone", ++ncs); printf("0\n0\n8\n"); printf("\t%g\t%g\t%g\n", x0, y0, z0); printf("\t%g\t%g\t%g\n", x1, y1, z1); @@ -443,10 +471,10 @@ sphere() exit(1); } if (r < 0.) { - printf("\nfill bubble s%d ", ++nspheres); + printf("\nfill bubble s%d \n", ++nspheres); printf("0\n0\n4 %g %g %g %g\n", x, y, z, -r); } else { - printf("\nfill sphere s%d ", ++nspheres); + printf("\nfill sphere s%d \n", ++nspheres); printf("0\n0\n4 %g %g %g %g\n", x, y, z, r); } } @@ -502,7 +530,7 @@ poly() } if (scanf("%d", &nverts) != 1) goto fmterr; - printf("\nfill polygon p%d ", ++npolys); + printf("\nfill polygon p%d \n", ++npolys); printf("0\n0\n%d\n", 3*nverts); while (nverts-- > 0) { if (scanf("%f %f %f", &x, &y, &z) != 3) @@ -515,4 +543,826 @@ poly() fmterr: fprintf(stderr, "%s: polygon or patch syntax error\n", progname); exit(1); +} +/*********************************************************************** + * $Author: greg $ (Mark VandeWettering, drizzle.cs.uoregon.edu) + * $Revision: 2.2 $ + * $Date: 1992/02/10 08:29:23 $ + * $Log: nff2rad.c,v $ + * Revision 2.2 1992/02/10 08:29:23 greg + * bug fixes and enhancements by Peter Averkamp + * + * Revision 1.2 88/09/12 12:53:47 markv + * Fixed problem in LookupColorbyName, had return ; and return(0). + * [ Thank you lint! ] + * + * Revision 1.1 88/09/11 11:00:37 markv + * Initial revision + * + * Peter Averkamp 92/02/01 + * added complete X11R5 rgb.txt-table, hacked standalone version + * for nff2rad + * + ***********************************************************************/ + +typedef double Flt ; +typedef Flt Vec[3] ; +typedef Vec Point ; +typedef Vec Color ; + +#define VecCopy(a,b) (b)[0]=(a)[0];(b)[1]=(a)[1];(b)[2]=(a)[2]; +#define NCOLORS (738) + +typedef struct t_color_entry { + char * ce_name ; + Vec ce_color ; +} ColorEntry ; + +#define LESS_THAN -1 +#define GREATER_THAN 1 +#define EQUAL_TO 0 + +/* + * Note: These colors must be in sorted order, because we binary search + * for them. + * + * They were swiped from the X-11 distribution. Sorry.... + */ + +ColorEntry Colors[] = { +"AliceBlue", {0.941176 , 0.972549 , 1.000000 }, +"AntiqueWhite", {0.980392 , 0.921569 , 0.843137 }, +"AntiqueWhite1", {1.000000 , 0.937255 , 0.858824 }, +"AntiqueWhite2", {0.933333 , 0.874510 , 0.800000 }, +"AntiqueWhite3", {0.803922 , 0.752941 , 0.690196 }, +"AntiqueWhite4", {0.545098 , 0.513725 , 0.470588 }, +"BlanchedAlmond", {1.000000 , 0.921569 , 0.803922 }, +"BlueViolet", {0.541176 , 0.168627 , 0.886275 }, +"CadetBlue", {0.372549 , 0.619608 , 0.627451 }, +"CadetBlue1", {0.596078 , 0.960784 , 1.000000 }, +"CadetBlue2", {0.556863 , 0.898039 , 0.933333 }, +"CadetBlue3", {0.478431 , 0.772549 , 0.803922 }, +"CadetBlue4", {0.325490 , 0.525490 , 0.545098 }, +"CornflowerBlue", {0.392157 , 0.584314 , 0.929412 }, +"DarkGoldenrod", {0.721569 , 0.525490 , 0.043137 }, +"DarkGoldenrod1", {1.000000 , 0.725490 , 0.058824 }, +"DarkGoldenrod2", {0.933333 , 0.678431 , 0.054902 }, +"DarkGoldenrod3", {0.803922 , 0.584314 , 0.047059 }, +"DarkGoldenrod4", {0.545098 , 0.396078 , 0.031373 }, +"DarkGreen", {0.000000 , 0.392157 , 0.000000 }, +"DarkKhaki", {0.741176 , 0.717647 , 0.419608 }, +"DarkOliveGreen", {0.333333 , 0.419608 , 0.184314 }, +"DarkOliveGreen1", {0.792157 , 1.000000 , 0.439216 }, +"DarkOliveGreen2", {0.737255 , 0.933333 , 0.407843 }, +"DarkOliveGreen3", {0.635294 , 0.803922 , 0.352941 }, +"DarkOliveGreen4", {0.431373 , 0.545098 , 0.239216 }, +"DarkOrange", {1.000000 , 0.549020 , 0.000000 }, +"DarkOrange1", {1.000000 , 0.498039 , 0.000000 }, +"DarkOrange2", {0.933333 , 0.462745 , 0.000000 }, +"DarkOrange3", {0.803922 , 0.400000 , 0.000000 }, +"DarkOrange4", {0.545098 , 0.270588 , 0.000000 }, +"DarkOrchid", {0.600000 , 0.196078 , 0.800000 }, +"DarkOrchid1", {0.749020 , 0.243137 , 1.000000 }, +"DarkOrchid2", {0.698039 , 0.227451 , 0.933333 }, +"DarkOrchid3", {0.603922 , 0.196078 , 0.803922 }, +"DarkOrchid4", {0.407843 , 0.133333 , 0.545098 }, +"DarkSalmon", {0.913725 , 0.588235 , 0.478431 }, +"DarkSeaGreen", {0.560784 , 0.737255 , 0.560784 }, +"DarkSeaGreen1", {0.756863 , 1.000000 , 0.756863 }, +"DarkSeaGreen2", {0.705882 , 0.933333 , 0.705882 }, +"DarkSeaGreen3", {0.607843 , 0.803922 , 0.607843 }, +"DarkSeaGreen4", {0.411765 , 0.545098 , 0.411765 }, +"DarkSlateBlue", {0.282353 , 0.239216 , 0.545098 }, +"DarkSlateGray", {0.184314 , 0.309804 , 0.309804 }, +"DarkSlateGray1", {0.592157 , 1.000000 , 1.000000 }, +"DarkSlateGray2", {0.552941 , 0.933333 , 0.933333 }, +"DarkSlateGray3", {0.474510 , 0.803922 , 0.803922 }, +"DarkSlateGray4", {0.321569 , 0.545098 , 0.545098 }, +"DarkSlateGrey", {0.184314 , 0.309804 , 0.309804 }, +"DarkTurquoise", {0.000000 , 0.807843 , 0.819608 }, +"DarkViolet", {0.580392 , 0.000000 , 0.827451 }, +"DeepPink", {1.000000 , 0.078431 , 0.576471 }, +"DeepPink1", {1.000000 , 0.078431 , 0.576471 }, +"DeepPink2", {0.933333 , 0.070588 , 0.537255 }, +"DeepPink3", {0.803922 , 0.062745 , 0.462745 }, +"DeepPink4", {0.545098 , 0.039216 , 0.313725 }, +"DeepSkyBlue", {0.000000 , 0.749020 , 1.000000 }, +"DeepSkyBlue1", {0.000000 , 0.749020 , 1.000000 }, +"DeepSkyBlue2", {0.000000 , 0.698039 , 0.933333 }, +"DeepSkyBlue3", {0.000000 , 0.603922 , 0.803922 }, +"DeepSkyBlue4", {0.000000 , 0.407843 , 0.545098 }, +"DimGray", {0.411765 , 0.411765 , 0.411765 }, +"DimGrey", {0.411765 , 0.411765 , 0.411765 }, +"DodgerBlue", {0.117647 , 0.564706 , 1.000000 }, +"DodgerBlue1", {0.117647 , 0.564706 , 1.000000 }, +"DodgerBlue2", {0.109804 , 0.525490 , 0.933333 }, +"DodgerBlue3", {0.094118 , 0.454902 , 0.803922 }, +"DodgerBlue4", {0.062745 , 0.305882 , 0.545098 }, +"FloralWhite", {1.000000 , 0.980392 , 0.941176 }, +"ForestGreen", {0.133333 , 0.545098 , 0.133333 }, +"GhostWhite", {0.972549 , 0.972549 , 1.000000 }, +"GreenYellow", {0.678431 , 1.000000 , 0.184314 }, +"HotPink", {1.000000 , 0.411765 , 0.705882 }, +"HotPink1", {1.000000 , 0.431373 , 0.705882 }, +"HotPink2", {0.933333 , 0.415686 , 0.654902 }, +"HotPink3", {0.803922 , 0.376471 , 0.564706 }, +"HotPink4", {0.545098 , 0.227451 , 0.384314 }, +"IndianRed", {0.803922 , 0.360784 , 0.360784 }, +"IndianRed1", {1.000000 , 0.415686 , 0.415686 }, +"IndianRed2", {0.933333 , 0.388235 , 0.388235 }, +"IndianRed3", {0.803922 , 0.333333 , 0.333333 }, +"IndianRed4", {0.545098 , 0.227451 , 0.227451 }, +"LavenderBlush", {1.000000 , 0.941176 , 0.960784 }, +"LavenderBlush1", {1.000000 , 0.941176 , 0.960784 }, +"LavenderBlush2", {0.933333 , 0.878431 , 0.898039 }, +"LavenderBlush3", {0.803922 , 0.756863 , 0.772549 }, +"LavenderBlush4", {0.545098 , 0.513725 , 0.525490 }, +"LawnGreen", {0.486275 , 0.988235 , 0.000000 }, +"LemonChiffon", {1.000000 , 0.980392 , 0.803922 }, +"LemonChiffon1", {1.000000 , 0.980392 , 0.803922 }, +"LemonChiffon2", {0.933333 , 0.913725 , 0.749020 }, +"LemonChiffon3", {0.803922 , 0.788235 , 0.647059 }, +"LemonChiffon4", {0.545098 , 0.537255 , 0.439216 }, +"LightBlue", {0.678431 , 0.847059 , 0.901961 }, +"LightBlue1", {0.749020 , 0.937255 , 1.000000 }, +"LightBlue2", {0.698039 , 0.874510 , 0.933333 }, +"LightBlue3", {0.603922 , 0.752941 , 0.803922 }, +"LightBlue4", {0.407843 , 0.513725 , 0.545098 }, +"LightCoral", {0.941176 , 0.501961 , 0.501961 }, +"LightCyan", {0.878431 , 1.000000 , 1.000000 }, +"LightCyan1", {0.878431 , 1.000000 , 1.000000 }, +"LightCyan2", {0.819608 , 0.933333 , 0.933333 }, +"LightCyan3", {0.705882 , 0.803922 , 0.803922 }, +"LightCyan4", {0.478431 , 0.545098 , 0.545098 }, +"LightGoldenrod", {0.933333 , 0.866667 , 0.509804 }, +"LightGoldenrod1", {1.000000 , 0.925490 , 0.545098 }, +"LightGoldenrod2", {0.933333 , 0.862745 , 0.509804 }, +"LightGoldenrod3", {0.803922 , 0.745098 , 0.439216 }, +"LightGoldenrod4", {0.545098 , 0.505882 , 0.298039 }, +"LightGoldenrodYellow", {0.980392 , 0.980392 , 0.823529 }, +"LightGray", {0.827451 , 0.827451 , 0.827451 }, +"LightGrey", {0.827451 , 0.827451 , 0.827451 }, +"LightPink", {1.000000 , 0.713725 , 0.756863 }, +"LightPink1", {1.000000 , 0.682353 , 0.725490 }, +"LightPink2", {0.933333 , 0.635294 , 0.678431 }, +"LightPink3", {0.803922 , 0.549020 , 0.584314 }, +"LightPink4", {0.545098 , 0.372549 , 0.396078 }, +"LightSalmon", {1.000000 , 0.627451 , 0.478431 }, +"LightSalmon1", {1.000000 , 0.627451 , 0.478431 }, +"LightSalmon2", {0.933333 , 0.584314 , 0.447059 }, +"LightSalmon3", {0.803922 , 0.505882 , 0.384314 }, +"LightSalmon4", {0.545098 , 0.341176 , 0.258824 }, +"LightSeaGreen", {0.125490 , 0.698039 , 0.666667 }, +"LightSkyBlue", {0.529412 , 0.807843 , 0.980392 }, +"LightSkyBlue1", {0.690196 , 0.886275 , 1.000000 }, +"LightSkyBlue2", {0.643137 , 0.827451 , 0.933333 }, +"LightSkyBlue3", {0.552941 , 0.713725 , 0.803922 }, +"LightSkyBlue4", {0.376471 , 0.482353 , 0.545098 }, +"LightSlateBlue", {0.517647 , 0.439216 , 1.000000 }, +"LightSlateGray", {0.466667 , 0.533333 , 0.600000 }, +"LightSlateGrey", {0.466667 , 0.533333 , 0.600000 }, +"LightSteelBlue", {0.690196 , 0.768627 , 0.870588 }, +"LightSteelBlue1", {0.792157 , 0.882353 , 1.000000 }, +"LightSteelBlue2", {0.737255 , 0.823529 , 0.933333 }, +"LightSteelBlue3", {0.635294 , 0.709804 , 0.803922 }, +"LightSteelBlue4", {0.431373 , 0.482353 , 0.545098 }, +"LightYellow", {1.000000 , 1.000000 , 0.878431 }, +"LightYellow1", {1.000000 , 1.000000 , 0.878431 }, +"LightYellow2", {0.933333 , 0.933333 , 0.819608 }, +"LightYellow3", {0.803922 , 0.803922 , 0.705882 }, +"LightYellow4", {0.545098 , 0.545098 , 0.478431 }, +"LimeGreen", {0.196078 , 0.803922 , 0.196078 }, +"MediumAquamarine", {0.400000 , 0.803922 , 0.666667 }, +"MediumBlue", {0.000000 , 0.000000 , 0.803922 }, +"MediumOrchid", {0.729412 , 0.333333 , 0.827451 }, +"MediumOrchid1", {0.878431 , 0.400000 , 1.000000 }, +"MediumOrchid2", {0.819608 , 0.372549 , 0.933333 }, +"MediumOrchid3", {0.705882 , 0.321569 , 0.803922 }, +"MediumOrchid4", {0.478431 , 0.215686 , 0.545098 }, +"MediumPurple", {0.576471 , 0.439216 , 0.858824 }, +"MediumPurple1", {0.670588 , 0.509804 , 1.000000 }, +"MediumPurple2", {0.623529 , 0.474510 , 0.933333 }, +"MediumPurple3", {0.537255 , 0.407843 , 0.803922 }, +"MediumPurple4", {0.364706 , 0.278431 , 0.545098 }, +"MediumSeaGreen", {0.235294 , 0.701961 , 0.443137 }, +"MediumSlateBlue", {0.482353 , 0.407843 , 0.933333 }, +"MediumSpringGreen", {0.000000 , 0.980392 , 0.603922 }, +"MediumTurquoise", {0.282353 , 0.819608 , 0.800000 }, +"MediumVioletRed", {0.780392 , 0.082353 , 0.521569 }, +"MidnightBlue", {0.098039 , 0.098039 , 0.439216 }, +"MintCream", {0.960784 , 1.000000 , 0.980392 }, +"MistyRose", {1.000000 , 0.894118 , 0.882353 }, +"MistyRose1", {1.000000 , 0.894118 , 0.882353 }, +"MistyRose2", {0.933333 , 0.835294 , 0.823529 }, +"MistyRose3", {0.803922 , 0.717647 , 0.709804 }, +"MistyRose4", {0.545098 , 0.490196 , 0.482353 }, +"NavajoWhite", {1.000000 , 0.870588 , 0.678431 }, +"NavajoWhite1", {1.000000 , 0.870588 , 0.678431 }, +"NavajoWhite2", {0.933333 , 0.811765 , 0.631373 }, +"NavajoWhite3", {0.803922 , 0.701961 , 0.545098 }, +"NavajoWhite4", {0.545098 , 0.474510 , 0.368627 }, +"NavyBlue", {0.000000 , 0.000000 , 0.501961 }, +"OldLace", {0.992157 , 0.960784 , 0.901961 }, +"OliveDrab", {0.419608 , 0.556863 , 0.137255 }, +"OliveDrab1", {0.752941 , 1.000000 , 0.243137 }, +"OliveDrab2", {0.701961 , 0.933333 , 0.227451 }, +"OliveDrab3", {0.603922 , 0.803922 , 0.196078 }, +"OliveDrab4", {0.411765 , 0.545098 , 0.133333 }, +"OrangeRed", {1.000000 , 0.270588 , 0.000000 }, +"OrangeRed1", {1.000000 , 0.270588 , 0.000000 }, +"OrangeRed2", {0.933333 , 0.250980 , 0.000000 }, +"OrangeRed3", {0.803922 , 0.215686 , 0.000000 }, +"OrangeRed4", {0.545098 , 0.145098 , 0.000000 }, +"PaleGoldenrod", {0.933333 , 0.909804 , 0.666667 }, +"PaleGreen", {0.596078 , 0.984314 , 0.596078 }, +"PaleGreen1", {0.603922 , 1.000000 , 0.603922 }, +"PaleGreen2", {0.564706 , 0.933333 , 0.564706 }, +"PaleGreen3", {0.486275 , 0.803922 , 0.486275 }, +"PaleGreen4", {0.329412 , 0.545098 , 0.329412 }, +"PaleTurquoise", {0.686275 , 0.933333 , 0.933333 }, +"PaleTurquoise1", {0.733333 , 1.000000 , 1.000000 }, +"PaleTurquoise2", {0.682353 , 0.933333 , 0.933333 }, +"PaleTurquoise3", {0.588235 , 0.803922 , 0.803922 }, +"PaleTurquoise4", {0.400000 , 0.545098 , 0.545098 }, +"PaleVioletRed", {0.858824 , 0.439216 , 0.576471 }, +"PaleVioletRed1", {1.000000 , 0.509804 , 0.670588 }, +"PaleVioletRed2", {0.933333 , 0.474510 , 0.623529 }, +"PaleVioletRed3", {0.803922 , 0.407843 , 0.537255 }, +"PaleVioletRed4", {0.545098 , 0.278431 , 0.364706 }, +"PapayaWhip", {1.000000 , 0.937255 , 0.835294 }, +"PeachPuff", {1.000000 , 0.854902 , 0.725490 }, +"PeachPuff1", {1.000000 , 0.854902 , 0.725490 }, +"PeachPuff2", {0.933333 , 0.796078 , 0.678431 }, +"PeachPuff3", {0.803922 , 0.686275 , 0.584314 }, +"PeachPuff4", {0.545098 , 0.466667 , 0.396078 }, +"PowderBlue", {0.690196 , 0.878431 , 0.901961 }, +"RosyBrown", {0.737255 , 0.560784 , 0.560784 }, +"RosyBrown1", {1.000000 , 0.756863 , 0.756863 }, +"RosyBrown2", {0.933333 , 0.705882 , 0.705882 }, +"RosyBrown3", {0.803922 , 0.607843 , 0.607843 }, +"RosyBrown4", {0.545098 , 0.411765 , 0.411765 }, +"RoyalBlue", {0.254902 , 0.411765 , 0.882353 }, +"RoyalBlue1", {0.282353 , 0.462745 , 1.000000 }, +"RoyalBlue2", {0.262745 , 0.431373 , 0.933333 }, +"RoyalBlue3", {0.227451 , 0.372549 , 0.803922 }, +"RoyalBlue4", {0.152941 , 0.250980 , 0.545098 }, +"SaddleBrown", {0.545098 , 0.270588 , 0.074510 }, +"SandyBrown", {0.956863 , 0.643137 , 0.376471 }, +"SeaGreen", {0.180392 , 0.545098 , 0.341176 }, +"SeaGreen1", {0.329412 , 1.000000 , 0.623529 }, +"SeaGreen2", {0.305882 , 0.933333 , 0.580392 }, +"SeaGreen3", {0.262745 , 0.803922 , 0.501961 }, +"SeaGreen4", {0.180392 , 0.545098 , 0.341176 }, +"SkyBlue", {0.529412 , 0.807843 , 0.921569 }, +"SkyBlue1", {0.529412 , 0.807843 , 1.000000 }, +"SkyBlue2", {0.494118 , 0.752941 , 0.933333 }, +"SkyBlue3", {0.423529 , 0.650980 , 0.803922 }, +"SkyBlue4", {0.290196 , 0.439216 , 0.545098 }, +"SlateBlue", {0.415686 , 0.352941 , 0.803922 }, +"SlateBlue1", {0.513725 , 0.435294 , 1.000000 }, +"SlateBlue2", {0.478431 , 0.403922 , 0.933333 }, +"SlateBlue3", {0.411765 , 0.349020 , 0.803922 }, +"SlateBlue4", {0.278431 , 0.235294 , 0.545098 }, +"SlateGray", {0.439216 , 0.501961 , 0.564706 }, +"SlateGray1", {0.776471 , 0.886275 , 1.000000 }, +"SlateGray2", {0.725490 , 0.827451 , 0.933333 }, +"SlateGray3", {0.623529 , 0.713725 , 0.803922 }, +"SlateGray4", {0.423529 , 0.482353 , 0.545098 }, +"SlateGrey", {0.439216 , 0.501961 , 0.564706 }, +"SpringGreen", {0.000000 , 1.000000 , 0.498039 }, +"SpringGreen1", {0.000000 , 1.000000 , 0.498039 }, +"SpringGreen2", {0.000000 , 0.933333 , 0.462745 }, +"SpringGreen3", {0.000000 , 0.803922 , 0.400000 }, +"SpringGreen4", {0.000000 , 0.545098 , 0.270588 }, +"SteelBlue", {0.274510 , 0.509804 , 0.705882 }, +"SteelBlue1", {0.388235 , 0.721569 , 1.000000 }, +"SteelBlue2", {0.360784 , 0.674510 , 0.933333 }, +"SteelBlue3", {0.309804 , 0.580392 , 0.803922 }, +"SteelBlue4", {0.211765 , 0.392157 , 0.545098 }, +"VioletRed", {0.815686 , 0.125490 , 0.564706 }, +"VioletRed1", {1.000000 , 0.243137 , 0.588235 }, +"VioletRed2", {0.933333 , 0.227451 , 0.549020 }, +"VioletRed3", {0.803922 , 0.196078 , 0.470588 }, +"VioletRed4", {0.545098 , 0.133333 , 0.321569 }, +"WhiteSmoke", {0.960784 , 0.960784 , 0.960784 }, +"YellowGreen", {0.603922 , 0.803922 , 0.196078 }, +"alice_blue", {0.941176 , 0.972549 , 1.000000 }, +"antique_white", {0.980392 , 0.921569 , 0.843137 }, +"aquamarine", {0.498039 , 1.000000 , 0.831373 }, +"aquamarine1", {0.498039 , 1.000000 , 0.831373 }, +"aquamarine2", {0.462745 , 0.933333 , 0.776471 }, +"aquamarine3", {0.400000 , 0.803922 , 0.666667 }, +"aquamarine4", {0.270588 , 0.545098 , 0.454902 }, +"azure", {0.941176 , 1.000000 , 1.000000 }, +"azure1", {0.941176 , 1.000000 , 1.000000 }, +"azure2", {0.878431 , 0.933333 , 0.933333 }, +"azure3", {0.756863 , 0.803922 , 0.803922 }, +"azure4", {0.513725 , 0.545098 , 0.545098 }, +"beige", {0.960784 , 0.960784 , 0.862745 }, +"bisque", {1.000000 , 0.894118 , 0.768627 }, +"bisque1", {1.000000 , 0.894118 , 0.768627 }, +"bisque2", {0.933333 , 0.835294 , 0.717647 }, +"bisque3", {0.803922 , 0.717647 , 0.619608 }, +"bisque4", {0.545098 , 0.490196 , 0.419608 }, +"black", {0.000000 , 0.000000 , 0.000000 }, +"blanched_almond", {1.000000 , 0.921569 , 0.803922 }, +"blue", {0.000000 , 0.000000 , 1.000000 }, +"blue1", {0.000000 , 0.000000 , 1.000000 }, +"blue2", {0.000000 , 0.000000 , 0.933333 }, +"blue3", {0.000000 , 0.000000 , 0.803922 }, +"blue4", {0.000000 , 0.000000 , 0.545098 }, +"blue_violet", {0.541176 , 0.168627 , 0.886275 }, +"brown", {0.647059 , 0.164706 , 0.164706 }, +"brown1", {1.000000 , 0.250980 , 0.250980 }, +"brown2", {0.933333 , 0.231373 , 0.231373 }, +"brown3", {0.803922 , 0.200000 , 0.200000 }, +"brown4", {0.545098 , 0.137255 , 0.137255 }, +"burlywood", {0.870588 , 0.721569 , 0.529412 }, +"burlywood1", {1.000000 , 0.827451 , 0.607843 }, +"burlywood2", {0.933333 , 0.772549 , 0.568627 }, +"burlywood3", {0.803922 , 0.666667 , 0.490196 }, +"burlywood4", {0.545098 , 0.450980 , 0.333333 }, +"cadet_blue", {0.372549 , 0.619608 , 0.627451 }, +"chartreuse", {0.498039 , 1.000000 , 0.000000 }, +"chartreuse1", {0.498039 , 1.000000 , 0.000000 }, +"chartreuse2", {0.462745 , 0.933333 , 0.000000 }, +"chartreuse3", {0.400000 , 0.803922 , 0.000000 }, +"chartreuse4", {0.270588 , 0.545098 , 0.000000 }, +"chocolate", {0.823529 , 0.411765 , 0.117647 }, +"chocolate1", {1.000000 , 0.498039 , 0.141176 }, +"chocolate2", {0.933333 , 0.462745 , 0.129412 }, +"chocolate3", {0.803922 , 0.400000 , 0.113725 }, +"chocolate4", {0.545098 , 0.270588 , 0.074510 }, +"coral", {1.000000 , 0.498039 , 0.313725 }, +"coral1", {1.000000 , 0.447059 , 0.337255 }, +"coral2", {0.933333 , 0.415686 , 0.313725 }, +"coral3", {0.803922 , 0.356863 , 0.270588 }, +"coral4", {0.545098 , 0.243137 , 0.184314 }, +"cornflower_blue", {0.392157 , 0.584314 , 0.929412 }, +"cornsilk", {1.000000 , 0.972549 , 0.862745 }, +"cornsilk1", {1.000000 , 0.972549 , 0.862745 }, +"cornsilk2", {0.933333 , 0.909804 , 0.803922 }, +"cornsilk3", {0.803922 , 0.784314 , 0.694118 }, +"cornsilk4", {0.545098 , 0.533333 , 0.470588 }, +"cyan", {0.000000 , 1.000000 , 1.000000 }, +"cyan1", {0.000000 , 1.000000 , 1.000000 }, +"cyan2", {0.000000 , 0.933333 , 0.933333 }, +"cyan3", {0.000000 , 0.803922 , 0.803922 }, +"cyan4", {0.000000 , 0.545098 , 0.545098 }, +"dark_goldenrod", {0.721569 , 0.525490 , 0.043137 }, +"dark_green", {0.000000 , 0.392157 , 0.000000 }, +"dark_khaki", {0.741176 , 0.717647 , 0.419608 }, +"dark_olive_green", {0.333333 , 0.419608 , 0.184314 }, +"dark_orange", {1.000000 , 0.549020 , 0.000000 }, +"dark_orchid", {0.600000 , 0.196078 , 0.800000 }, +"dark_salmon", {0.913725 , 0.588235 , 0.478431 }, +"dark_sea_green", {0.560784 , 0.737255 , 0.560784 }, +"dark_slate_blue", {0.282353 , 0.239216 , 0.545098 }, +"dark_slate_gray", {0.184314 , 0.309804 , 0.309804 }, +"dark_slate_grey", {0.184314 , 0.309804 , 0.309804 }, +"dark_turquoise", {0.000000 , 0.807843 , 0.819608 }, +"dark_violet", {0.580392 , 0.000000 , 0.827451 }, +"deep_pink", {1.000000 , 0.078431 , 0.576471 }, +"deep_sky_blue", {0.000000 , 0.749020 , 1.000000 }, +"dim_gray", {0.411765 , 0.411765 , 0.411765 }, +"dim_grey", {0.411765 , 0.411765 , 0.411765 }, +"dodger_blue", {0.117647 , 0.564706 , 1.000000 }, +"firebrick", {0.698039 , 0.133333 , 0.133333 }, +"firebrick1", {1.000000 , 0.188235 , 0.188235 }, +"firebrick2", {0.933333 , 0.172549 , 0.172549 }, +"firebrick3", {0.803922 , 0.149020 , 0.149020 }, +"firebrick4", {0.545098 , 0.101961 , 0.101961 }, +"floral_white", {1.000000 , 0.980392 , 0.941176 }, +"forest_green", {0.133333 , 0.545098 , 0.133333 }, +"gainsboro", {0.862745 , 0.862745 , 0.862745 }, +"ghost_white", {0.972549 , 0.972549 , 1.000000 }, +"gold", {1.000000 , 0.843137 , 0.000000 }, +"gold1", {1.000000 , 0.843137 , 0.000000 }, +"gold2", {0.933333 , 0.788235 , 0.000000 }, +"gold3", {0.803922 , 0.678431 , 0.000000 }, +"gold4", {0.545098 , 0.458824 , 0.000000 }, +"goldenrod", {0.854902 , 0.647059 , 0.125490 }, +"goldenrod1", {1.000000 , 0.756863 , 0.145098 }, +"goldenrod2", {0.933333 , 0.705882 , 0.133333 }, +"goldenrod3", {0.803922 , 0.607843 , 0.113725 }, +"goldenrod4", {0.545098 , 0.411765 , 0.078431 }, +"gray", {0.752941 , 0.752941 , 0.752941 }, +"gray0", {0.000000 , 0.000000 , 0.000000 }, +"gray1", {0.011765 , 0.011765 , 0.011765 }, +"gray10", {0.101961 , 0.101961 , 0.101961 }, +"gray100", {1.000000 , 1.000000 , 1.000000 }, +"gray11", {0.109804 , 0.109804 , 0.109804 }, +"gray12", {0.121569 , 0.121569 , 0.121569 }, +"gray13", {0.129412 , 0.129412 , 0.129412 }, +"gray14", {0.141176 , 0.141176 , 0.141176 }, +"gray15", {0.149020 , 0.149020 , 0.149020 }, +"gray16", {0.160784 , 0.160784 , 0.160784 }, +"gray17", {0.168627 , 0.168627 , 0.168627 }, +"gray18", {0.180392 , 0.180392 , 0.180392 }, +"gray19", {0.188235 , 0.188235 , 0.188235 }, +"gray2", {0.019608 , 0.019608 , 0.019608 }, +"gray20", {0.200000 , 0.200000 , 0.200000 }, +"gray21", {0.211765 , 0.211765 , 0.211765 }, +"gray22", {0.219608 , 0.219608 , 0.219608 }, +"gray23", {0.231373 , 0.231373 , 0.231373 }, +"gray24", {0.239216 , 0.239216 , 0.239216 }, +"gray25", {0.250980 , 0.250980 , 0.250980 }, +"gray26", {0.258824 , 0.258824 , 0.258824 }, +"gray27", {0.270588 , 0.270588 , 0.270588 }, +"gray28", {0.278431 , 0.278431 , 0.278431 }, +"gray29", {0.290196 , 0.290196 , 0.290196 }, +"gray3", {0.031373 , 0.031373 , 0.031373 }, +"gray30", {0.301961 , 0.301961 , 0.301961 }, +"gray31", {0.309804 , 0.309804 , 0.309804 }, +"gray32", {0.321569 , 0.321569 , 0.321569 }, +"gray33", {0.329412 , 0.329412 , 0.329412 }, +"gray34", {0.341176 , 0.341176 , 0.341176 }, +"gray35", {0.349020 , 0.349020 , 0.349020 }, +"gray36", {0.360784 , 0.360784 , 0.360784 }, +"gray37", {0.368627 , 0.368627 , 0.368627 }, +"gray38", {0.380392 , 0.380392 , 0.380392 }, +"gray39", {0.388235 , 0.388235 , 0.388235 }, +"gray4", {0.039216 , 0.039216 , 0.039216 }, +"gray40", {0.400000 , 0.400000 , 0.400000 }, +"gray41", {0.411765 , 0.411765 , 0.411765 }, +"gray42", {0.419608 , 0.419608 , 0.419608 }, +"gray43", {0.431373 , 0.431373 , 0.431373 }, +"gray44", {0.439216 , 0.439216 , 0.439216 }, +"gray45", {0.450980 , 0.450980 , 0.450980 }, +"gray46", {0.458824 , 0.458824 , 0.458824 }, +"gray47", {0.470588 , 0.470588 , 0.470588 }, +"gray48", {0.478431 , 0.478431 , 0.478431 }, +"gray49", {0.490196 , 0.490196 , 0.490196 }, +"gray5", {0.050980 , 0.050980 , 0.050980 }, +"gray50", {0.498039 , 0.498039 , 0.498039 }, +"gray51", {0.509804 , 0.509804 , 0.509804 }, +"gray52", {0.521569 , 0.521569 , 0.521569 }, +"gray53", {0.529412 , 0.529412 , 0.529412 }, +"gray54", {0.541176 , 0.541176 , 0.541176 }, +"gray55", {0.549020 , 0.549020 , 0.549020 }, +"gray56", {0.560784 , 0.560784 , 0.560784 }, +"gray57", {0.568627 , 0.568627 , 0.568627 }, +"gray58", {0.580392 , 0.580392 , 0.580392 }, +"gray59", {0.588235 , 0.588235 , 0.588235 }, +"gray6", {0.058824 , 0.058824 , 0.058824 }, +"gray60", {0.600000 , 0.600000 , 0.600000 }, +"gray61", {0.611765 , 0.611765 , 0.611765 }, +"gray62", {0.619608 , 0.619608 , 0.619608 }, +"gray63", {0.631373 , 0.631373 , 0.631373 }, +"gray64", {0.639216 , 0.639216 , 0.639216 }, +"gray65", {0.650980 , 0.650980 , 0.650980 }, +"gray66", {0.658824 , 0.658824 , 0.658824 }, +"gray67", {0.670588 , 0.670588 , 0.670588 }, +"gray68", {0.678431 , 0.678431 , 0.678431 }, +"gray69", {0.690196 , 0.690196 , 0.690196 }, +"gray7", {0.070588 , 0.070588 , 0.070588 }, +"gray70", {0.701961 , 0.701961 , 0.701961 }, +"gray71", {0.709804 , 0.709804 , 0.709804 }, +"gray72", {0.721569 , 0.721569 , 0.721569 }, +"gray73", {0.729412 , 0.729412 , 0.729412 }, +"gray74", {0.741176 , 0.741176 , 0.741176 }, +"gray75", {0.749020 , 0.749020 , 0.749020 }, +"gray76", {0.760784 , 0.760784 , 0.760784 }, +"gray77", {0.768627 , 0.768627 , 0.768627 }, +"gray78", {0.780392 , 0.780392 , 0.780392 }, +"gray79", {0.788235 , 0.788235 , 0.788235 }, +"gray8", {0.078431 , 0.078431 , 0.078431 }, +"gray80", {0.800000 , 0.800000 , 0.800000 }, +"gray81", {0.811765 , 0.811765 , 0.811765 }, +"gray82", {0.819608 , 0.819608 , 0.819608 }, +"gray83", {0.831373 , 0.831373 , 0.831373 }, +"gray84", {0.839216 , 0.839216 , 0.839216 }, +"gray85", {0.850980 , 0.850980 , 0.850980 }, +"gray86", {0.858824 , 0.858824 , 0.858824 }, +"gray87", {0.870588 , 0.870588 , 0.870588 }, +"gray88", {0.878431 , 0.878431 , 0.878431 }, +"gray89", {0.890196 , 0.890196 , 0.890196 }, +"gray9", {0.090196 , 0.090196 , 0.090196 }, +"gray90", {0.898039 , 0.898039 , 0.898039 }, +"gray91", {0.909804 , 0.909804 , 0.909804 }, +"gray92", {0.921569 , 0.921569 , 0.921569 }, +"gray93", {0.929412 , 0.929412 , 0.929412 }, +"gray94", {0.941176 , 0.941176 , 0.941176 }, +"gray95", {0.949020 , 0.949020 , 0.949020 }, +"gray96", {0.960784 , 0.960784 , 0.960784 }, +"gray97", {0.968627 , 0.968627 , 0.968627 }, +"gray98", {0.980392 , 0.980392 , 0.980392 }, +"gray99", {0.988235 , 0.988235 , 0.988235 }, +"green", {0.000000 , 1.000000 , 0.000000 }, +"green1", {0.000000 , 1.000000 , 0.000000 }, +"green2", {0.000000 , 0.933333 , 0.000000 }, +"green3", {0.000000 , 0.803922 , 0.000000 }, +"green4", {0.000000 , 0.545098 , 0.000000 }, +"green_yellow", {0.678431 , 1.000000 , 0.184314 }, +"grey", {0.752941 , 0.752941 , 0.752941 }, +"grey0", {0.000000 , 0.000000 , 0.000000 }, +"grey1", {0.011765 , 0.011765 , 0.011765 }, +"grey10", {0.101961 , 0.101961 , 0.101961 }, +"grey100", {1.000000 , 1.000000 , 1.000000 }, +"grey11", {0.109804 , 0.109804 , 0.109804 }, +"grey12", {0.121569 , 0.121569 , 0.121569 }, +"grey13", {0.129412 , 0.129412 , 0.129412 }, +"grey14", {0.141176 , 0.141176 , 0.141176 }, +"grey15", {0.149020 , 0.149020 , 0.149020 }, +"grey16", {0.160784 , 0.160784 , 0.160784 }, +"grey17", {0.168627 , 0.168627 , 0.168627 }, +"grey18", {0.180392 , 0.180392 , 0.180392 }, +"grey19", {0.188235 , 0.188235 , 0.188235 }, +"grey2", {0.019608 , 0.019608 , 0.019608 }, +"grey20", {0.200000 , 0.200000 , 0.200000 }, +"grey21", {0.211765 , 0.211765 , 0.211765 }, +"grey22", {0.219608 , 0.219608 , 0.219608 }, +"grey23", {0.231373 , 0.231373 , 0.231373 }, +"grey24", {0.239216 , 0.239216 , 0.239216 }, +"grey25", {0.250980 , 0.250980 , 0.250980 }, +"grey26", {0.258824 , 0.258824 , 0.258824 }, +"grey27", {0.270588 , 0.270588 , 0.270588 }, +"grey28", {0.278431 , 0.278431 , 0.278431 }, +"grey29", {0.290196 , 0.290196 , 0.290196 }, +"grey3", {0.031373 , 0.031373 , 0.031373 }, +"grey30", {0.301961 , 0.301961 , 0.301961 }, +"grey31", {0.309804 , 0.309804 , 0.309804 }, +"grey32", {0.321569 , 0.321569 , 0.321569 }, +"grey33", {0.329412 , 0.329412 , 0.329412 }, +"grey34", {0.341176 , 0.341176 , 0.341176 }, +"grey35", {0.349020 , 0.349020 , 0.349020 }, +"grey36", {0.360784 , 0.360784 , 0.360784 }, +"grey37", {0.368627 , 0.368627 , 0.368627 }, +"grey38", {0.380392 , 0.380392 , 0.380392 }, +"grey39", {0.388235 , 0.388235 , 0.388235 }, +"grey4", {0.039216 , 0.039216 , 0.039216 }, +"grey40", {0.400000 , 0.400000 , 0.400000 }, +"grey41", {0.411765 , 0.411765 , 0.411765 }, +"grey42", {0.419608 , 0.419608 , 0.419608 }, +"grey43", {0.431373 , 0.431373 , 0.431373 }, +"grey44", {0.439216 , 0.439216 , 0.439216 }, +"grey45", {0.450980 , 0.450980 , 0.450980 }, +"grey46", {0.458824 , 0.458824 , 0.458824 }, +"grey47", {0.470588 , 0.470588 , 0.470588 }, +"grey48", {0.478431 , 0.478431 , 0.478431 }, +"grey49", {0.490196 , 0.490196 , 0.490196 }, +"grey5", {0.050980 , 0.050980 , 0.050980 }, +"grey50", {0.498039 , 0.498039 , 0.498039 }, +"grey51", {0.509804 , 0.509804 , 0.509804 }, +"grey52", {0.521569 , 0.521569 , 0.521569 }, +"grey53", {0.529412 , 0.529412 , 0.529412 }, +"grey54", {0.541176 , 0.541176 , 0.541176 }, +"grey55", {0.549020 , 0.549020 , 0.549020 }, +"grey56", {0.560784 , 0.560784 , 0.560784 }, +"grey57", {0.568627 , 0.568627 , 0.568627 }, +"grey58", {0.580392 , 0.580392 , 0.580392 }, +"grey59", {0.588235 , 0.588235 , 0.588235 }, +"grey6", {0.058824 , 0.058824 , 0.058824 }, +"grey60", {0.600000 , 0.600000 , 0.600000 }, +"grey61", {0.611765 , 0.611765 , 0.611765 }, +"grey62", {0.619608 , 0.619608 , 0.619608 }, +"grey63", {0.631373 , 0.631373 , 0.631373 }, +"grey64", {0.639216 , 0.639216 , 0.639216 }, +"grey65", {0.650980 , 0.650980 , 0.650980 }, +"grey66", {0.658824 , 0.658824 , 0.658824 }, +"grey67", {0.670588 , 0.670588 , 0.670588 }, +"grey68", {0.678431 , 0.678431 , 0.678431 }, +"grey69", {0.690196 , 0.690196 , 0.690196 }, +"grey7", {0.070588 , 0.070588 , 0.070588 }, +"grey70", {0.701961 , 0.701961 , 0.701961 }, +"grey71", {0.709804 , 0.709804 , 0.709804 }, +"grey72", {0.721569 , 0.721569 , 0.721569 }, +"grey73", {0.729412 , 0.729412 , 0.729412 }, +"grey74", {0.741176 , 0.741176 , 0.741176 }, +"grey75", {0.749020 , 0.749020 , 0.749020 }, +"grey76", {0.760784 , 0.760784 , 0.760784 }, +"grey77", {0.768627 , 0.768627 , 0.768627 }, +"grey78", {0.780392 , 0.780392 , 0.780392 }, +"grey79", {0.788235 , 0.788235 , 0.788235 }, +"grey8", {0.078431 , 0.078431 , 0.078431 }, +"grey80", {0.800000 , 0.800000 , 0.800000 }, +"grey81", {0.811765 , 0.811765 , 0.811765 }, +"grey82", {0.819608 , 0.819608 , 0.819608 }, +"grey83", {0.831373 , 0.831373 , 0.831373 }, +"grey84", {0.839216 , 0.839216 , 0.839216 }, +"grey85", {0.850980 , 0.850980 , 0.850980 }, +"grey86", {0.858824 , 0.858824 , 0.858824 }, +"grey87", {0.870588 , 0.870588 , 0.870588 }, +"grey88", {0.878431 , 0.878431 , 0.878431 }, +"grey89", {0.890196 , 0.890196 , 0.890196 }, +"grey9", {0.090196 , 0.090196 , 0.090196 }, +"grey90", {0.898039 , 0.898039 , 0.898039 }, +"grey91", {0.909804 , 0.909804 , 0.909804 }, +"grey92", {0.921569 , 0.921569 , 0.921569 }, +"grey93", {0.929412 , 0.929412 , 0.929412 }, +"grey94", {0.941176 , 0.941176 , 0.941176 }, +"grey95", {0.949020 , 0.949020 , 0.949020 }, +"grey96", {0.960784 , 0.960784 , 0.960784 }, +"grey97", {0.968627 , 0.968627 , 0.968627 }, +"grey98", {0.980392 , 0.980392 , 0.980392 }, +"grey99", {0.988235 , 0.988235 , 0.988235 }, +"honeydew", {0.941176 , 1.000000 , 0.941176 }, +"honeydew1", {0.941176 , 1.000000 , 0.941176 }, +"honeydew2", {0.878431 , 0.933333 , 0.878431 }, +"honeydew3", {0.756863 , 0.803922 , 0.756863 }, +"honeydew4", {0.513725 , 0.545098 , 0.513725 }, +"hot_pink", {1.000000 , 0.411765 , 0.705882 }, +"indian_red", {0.803922 , 0.360784 , 0.360784 }, +"ivory", {1.000000 , 1.000000 , 0.941176 }, +"ivory1", {1.000000 , 1.000000 , 0.941176 }, +"ivory2", {0.933333 , 0.933333 , 0.878431 }, +"ivory3", {0.803922 , 0.803922 , 0.756863 }, +"ivory4", {0.545098 , 0.545098 , 0.513725 }, +"khaki", {0.941176 , 0.901961 , 0.549020 }, +"khaki1", {1.000000 , 0.964706 , 0.560784 }, +"khaki2", {0.933333 , 0.901961 , 0.521569 }, +"khaki3", {0.803922 , 0.776471 , 0.450980 }, +"khaki4", {0.545098 , 0.525490 , 0.305882 }, +"lavender", {0.901961 , 0.901961 , 0.980392 }, +"lavender_blush", {1.000000 , 0.941176 , 0.960784 }, +"lawn_green", {0.486275 , 0.988235 , 0.000000 }, +"lemon_chiffon", {1.000000 , 0.980392 , 0.803922 }, +"light_blue", {0.678431 , 0.847059 , 0.901961 }, +"light_coral", {0.941176 , 0.501961 , 0.501961 }, +"light_cyan", {0.878431 , 1.000000 , 1.000000 }, +"light_goldenrod", {0.933333 , 0.866667 , 0.509804 }, +"light_goldenrod_yellow", {0.980392 , 0.980392 , 0.823529 }, +"light_gray", {0.827451 , 0.827451 , 0.827451 }, +"light_grey", {0.827451 , 0.827451 , 0.827451 }, +"light_pink", {1.000000 , 0.713725 , 0.756863 }, +"light_salmon", {1.000000 , 0.627451 , 0.478431 }, +"light_sea_green", {0.125490 , 0.698039 , 0.666667 }, +"light_sky_blue", {0.529412 , 0.807843 , 0.980392 }, +"light_slate_blue", {0.517647 , 0.439216 , 1.000000 }, +"light_slate_gray", {0.466667 , 0.533333 , 0.600000 }, +"light_slate_grey", {0.466667 , 0.533333 , 0.600000 }, +"light_steel_blue", {0.690196 , 0.768627 , 0.870588 }, +"light_yellow", {1.000000 , 1.000000 , 0.878431 }, +"lime_green", {0.196078 , 0.803922 , 0.196078 }, +"linen", {0.980392 , 0.941176 , 0.901961 }, +"magenta", {1.000000 , 0.000000 , 1.000000 }, +"magenta1", {1.000000 , 0.000000 , 1.000000 }, +"magenta2", {0.933333 , 0.000000 , 0.933333 }, +"magenta3", {0.803922 , 0.000000 , 0.803922 }, +"magenta4", {0.545098 , 0.000000 , 0.545098 }, +"maroon", {0.690196 , 0.188235 , 0.376471 }, +"maroon1", {1.000000 , 0.203922 , 0.701961 }, +"maroon2", {0.933333 , 0.188235 , 0.654902 }, +"maroon3", {0.803922 , 0.160784 , 0.564706 }, +"maroon4", {0.545098 , 0.109804 , 0.384314 }, +"medium_aquamarine", {0.400000 , 0.803922 , 0.666667 }, +"medium_blue", {0.000000 , 0.000000 , 0.803922 }, +"medium_orchid", {0.729412 , 0.333333 , 0.827451 }, +"medium_purple", {0.576471 , 0.439216 , 0.858824 }, +"medium_sea_green", {0.235294 , 0.701961 , 0.443137 }, +"medium_slate_blue", {0.482353 , 0.407843 , 0.933333 }, +"medium_spring_green", {0.000000 , 0.980392 , 0.603922 }, +"medium_turquoise", {0.282353 , 0.819608 , 0.800000 }, +"medium_violet_red", {0.780392 , 0.082353 , 0.521569 }, +"midnight_blue", {0.098039 , 0.098039 , 0.439216 }, +"mint_cream", {0.960784 , 1.000000 , 0.980392 }, +"misty_rose", {1.000000 , 0.894118 , 0.882353 }, +"moccasin", {1.000000 , 0.894118 , 0.709804 }, +"navajo_white", {1.000000 , 0.870588 , 0.678431 }, +"navy", {0.000000 , 0.000000 , 0.501961 }, +"navy_blue", {0.000000 , 0.000000 , 0.501961 }, +"old_lace", {0.992157 , 0.960784 , 0.901961 }, +"olive_drab", {0.419608 , 0.556863 , 0.137255 }, +"orange", {1.000000 , 0.647059 , 0.000000 }, +"orange1", {1.000000 , 0.647059 , 0.000000 }, +"orange2", {0.933333 , 0.603922 , 0.000000 }, +"orange3", {0.803922 , 0.521569 , 0.000000 }, +"orange4", {0.545098 , 0.352941 , 0.000000 }, +"orange_red", {1.000000 , 0.270588 , 0.000000 }, +"orchid", {0.854902 , 0.439216 , 0.839216 }, +"orchid1", {1.000000 , 0.513725 , 0.980392 }, +"orchid2", {0.933333 , 0.478431 , 0.913725 }, +"orchid3", {0.803922 , 0.411765 , 0.788235 }, +"orchid4", {0.545098 , 0.278431 , 0.537255 }, +"pale_goldenrod", {0.933333 , 0.909804 , 0.666667 }, +"pale_green", {0.596078 , 0.984314 , 0.596078 }, +"pale_turquoise", {0.686275 , 0.933333 , 0.933333 }, +"pale_violet_red", {0.858824 , 0.439216 , 0.576471 }, +"papaya_whip", {1.000000 , 0.937255 , 0.835294 }, +"peach_puff", {1.000000 , 0.854902 , 0.725490 }, +"peru", {0.803922 , 0.521569 , 0.247059 }, +"pink", {1.000000 , 0.752941 , 0.796078 }, +"pink1", {1.000000 , 0.709804 , 0.772549 }, +"pink2", {0.933333 , 0.662745 , 0.721569 }, +"pink3", {0.803922 , 0.568627 , 0.619608 }, +"pink4", {0.545098 , 0.388235 , 0.423529 }, +"plum", {0.866667 , 0.627451 , 0.866667 }, +"plum1", {1.000000 , 0.733333 , 1.000000 }, +"plum2", {0.933333 , 0.682353 , 0.933333 }, +"plum3", {0.803922 , 0.588235 , 0.803922 }, +"plum4", {0.545098 , 0.400000 , 0.545098 }, +"powder_blue", {0.690196 , 0.878431 , 0.901961 }, +"purple", {0.627451 , 0.125490 , 0.941176 }, +"purple1", {0.607843 , 0.188235 , 1.000000 }, +"purple2", {0.568627 , 0.172549 , 0.933333 }, +"purple3", {0.490196 , 0.149020 , 0.803922 }, +"purple4", {0.333333 , 0.101961 , 0.545098 }, +"red", {1.000000 , 0.000000 , 0.000000 }, +"red1", {1.000000 , 0.000000 , 0.000000 }, +"red2", {0.933333 , 0.000000 , 0.000000 }, +"red3", {0.803922 , 0.000000 , 0.000000 }, +"red4", {0.545098 , 0.000000 , 0.000000 }, +"rosy_brown", {0.737255 , 0.560784 , 0.560784 }, +"royal_blue", {0.254902 , 0.411765 , 0.882353 }, +"saddle_brown", {0.545098 , 0.270588 , 0.074510 }, +"salmon", {0.980392 , 0.501961 , 0.447059 }, +"salmon1", {1.000000 , 0.549020 , 0.411765 }, +"salmon2", {0.933333 , 0.509804 , 0.384314 }, +"salmon3", {0.803922 , 0.439216 , 0.329412 }, +"salmon4", {0.545098 , 0.298039 , 0.223529 }, +"sandy_brown", {0.956863 , 0.643137 , 0.376471 }, +"sea_green", {0.180392 , 0.545098 , 0.341176 }, +"seashell", {1.000000 , 0.960784 , 0.933333 }, +"seashell1", {1.000000 , 0.960784 , 0.933333 }, +"seashell2", {0.933333 , 0.898039 , 0.870588 }, +"seashell3", {0.803922 , 0.772549 , 0.749020 }, +"seashell4", {0.545098 , 0.525490 , 0.509804 }, +"sienna", {0.627451 , 0.321569 , 0.176471 }, +"sienna1", {1.000000 , 0.509804 , 0.278431 }, +"sienna2", {0.933333 , 0.474510 , 0.258824 }, +"sienna3", {0.803922 , 0.407843 , 0.223529 }, +"sienna4", {0.545098 , 0.278431 , 0.149020 }, +"sky_blue", {0.529412 , 0.807843 , 0.921569 }, +"slate_blue", {0.415686 , 0.352941 , 0.803922 }, +"slate_gray", {0.439216 , 0.501961 , 0.564706 }, +"slate_grey", {0.439216 , 0.501961 , 0.564706 }, +"snow", {1.000000 , 0.980392 , 0.980392 }, +"snow1", {1.000000 , 0.980392 , 0.980392 }, +"snow2", {0.933333 , 0.913725 , 0.913725 }, +"snow3", {0.803922 , 0.788235 , 0.788235 }, +"snow4", {0.545098 , 0.537255 , 0.537255 }, +"spring_green", {0.000000 , 1.000000 , 0.498039 }, +"steel_blue", {0.274510 , 0.509804 , 0.705882 }, +"tan", {0.823529 , 0.705882 , 0.549020 }, +"tan1", {1.000000 , 0.647059 , 0.309804 }, +"tan2", {0.933333 , 0.603922 , 0.286275 }, +"tan3", {0.803922 , 0.521569 , 0.247059 }, +"tan4", {0.545098 , 0.352941 , 0.168627 }, +"thistle", {0.847059 , 0.749020 , 0.847059 }, +"thistle1", {1.000000 , 0.882353 , 1.000000 }, +"thistle2", {0.933333 , 0.823529 , 0.933333 }, +"thistle3", {0.803922 , 0.709804 , 0.803922 }, +"thistle4", {0.545098 , 0.482353 , 0.545098 }, +"tomato", {1.000000 , 0.388235 , 0.278431 }, +"tomato1", {1.000000 , 0.388235 , 0.278431 }, +"tomato2", {0.933333 , 0.360784 , 0.258824 }, +"tomato3", {0.803922 , 0.309804 , 0.223529 }, +"tomato4", {0.545098 , 0.211765 , 0.149020 }, +"turquoise", {0.250980 , 0.878431 , 0.815686 }, +"turquoise1", {0.000000 , 0.960784 , 1.000000 }, +"turquoise2", {0.000000 , 0.898039 , 0.933333 }, +"turquoise3", {0.000000 , 0.772549 , 0.803922 }, +"turquoise4", {0.000000 , 0.525490 , 0.545098 }, +"violet", {0.933333 , 0.509804 , 0.933333 }, +"violet_red", {0.815686 , 0.125490 , 0.564706 }, +"wheat", {0.960784 , 0.870588 , 0.701961 }, +"wheat1", {1.000000 , 0.905882 , 0.729412 }, +"wheat2", {0.933333 , 0.847059 , 0.682353 }, +"wheat3", {0.803922 , 0.729412 , 0.588235 }, +"wheat4", {0.545098 , 0.494118 , 0.400000 }, +"white", {1.000000 , 1.000000 , 1.000000 }, +"white_smoke", {0.960784 , 0.960784 , 0.960784 }, +"yellow", {1.000000 , 1.000000 , 0.000000 }, +"yellow1", {1.000000 , 1.000000 , 0.000000 }, +"yellow2", {0.933333 , 0.933333 , 0.000000 }, +"yellow3", {0.803922 , 0.803922 , 0.000000 }, +"yellow4", {0.545098 , 0.545098 , 0.000000 }, +"yellow_green", {0.603922 , 0.803922 , 0.196078 } +} ; + +int +LookupColorByName(name, color) + char * name ; + Vec color ; +{ + int rc ; + rc = BinarySearch(name, 0, NCOLORS - 1 , Colors) ; + if (rc < 0) { + return(0) ; + } + + VecCopy(Colors[rc].ce_color, color) ; + return 1 ; +} + + +int +BinarySearch(name, l, h, array) + char * name ; + int l, h ; + ColorEntry array[] ; +{ + int m, rc ; + if (l > h) + return(-1) ; + + m = (l + h) / 2 ; + + rc = strcmp(name, array[m].ce_name) ; + if (rc == 0) + return m ; + else if (rc < 0) + return BinarySearch(name, l, m-1, array) ; + else + return BinarySearch(name, m + 1, h, array) ; }
