1 |
/* Copyright (c) 1990 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Convert Neutral File Format input to Radiance scene description. |
9 |
10 |
* 12/9/90 Greg Ward |
11 |
12 |
13 |
14 |
15 |
Since Eric Haines wrote such excellent documentation of his |
16 |
Neutral File Format, I am just going to reprint it here with |
17 |
my added comments in braces {}. |
18 |
19 |
Neutral File Format (NFF), by Eric Haines |
20 |
21 |
Draft document #1, 10/3/88 |
22 |
23 |
The NFF (Neutral File Format) is designed as a minimal scene description |
24 |
language. The language was designed in order to test various rendering |
25 |
algorithms and efficiency schemes. It is meant to describe the geometry and |
26 |
basic surface characteristics of objects, the placement of lights, and the |
27 |
viewing frustum for the eye. Some additional information is provided for |
28 |
esthetic reasons (such as the color of the objects, which is not strictly |
29 |
necessary for testing rendering algorithms). |
30 |
31 |
Future enhancements include: circle and torus objects, spline surfaces |
32 |
with trimming curves, directional lights, characteristics for positional |
33 |
lights, CSG descriptions, and probably more by the time you read this. |
34 |
Comments, suggestions, and criticisms are all welcome. |
35 |
36 |
At present the NFF file format is used in conjunction with the SPD (Standard |
37 |
Procedural Database) software, a package designed to create a variety of |
38 |
databases for testing rendering schemes. The SPD package is available |
39 |
from Netlib and via ftp from drizzle.cs.uoregon.edu. For more information |
40 |
about SPD see "A Proposal for Standard Graphics Environments," IEEE Computer |
41 |
Graphics and Applications, vol. 7, no. 11, November 1987, pp. 3-5. |
42 |
43 |
By providing a minimal interface, NFF is meant to act as a simple format to |
44 |
allow the programmer to quickly write filters to move from NFF to the |
45 |
local file format. Presently the following entities are supported: |
46 |
A simple perspective frustum |
47 |
A positional (vs. directional) light source description |
48 |
A background color description |
49 |
A surface properties description |
50 |
Polygon, polygonal patch, cylinder/cone, and sphere descriptions |
51 |
52 |
Files are output as lines of text. For each entity, the first line |
53 |
defines its type. The rest of the first line and possibly other lines |
54 |
contain further information about the entity. Entities include: |
55 |
56 |
"v" - viewing vectors and angles { optionally creates view file } |
57 |
"l" - positional light location { it's there, but bad to use } |
58 |
"b" - background color { ditto } |
59 |
"f" - object material properties { this is flakey } |
60 |
"c" - cone or cylinder primitive |
61 |
"s" - sphere primitive |
62 |
"p" - polygon primitive |
63 |
"pp" - polygonal patch primitive { interpreted same as p for now } |
64 |
65 |
These are explained in depth below: { see conversion routines } |
66 |
67 |
68 |
69 |
#include <stdio.h> |
70 |
71 |
char *viewfile = NULL; /* view parameters file */ |
72 |
73 |
char *progname; |
74 |
75 |
76 |
main(argc, argv) /* convert NFF file to Radiance */ |
77 |
int argc; |
78 |
char *argv[]; |
79 |
80 |
int i; |
81 |
82 |
progname = argv[0]; |
83 |
for (i = 1; i < argc; i++) |
84 |
if (argc-i > 1 && !strcmp(argv[i], "-vf")) |
85 |
viewfile = argv[++i]; |
86 |
else |
87 |
break; |
88 |
if (i-argc > 1) |
89 |
goto userr; |
90 |
if (i-argc == 1 && freopen(argv[i], "r", stdin) == NULL) { |
91 |
perror(argv[i]); |
92 |
exit(1); |
93 |
94 |
init(); |
95 |
nff2rad(); |
96 |
exit(0); |
97 |
userr: |
98 |
fprintf(stderr, "Usage: %s [-vf viewfile] [input]\n", progname); |
99 |
exit(1); |
100 |
101 |
102 |
103 |
init() /* spit out initial definitions */ |
104 |
105 |
printf("# File created by %s\n", progname); |
106 |
printf("\nvoid light light\n"); |
107 |
printf("0\n0\n3 1 1 1\n"); |
108 |
printf("\nvoid plastic fill\n"); |
109 |
printf("0\n0\n5 .5 .5 .5 0 0\n"); |
110 |
111 |
112 |
113 |
nff2rad() /* convert NFF on stdin to Radiance on stdout */ |
114 |
115 |
register int c; |
116 |
117 |
while ((c = getchar()) != EOF) |
118 |
switch (c) { |
119 |
case ' ': /* white space */ |
120 |
case '\t': |
121 |
case '\n': |
122 |
case '\f': |
123 |
case '\r': |
124 |
continue; |
125 |
case '#': /* comment */ |
126 |
comment(); |
127 |
break; |
128 |
case 'v': /* view point */ |
129 |
view(); |
130 |
break; |
131 |
case 'l': /* light source */ |
132 |
light(); |
133 |
break; |
134 |
case 'b': /* background color */ |
135 |
background(); |
136 |
break; |
137 |
case 'f': /* fill material */ |
138 |
fill(); |
139 |
break; |
140 |
case 'c': /* cylinder or cone */ |
141 |
cone(); |
142 |
break; |
143 |
case 's': /* sphere */ |
144 |
sphere(); |
145 |
break; |
146 |
case 'p': /* polygon or patch */ |
147 |
poly(); |
148 |
break; |
149 |
default: /* unknown */ |
150 |
fprintf(stderr, "%c: unknown NFF primitive\n", c); |
151 |
exit(1); |
152 |
153 |
154 |
155 |
156 |
157 |
158 |
Comment. Description: |
159 |
"#" [ string ] |
160 |
161 |
Format: |
162 |
# [ string ] |
163 |
164 |
As soon as a "#" character is detected, the rest of the line is considered |
165 |
a comment. |
166 |
167 |
168 |
169 |
comment() |
170 |
171 |
register int c; |
172 |
173 |
putchar('#'); |
174 |
while ((c = getchar()) != EOF) { |
175 |
putchar(c); |
176 |
if (c == '\n') |
177 |
break; |
178 |
179 |
180 |
181 |
182 |
183 |
184 |
Viewpoint location. Description: |
185 |
"v" |
186 |
"from" Fx Fy Fz |
187 |
"at" Ax Ay Az |
188 |
"up" Ux Uy Uz |
189 |
"angle" angle |
190 |
"hither" hither |
191 |
"resolution" xres yres |
192 |
193 |
Format: |
194 |
195 |
v |
196 |
from %g %g %g |
197 |
at %g %g %g |
198 |
up %g %g %g |
199 |
angle %g |
200 |
hither %g |
201 |
resolution %d %d |
202 |
203 |
The parameters are: |
204 |
205 |
206 |
At: a position to be at the center of the image, in XYZ world |
207 |
coordinates. A.k.a. "lookat". |
208 |
Up: a vector defining which direction is up, as an XYZ vector. |
209 |
Angle: in degrees, defined as from the center of top pixel row to |
210 |
bottom pixel row and left column to right column. |
211 |
Resolution: in pixels, in x and in y. |
212 |
213 |
Note that no assumptions are made about normalizing the data (e.g. the |
214 |
from-at distance does not have to be 1). Also, vectors are not |
215 |
required to be perpendicular to each other. |
216 |
217 |
For all databases some viewing parameters are always the same: |
218 |
Yon is "at infinity." |
219 |
Aspect ratio is 1.0. |
220 |
221 |
A view entity must be defined before any objects are defined (this |
222 |
requirement is so that NFF files can be used by hidden surface machines). |
223 |
224 |
225 |
226 |
view() |
227 |
228 |
static FILE *fp = NULL; |
229 |
float from[3], at[3], up[3], angle; |
230 |
231 |
if (scanf(" from %f %f %f", &from[0], &from[1], &from[2]) != 3) |
232 |
goto fmterr; |
233 |
if (scanf(" at %f %f %f", &at[0], &at[1], &at[2]) != 3) |
234 |
goto fmterr; |
235 |
if (scanf(" up %f %f %f", &up[0], &up[1], &up[2]) != 3) |
236 |
goto fmterr; |
237 |
if (scanf(" angle %f", &angle) != 1) |
238 |
goto fmterr; |
239 |
scanf(" hither %*f"); |
240 |
scanf(" resolution %*d %*d"); |
241 |
if (viewfile != NULL) { |
242 |
if (fp == NULL && (fp = fopen(viewfile, "a")) == NULL) { |
243 |
perror(viewfile); |
244 |
exit(1); |
245 |
246 |
fprintf(fp, |
247 |
"VIEW= -vp %g %g %g -vd %g %g %g -vu %g %g %g -vh %g -vv %g\n", |
248 |
from[0], from[1], from[2], |
249 |
at[0]-from[0], at[1]-from[1], at[2]-from[2], |
250 |
up[0], up[1], up[2], |
251 |
angle, angle); |
252 |
253 |
return; |
254 |
fmterr: |
255 |
fprintf(stderr, "%s: view syntax error\n", progname); |
256 |
exit(1); |
257 |
258 |
259 |
260 |
261 |
262 |
Positional light. A light is defined by XYZ position. Description: |
263 |
"l" X Y Z |
264 |
265 |
Format: |
266 |
l %g %g %g |
267 |
268 |
All light entities must be defined before any objects are defined (this |
269 |
270 |
Lights have a non-zero intensity of no particular value [this definition |
271 |
may change soon, with the addition of an intensity and/or color]. |
272 |
273 |
274 |
275 |
light() |
276 |
277 |
static int nlights = 0; |
278 |
register int c; |
279 |
float x, y, z; |
280 |
281 |
if (scanf("%f %f %f", &x, &y, &z) != 3) { |
282 |
fprintf(stderr, "%s: light source syntax error\n", progname); |
283 |
exit(1); |
284 |
285 |
while ((c = getchar()) != EOF && c != '\n') |
286 |
287 |
printf("\nlight sphere l%d ", ++nlights); |
288 |
printf("0\n0\n4 %g %g %g 1\n", x, y, z); |
289 |
290 |
291 |
292 |
293 |
294 |
Background color. A color is simply RGB with values between 0 and 1: |
295 |
"b" R G B |
296 |
297 |
Format: |
298 |
b %g %g %g |
299 |
300 |
If no background color is set, assume RGB = {0,0,0}. |
301 |
302 |
303 |
304 |
background() |
305 |
306 |
float r, g, b; |
307 |
308 |
if (scanf("%f %f %f", &r, &g, &b) != 3) { |
309 |
fprintf(stderr, "%s: background syntax error\n", progname); |
310 |
exit(1); |
311 |
312 |
printf("\nvoid glow backg_color\n"); |
313 |
printf("0\n0\n4 %g %g %g 0\n", r, g, b); |
314 |
printf("\nbackg_color source background\n"); |
315 |
printf("0\n0\n4 0 0 1 360\n"); |
316 |
317 |
318 |
319 |
320 |
321 |
Fill color and shading parameters. Description: |
322 |
"f" red green blue Kd Ks Shine T index_of_refraction |
323 |
324 |
Format: |
325 |
f %g %g %g %g %g %g %g %g |
326 |
327 |
RGB is in terms of 0.0 to 1.0. |
328 |
329 |
Kd is the diffuse component, Ks the specular, Shine is the Phong cosine |
330 |
power for highlights, T is transmittance (fraction of light passed per |
331 |
unit). Usually, 0 <= Kd <= 1 and 0 <= Ks <= 1, though it is not required |
332 |
that Kd + Ks == 1. Note that transmitting objects ( T > 0 ) are considered |
333 |
to have two sides for algorithms that need these (normally objects have |
334 |
one side). |
335 |
336 |
The fill color is used to color the objects following it until a new color |
337 |
is assigned. |
338 |
339 |
340 |
341 |
fill() |
342 |
343 |
float r, g, b, d, s, p, t, n; |
344 |
345 |
if (scanf("%f %f %f %f %f %f %f %f", &r, &g, &b, |
346 |
&d, &s, &p, &t, &n) != 8) { |
347 |
fprintf(stderr, "%s: fill material syntax error\n", progname); |
348 |
exit(1); |
349 |
350 |
d /= 1.-s-t; |
351 |
r *= d; |
352 |
g *= d; |
353 |
b *= d; |
354 |
if (p > 1.) |
355 |
p = 1./p; |
356 |
if (t > .001) { /* has transmission */ |
357 |
printf("\nvoid trans fill\n"); |
358 |
printf("0\n0\n7 %g %g %g %g %g %g 1\n", r, g, b, s, p, t); |
359 |
} else { /* no transmission */ |
360 |
361 |
printf("0\n0\n5 %g %g %g %g %g\n", r, g, b, s, p); |
362 |
363 |
364 |
365 |
366 |
367 |
368 |
Cylinder or cone. A cylinder is defined as having a radius and an axis |
369 |
defined by two points, which also define the top and bottom edge of the |
370 |
cylinder. A cone is defined similarly, the difference being that the apex |
371 |
and base radii are different. The apex radius is defined as being smaller |
372 |
than the base radius. Note that the surface exists without endcaps. The |
373 |
cone or cylinder description: |
374 |
375 |
"c" |
376 |
base.x base.y base.z base_radius |
377 |
apex.x apex.y apex.z apex_radius |
378 |
379 |
Format: |
380 |
c |
381 |
%g %g %g %g |
382 |
%g %g %g %g |
383 |
384 |
A negative value for both radii means that only the inside of the object is |
385 |
visible (objects are normally considered one sided, with the outside |
386 |
visible). Note that the base and apex cannot be coincident for a cylinder |
387 |
or cone. |
388 |
389 |
390 |
391 |
cone() |
392 |
393 |
static int ncs = 0; |
394 |
int invert; |
395 |
float x0, y0, z0, x1, y1, z1, r0, r1; |
396 |
397 |
if (scanf("%f %f %f %f %f %f %f %f", &x0, &y0, &z0, &r0, |
398 |
&x1, &y1, &z1, &r1) != 8) { |
399 |
fprintf(stderr, "%s: cylinder or cone syntax error\n", |
400 |
progname); |
401 |
exit(1); |
402 |
403 |
if (invert = r0 < 0.) { |
404 |
r0 = -r0; |
405 |
r1 = -r1; |
406 |
407 |
if (r0-r1 < .001 && r1-r0 < .001) { /* cylinder */ |
408 |
printf("\nfill %s c%d ", invert?"tube":"cylinder", ++ncs); |
409 |
printf("0\n0\n7\n"); |
410 |
printf("\t%g\t%g\t%g\n", x0, y0, z0); |
411 |
printf("\t%g\t%g\t%g\n", x1, y1, z1); |
412 |
printf("\t%g\n", r0); |
413 |
} else { /* cone */ |
414 |
printf("\nfill %s c%d ", invert?"cup":"cone", ++ncs); |
415 |
printf("0\n0\n8\n"); |
416 |
417 |
418 |
printf("\t%g\t%g\n", r0, r1); |
419 |
420 |
421 |
422 |
423 |
424 |
425 |
Sphere. A sphere is defined by a radius and center position: |
426 |
"s" center.x center.y center.z radius |
427 |
428 |
Format: |
429 |
s %g %g %g %g |
430 |
431 |
If the radius is negative, then only the sphere's inside is visible |
432 |
(objects are normally considered one sided, with the outside visible). |
433 |
434 |
435 |
436 |
sphere() |
437 |
438 |
static int nspheres = 0; |
439 |
float x, y, z, r; |
440 |
441 |
if (scanf("%f %f %f %f", &x, &y, &z, &r) != 4) { |
442 |
fprintf(stderr, "%s: sphere syntax error\n", progname); |
443 |
exit(1); |
444 |
445 |
if (r < 0.) { |
446 |
printf("\nfill bubble s%d ", ++nspheres); |
447 |
printf("0\n0\n4 %g %g %g %g\n", x, y, z, -r); |
448 |
} else { |
449 |
printf("\nfill sphere s%d ", ++nspheres); |
450 |
printf("0\n0\n4 %g %g %g %g\n", x, y, z, r); |
451 |
452 |
453 |
454 |
455 |
456 |
457 |
Polygon. A polygon is defined by a set of vertices. With these databases, |
458 |
a polygon is defined to have all points coplanar. A polygon has only |
459 |
one side, with the order of the vertices being counterclockwise as you |
460 |
face the polygon (right-handed coordinate system). The first two edges |
461 |
must form a non-zero convex angle, so that the normal and side visibility |
462 |
can be determined. Description: |
463 |
464 |
"p" total_vertices |
465 |
vert1.x vert1.y vert1.z |
466 |
[etc. for total_vertices vertices] |
467 |
468 |
Format: |
469 |
p %d |
470 |
[ %g %g %g ] <-- for total_vertices vertices |
471 |
472 |
473 |
474 |
Polygonal patch. A patch is defined by a set of vertices and their normals. |
475 |
With these databases, a patch is defined to have all points coplanar. |
476 |
A patch has only one side, with the order of the vertices being |
477 |
counterclockwise as you face the patch (right-handed coordinate system). |
478 |
The first two edges must form a non-zero convex angle, so that the normal |
479 |
and side visibility can be determined. Description: |
480 |
481 |
"pp" total_vertices |
482 |
vert1.x vert1.y vert1.z norm1.x norm1.y norm1.z |
483 |
484 |
485 |
Format: |
486 |
pp %d |
487 |
[ %g %g %g %g %g %g ] <-- for total_vertices vertices |
488 |
489 |
490 |
491 |
poly() |
492 |
493 |
static int npolys = 0; |
494 |
int ispatch; |
495 |
int nverts; |
496 |
float x, y, z; |
497 |
498 |
ispatch = getchar(); |
499 |
if (ispatch != 'p') { |
500 |
ungetc(ispatch, stdin); |
501 |
ispatch = 0; |
502 |
503 |
if (scanf("%d", &nverts) != 1) |
504 |
goto fmterr; |
505 |
printf("\nfill polygon p%d ", ++npolys); |
506 |
printf("0\n0\n%d\n", 3*nverts); |
507 |
while (nverts-- > 0) { |
508 |
if (scanf("%f %f %f", &x, &y, &z) != 3) |
509 |
goto fmterr; |
510 |
if (ispatch) |
511 |
scanf("%*f %*f %*f"); |
512 |
printf("\t%g\t%g\t%g\n", x, y, z); |
513 |
514 |
return; |
515 |
fmterr: |
516 |
fprintf(stderr, "%s: polygon or patch syntax error\n", progname); |
517 |
exit(1); |
518 |
