--- ray/src/cv/nff2rad.c 1990/12/11 09:28:27 1.2 +++ ray/src/cv/nff2rad.c 2003/02/22 02:07:23 2.5 @@ -1,13 +1,13 @@ -/* Copyright (c) 1990 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: nff2rad.c,v 2.5 2003/02/22 02:07:23 greg Exp $"; #endif - /* * Convert Neutral File Format input to Radiance scene description. * * 12/9/90 Greg Ward + * 02/7/92 Peter Averkamp added X11(MTV)color names & + * fixed some lf's for direct import of MTV + * source files */ /****************************************************************** @@ -83,11 +83,13 @@ char *argv[]; for (i = 1; i < argc; i++) if (argc-i > 1 && !strcmp(argv[i], "-vf")) viewfile = argv[++i]; + else if (!strncmp(argv[i], "-h",2)) + goto userr; else break; - if (i-argc > 1) + if (argc-i > 1) goto userr; - if (i-argc == 1 && freopen(argv[i], "r", stdin) == NULL) { + if (argc-i == 1 && freopen(argv[i], "r", stdin) == NULL) { perror(argv[i]); exit(1); } @@ -104,7 +106,7 @@ init() /* spit out initial definitions */ { printf("# File created by %s\n", progname); printf("\nvoid light light\n"); - printf("0\n0\n3 1 1 1\n"); + printf("0\n0\n3 1e6 1e6 1e6\n"); printf("\nvoid plastic fill\n"); printf("0\n0\n5 .5 .5 .5 0 0\n"); } @@ -277,15 +279,15 @@ light() static int nlights = 0; register int c; float x, y, z; - - if (scanf("%f %f %f", &x, &y, &z) != 3) { - fprintf(stderr, "%s: light source syntax error\n", progname); - exit(1); + + if (scanf("%f %f %f",&x, &y, &z) != 3) { + fprintf(stderr, "%s: light source syntax error\n", progname); + exit(1); } while ((c = getchar()) != EOF && c != '\n') ; - printf("\nlight sphere l%d ", ++nlights); - printf("0\n0\n4 %g %g %g 1\n", x, y, z); + printf("\nlight sphere l%d \n", ++nlights); + printf("0\n0\n4 %g %g %g .01\n", x, y, z); } @@ -304,10 +306,20 @@ Format: background() { float r, g, b; - - if (scanf("%f %f %f", &r, &g, &b) != 3) { + char colname[50]; + double cvec[3]; + + if (scanf("%s", colname) != 1) { + fprintf(stderr,"%s: background syntax error\n",progname);exit(1); + } + if(LookupColorByName(colname,cvec)==1){ + r=cvec[0];g=cvec[1];b=cvec[2]; + }else{ + if(sscanf(colname,"%f",&r)!=1 || + scanf("%f %f", &g, &b) !=2) { fprintf(stderr, "%s: background syntax error\n", progname); exit(1); + } } printf("\nvoid glow backg_color\n"); printf("0\n0\n4 %g %g %g 0\n", r, g, b); @@ -341,24 +353,39 @@ Format: fill() { float r, g, b, d, s, p, t, n; - - if (scanf("%f %f %f %f %f %f %f %f", &r, &g, &b, - &d, &s, &p, &t, &n) != 8) { + char colname[50]; + double cvec[3]; + + if (scanf("%s", colname) != 1) { + fprintf(stderr,"%s: fill syntax error\n",progname);exit(1); + } + if(LookupColorByName(colname,cvec)==1){ + r=cvec[0];g=cvec[1];b=cvec[2]; + }else{ + if(sscanf(colname,"%f",&r)!=1 || + scanf("%f %f", &g, &b) !=2) { + fprintf(stderr, "%s: fill syntax error\n", progname); + exit(1); + } + } + if (scanf("%f %f %f %f %f", &d, &s, &p, &t, &n) != 5) { fprintf(stderr, "%s: fill material syntax error\n", progname); exit(1); } - d /= 1.-s-t; - r *= d; - g *= d; - b *= d; if (p > 1.) p = 1./p; if (t > .001) { /* has transmission */ - printf("\nvoid trans fill\n"); - printf("0\n0\n7 %g %g %g %g 0 %g 1\n", r, g, b, s, t); + if (n > 1.1) { /* has index of refraction */ + printf("\nvoid dielectric fill\n"); + printf("0\n0\n5 %g %g %g %g 0\n", r, g, b, n); + } else { /* transmits w/o refraction */ + printf("\nvoid trans fill\n"); + printf("0\n0\n7 %g %g %g %g 0 %g 1\n", + r*d, g*d, b*d, s, t); + } } else { /* no transmission */ printf("\nvoid plastic fill\n"); - printf("0\n0\n5 %g %g %g %g %g\n", r, g, b, s, p); + printf("0\n0\n5 %g %g %g %g %g\n", r*d, g*d, b*d, s, p); } } @@ -405,13 +432,13 @@ cone() r1 = -r1; } if (r0-r1 < .001 && r1-r0 < .001) { /* cylinder */ - printf("\nfill %s c%d ", invert?"tube":"cylinder", ++ncs); + printf("\nfill %s c%d \n", invert?"tube":"cylinder", ++ncs); printf("0\n0\n7\n"); printf("\t%g\t%g\t%g\n", x0, y0, z0); printf("\t%g\t%g\t%g\n", x1, y1, z1); printf("\t%g\n", r0); } else { /* cone */ - printf("\nfill %s c%d ", invert?"cup":"cone", ++ncs); + printf("\nfill %s c%d \n", invert?"cup":"cone", ++ncs); printf("0\n0\n8\n"); printf("\t%g\t%g\t%g\n", x0, y0, z0); printf("\t%g\t%g\t%g\n", x1, y1, z1); @@ -443,10 +470,10 @@ sphere() exit(1); } if (r < 0.) { - printf("\nfill bubble s%d ", ++nspheres); + printf("\nfill bubble s%d \n", ++nspheres); printf("0\n0\n4 %g %g %g %g\n", x, y, z, -r); } else { - printf("\nfill sphere s%d ", ++nspheres); + printf("\nfill sphere s%d \n", ++nspheres); printf("0\n0\n4 %g %g %g %g\n", x, y, z, r); } } @@ -502,7 +529,7 @@ poly() } if (scanf("%d", &nverts) != 1) goto fmterr; - printf("\nfill polygon p%d ", ++npolys); + printf("\nfill polygon p%d \n", ++npolys); printf("0\n0\n%d\n", 3*nverts); while (nverts-- > 0) { if (scanf("%f %f %f", &x, &y, &z) != 3) @@ -515,4 +542,828 @@ poly() fmterr: fprintf(stderr, "%s: polygon or patch syntax error\n", progname); exit(1); +} +/*********************************************************************** + * $Author: greg $ (Mark VandeWettering, drizzle.cs.uoregon.edu) + * $Revision: 2.5 $ + * $Date: 2003/02/22 02:07:23 $ + * $Log: nff2rad.c,v $ + * Revision 2.5 2003/02/22 02:07:23 greg + * Changes and check-in for 3.5 release + * Includes new source files and modifications not recorded for many years + * See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release + * + * Revision 1.2 88/09/12 12:53:47 markv + * Fixed problem in LookupColorbyName, had return ; and return(0). + * [ Thank you lint! ] + * + * Revision 1.1 88/09/11 11:00:37 markv + * Initial revision + * + * Peter Averkamp 92/02/01 + * added complete X11R5 rgb.txt-table, hacked standalone version + * for nff2rad + * + ***********************************************************************/ + +typedef double Flt ; +typedef Flt Vec[3] ; +typedef Vec Point ; +typedef Vec Color ; + +#define VecCopy(a,b) (b)[0]=(a)[0];(b)[1]=(a)[1];(b)[2]=(a)[2]; +#define NCOLORS (738) + +typedef struct t_color_entry { + char * ce_name ; + Vec ce_color ; +} ColorEntry ; + +#define LESS_THAN -1 +#define GREATER_THAN 1 +#define EQUAL_TO 0 + +/* + * Note: These colors must be in sorted order, because we binary search + * for them. + * + * They were swiped from the X-11 distribution. Sorry.... + */ + +ColorEntry Colors[] = { +{"AliceBlue", {0.941176 , 0.972549 , 1.000000 }}, +{"AntiqueWhite", {0.980392 , 0.921569 , 0.843137 }}, +{"AntiqueWhite1", {1.000000 , 0.937255 , 0.858824 }}, +{"AntiqueWhite2", {0.933333 , 0.874510 , 0.800000 }}, +{"AntiqueWhite3", {0.803922 , 0.752941 , 0.690196 }}, +{"AntiqueWhite4", {0.545098 , 0.513725 , 0.470588 }}, +{"BlanchedAlmond", {1.000000 , 0.921569 , 0.803922 }}, +{"BlueViolet", {0.541176 , 0.168627 , 0.886275 }}, +{"CadetBlue", {0.372549 , 0.619608 , 0.627451 }}, +{"CadetBlue1", {0.596078 , 0.960784 , 1.000000 }}, +{"CadetBlue2", {0.556863 , 0.898039 , 0.933333 }}, +{"CadetBlue3", {0.478431 , 0.772549 , 0.803922 }}, +{"CadetBlue4", {0.325490 , 0.525490 , 0.545098 }}, +{"CornflowerBlue", {0.392157 , 0.584314 , 0.929412 }}, +{"DarkGoldenrod", {0.721569 , 0.525490 , 0.043137 }}, +{"DarkGoldenrod1", {1.000000 , 0.725490 , 0.058824 }}, +{"DarkGoldenrod2", {0.933333 , 0.678431 , 0.054902 }}, +{"DarkGoldenrod3", {0.803922 , 0.584314 , 0.047059 }}, +{"DarkGoldenrod4", {0.545098 , 0.396078 , 0.031373 }}, +{"DarkGreen", {0.000000 , 0.392157 , 0.000000 }}, +{"DarkKhaki", {0.741176 , 0.717647 , 0.419608 }}, +{"DarkOliveGreen", {0.333333 , 0.419608 , 0.184314 }}, +{"DarkOliveGreen1", {0.792157 , 1.000000 , 0.439216 }}, +{"DarkOliveGreen2", {0.737255 , 0.933333 , 0.407843 }}, +{"DarkOliveGreen3", {0.635294 , 0.803922 , 0.352941 }}, +{"DarkOliveGreen4", {0.431373 , 0.545098 , 0.239216 }}, +{"DarkOrange", {1.000000 , 0.549020 , 0.000000 }}, +{"DarkOrange1", {1.000000 , 0.498039 , 0.000000 }}, +{"DarkOrange2", {0.933333 , 0.462745 , 0.000000 }}, +{"DarkOrange3", {0.803922 , 0.400000 , 0.000000 }}, +{"DarkOrange4", {0.545098 , 0.270588 , 0.000000 }}, +{"DarkOrchid", {0.600000 , 0.196078 , 0.800000 }}, +{"DarkOrchid1", {0.749020 , 0.243137 , 1.000000 }}, +{"DarkOrchid2", {0.698039 , 0.227451 , 0.933333 }}, +{"DarkOrchid3", {0.603922 , 0.196078 , 0.803922 }}, +{"DarkOrchid4", {0.407843 , 0.133333 , 0.545098 }}, +{"DarkSalmon", {0.913725 , 0.588235 , 0.478431 }}, +{"DarkSeaGreen", {0.560784 , 0.737255 , 0.560784 }}, +{"DarkSeaGreen1", {0.756863 , 1.000000 , 0.756863 }}, +{"DarkSeaGreen2", {0.705882 , 0.933333 , 0.705882 }}, +{"DarkSeaGreen3", {0.607843 , 0.803922 , 0.607843 }}, +{"DarkSeaGreen4", {0.411765 , 0.545098 , 0.411765 }}, +{"DarkSlateBlue", {0.282353 , 0.239216 , 0.545098 }}, +{"DarkSlateGray", {0.184314 , 0.309804 , 0.309804 }}, +{"DarkSlateGray1", {0.592157 , 1.000000 , 1.000000 }}, +{"DarkSlateGray2", {0.552941 , 0.933333 , 0.933333 }}, +{"DarkSlateGray3", {0.474510 , 0.803922 , 0.803922 }}, +{"DarkSlateGray4", {0.321569 , 0.545098 , 0.545098 }}, +{"DarkSlateGrey", {0.184314 , 0.309804 , 0.309804 }}, +{"DarkTurquoise", {0.000000 , 0.807843 , 0.819608 }}, +{"DarkViolet", {0.580392 , 0.000000 , 0.827451 }}, +{"DeepPink", {1.000000 , 0.078431 , 0.576471 }}, +{"DeepPink1", {1.000000 , 0.078431 , 0.576471 }}, +{"DeepPink2", {0.933333 , 0.070588 , 0.537255 }}, +{"DeepPink3", {0.803922 , 0.062745 , 0.462745 }}, +{"DeepPink4", {0.545098 , 0.039216 , 0.313725 }}, +{"DeepSkyBlue", {0.000000 , 0.749020 , 1.000000 }}, +{"DeepSkyBlue1", {0.000000 , 0.749020 , 1.000000 }}, +{"DeepSkyBlue2", {0.000000 , 0.698039 , 0.933333 }}, +{"DeepSkyBlue3", {0.000000 , 0.603922 , 0.803922 }}, +{"DeepSkyBlue4", {0.000000 , 0.407843 , 0.545098 }}, +{"DimGray", {0.411765 , 0.411765 , 0.411765 }}, +{"DimGrey", {0.411765 , 0.411765 , 0.411765 }}, +{"DodgerBlue", {0.117647 , 0.564706 , 1.000000 }}, +{"DodgerBlue1", {0.117647 , 0.564706 , 1.000000 }}, +{"DodgerBlue2", {0.109804 , 0.525490 , 0.933333 }}, +{"DodgerBlue3", {0.094118 , 0.454902 , 0.803922 }}, +{"DodgerBlue4", {0.062745 , 0.305882 , 0.545098 }}, +{"FloralWhite", {1.000000 , 0.980392 , 0.941176 }}, +{"ForestGreen", {0.133333 , 0.545098 , 0.133333 }}, +{"GhostWhite", {0.972549 , 0.972549 , 1.000000 }}, +{"GreenYellow", {0.678431 , 1.000000 , 0.184314 }}, +{"HotPink", {1.000000 , 0.411765 , 0.705882 }}, +{"HotPink1", {1.000000 , 0.431373 , 0.705882 }}, +{"HotPink2", {0.933333 , 0.415686 , 0.654902 }}, +{"HotPink3", {0.803922 , 0.376471 , 0.564706 }}, +{"HotPink4", {0.545098 , 0.227451 , 0.384314 }}, +{"IndianRed", {0.803922 , 0.360784 , 0.360784 }}, +{"IndianRed1", {1.000000 , 0.415686 , 0.415686 }}, +{"IndianRed2", {0.933333 , 0.388235 , 0.388235 }}, +{"IndianRed3", {0.803922 , 0.333333 , 0.333333 }}, +{"IndianRed4", {0.545098 , 0.227451 , 0.227451 }}, +{"LavenderBlush", {1.000000 , 0.941176 , 0.960784 }}, +{"LavenderBlush1", {1.000000 , 0.941176 , 0.960784 }}, +{"LavenderBlush2", {0.933333 , 0.878431 , 0.898039 }}, +{"LavenderBlush3", {0.803922 , 0.756863 , 0.772549 }}, +{"LavenderBlush4", {0.545098 , 0.513725 , 0.525490 }}, +{"LawnGreen", {0.486275 , 0.988235 , 0.000000 }}, +{"LemonChiffon", {1.000000 , 0.980392 , 0.803922 }}, +{"LemonChiffon1", {1.000000 , 0.980392 , 0.803922 }}, +{"LemonChiffon2", {0.933333 , 0.913725 , 0.749020 }}, +{"LemonChiffon3", {0.803922 , 0.788235 , 0.647059 }}, +{"LemonChiffon4", {0.545098 , 0.537255 , 0.439216 }}, +{"LightBlue", {0.678431 , 0.847059 , 0.901961 }}, +{"LightBlue1", {0.749020 , 0.937255 , 1.000000 }}, +{"LightBlue2", {0.698039 , 0.874510 , 0.933333 }}, +{"LightBlue3", {0.603922 , 0.752941 , 0.803922 }}, +{"LightBlue4", {0.407843 , 0.513725 , 0.545098 }}, +{"LightCoral", {0.941176 , 0.501961 , 0.501961 }}, +{"LightCyan", {0.878431 , 1.000000 , 1.000000 }}, +{"LightCyan1", {0.878431 , 1.000000 , 1.000000 }}, +{"LightCyan2", {0.819608 , 0.933333 , 0.933333 }}, +{"LightCyan3", {0.705882 , 0.803922 , 0.803922 }}, +{"LightCyan4", {0.478431 , 0.545098 , 0.545098 }}, +{"LightGoldenrod", {0.933333 , 0.866667 , 0.509804 }}, +{"LightGoldenrod1", {1.000000 , 0.925490 , 0.545098 }}, +{"LightGoldenrod2", {0.933333 , 0.862745 , 0.509804 }}, +{"LightGoldenrod3", {0.803922 , 0.745098 , 0.439216 }}, +{"LightGoldenrod4", {0.545098 , 0.505882 , 0.298039 }}, +{"LightGoldenrodYellow", {0.980392 , 0.980392 , 0.823529 }}, +{"LightGray", {0.827451 , 0.827451 , 0.827451 }}, +{"LightGrey", {0.827451 , 0.827451 , 0.827451 }}, +{"LightPink", {1.000000 , 0.713725 , 0.756863 }}, +{"LightPink1", {1.000000 , 0.682353 , 0.725490 }}, +{"LightPink2", {0.933333 , 0.635294 , 0.678431 }}, +{"LightPink3", {0.803922 , 0.549020 , 0.584314 }}, +{"LightPink4", {0.545098 , 0.372549 , 0.396078 }}, +{"LightSalmon", {1.000000 , 0.627451 , 0.478431 }}, +{"LightSalmon1", {1.000000 , 0.627451 , 0.478431 }}, +{"LightSalmon2", {0.933333 , 0.584314 , 0.447059 }}, +{"LightSalmon3", {0.803922 , 0.505882 , 0.384314 }}, +{"LightSalmon4", {0.545098 , 0.341176 , 0.258824 }}, +{"LightSeaGreen", {0.125490 , 0.698039 , 0.666667 }}, +{"LightSkyBlue", {0.529412 , 0.807843 , 0.980392 }}, +{"LightSkyBlue1", {0.690196 , 0.886275 , 1.000000 }}, +{"LightSkyBlue2", {0.643137 , 0.827451 , 0.933333 }}, +{"LightSkyBlue3", {0.552941 , 0.713725 , 0.803922 }}, +{"LightSkyBlue4", {0.376471 , 0.482353 , 0.545098 }}, +{"LightSlateBlue", {0.517647 , 0.439216 , 1.000000 }}, +{"LightSlateGray", {0.466667 , 0.533333 , 0.600000 }}, +{"LightSlateGrey", {0.466667 , 0.533333 , 0.600000 }}, +{"LightSteelBlue", {0.690196 , 0.768627 , 0.870588 }}, +{"LightSteelBlue1", {0.792157 , 0.882353 , 1.000000 }}, +{"LightSteelBlue2", {0.737255 , 0.823529 , 0.933333 }}, +{"LightSteelBlue3", {0.635294 , 0.709804 , 0.803922 }}, +{"LightSteelBlue4", {0.431373 , 0.482353 , 0.545098 }}, +{"LightYellow", {1.000000 , 1.000000 , 0.878431 }}, +{"LightYellow1", {1.000000 , 1.000000 , 0.878431 }}, +{"LightYellow2", {0.933333 , 0.933333 , 0.819608 }}, +{"LightYellow3", {0.803922 , 0.803922 , 0.705882 }}, +{"LightYellow4", {0.545098 , 0.545098 , 0.478431 }}, +{"LimeGreen", {0.196078 , 0.803922 , 0.196078 }}, +{"MediumAquamarine", {0.400000 , 0.803922 , 0.666667 }}, +{"MediumBlue", {0.000000 , 0.000000 , 0.803922 }}, +{"MediumOrchid", {0.729412 , 0.333333 , 0.827451 }}, +{"MediumOrchid1", {0.878431 , 0.400000 , 1.000000 }}, +{"MediumOrchid2", {0.819608 , 0.372549 , 0.933333 }}, +{"MediumOrchid3", {0.705882 , 0.321569 , 0.803922 }}, +{"MediumOrchid4", {0.478431 , 0.215686 , 0.545098 }}, +{"MediumPurple", {0.576471 , 0.439216 , 0.858824 }}, +{"MediumPurple1", {0.670588 , 0.509804 , 1.000000 }}, +{"MediumPurple2", {0.623529 , 0.474510 , 0.933333 }}, +{"MediumPurple3", {0.537255 , 0.407843 , 0.803922 }}, +{"MediumPurple4", {0.364706 , 0.278431 , 0.545098 }}, +{"MediumSeaGreen", {0.235294 , 0.701961 , 0.443137 }}, +{"MediumSlateBlue", {0.482353 , 0.407843 , 0.933333 }}, +{"MediumSpringGreen", {0.000000 , 0.980392 , 0.603922 }}, +{"MediumTurquoise", {0.282353 , 0.819608 , 0.800000 }}, +{"MediumVioletRed", {0.780392 , 0.082353 , 0.521569 }}, +{"MidnightBlue", {0.098039 , 0.098039 , 0.439216 }}, +{"MintCream", {0.960784 , 1.000000 , 0.980392 }}, +{"MistyRose", {1.000000 , 0.894118 , 0.882353 }}, +{"MistyRose1", {1.000000 , 0.894118 , 0.882353 }}, +{"MistyRose2", {0.933333 , 0.835294 , 0.823529 }}, +{"MistyRose3", {0.803922 , 0.717647 , 0.709804 }}, +{"MistyRose4", {0.545098 , 0.490196 , 0.482353 }}, +{"NavajoWhite", {1.000000 , 0.870588 , 0.678431 }}, +{"NavajoWhite1", {1.000000 , 0.870588 , 0.678431 }}, +{"NavajoWhite2", {0.933333 , 0.811765 , 0.631373 }}, +{"NavajoWhite3", {0.803922 , 0.701961 , 0.545098 }}, +{"NavajoWhite4", {0.545098 , 0.474510 , 0.368627 }}, +{"NavyBlue", {0.000000 , 0.000000 , 0.501961 }}, +{"OldLace", {0.992157 , 0.960784 , 0.901961 }}, +{"OliveDrab", {0.419608 , 0.556863 , 0.137255 }}, +{"OliveDrab1", {0.752941 , 1.000000 , 0.243137 }}, +{"OliveDrab2", {0.701961 , 0.933333 , 0.227451 }}, +{"OliveDrab3", {0.603922 , 0.803922 , 0.196078 }}, +{"OliveDrab4", {0.411765 , 0.545098 , 0.133333 }}, +{"OrangeRed", {1.000000 , 0.270588 , 0.000000 }}, +{"OrangeRed1", {1.000000 , 0.270588 , 0.000000 }}, +{"OrangeRed2", {0.933333 , 0.250980 , 0.000000 }}, +{"OrangeRed3", {0.803922 , 0.215686 , 0.000000 }}, +{"OrangeRed4", {0.545098 , 0.145098 , 0.000000 }}, +{"PaleGoldenrod", {0.933333 , 0.909804 , 0.666667 }}, +{"PaleGreen", {0.596078 , 0.984314 , 0.596078 }}, +{"PaleGreen1", {0.603922 , 1.000000 , 0.603922 }}, +{"PaleGreen2", {0.564706 , 0.933333 , 0.564706 }}, +{"PaleGreen3", {0.486275 , 0.803922 , 0.486275 }}, +{"PaleGreen4", {0.329412 , 0.545098 , 0.329412 }}, +{"PaleTurquoise", {0.686275 , 0.933333 , 0.933333 }}, +{"PaleTurquoise1", {0.733333 , 1.000000 , 1.000000 }}, +{"PaleTurquoise2", {0.682353 , 0.933333 , 0.933333 }}, +{"PaleTurquoise3", {0.588235 , 0.803922 , 0.803922 }}, +{"PaleTurquoise4", {0.400000 , 0.545098 , 0.545098 }}, +{"PaleVioletRed", {0.858824 , 0.439216 , 0.576471 }}, +{"PaleVioletRed1", {1.000000 , 0.509804 , 0.670588 }}, +{"PaleVioletRed2", {0.933333 , 0.474510 , 0.623529 }}, +{"PaleVioletRed3", {0.803922 , 0.407843 , 0.537255 }}, +{"PaleVioletRed4", {0.545098 , 0.278431 , 0.364706 }}, +{"PapayaWhip", {1.000000 , 0.937255 , 0.835294 }}, +{"PeachPuff", {1.000000 , 0.854902 , 0.725490 }}, +{"PeachPuff1", {1.000000 , 0.854902 , 0.725490 }}, +{"PeachPuff2", {0.933333 , 0.796078 , 0.678431 }}, +{"PeachPuff3", {0.803922 , 0.686275 , 0.584314 }}, +{"PeachPuff4", {0.545098 , 0.466667 , 0.396078 }}, +{"PowderBlue", {0.690196 , 0.878431 , 0.901961 }}, +{"RosyBrown", {0.737255 , 0.560784 , 0.560784 }}, +{"RosyBrown1", {1.000000 , 0.756863 , 0.756863 }}, +{"RosyBrown2", {0.933333 , 0.705882 , 0.705882 }}, +{"RosyBrown3", {0.803922 , 0.607843 , 0.607843 }}, +{"RosyBrown4", {0.545098 , 0.411765 , 0.411765 }}, +{"RoyalBlue", {0.254902 , 0.411765 , 0.882353 }}, +{"RoyalBlue1", {0.282353 , 0.462745 , 1.000000 }}, +{"RoyalBlue2", {0.262745 , 0.431373 , 0.933333 }}, +{"RoyalBlue3", {0.227451 , 0.372549 , 0.803922 }}, +{"RoyalBlue4", {0.152941 , 0.250980 , 0.545098 }}, +{"SaddleBrown", {0.545098 , 0.270588 , 0.074510 }}, +{"SandyBrown", {0.956863 , 0.643137 , 0.376471 }}, +{"SeaGreen", {0.180392 , 0.545098 , 0.341176 }}, +{"SeaGreen1", {0.329412 , 1.000000 , 0.623529 }}, +{"SeaGreen2", {0.305882 , 0.933333 , 0.580392 }}, +{"SeaGreen3", {0.262745 , 0.803922 , 0.501961 }}, +{"SeaGreen4", {0.180392 , 0.545098 , 0.341176 }}, +{"SkyBlue", {0.529412 , 0.807843 , 0.921569 }}, +{"SkyBlue1", {0.529412 , 0.807843 , 1.000000 }}, +{"SkyBlue2", {0.494118 , 0.752941 , 0.933333 }}, +{"SkyBlue3", {0.423529 , 0.650980 , 0.803922 }}, +{"SkyBlue4", {0.290196 , 0.439216 , 0.545098 }}, +{"SlateBlue", {0.415686 , 0.352941 , 0.803922 }}, +{"SlateBlue1", {0.513725 , 0.435294 , 1.000000 }}, +{"SlateBlue2", {0.478431 , 0.403922 , 0.933333 }}, +{"SlateBlue3", {0.411765 , 0.349020 , 0.803922 }}, +{"SlateBlue4", {0.278431 , 0.235294 , 0.545098 }}, +{"SlateGray", {0.439216 , 0.501961 , 0.564706 }}, +{"SlateGray1", {0.776471 , 0.886275 , 1.000000 }}, +{"SlateGray2", {0.725490 , 0.827451 , 0.933333 }}, +{"SlateGray3", {0.623529 , 0.713725 , 0.803922 }}, +{"SlateGray4", {0.423529 , 0.482353 , 0.545098 }}, +{"SlateGrey", {0.439216 , 0.501961 , 0.564706 }}, +{"SpringGreen", {0.000000 , 1.000000 , 0.498039 }}, +{"SpringGreen1", {0.000000 , 1.000000 , 0.498039 }}, +{"SpringGreen2", {0.000000 , 0.933333 , 0.462745 }}, +{"SpringGreen3", {0.000000 , 0.803922 , 0.400000 }}, +{"SpringGreen4", {0.000000 , 0.545098 , 0.270588 }}, +{"SteelBlue", {0.274510 , 0.509804 , 0.705882 }}, +{"SteelBlue1", {0.388235 , 0.721569 , 1.000000 }}, +{"SteelBlue2", {0.360784 , 0.674510 , 0.933333 }}, +{"SteelBlue3", {0.309804 , 0.580392 , 0.803922 }}, +{"SteelBlue4", {0.211765 , 0.392157 , 0.545098 }}, +{"VioletRed", {0.815686 , 0.125490 , 0.564706 }}, +{"VioletRed1", {1.000000 , 0.243137 , 0.588235 }}, +{"VioletRed2", {0.933333 , 0.227451 , 0.549020 }}, +{"VioletRed3", {0.803922 , 0.196078 , 0.470588 }}, +{"VioletRed4", {0.545098 , 0.133333 , 0.321569 }}, +{"WhiteSmoke", {0.960784 , 0.960784 , 0.960784 }}, +{"YellowGreen", {0.603922 , 0.803922 , 0.196078 }}, +{"alice_blue", {0.941176 , 0.972549 , 1.000000 }}, +{"antique_white", {0.980392 , 0.921569 , 0.843137 }}, +{"aquamarine", {0.498039 , 1.000000 , 0.831373 }}, +{"aquamarine1", {0.498039 , 1.000000 , 0.831373 }}, +{"aquamarine2", {0.462745 , 0.933333 , 0.776471 }}, +{"aquamarine3", {0.400000 , 0.803922 , 0.666667 }}, +{"aquamarine4", {0.270588 , 0.545098 , 0.454902 }}, +{"azure", {0.941176 , 1.000000 , 1.000000 }}, +{"azure1", {0.941176 , 1.000000 , 1.000000 }}, +{"azure2", {0.878431 , 0.933333 , 0.933333 }}, +{"azure3", {0.756863 , 0.803922 , 0.803922 }}, +{"azure4", {0.513725 , 0.545098 , 0.545098 }}, +{"beige", {0.960784 , 0.960784 , 0.862745 }}, +{"bisque", {1.000000 , 0.894118 , 0.768627 }}, +{"bisque1", {1.000000 , 0.894118 , 0.768627 }}, +{"bisque2", {0.933333 , 0.835294 , 0.717647 }}, +{"bisque3", {0.803922 , 0.717647 , 0.619608 }}, +{"bisque4", {0.545098 , 0.490196 , 0.419608 }}, +{"black", {0.000000 , 0.000000 , 0.000000 }}, +{"blanched_almond", {1.000000 , 0.921569 , 0.803922 }}, +{"blue", {0.000000 , 0.000000 , 1.000000 }}, +{"blue1", {0.000000 , 0.000000 , 1.000000 }}, +{"blue2", {0.000000 , 0.000000 , 0.933333 }}, +{"blue3", {0.000000 , 0.000000 , 0.803922 }}, +{"blue4", {0.000000 , 0.000000 , 0.545098 }}, +{"blue_violet", {0.541176 , 0.168627 , 0.886275 }}, +{"brown", {0.647059 , 0.164706 , 0.164706 }}, +{"brown1", {1.000000 , 0.250980 , 0.250980 }}, +{"brown2", {0.933333 , 0.231373 , 0.231373 }}, +{"brown3", {0.803922 , 0.200000 , 0.200000 }}, +{"brown4", {0.545098 , 0.137255 , 0.137255 }}, +{"burlywood", {0.870588 , 0.721569 , 0.529412 }}, +{"burlywood1", {1.000000 , 0.827451 , 0.607843 }}, +{"burlywood2", {0.933333 , 0.772549 , 0.568627 }}, +{"burlywood3", {0.803922 , 0.666667 , 0.490196 }}, +{"burlywood4", {0.545098 , 0.450980 , 0.333333 }}, +{"cadet_blue", {0.372549 , 0.619608 , 0.627451 }}, +{"chartreuse", {0.498039 , 1.000000 , 0.000000 }}, +{"chartreuse1", {0.498039 , 1.000000 , 0.000000 }}, +{"chartreuse2", {0.462745 , 0.933333 , 0.000000 }}, +{"chartreuse3", {0.400000 , 0.803922 , 0.000000 }}, +{"chartreuse4", {0.270588 , 0.545098 , 0.000000 }}, +{"chocolate", {0.823529 , 0.411765 , 0.117647 }}, +{"chocolate1", {1.000000 , 0.498039 , 0.141176 }}, +{"chocolate2", {0.933333 , 0.462745 , 0.129412 }}, +{"chocolate3", {0.803922 , 0.400000 , 0.113725 }}, +{"chocolate4", {0.545098 , 0.270588 , 0.074510 }}, +{"coral", {1.000000 , 0.498039 , 0.313725 }}, +{"coral1", {1.000000 , 0.447059 , 0.337255 }}, +{"coral2", {0.933333 , 0.415686 , 0.313725 }}, +{"coral3", {0.803922 , 0.356863 , 0.270588 }}, +{"coral4", {0.545098 , 0.243137 , 0.184314 }}, +{"cornflower_blue", {0.392157 , 0.584314 , 0.929412 }}, +{"cornsilk", {1.000000 , 0.972549 , 0.862745 }}, +{"cornsilk1", {1.000000 , 0.972549 , 0.862745 }}, +{"cornsilk2", {0.933333 , 0.909804 , 0.803922 }}, +{"cornsilk3", {0.803922 , 0.784314 , 0.694118 }}, +{"cornsilk4", {0.545098 , 0.533333 , 0.470588 }}, +{"cyan", {0.000000 , 1.000000 , 1.000000 }}, +{"cyan1", {0.000000 , 1.000000 , 1.000000 }}, +{"cyan2", {0.000000 , 0.933333 , 0.933333 }}, +{"cyan3", {0.000000 , 0.803922 , 0.803922 }}, +{"cyan4", {0.000000 , 0.545098 , 0.545098 }}, +{"dark_goldenrod", {0.721569 , 0.525490 , 0.043137 }}, +{"dark_green", {0.000000 , 0.392157 , 0.000000 }}, +{"dark_khaki", {0.741176 , 0.717647 , 0.419608 }}, +{"dark_olive_green", {0.333333 , 0.419608 , 0.184314 }}, +{"dark_orange", {1.000000 , 0.549020 , 0.000000 }}, +{"dark_orchid", {0.600000 , 0.196078 , 0.800000 }}, +{"dark_salmon", {0.913725 , 0.588235 , 0.478431 }}, +{"dark_sea_green", {0.560784 , 0.737255 , 0.560784 }}, +{"dark_slate_blue", {0.282353 , 0.239216 , 0.545098 }}, +{"dark_slate_gray", {0.184314 , 0.309804 , 0.309804 }}, +{"dark_slate_grey", {0.184314 , 0.309804 , 0.309804 }}, +{"dark_turquoise", {0.000000 , 0.807843 , 0.819608 }}, +{"dark_violet", {0.580392 , 0.000000 , 0.827451 }}, +{"deep_pink", {1.000000 , 0.078431 , 0.576471 }}, +{"deep_sky_blue", {0.000000 , 0.749020 , 1.000000 }}, +{"dim_gray", {0.411765 , 0.411765 , 0.411765 }}, +{"dim_grey", {0.411765 , 0.411765 , 0.411765 }}, +{"dodger_blue", {0.117647 , 0.564706 , 1.000000 }}, +{"firebrick", {0.698039 , 0.133333 , 0.133333 }}, +{"firebrick1", {1.000000 , 0.188235 , 0.188235 }}, +{"firebrick2", {0.933333 , 0.172549 , 0.172549 }}, +{"firebrick3", {0.803922 , 0.149020 , 0.149020 }}, +{"firebrick4", {0.545098 , 0.101961 , 0.101961 }}, +{"floral_white", {1.000000 , 0.980392 , 0.941176 }}, +{"forest_green", {0.133333 , 0.545098 , 0.133333 }}, +{"gainsboro", {0.862745 , 0.862745 , 0.862745 }}, +{"ghost_white", {0.972549 , 0.972549 , 1.000000 }}, +{"gold", {1.000000 , 0.843137 , 0.000000 }}, +{"gold1", {1.000000 , 0.843137 , 0.000000 }}, +{"gold2", {0.933333 , 0.788235 , 0.000000 }}, +{"gold3", {0.803922 , 0.678431 , 0.000000 }}, +{"gold4", {0.545098 , 0.458824 , 0.000000 }}, +{"goldenrod", {0.854902 , 0.647059 , 0.125490 }}, +{"goldenrod1", {1.000000 , 0.756863 , 0.145098 }}, +{"goldenrod2", {0.933333 , 0.705882 , 0.133333 }}, +{"goldenrod3", {0.803922 , 0.607843 , 0.113725 }}, +{"goldenrod4", {0.545098 , 0.411765 , 0.078431 }}, +{"gray", {0.752941 , 0.752941 , 0.752941 }}, +{"gray0", {0.000000 , 0.000000 , 0.000000 }}, +{"gray1", {0.011765 , 0.011765 , 0.011765 }}, +{"gray10", {0.101961 , 0.101961 , 0.101961 }}, +{"gray100", {1.000000 , 1.000000 , 1.000000 }}, +{"gray11", {0.109804 , 0.109804 , 0.109804 }}, +{"gray12", {0.121569 , 0.121569 , 0.121569 }}, +{"gray13", {0.129412 , 0.129412 , 0.129412 }}, +{"gray14", {0.141176 , 0.141176 , 0.141176 }}, +{"gray15", {0.149020 , 0.149020 , 0.149020 }}, +{"gray16", {0.160784 , 0.160784 , 0.160784 }}, +{"gray17", {0.168627 , 0.168627 , 0.168627 }}, +{"gray18", {0.180392 , 0.180392 , 0.180392 }}, +{"gray19", {0.188235 , 0.188235 , 0.188235 }}, +{"gray2", {0.019608 , 0.019608 , 0.019608 }}, +{"gray20", {0.200000 , 0.200000 , 0.200000 }}, +{"gray21", {0.211765 , 0.211765 , 0.211765 }}, +{"gray22", {0.219608 , 0.219608 , 0.219608 }}, +{"gray23", {0.231373 , 0.231373 , 0.231373 }}, +{"gray24", {0.239216 , 0.239216 , 0.239216 }}, +{"gray25", {0.250980 , 0.250980 , 0.250980 }}, +{"gray26", {0.258824 , 0.258824 , 0.258824 }}, +{"gray27", {0.270588 , 0.270588 , 0.270588 }}, +{"gray28", {0.278431 , 0.278431 , 0.278431 }}, +{"gray29", {0.290196 , 0.290196 , 0.290196 }}, +{"gray3", {0.031373 , 0.031373 , 0.031373 }}, +{"gray30", {0.301961 , 0.301961 , 0.301961 }}, +{"gray31", {0.309804 , 0.309804 , 0.309804 }}, +{"gray32", {0.321569 , 0.321569 , 0.321569 }}, +{"gray33", {0.329412 , 0.329412 , 0.329412 }}, +{"gray34", {0.341176 , 0.341176 , 0.341176 }}, +{"gray35", {0.349020 , 0.349020 , 0.349020 }}, +{"gray36", {0.360784 , 0.360784 , 0.360784 }}, +{"gray37", {0.368627 , 0.368627 , 0.368627 }}, +{"gray38", {0.380392 , 0.380392 , 0.380392 }}, +{"gray39", {0.388235 , 0.388235 , 0.388235 }}, +{"gray4", {0.039216 , 0.039216 , 0.039216 }}, +{"gray40", {0.400000 , 0.400000 , 0.400000 }}, +{"gray41", {0.411765 , 0.411765 , 0.411765 }}, +{"gray42", {0.419608 , 0.419608 , 0.419608 }}, +{"gray43", {0.431373 , 0.431373 , 0.431373 }}, +{"gray44", {0.439216 , 0.439216 , 0.439216 }}, +{"gray45", {0.450980 , 0.450980 , 0.450980 }}, +{"gray46", {0.458824 , 0.458824 , 0.458824 }}, +{"gray47", {0.470588 , 0.470588 , 0.470588 }}, +{"gray48", {0.478431 , 0.478431 , 0.478431 }}, +{"gray49", {0.490196 , 0.490196 , 0.490196 }}, +{"gray5", {0.050980 , 0.050980 , 0.050980 }}, +{"gray50", {0.498039 , 0.498039 , 0.498039 }}, +{"gray51", {0.509804 , 0.509804 , 0.509804 }}, +{"gray52", {0.521569 , 0.521569 , 0.521569 }}, +{"gray53", {0.529412 , 0.529412 , 0.529412 }}, +{"gray54", {0.541176 , 0.541176 , 0.541176 }}, +{"gray55", {0.549020 , 0.549020 , 0.549020 }}, +{"gray56", {0.560784 , 0.560784 , 0.560784 }}, +{"gray57", {0.568627 , 0.568627 , 0.568627 }}, +{"gray58", {0.580392 , 0.580392 , 0.580392 }}, +{"gray59", {0.588235 , 0.588235 , 0.588235 }}, +{"gray6", {0.058824 , 0.058824 , 0.058824 }}, +{"gray60", {0.600000 , 0.600000 , 0.600000 }}, +{"gray61", {0.611765 , 0.611765 , 0.611765 }}, +{"gray62", {0.619608 , 0.619608 , 0.619608 }}, +{"gray63", {0.631373 , 0.631373 , 0.631373 }}, +{"gray64", {0.639216 , 0.639216 , 0.639216 }}, +{"gray65", {0.650980 , 0.650980 , 0.650980 }}, +{"gray66", {0.658824 , 0.658824 , 0.658824 }}, +{"gray67", {0.670588 , 0.670588 , 0.670588 }}, +{"gray68", {0.678431 , 0.678431 , 0.678431 }}, +{"gray69", {0.690196 , 0.690196 , 0.690196 }}, +{"gray7", {0.070588 , 0.070588 , 0.070588 }}, +{"gray70", {0.701961 , 0.701961 , 0.701961 }}, +{"gray71", {0.709804 , 0.709804 , 0.709804 }}, +{"gray72", {0.721569 , 0.721569 , 0.721569 }}, +{"gray73", {0.729412 , 0.729412 , 0.729412 }}, +{"gray74", {0.741176 , 0.741176 , 0.741176 }}, +{"gray75", {0.749020 , 0.749020 , 0.749020 }}, +{"gray76", {0.760784 , 0.760784 , 0.760784 }}, +{"gray77", {0.768627 , 0.768627 , 0.768627 }}, +{"gray78", {0.780392 , 0.780392 , 0.780392 }}, +{"gray79", {0.788235 , 0.788235 , 0.788235 }}, +{"gray8", {0.078431 , 0.078431 , 0.078431 }}, +{"gray80", {0.800000 , 0.800000 , 0.800000 }}, +{"gray81", {0.811765 , 0.811765 , 0.811765 }}, +{"gray82", {0.819608 , 0.819608 , 0.819608 }}, +{"gray83", {0.831373 , 0.831373 , 0.831373 }}, +{"gray84", {0.839216 , 0.839216 , 0.839216 }}, +{"gray85", {0.850980 , 0.850980 , 0.850980 }}, +{"gray86", {0.858824 , 0.858824 , 0.858824 }}, +{"gray87", {0.870588 , 0.870588 , 0.870588 }}, +{"gray88", {0.878431 , 0.878431 , 0.878431 }}, +{"gray89", {0.890196 , 0.890196 , 0.890196 }}, +{"gray9", {0.090196 , 0.090196 , 0.090196 }}, +{"gray90", {0.898039 , 0.898039 , 0.898039 }}, +{"gray91", {0.909804 , 0.909804 , 0.909804 }}, +{"gray92", {0.921569 , 0.921569 , 0.921569 }}, +{"gray93", {0.929412 , 0.929412 , 0.929412 }}, +{"gray94", {0.941176 , 0.941176 , 0.941176 }}, +{"gray95", {0.949020 , 0.949020 , 0.949020 }}, +{"gray96", {0.960784 , 0.960784 , 0.960784 }}, +{"gray97", {0.968627 , 0.968627 , 0.968627 }}, +{"gray98", {0.980392 , 0.980392 , 0.980392 }}, +{"gray99", {0.988235 , 0.988235 , 0.988235 }}, +{"green", {0.000000 , 1.000000 , 0.000000 }}, +{"green1", {0.000000 , 1.000000 , 0.000000 }}, +{"green2", {0.000000 , 0.933333 , 0.000000 }}, +{"green3", {0.000000 , 0.803922 , 0.000000 }}, +{"green4", {0.000000 , 0.545098 , 0.000000 }}, +{"green_yellow", {0.678431 , 1.000000 , 0.184314 }}, +{"grey", {0.752941 , 0.752941 , 0.752941 }}, +{"grey0", {0.000000 , 0.000000 , 0.000000 }}, +{"grey1", {0.011765 , 0.011765 , 0.011765 }}, +{"grey10", {0.101961 , 0.101961 , 0.101961 }}, +{"grey100", {1.000000 , 1.000000 , 1.000000 }}, +{"grey11", {0.109804 , 0.109804 , 0.109804 }}, +{"grey12", {0.121569 , 0.121569 , 0.121569 }}, +{"grey13", {0.129412 , 0.129412 , 0.129412 }}, +{"grey14", {0.141176 , 0.141176 , 0.141176 }}, +{"grey15", {0.149020 , 0.149020 , 0.149020 }}, +{"grey16", {0.160784 , 0.160784 , 0.160784 }}, +{"grey17", {0.168627 , 0.168627 , 0.168627 }}, +{"grey18", {0.180392 , 0.180392 , 0.180392 }}, +{"grey19", {0.188235 , 0.188235 , 0.188235 }}, +{"grey2", {0.019608 , 0.019608 , 0.019608 }}, +{"grey20", {0.200000 , 0.200000 , 0.200000 }}, +{"grey21", {0.211765 , 0.211765 , 0.211765 }}, +{"grey22", {0.219608 , 0.219608 , 0.219608 }}, +{"grey23", {0.231373 , 0.231373 , 0.231373 }}, +{"grey24", {0.239216 , 0.239216 , 0.239216 }}, +{"grey25", {0.250980 , 0.250980 , 0.250980 }}, +{"grey26", {0.258824 , 0.258824 , 0.258824 }}, +{"grey27", {0.270588 , 0.270588 , 0.270588 }}, +{"grey28", {0.278431 , 0.278431 , 0.278431 }}, +{"grey29", {0.290196 , 0.290196 , 0.290196 }}, +{"grey3", {0.031373 , 0.031373 , 0.031373 }}, +{"grey30", {0.301961 , 0.301961 , 0.301961 }}, +{"grey31", {0.309804 , 0.309804 , 0.309804 }}, +{"grey32", {0.321569 , 0.321569 , 0.321569 }}, +{"grey33", {0.329412 , 0.329412 , 0.329412 }}, +{"grey34", {0.341176 , 0.341176 , 0.341176 }}, +{"grey35", {0.349020 , 0.349020 , 0.349020 }}, +{"grey36", {0.360784 , 0.360784 , 0.360784 }}, +{"grey37", {0.368627 , 0.368627 , 0.368627 }}, +{"grey38", {0.380392 , 0.380392 , 0.380392 }}, +{"grey39", {0.388235 , 0.388235 , 0.388235 }}, +{"grey4", {0.039216 , 0.039216 , 0.039216 }}, +{"grey40", {0.400000 , 0.400000 , 0.400000 }}, +{"grey41", {0.411765 , 0.411765 , 0.411765 }}, +{"grey42", {0.419608 , 0.419608 , 0.419608 }}, +{"grey43", {0.431373 , 0.431373 , 0.431373 }}, +{"grey44", {0.439216 , 0.439216 , 0.439216 }}, +{"grey45", {0.450980 , 0.450980 , 0.450980 }}, +{"grey46", {0.458824 , 0.458824 , 0.458824 }}, +{"grey47", {0.470588 , 0.470588 , 0.470588 }}, +{"grey48", {0.478431 , 0.478431 , 0.478431 }}, +{"grey49", {0.490196 , 0.490196 , 0.490196 }}, +{"grey5", {0.050980 , 0.050980 , 0.050980 }}, +{"grey50", {0.498039 , 0.498039 , 0.498039 }}, +{"grey51", {0.509804 , 0.509804 , 0.509804 }}, +{"grey52", {0.521569 , 0.521569 , 0.521569 }}, +{"grey53", {0.529412 , 0.529412 , 0.529412 }}, +{"grey54", {0.541176 , 0.541176 , 0.541176 }}, +{"grey55", {0.549020 , 0.549020 , 0.549020 }}, +{"grey56", {0.560784 , 0.560784 , 0.560784 }}, +{"grey57", {0.568627 , 0.568627 , 0.568627 }}, +{"grey58", {0.580392 , 0.580392 , 0.580392 }}, +{"grey59", {0.588235 , 0.588235 , 0.588235 }}, +{"grey6", {0.058824 , 0.058824 , 0.058824 }}, +{"grey60", {0.600000 , 0.600000 , 0.600000 }}, +{"grey61", {0.611765 , 0.611765 , 0.611765 }}, +{"grey62", {0.619608 , 0.619608 , 0.619608 }}, +{"grey63", {0.631373 , 0.631373 , 0.631373 }}, +{"grey64", {0.639216 , 0.639216 , 0.639216 }}, +{"grey65", {0.650980 , 0.650980 , 0.650980 }}, +{"grey66", {0.658824 , 0.658824 , 0.658824 }}, +{"grey67", {0.670588 , 0.670588 , 0.670588 }}, +{"grey68", {0.678431 , 0.678431 , 0.678431 }}, +{"grey69", {0.690196 , 0.690196 , 0.690196 }}, +{"grey7", {0.070588 , 0.070588 , 0.070588 }}, +{"grey70", {0.701961 , 0.701961 , 0.701961 }}, +{"grey71", {0.709804 , 0.709804 , 0.709804 }}, +{"grey72", {0.721569 , 0.721569 , 0.721569 }}, +{"grey73", {0.729412 , 0.729412 , 0.729412 }}, +{"grey74", {0.741176 , 0.741176 , 0.741176 }}, +{"grey75", {0.749020 , 0.749020 , 0.749020 }}, +{"grey76", {0.760784 , 0.760784 , 0.760784 }}, +{"grey77", {0.768627 , 0.768627 , 0.768627 }}, +{"grey78", {0.780392 , 0.780392 , 0.780392 }}, +{"grey79", {0.788235 , 0.788235 , 0.788235 }}, +{"grey8", {0.078431 , 0.078431 , 0.078431 }}, +{"grey80", {0.800000 , 0.800000 , 0.800000 }}, +{"grey81", {0.811765 , 0.811765 , 0.811765 }}, +{"grey82", {0.819608 , 0.819608 , 0.819608 }}, +{"grey83", {0.831373 , 0.831373 , 0.831373 }}, +{"grey84", {0.839216 , 0.839216 , 0.839216 }}, +{"grey85", {0.850980 , 0.850980 , 0.850980 }}, +{"grey86", {0.858824 , 0.858824 , 0.858824 }}, +{"grey87", {0.870588 , 0.870588 , 0.870588 }}, +{"grey88", {0.878431 , 0.878431 , 0.878431 }}, +{"grey89", {0.890196 , 0.890196 , 0.890196 }}, +{"grey9", {0.090196 , 0.090196 , 0.090196 }}, +{"grey90", {0.898039 , 0.898039 , 0.898039 }}, +{"grey91", {0.909804 , 0.909804 , 0.909804 }}, +{"grey92", {0.921569 , 0.921569 , 0.921569 }}, +{"grey93", {0.929412 , 0.929412 , 0.929412 }}, +{"grey94", {0.941176 , 0.941176 , 0.941176 }}, +{"grey95", {0.949020 , 0.949020 , 0.949020 }}, +{"grey96", {0.960784 , 0.960784 , 0.960784 }}, +{"grey97", {0.968627 , 0.968627 , 0.968627 }}, +{"grey98", {0.980392 , 0.980392 , 0.980392 }}, +{"grey99", {0.988235 , 0.988235 , 0.988235 }}, +{"honeydew", {0.941176 , 1.000000 , 0.941176 }}, +{"honeydew1", {0.941176 , 1.000000 , 0.941176 }}, +{"honeydew2", {0.878431 , 0.933333 , 0.878431 }}, +{"honeydew3", {0.756863 , 0.803922 , 0.756863 }}, +{"honeydew4", {0.513725 , 0.545098 , 0.513725 }}, +{"hot_pink", {1.000000 , 0.411765 , 0.705882 }}, +{"indian_red", {0.803922 , 0.360784 , 0.360784 }}, +{"ivory", {1.000000 , 1.000000 , 0.941176 }}, +{"ivory1", {1.000000 , 1.000000 , 0.941176 }}, +{"ivory2", {0.933333 , 0.933333 , 0.878431 }}, +{"ivory3", {0.803922 , 0.803922 , 0.756863 }}, +{"ivory4", {0.545098 , 0.545098 , 0.513725 }}, +{"khaki", {0.941176 , 0.901961 , 0.549020 }}, +{"khaki1", {1.000000 , 0.964706 , 0.560784 }}, +{"khaki2", {0.933333 , 0.901961 , 0.521569 }}, +{"khaki3", {0.803922 , 0.776471 , 0.450980 }}, +{"khaki4", {0.545098 , 0.525490 , 0.305882 }}, +{"lavender", {0.901961 , 0.901961 , 0.980392 }}, +{"lavender_blush", {1.000000 , 0.941176 , 0.960784 }}, +{"lawn_green", {0.486275 , 0.988235 , 0.000000 }}, +{"lemon_chiffon", {1.000000 , 0.980392 , 0.803922 }}, +{"light_blue", {0.678431 , 0.847059 , 0.901961 }}, +{"light_coral", {0.941176 , 0.501961 , 0.501961 }}, +{"light_cyan", {0.878431 , 1.000000 , 1.000000 }}, +{"light_goldenrod", {0.933333 , 0.866667 , 0.509804 }}, +{"light_goldenrod_yellow", {0.980392 , 0.980392 , 0.823529 }}, +{"light_gray", {0.827451 , 0.827451 , 0.827451 }}, +{"light_grey", {0.827451 , 0.827451 , 0.827451 }}, +{"light_pink", {1.000000 , 0.713725 , 0.756863 }}, +{"light_salmon", {1.000000 , 0.627451 , 0.478431 }}, +{"light_sea_green", {0.125490 , 0.698039 , 0.666667 }}, +{"light_sky_blue", {0.529412 , 0.807843 , 0.980392 }}, +{"light_slate_blue", {0.517647 , 0.439216 , 1.000000 }}, +{"light_slate_gray", {0.466667 , 0.533333 , 0.600000 }}, +{"light_slate_grey", {0.466667 , 0.533333 , 0.600000 }}, +{"light_steel_blue", {0.690196 , 0.768627 , 0.870588 }}, +{"light_yellow", {1.000000 , 1.000000 , 0.878431 }}, +{"lime_green", {0.196078 , 0.803922 , 0.196078 }}, +{"linen", {0.980392 , 0.941176 , 0.901961 }}, +{"magenta", {1.000000 , 0.000000 , 1.000000 }}, +{"magenta1", {1.000000 , 0.000000 , 1.000000 }}, +{"magenta2", {0.933333 , 0.000000 , 0.933333 }}, +{"magenta3", {0.803922 , 0.000000 , 0.803922 }}, +{"magenta4", {0.545098 , 0.000000 , 0.545098 }}, +{"maroon", {0.690196 , 0.188235 , 0.376471 }}, +{"maroon1", {1.000000 , 0.203922 , 0.701961 }}, +{"maroon2", {0.933333 , 0.188235 , 0.654902 }}, +{"maroon3", {0.803922 , 0.160784 , 0.564706 }}, +{"maroon4", {0.545098 , 0.109804 , 0.384314 }}, +{"medium_aquamarine", {0.400000 , 0.803922 , 0.666667 }}, +{"medium_blue", {0.000000 , 0.000000 , 0.803922 }}, +{"medium_orchid", {0.729412 , 0.333333 , 0.827451 }}, +{"medium_purple", {0.576471 , 0.439216 , 0.858824 }}, +{"medium_sea_green", {0.235294 , 0.701961 , 0.443137 }}, +{"medium_slate_blue", {0.482353 , 0.407843 , 0.933333 }}, +{"medium_spring_green", {0.000000 , 0.980392 , 0.603922 }}, +{"medium_turquoise", {0.282353 , 0.819608 , 0.800000 }}, +{"medium_violet_red", {0.780392 , 0.082353 , 0.521569 }}, +{"midnight_blue", {0.098039 , 0.098039 , 0.439216 }}, +{"mint_cream", {0.960784 , 1.000000 , 0.980392 }}, +{"misty_rose", {1.000000 , 0.894118 , 0.882353 }}, +{"moccasin", {1.000000 , 0.894118 , 0.709804 }}, +{"navajo_white", {1.000000 , 0.870588 , 0.678431 }}, +{"navy", {0.000000 , 0.000000 , 0.501961 }}, +{"navy_blue", {0.000000 , 0.000000 , 0.501961 }}, +{"old_lace", {0.992157 , 0.960784 , 0.901961 }}, +{"olive_drab", {0.419608 , 0.556863 , 0.137255 }}, +{"orange", {1.000000 , 0.647059 , 0.000000 }}, +{"orange1", {1.000000 , 0.647059 , 0.000000 }}, +{"orange2", {0.933333 , 0.603922 , 0.000000 }}, +{"orange3", {0.803922 , 0.521569 , 0.000000 }}, +{"orange4", {0.545098 , 0.352941 , 0.000000 }}, +{"orange_red", {1.000000 , 0.270588 , 0.000000 }}, +{"orchid", {0.854902 , 0.439216 , 0.839216 }}, +{"orchid1", {1.000000 , 0.513725 , 0.980392 }}, +{"orchid2", {0.933333 , 0.478431 , 0.913725 }}, +{"orchid3", {0.803922 , 0.411765 , 0.788235 }}, +{"orchid4", {0.545098 , 0.278431 , 0.537255 }}, +{"pale_goldenrod", {0.933333 , 0.909804 , 0.666667 }}, +{"pale_green", {0.596078 , 0.984314 , 0.596078 }}, +{"pale_turquoise", {0.686275 , 0.933333 , 0.933333 }}, +{"pale_violet_red", {0.858824 , 0.439216 , 0.576471 }}, +{"papaya_whip", {1.000000 , 0.937255 , 0.835294 }}, +{"peach_puff", {1.000000 , 0.854902 , 0.725490 }}, +{"peru", {0.803922 , 0.521569 , 0.247059 }}, +{"pink", {1.000000 , 0.752941 , 0.796078 }}, +{"pink1", {1.000000 , 0.709804 , 0.772549 }}, +{"pink2", {0.933333 , 0.662745 , 0.721569 }}, +{"pink3", {0.803922 , 0.568627 , 0.619608 }}, +{"pink4", {0.545098 , 0.388235 , 0.423529 }}, +{"plum", {0.866667 , 0.627451 , 0.866667 }}, +{"plum1", {1.000000 , 0.733333 , 1.000000 }}, +{"plum2", {0.933333 , 0.682353 , 0.933333 }}, +{"plum3", {0.803922 , 0.588235 , 0.803922 }}, +{"plum4", {0.545098 , 0.400000 , 0.545098 }}, +{"powder_blue", {0.690196 , 0.878431 , 0.901961 }}, +{"purple", {0.627451 , 0.125490 , 0.941176 }}, +{"purple1", {0.607843 , 0.188235 , 1.000000 }}, +{"purple2", {0.568627 , 0.172549 , 0.933333 }}, +{"purple3", {0.490196 , 0.149020 , 0.803922 }}, +{"purple4", {0.333333 , 0.101961 , 0.545098 }}, +{"red", {1.000000 , 0.000000 , 0.000000 }}, +{"red1", {1.000000 , 0.000000 , 0.000000 }}, +{"red2", {0.933333 , 0.000000 , 0.000000 }}, +{"red3", {0.803922 , 0.000000 , 0.000000 }}, +{"red4", {0.545098 , 0.000000 , 0.000000 }}, +{"rosy_brown", {0.737255 , 0.560784 , 0.560784 }}, +{"royal_blue", {0.254902 , 0.411765 , 0.882353 }}, +{"saddle_brown", {0.545098 , 0.270588 , 0.074510 }}, +{"salmon", {0.980392 , 0.501961 , 0.447059 }}, +{"salmon1", {1.000000 , 0.549020 , 0.411765 }}, +{"salmon2", {0.933333 , 0.509804 , 0.384314 }}, +{"salmon3", {0.803922 , 0.439216 , 0.329412 }}, +{"salmon4", {0.545098 , 0.298039 , 0.223529 }}, +{"sandy_brown", {0.956863 , 0.643137 , 0.376471 }}, +{"sea_green", {0.180392 , 0.545098 , 0.341176 }}, +{"seashell", {1.000000 , 0.960784 , 0.933333 }}, +{"seashell1", {1.000000 , 0.960784 , 0.933333 }}, +{"seashell2", {0.933333 , 0.898039 , 0.870588 }}, +{"seashell3", {0.803922 , 0.772549 , 0.749020 }}, +{"seashell4", {0.545098 , 0.525490 , 0.509804 }}, +{"sienna", {0.627451 , 0.321569 , 0.176471 }}, +{"sienna1", {1.000000 , 0.509804 , 0.278431 }}, +{"sienna2", {0.933333 , 0.474510 , 0.258824 }}, +{"sienna3", {0.803922 , 0.407843 , 0.223529 }}, +{"sienna4", {0.545098 , 0.278431 , 0.149020 }}, +{"sky_blue", {0.529412 , 0.807843 , 0.921569 }}, +{"slate_blue", {0.415686 , 0.352941 , 0.803922 }}, +{"slate_gray", {0.439216 , 0.501961 , 0.564706 }}, +{"slate_grey", {0.439216 , 0.501961 , 0.564706 }}, +{"snow", {1.000000 , 0.980392 , 0.980392 }}, +{"snow1", {1.000000 , 0.980392 , 0.980392 }}, +{"snow2", {0.933333 , 0.913725 , 0.913725 }}, +{"snow3", {0.803922 , 0.788235 , 0.788235 }}, +{"snow4", {0.545098 , 0.537255 , 0.537255 }}, +{"spring_green", {0.000000 , 1.000000 , 0.498039 }}, +{"steel_blue", {0.274510 , 0.509804 , 0.705882 }}, +{"tan", {0.823529 , 0.705882 , 0.549020 }}, +{"tan1", {1.000000 , 0.647059 , 0.309804 }}, +{"tan2", {0.933333 , 0.603922 , 0.286275 }}, +{"tan3", {0.803922 , 0.521569 , 0.247059 }}, +{"tan4", {0.545098 , 0.352941 , 0.168627 }}, +{"thistle", {0.847059 , 0.749020 , 0.847059 }}, +{"thistle1", {1.000000 , 0.882353 , 1.000000 }}, +{"thistle2", {0.933333 , 0.823529 , 0.933333 }}, +{"thistle3", {0.803922 , 0.709804 , 0.803922 }}, +{"thistle4", {0.545098 , 0.482353 , 0.545098 }}, +{"tomato", {1.000000 , 0.388235 , 0.278431 }}, +{"tomato1", {1.000000 , 0.388235 , 0.278431 }}, +{"tomato2", {0.933333 , 0.360784 , 0.258824 }}, +{"tomato3", {0.803922 , 0.309804 , 0.223529 }}, +{"tomato4", {0.545098 , 0.211765 , 0.149020 }}, +{"turquoise", {0.250980 , 0.878431 , 0.815686 }}, +{"turquoise1", {0.000000 , 0.960784 , 1.000000 }}, +{"turquoise2", {0.000000 , 0.898039 , 0.933333 }}, +{"turquoise3", {0.000000 , 0.772549 , 0.803922 }}, +{"turquoise4", {0.000000 , 0.525490 , 0.545098 }}, +{"violet", {0.933333 , 0.509804 , 0.933333 }}, +{"violet_red", {0.815686 , 0.125490 , 0.564706 }}, +{"wheat", {0.960784 , 0.870588 , 0.701961 }}, +{"wheat1", {1.000000 , 0.905882 , 0.729412 }}, +{"wheat2", {0.933333 , 0.847059 , 0.682353 }}, +{"wheat3", {0.803922 , 0.729412 , 0.588235 }}, +{"wheat4", {0.545098 , 0.494118 , 0.400000 }}, +{"white", {1.000000 , 1.000000 , 1.000000 }}, +{"white_smoke", {0.960784 , 0.960784 , 0.960784 }}, +{"yellow", {1.000000 , 1.000000 , 0.000000 }}, +{"yellow1", {1.000000 , 1.000000 , 0.000000 }}, +{"yellow2", {0.933333 , 0.933333 , 0.000000 }}, +{"yellow3", {0.803922 , 0.803922 , 0.000000 }}, +{"yellow4", {0.545098 , 0.545098 , 0.000000 }}, +{"yellow_green", {0.603922 , 0.803922 , 0.196078} } +} ; + +int +LookupColorByName(name, color) + char * name ; + Vec color ; +{ + int rc ; + rc = BinarySearch(name, 0, NCOLORS - 1 , Colors) ; + if (rc < 0) { + return(0) ; + } + + VecCopy(Colors[rc].ce_color, color) ; + return 1 ; +} + + +int +BinarySearch(name, l, h, array) + char * name ; + int l, h ; + ColorEntry array[] ; +{ + int m, rc ; + if (l > h) + return(-1) ; + + m = (l + h) / 2 ; + + rc = strcmp(name, array[m].ce_name) ; + if (rc == 0) + return m ; + else if (rc < 0) + return BinarySearch(name, l, m-1, array) ; + else + return BinarySearch(name, m + 1, h, array) ; }
