| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* Convert Neutral File Format input to Radiance scene description.
| 6 |
| 7 |
* 12/9/90 Greg Ward
| 8 |
* 02/7/92 Peter Averkamp added X11(MTV)color names &
| 9 |
* fixed some lf's for direct import of MTV
| 10 |
* source files
| 11 |
| 12 |
| 13 |
| 14 |
| 15 |
Since Eric Haines wrote such excellent documentation of his
| 16 |
Neutral File Format, I am just going to reprint it here with
| 17 |
my added comments in braces {}.
| 18 |
| 19 |
Neutral File Format (NFF), by Eric Haines
| 20 |
| 21 |
Draft document #1, 10/3/88
| 22 |
| 23 |
The NFF (Neutral File Format) is designed as a minimal scene description
| 24 |
language. The language was designed in order to test various rendering
| 25 |
algorithms and efficiency schemes. It is meant to describe the geometry and
| 26 |
basic surface characteristics of objects, the placement of lights, and the
| 27 |
viewing frustum for the eye. Some additional information is provided for
| 28 |
esthetic reasons (such as the color of the objects, which is not strictly
| 29 |
necessary for testing rendering algorithms).
| 30 |
| 31 |
Future enhancements include: circle and torus objects, spline surfaces
| 32 |
with trimming curves, directional lights, characteristics for positional
| 33 |
lights, CSG descriptions, and probably more by the time you read this.
| 34 |
Comments, suggestions, and criticisms are all welcome.
| 35 |
| 36 |
At present the NFF file format is used in conjunction with the SPD (Standard
| 37 |
Procedural Database) software, a package designed to create a variety of
| 38 |
databases for testing rendering schemes. The SPD package is available
| 39 |
from Netlib and via ftp from drizzle.cs.uoregon.edu. For more information
| 40 |
about SPD see "A Proposal for Standard Graphics Environments," IEEE Computer
| 41 |
Graphics and Applications, vol. 7, no. 11, November 1987, pp. 3-5.
| 42 |
| 43 |
By providing a minimal interface, NFF is meant to act as a simple format to
| 44 |
allow the programmer to quickly write filters to move from NFF to the
| 45 |
local file format. Presently the following entities are supported:
| 46 |
A simple perspective frustum
| 47 |
A positional (vs. directional) light source description
| 48 |
A background color description
| 49 |
A surface properties description
| 50 |
Polygon, polygonal patch, cylinder/cone, and sphere descriptions
| 51 |
| 52 |
Files are output as lines of text. For each entity, the first line
| 53 |
defines its type. The rest of the first line and possibly other lines
| 54 |
contain further information about the entity. Entities include:
| 55 |
| 56 |
"v" - viewing vectors and angles { optionally creates view file }
| 57 |
"l" - positional light location { it's there, but bad to use }
| 58 |
"b" - background color { ditto }
| 59 |
"f" - object material properties { this is flakey }
| 60 |
"c" - cone or cylinder primitive
| 61 |
"s" - sphere primitive
| 62 |
"p" - polygon primitive
| 63 |
"pp" - polygonal patch primitive { interpreted same as p for now }
| 64 |
| 65 |
These are explained in depth below: { see conversion routines }
| 66 |
| 67 |
| 68 |
| 69 |
#include <stdio.h>
| 70 |
| 71 |
char *viewfile = NULL; /* view parameters file */
| 72 |
| 73 |
char *progname;
| 74 |
| 75 |
| 76 |
main(argc, argv) /* convert NFF file to Radiance */
| 77 |
int argc;
| 78 |
char *argv[];
| 79 |
| 80 |
int i;
| 81 |
| 82 |
progname = argv[0];
| 83 |
for (i = 1; i < argc; i++)
| 84 |
if (argc-i > 1 && !strcmp(argv[i], "-vf"))
| 85 |
viewfile = argv[++i];
| 86 |
else if (!strncmp(argv[i], "-h",2))
| 87 |
goto userr;
| 88 |
else
| 89 |
break;
| 90 |
if (argc-i > 1)
| 91 |
goto userr;
| 92 |
if (argc-i == 1 && freopen(argv[i], "r", stdin) == NULL) {
| 93 |
perror(argv[i]);
| 94 |
exit(1);
| 95 |
| 96 |
init();
| 97 |
nff2rad();
| 98 |
exit(0);
| 99 |
userr:
| 100 |
fprintf(stderr, "Usage: %s [-vf viewfile] [input]\n", progname);
| 101 |
exit(1);
| 102 |
| 103 |
| 104 |
| 105 |
init() /* spit out initial definitions */
| 106 |
| 107 |
printf("# File created by %s\n", progname);
| 108 |
printf("\nvoid light light\n");
| 109 |
printf("0\n0\n3 1e6 1e6 1e6\n");
| 110 |
printf("\nvoid plastic fill\n");
| 111 |
printf("0\n0\n5 .5 .5 .5 0 0\n");
| 112 |
| 113 |
| 114 |
| 115 |
nff2rad() /* convert NFF on stdin to Radiance on stdout */
| 116 |
| 117 |
register int c;
| 118 |
| 119 |
while ((c = getchar()) != EOF)
| 120 |
switch (c) {
| 121 |
case ' ': /* white space */
| 122 |
case '\t':
| 123 |
case '\n':
| 124 |
case '\f':
| 125 |
case '\r':
| 126 |
continue;
| 127 |
case '#': /* comment */
| 128 |
comment();
| 129 |
break;
| 130 |
case 'v': /* view point */
| 131 |
view();
| 132 |
break;
| 133 |
case 'l': /* light source */
| 134 |
light();
| 135 |
break;
| 136 |
case 'b': /* background color */
| 137 |
background();
| 138 |
break;
| 139 |
case 'f': /* fill material */
| 140 |
fill();
| 141 |
break;
| 142 |
case 'c': /* cylinder or cone */
| 143 |
cone();
| 144 |
break;
| 145 |
case 's': /* sphere */
| 146 |
sphere();
| 147 |
break;
| 148 |
case 'p': /* polygon or patch */
| 149 |
poly();
| 150 |
break;
| 151 |
default: /* unknown */
| 152 |
fprintf(stderr, "%c: unknown NFF primitive\n", c);
| 153 |
exit(1);
| 154 |
| 155 |
| 156 |
| 157 |
| 158 |
| 159 |
| 160 |
Comment. Description:
| 161 |
"#" [ string ]
| 162 |
| 163 |
Format:
| 164 |
# [ string ]
| 165 |
| 166 |
As soon as a "#" character is detected, the rest of the line is considered
| 167 |
a comment.
| 168 |
| 169 |
| 170 |
| 171 |
comment()
| 172 |
| 173 |
register int c;
| 174 |
| 175 |
putchar('#');
| 176 |
while ((c = getchar()) != EOF) {
| 177 |
putchar(c);
| 178 |
if (c == '\n')
| 179 |
break;
| 180 |
| 181 |
| 182 |
| 183 |
| 184 |
| 185 |
| 186 |
Viewpoint location. Description:
| 187 |
"v"
| 188 |
"from" Fx Fy Fz
| 189 |
"at" Ax Ay Az
| 190 |
"up" Ux Uy Uz
| 191 |
"angle" angle
| 192 |
"hither" hither
| 193 |
"resolution" xres yres
| 194 |
| 195 |
Format:
| 196 |
| 197 |
v
| 198 |
from %g %g %g
| 199 |
at %g %g %g
| 200 |
up %g %g %g
| 201 |
angle %g
| 202 |
hither %g
| 203 |
resolution %d %d
| 204 |
| 205 |
The parameters are:
| 206 |
| 207 |
| 208 |
At: a position to be at the center of the image, in XYZ world
| 209 |
coordinates. A.k.a. "lookat".
| 210 |
Up: a vector defining which direction is up, as an XYZ vector.
| 211 |
Angle: in degrees, defined as from the center of top pixel row to
| 212 |
bottom pixel row and left column to right column.
| 213 |
Resolution: in pixels, in x and in y.
| 214 |
| 215 |
Note that no assumptions are made about normalizing the data (e.g. the
| 216 |
from-at distance does not have to be 1). Also, vectors are not
| 217 |
required to be perpendicular to each other.
| 218 |
| 219 |
For all databases some viewing parameters are always the same:
| 220 |
Yon is "at infinity."
| 221 |
Aspect ratio is 1.0.
| 222 |
| 223 |
A view entity must be defined before any objects are defined (this
| 224 |
requirement is so that NFF files can be used by hidden surface machines).
| 225 |
| 226 |
| 227 |
| 228 |
view()
| 229 |
| 230 |
static FILE *fp = NULL;
| 231 |
float from[3], at[3], up[3], angle;
| 232 |
| 233 |
if (scanf(" from %f %f %f", &from[0], &from[1], &from[2]) != 3)
| 234 |
goto fmterr;
| 235 |
if (scanf(" at %f %f %f", &at[0], &at[1], &at[2]) != 3)
| 236 |
goto fmterr;
| 237 |
if (scanf(" up %f %f %f", &up[0], &up[1], &up[2]) != 3)
| 238 |
goto fmterr;
| 239 |
if (scanf(" angle %f", &angle) != 1)
| 240 |
goto fmterr;
| 241 |
scanf(" hither %*f");
| 242 |
scanf(" resolution %*d %*d");
| 243 |
if (viewfile != NULL) {
| 244 |
if (fp == NULL && (fp = fopen(viewfile, "a")) == NULL) {
| 245 |
perror(viewfile);
| 246 |
exit(1);
| 247 |
| 248 |
fprintf(fp,
| 249 |
"VIEW= -vp %g %g %g -vd %g %g %g -vu %g %g %g -vh %g -vv %g\n",
| 250 |
from[0], from[1], from[2],
| 251 |
at[0]-from[0], at[1]-from[1], at[2]-from[2],
| 252 |
up[0], up[1], up[2],
| 253 |
angle, angle);
| 254 |
| 255 |
return;
| 256 |
fmterr:
| 257 |
fprintf(stderr, "%s: view syntax error\n", progname);
| 258 |
exit(1);
| 259 |
| 260 |
| 261 |
| 262 |
| 263 |
| 264 |
Positional light. A light is defined by XYZ position. Description:
| 265 |
"l" X Y Z
| 266 |
| 267 |
Format:
| 268 |
l %g %g %g
| 269 |
| 270 |
All light entities must be defined before any objects are defined (this
| 271 |
| 272 |
Lights have a non-zero intensity of no particular value [this definition
| 273 |
may change soon, with the addition of an intensity and/or color].
| 274 |
| 275 |
| 276 |
| 277 |
light()
| 278 |
| 279 |
static int nlights = 0;
| 280 |
register int c;
| 281 |
float x, y, z;
| 282 |
| 283 |
if (scanf("%f %f %f",&x, &y, &z) != 3) {
| 284 |
fprintf(stderr, "%s: light source syntax error\n", progname);
| 285 |
exit(1);
| 286 |
| 287 |
while ((c = getchar()) != EOF && c != '\n')
| 288 |
| 289 |
printf("\nlight sphere l%d \n", ++nlights);
| 290 |
printf("0\n0\n4 %g %g %g .01\n", x, y, z);
| 291 |
| 292 |
| 293 |
| 294 |
| 295 |
| 296 |
Background color. A color is simply RGB with values between 0 and 1:
| 297 |
"b" R G B
| 298 |
| 299 |
Format:
| 300 |
b %g %g %g
| 301 |
| 302 |
If no background color is set, assume RGB = {0,0,0}.
| 303 |
| 304 |
| 305 |
| 306 |
background()
| 307 |
| 308 |
float r, g, b;
| 309 |
char colname[50];
| 310 |
double cvec[3];
| 311 |
| 312 |
if (scanf("%s", colname) != 1) {
| 313 |
fprintf(stderr,"%s: background syntax error\n",progname);exit(1);
| 314 |
| 315 |
if(LookupColorByName(colname,cvec)==1){
| 316 |
r=cvec[0];g=cvec[1];b=cvec[2];
| 317 |
}else{
| 318 |
if(sscanf(colname,"%f",&r)!=1 ||
| 319 |
scanf("%f %f", &g, &b) !=2) {
| 320 |
fprintf(stderr, "%s: background syntax error\n", progname);
| 321 |
exit(1);
| 322 |
| 323 |
| 324 |
printf("\nvoid glow backg_color\n");
| 325 |
printf("0\n0\n4 %g %g %g 0\n", r, g, b);
| 326 |
printf("\nbackg_color source background\n");
| 327 |
printf("0\n0\n4 0 0 1 360\n");
| 328 |
| 329 |
| 330 |
| 331 |
| 332 |
| 333 |
Fill color and shading parameters. Description:
| 334 |
"f" red green blue Kd Ks Shine T index_of_refraction
| 335 |
| 336 |
Format:
| 337 |
f %g %g %g %g %g %g %g %g
| 338 |
| 339 |
RGB is in terms of 0.0 to 1.0.
| 340 |
| 341 |
Kd is the diffuse component, Ks the specular, Shine is the Phong cosine
| 342 |
power for highlights, T is transmittance (fraction of light passed per
| 343 |
unit). Usually, 0 <= Kd <= 1 and 0 <= Ks <= 1, though it is not required
| 344 |
that Kd + Ks == 1. Note that transmitting objects ( T > 0 ) are considered
| 345 |
to have two sides for algorithms that need these (normally objects have
| 346 |
one side).
| 347 |
| 348 |
The fill color is used to color the objects following it until a new color
| 349 |
is assigned.
| 350 |
| 351 |
| 352 |
| 353 |
fill()
| 354 |
| 355 |
float r, g, b, d, s, p, t, n;
| 356 |
char colname[50];
| 357 |
double cvec[3];
| 358 |
| 359 |
| 360 |
fprintf(stderr,"%s: fill syntax error\n",progname);exit(1);
| 361 |
| 362 |
| 363 |
| 364 |
}else{
| 365 |
| 366 |
| 367 |
fprintf(stderr, "%s: fill syntax error\n", progname);
| 368 |
exit(1);
| 369 |
| 370 |
| 371 |
if (scanf("%f %f %f %f %f", &d, &s, &p, &t, &n) != 5) {
| 372 |
fprintf(stderr, "%s: fill material syntax error\n", progname);
| 373 |
exit(1);
| 374 |
| 375 |
if (p > 1.)
| 376 |
p = 1./p;
| 377 |
if (t > .001) { /* has transmission */
| 378 |
if (n > 1.1) { /* has index of refraction */
| 379 |
printf("\nvoid dielectric fill\n");
| 380 |
printf("0\n0\n5 %g %g %g %g 0\n", r, g, b, n);
| 381 |
} else { /* transmits w/o refraction */
| 382 |
printf("\nvoid trans fill\n");
| 383 |
printf("0\n0\n7 %g %g %g %g 0 %g 1\n",
| 384 |
r*d, g*d, b*d, s, t);
| 385 |
| 386 |
} else { /* no transmission */
| 387 |
| 388 |
printf("0\n0\n5 %g %g %g %g %g\n", r*d, g*d, b*d, s, p);
| 389 |
| 390 |
| 391 |
| 392 |
| 393 |
| 394 |
| 395 |
Cylinder or cone. A cylinder is defined as having a radius and an axis
| 396 |
defined by two points, which also define the top and bottom edge of the
| 397 |
cylinder. A cone is defined similarly, the difference being that the apex
| 398 |
and base radii are different. The apex radius is defined as being smaller
| 399 |
than the base radius. Note that the surface exists without endcaps. The
| 400 |
cone or cylinder description:
| 401 |
| 402 |
"c"
| 403 |
base.x base.y base.z base_radius
| 404 |
apex.x apex.y apex.z apex_radius
| 405 |
| 406 |
Format:
| 407 |
c
| 408 |
%g %g %g %g
| 409 |
%g %g %g %g
| 410 |
| 411 |
A negative value for both radii means that only the inside of the object is
| 412 |
visible (objects are normally considered one sided, with the outside
| 413 |
visible). Note that the base and apex cannot be coincident for a cylinder
| 414 |
or cone.
| 415 |
| 416 |
| 417 |
| 418 |
cone()
| 419 |
| 420 |
static int ncs = 0;
| 421 |
int invert;
| 422 |
float x0, y0, z0, x1, y1, z1, r0, r1;
| 423 |
| 424 |
if (scanf("%f %f %f %f %f %f %f %f", &x0, &y0, &z0, &r0,
| 425 |
&x1, &y1, &z1, &r1) != 8) {
| 426 |
fprintf(stderr, "%s: cylinder or cone syntax error\n",
| 427 |
progname);
| 428 |
exit(1);
| 429 |
| 430 |
if (invert = r0 < 0.) {
| 431 |
r0 = -r0;
| 432 |
r1 = -r1;
| 433 |
| 434 |
if (r0-r1 < .001 && r1-r0 < .001) { /* cylinder */
| 435 |
printf("\nfill %s c%d \n", invert?"tube":"cylinder", ++ncs);
| 436 |
printf("0\n0\n7\n");
| 437 |
printf("\t%g\t%g\t%g\n", x0, y0, z0);
| 438 |
printf("\t%g\t%g\t%g\n", x1, y1, z1);
| 439 |
printf("\t%g\n", r0);
| 440 |
} else { /* cone */
| 441 |
printf("\nfill %s c%d \n", invert?"cup":"cone", ++ncs);
| 442 |
printf("0\n0\n8\n");
| 443 |
| 444 |
| 445 |
printf("\t%g\t%g\n", r0, r1);
| 446 |
| 447 |
| 448 |
| 449 |
| 450 |
| 451 |
| 452 |
Sphere. A sphere is defined by a radius and center position:
| 453 |
"s" center.x center.y center.z radius
| 454 |
| 455 |
Format:
| 456 |
s %g %g %g %g
| 457 |
| 458 |
If the radius is negative, then only the sphere's inside is visible
| 459 |
(objects are normally considered one sided, with the outside visible).
| 460 |
| 461 |
| 462 |
| 463 |
sphere()
| 464 |
| 465 |
static int nspheres = 0;
| 466 |
float x, y, z, r;
| 467 |
| 468 |
if (scanf("%f %f %f %f", &x, &y, &z, &r) != 4) {
| 469 |
fprintf(stderr, "%s: sphere syntax error\n", progname);
| 470 |
exit(1);
| 471 |
| 472 |
if (r < 0.) {
| 473 |
printf("\nfill bubble s%d \n", ++nspheres);
| 474 |
printf("0\n0\n4 %g %g %g %g\n", x, y, z, -r);
| 475 |
} else {
| 476 |
printf("\nfill sphere s%d \n", ++nspheres);
| 477 |
printf("0\n0\n4 %g %g %g %g\n", x, y, z, r);
| 478 |
| 479 |
| 480 |
| 481 |
| 482 |
| 483 |
| 484 |
Polygon. A polygon is defined by a set of vertices. With these databases,
| 485 |
a polygon is defined to have all points coplanar. A polygon has only
| 486 |
one side, with the order of the vertices being counterclockwise as you
| 487 |
face the polygon (right-handed coordinate system). The first two edges
| 488 |
must form a non-zero convex angle, so that the normal and side visibility
| 489 |
can be determined. Description:
| 490 |
| 491 |
"p" total_vertices
| 492 |
vert1.x vert1.y vert1.z
| 493 |
[etc. for total_vertices vertices]
| 494 |
| 495 |
Format:
| 496 |
p %d
| 497 |
[ %g %g %g ] <-- for total_vertices vertices
| 498 |
| 499 |
| 500 |
| 501 |
Polygonal patch. A patch is defined by a set of vertices and their normals.
| 502 |
With these databases, a patch is defined to have all points coplanar.
| 503 |
A patch has only one side, with the order of the vertices being
| 504 |
counterclockwise as you face the patch (right-handed coordinate system).
| 505 |
The first two edges must form a non-zero convex angle, so that the normal
| 506 |
and side visibility can be determined. Description:
| 507 |
| 508 |
"pp" total_vertices
| 509 |
vert1.x vert1.y vert1.z norm1.x norm1.y norm1.z
| 510 |
| 511 |
| 512 |
Format:
| 513 |
pp %d
| 514 |
[ %g %g %g %g %g %g ] <-- for total_vertices vertices
| 515 |
| 516 |
| 517 |
| 518 |
poly()
| 519 |
| 520 |
static int npolys = 0;
| 521 |
int ispatch;
| 522 |
int nverts;
| 523 |
float x, y, z;
| 524 |
| 525 |
ispatch = getchar();
| 526 |
if (ispatch != 'p') {
| 527 |
ungetc(ispatch, stdin);
| 528 |
ispatch = 0;
| 529 |
| 530 |
if (scanf("%d", &nverts) != 1)
| 531 |
goto fmterr;
| 532 |
printf("\nfill polygon p%d \n", ++npolys);
| 533 |
printf("0\n0\n%d\n", 3*nverts);
| 534 |
while (nverts-- > 0) {
| 535 |
if (scanf("%f %f %f", &x, &y, &z) != 3)
| 536 |
goto fmterr;
| 537 |
if (ispatch)
| 538 |
scanf("%*f %*f %*f");
| 539 |
printf("\t%g\t%g\t%g\n", x, y, z);
| 540 |
| 541 |
return;
| 542 |
fmterr:
| 543 |
fprintf(stderr, "%s: polygon or patch syntax error\n", progname);
| 544 |
exit(1);
| 545 |
| 546 |
| 547 |
* $Author: markv $ (Mark VandeWettering, drizzle.cs.uoregon.edu)
| 548 |
* $Revision: 1.2 $
| 549 |
* $Date: 88/09/12 12:53:47 $
| 550 |
* $Log: color.c,v $
| 551 |
* Revision 1.2 88/09/12 12:53:47 markv
| 552 |
* Fixed problem in LookupColorbyName, had return ; and return(0).
| 553 |
* [ Thank you lint! ]
| 554 |
| 555 |
* Revision 1.1 88/09/11 11:00:37 markv
| 556 |
* Initial revision
| 557 |
| 558 |
* Peter Averkamp 92/02/01
| 559 |
* added complete X11R5 rgb.txt-table, hacked standalone version
| 560 |
* for nff2rad
| 561 |
| 562 |
| 563 |
| 564 |
typedef double Flt ;
| 565 |
typedef Flt Vec[3] ;
| 566 |
typedef Vec Point ;
| 567 |
typedef Vec Color ;
| 568 |
| 569 |
#define VecCopy(a,b) (b)[0]=(a)[0];(b)[1]=(a)[1];(b)[2]=(a)[2];
| 570 |
#define NCOLORS (738)
| 571 |
| 572 |
typedef struct t_color_entry {
| 573 |
char * ce_name ;
| 574 |
Vec ce_color ;
| 575 |
} ColorEntry ;
| 576 |
| 577 |
#define LESS_THAN -1
| 578 |
#define GREATER_THAN 1
| 579 |
#define EQUAL_TO 0
| 580 |
| 581 |
| 582 |
* Note: These colors must be in sorted order, because we binary search
| 583 |
* for them.
| 584 |
| 585 |
* They were swiped from the X-11 distribution. Sorry....
| 586 |
| 587 |
| 588 |
ColorEntry Colors[] = {
| 589 |
{"AliceBlue", {0.941176 , 0.972549 , 1.000000 }},
| 590 |
{"AntiqueWhite", {0.980392 , 0.921569 , 0.843137 }},
| 591 |
{"AntiqueWhite1", {1.000000 , 0.937255 , 0.858824 }},
| 592 |
{"AntiqueWhite2", {0.933333 , 0.874510 , 0.800000 }},
| 593 |
{"AntiqueWhite3", {0.803922 , 0.752941 , 0.690196 }},
| 594 |
{"AntiqueWhite4", {0.545098 , 0.513725 , 0.470588 }},
| 595 |
{"BlanchedAlmond", {1.000000 , 0.921569 , 0.803922 }},
| 596 |
{"BlueViolet", {0.541176 , 0.168627 , 0.886275 }},
| 597 |
{"CadetBlue", {0.372549 , 0.619608 , 0.627451 }},
| 598 |
{"CadetBlue1", {0.596078 , 0.960784 , 1.000000 }},
| 599 |
{"CadetBlue2", {0.556863 , 0.898039 , 0.933333 }},
| 600 |
{"CadetBlue3", {0.478431 , 0.772549 , 0.803922 }},
| 601 |
{"CadetBlue4", {0.325490 , 0.525490 , 0.545098 }},
| 602 |
{"CornflowerBlue", {0.392157 , 0.584314 , 0.929412 }},
| 603 |
{"DarkGoldenrod", {0.721569 , 0.525490 , 0.043137 }},
| 604 |
{"DarkGoldenrod1", {1.000000 , 0.725490 , 0.058824 }},
| 605 |
{"DarkGoldenrod2", {0.933333 , 0.678431 , 0.054902 }},
| 606 |
{"DarkGoldenrod3", {0.803922 , 0.584314 , 0.047059 }},
| 607 |
{"DarkGoldenrod4", {0.545098 , 0.396078 , 0.031373 }},
| 608 |
{"DarkGreen", {0.000000 , 0.392157 , 0.000000 }},
| 609 |
{"DarkKhaki", {0.741176 , 0.717647 , 0.419608 }},
| 610 |
{"DarkOliveGreen", {0.333333 , 0.419608 , 0.184314 }},
| 611 |
{"DarkOliveGreen1", {0.792157 , 1.000000 , 0.439216 }},
| 612 |
{"DarkOliveGreen2", {0.737255 , 0.933333 , 0.407843 }},
| 613 |
{"DarkOliveGreen3", {0.635294 , 0.803922 , 0.352941 }},
| 614 |
{"DarkOliveGreen4", {0.431373 , 0.545098 , 0.239216 }},
| 615 |
{"DarkOrange", {1.000000 , 0.549020 , 0.000000 }},
| 616 |
{"DarkOrange1", {1.000000 , 0.498039 , 0.000000 }},
| 617 |
{"DarkOrange2", {0.933333 , 0.462745 , 0.000000 }},
| 618 |
{"DarkOrange3", {0.803922 , 0.400000 , 0.000000 }},
| 619 |
{"DarkOrange4", {0.545098 , 0.270588 , 0.000000 }},
| 620 |
{"DarkOrchid", {0.600000 , 0.196078 , 0.800000 }},
| 621 |
{"DarkOrchid1", {0.749020 , 0.243137 , 1.000000 }},
| 622 |
{"DarkOrchid2", {0.698039 , 0.227451 , 0.933333 }},
| 623 |
{"DarkOrchid3", {0.603922 , 0.196078 , 0.803922 }},
| 624 |
{"DarkOrchid4", {0.407843 , 0.133333 , 0.545098 }},
| 625 |
{"DarkSalmon", {0.913725 , 0.588235 , 0.478431 }},
| 626 |
{"DarkSeaGreen", {0.560784 , 0.737255 , 0.560784 }},
| 627 |
{"DarkSeaGreen1", {0.756863 , 1.000000 , 0.756863 }},
| 628 |
{"DarkSeaGreen2", {0.705882 , 0.933333 , 0.705882 }},
| 629 |
{"DarkSeaGreen3", {0.607843 , 0.803922 , 0.607843 }},
| 630 |
{"DarkSeaGreen4", {0.411765 , 0.545098 , 0.411765 }},
| 631 |
{"DarkSlateBlue", {0.282353 , 0.239216 , 0.545098 }},
| 632 |
{"DarkSlateGray", {0.184314 , 0.309804 , 0.309804 }},
| 633 |
{"DarkSlateGray1", {0.592157 , 1.000000 , 1.000000 }},
| 634 |
{"DarkSlateGray2", {0.552941 , 0.933333 , 0.933333 }},
| 635 |
{"DarkSlateGray3", {0.474510 , 0.803922 , 0.803922 }},
| 636 |
{"DarkSlateGray4", {0.321569 , 0.545098 , 0.545098 }},
| 637 |
{"DarkSlateGrey", {0.184314 , 0.309804 , 0.309804 }},
| 638 |
{"DarkTurquoise", {0.000000 , 0.807843 , 0.819608 }},
| 639 |
{"DarkViolet", {0.580392 , 0.000000 , 0.827451 }},
| 640 |
{"DeepPink", {1.000000 , 0.078431 , 0.576471 }},
| 641 |
{"DeepPink1", {1.000000 , 0.078431 , 0.576471 }},
| 642 |
{"DeepPink2", {0.933333 , 0.070588 , 0.537255 }},
| 643 |
{"DeepPink3", {0.803922 , 0.062745 , 0.462745 }},
| 644 |
{"DeepPink4", {0.545098 , 0.039216 , 0.313725 }},
| 645 |
{"DeepSkyBlue", {0.000000 , 0.749020 , 1.000000 }},
| 646 |
{"DeepSkyBlue1", {0.000000 , 0.749020 , 1.000000 }},
| 647 |
{"DeepSkyBlue2", {0.000000 , 0.698039 , 0.933333 }},
| 648 |
{"DeepSkyBlue3", {0.000000 , 0.603922 , 0.803922 }},
| 649 |
{"DeepSkyBlue4", {0.000000 , 0.407843 , 0.545098 }},
| 650 |
{"DimGray", {0.411765 , 0.411765 , 0.411765 }},
| 651 |
{"DimGrey", {0.411765 , 0.411765 , 0.411765 }},
| 652 |
{"DodgerBlue", {0.117647 , 0.564706 , 1.000000 }},
| 653 |
{"DodgerBlue1", {0.117647 , 0.564706 , 1.000000 }},
| 654 |
{"DodgerBlue2", {0.109804 , 0.525490 , 0.933333 }},
| 655 |
{"DodgerBlue3", {0.094118 , 0.454902 , 0.803922 }},
| 656 |
{"DodgerBlue4", {0.062745 , 0.305882 , 0.545098 }},
| 657 |
{"FloralWhite", {1.000000 , 0.980392 , 0.941176 }},
| 658 |
{"ForestGreen", {0.133333 , 0.545098 , 0.133333 }},
| 659 |
{"GhostWhite", {0.972549 , 0.972549 , 1.000000 }},
| 660 |
{"GreenYellow", {0.678431 , 1.000000 , 0.184314 }},
| 661 |
{"HotPink", {1.000000 , 0.411765 , 0.705882 }},
| 662 |
{"HotPink1", {1.000000 , 0.431373 , 0.705882 }},
| 663 |
{"HotPink2", {0.933333 , 0.415686 , 0.654902 }},
| 664 |
{"HotPink3", {0.803922 , 0.376471 , 0.564706 }},
| 665 |
{"HotPink4", {0.545098 , 0.227451 , 0.384314 }},
| 666 |
{"IndianRed", {0.803922 , 0.360784 , 0.360784 }},
| 667 |
{"IndianRed1", {1.000000 , 0.415686 , 0.415686 }},
| 668 |
{"IndianRed2", {0.933333 , 0.388235 , 0.388235 }},
| 669 |
{"IndianRed3", {0.803922 , 0.333333 , 0.333333 }},
| 670 |
{"IndianRed4", {0.545098 , 0.227451 , 0.227451 }},
| 671 |
{"LavenderBlush", {1.000000 , 0.941176 , 0.960784 }},
| 672 |
{"LavenderBlush1", {1.000000 , 0.941176 , 0.960784 }},
| 673 |
{"LavenderBlush2", {0.933333 , 0.878431 , 0.898039 }},
| 674 |
{"LavenderBlush3", {0.803922 , 0.756863 , 0.772549 }},
| 675 |
{"LavenderBlush4", {0.545098 , 0.513725 , 0.525490 }},
| 676 |
{"LawnGreen", {0.486275 , 0.988235 , 0.000000 }},
| 677 |
{"LemonChiffon", {1.000000 , 0.980392 , 0.803922 }},
| 678 |
{"LemonChiffon1", {1.000000 , 0.980392 , 0.803922 }},
| 679 |
{"LemonChiffon2", {0.933333 , 0.913725 , 0.749020 }},
| 680 |
{"LemonChiffon3", {0.803922 , 0.788235 , 0.647059 }},
| 681 |
{"LemonChiffon4", {0.545098 , 0.537255 , 0.439216 }},
| 682 |
{"LightBlue", {0.678431 , 0.847059 , 0.901961 }},
| 683 |
{"LightBlue1", {0.749020 , 0.937255 , 1.000000 }},
| 684 |
{"LightBlue2", {0.698039 , 0.874510 , 0.933333 }},
| 685 |
{"LightBlue3", {0.603922 , 0.752941 , 0.803922 }},
| 686 |
{"LightBlue4", {0.407843 , 0.513725 , 0.545098 }},
| 687 |
{"LightCoral", {0.941176 , 0.501961 , 0.501961 }},
| 688 |
{"LightCyan", {0.878431 , 1.000000 , 1.000000 }},
| 689 |
{"LightCyan1", {0.878431 , 1.000000 , 1.000000 }},
| 690 |
{"LightCyan2", {0.819608 , 0.933333 , 0.933333 }},
| 691 |
{"LightCyan3", {0.705882 , 0.803922 , 0.803922 }},
| 692 |
{"LightCyan4", {0.478431 , 0.545098 , 0.545098 }},
| 693 |
{"LightGoldenrod", {0.933333 , 0.866667 , 0.509804 }},
| 694 |
{"LightGoldenrod1", {1.000000 , 0.925490 , 0.545098 }},
| 695 |
{"LightGoldenrod2", {0.933333 , 0.862745 , 0.509804 }},
| 696 |
{"LightGoldenrod3", {0.803922 , 0.745098 , 0.439216 }},
| 697 |
{"LightGoldenrod4", {0.545098 , 0.505882 , 0.298039 }},
| 698 |
{"LightGoldenrodYellow", {0.980392 , 0.980392 , 0.823529 }},
| 699 |
{"LightGray", {0.827451 , 0.827451 , 0.827451 }},
| 700 |
{"LightGrey", {0.827451 , 0.827451 , 0.827451 }},
| 701 |
{"LightPink", {1.000000 , 0.713725 , 0.756863 }},
| 702 |
{"LightPink1", {1.000000 , 0.682353 , 0.725490 }},
| 703 |
{"LightPink2", {0.933333 , 0.635294 , 0.678431 }},
| 704 |
{"LightPink3", {0.803922 , 0.549020 , 0.584314 }},
| 705 |
{"LightPink4", {0.545098 , 0.372549 , 0.396078 }},
| 706 |
{"LightSalmon", {1.000000 , 0.627451 , 0.478431 }},
| 707 |
{"LightSalmon1", {1.000000 , 0.627451 , 0.478431 }},
| 708 |
{"LightSalmon2", {0.933333 , 0.584314 , 0.447059 }},
| 709 |
{"LightSalmon3", {0.803922 , 0.505882 , 0.384314 }},
| 710 |
{"LightSalmon4", {0.545098 , 0.341176 , 0.258824 }},
| 711 |
{"LightSeaGreen", {0.125490 , 0.698039 , 0.666667 }},
| 712 |
{"LightSkyBlue", {0.529412 , 0.807843 , 0.980392 }},
| 713 |
{"LightSkyBlue1", {0.690196 , 0.886275 , 1.000000 }},
| 714 |
{"LightSkyBlue2", {0.643137 , 0.827451 , 0.933333 }},
| 715 |
{"LightSkyBlue3", {0.552941 , 0.713725 , 0.803922 }},
| 716 |
{"LightSkyBlue4", {0.376471 , 0.482353 , 0.545098 }},
| 717 |
{"LightSlateBlue", {0.517647 , 0.439216 , 1.000000 }},
| 718 |
{"LightSlateGray", {0.466667 , 0.533333 , 0.600000 }},
| 719 |
{"LightSlateGrey", {0.466667 , 0.533333 , 0.600000 }},
| 720 |
{"LightSteelBlue", {0.690196 , 0.768627 , 0.870588 }},
| 721 |
{"LightSteelBlue1", {0.792157 , 0.882353 , 1.000000 }},
| 722 |
{"LightSteelBlue2", {0.737255 , 0.823529 , 0.933333 }},
| 723 |
{"LightSteelBlue3", {0.635294 , 0.709804 , 0.803922 }},
| 724 |
{"LightSteelBlue4", {0.431373 , 0.482353 , 0.545098 }},
| 725 |
{"LightYellow", {1.000000 , 1.000000 , 0.878431 }},
| 726 |
{"LightYellow1", {1.000000 , 1.000000 , 0.878431 }},
| 727 |
{"LightYellow2", {0.933333 , 0.933333 , 0.819608 }},
| 728 |
{"LightYellow3", {0.803922 , 0.803922 , 0.705882 }},
| 729 |
{"LightYellow4", {0.545098 , 0.545098 , 0.478431 }},
| 730 |
{"LimeGreen", {0.196078 , 0.803922 , 0.196078 }},
| 731 |
{"MediumAquamarine", {0.400000 , 0.803922 , 0.666667 }},
| 732 |
{"MediumBlue", {0.000000 , 0.000000 , 0.803922 }},
| 733 |
{"MediumOrchid", {0.729412 , 0.333333 , 0.827451 }},
| 734 |
{"MediumOrchid1", {0.878431 , 0.400000 , 1.000000 }},
| 735 |
{"MediumOrchid2", {0.819608 , 0.372549 , 0.933333 }},
| 736 |
{"MediumOrchid3", {0.705882 , 0.321569 , 0.803922 }},
| 737 |
{"MediumOrchid4", {0.478431 , 0.215686 , 0.545098 }},
| 738 |
{"MediumPurple", {0.576471 , 0.439216 , 0.858824 }},
| 739 |
{"MediumPurple1", {0.670588 , 0.509804 , 1.000000 }},
| 740 |
{"MediumPurple2", {0.623529 , 0.474510 , 0.933333 }},
| 741 |
{"MediumPurple3", {0.537255 , 0.407843 , 0.803922 }},
| 742 |
{"MediumPurple4", {0.364706 , 0.278431 , 0.545098 }},
| 743 |
{"MediumSeaGreen", {0.235294 , 0.701961 , 0.443137 }},
| 744 |
{"MediumSlateBlue", {0.482353 , 0.407843 , 0.933333 }},
| 745 |
{"MediumSpringGreen", {0.000000 , 0.980392 , 0.603922 }},
| 746 |
{"MediumTurquoise", {0.282353 , 0.819608 , 0.800000 }},
| 747 |
{"MediumVioletRed", {0.780392 , 0.082353 , 0.521569 }},
| 748 |
{"MidnightBlue", {0.098039 , 0.098039 , 0.439216 }},
| 749 |
{"MintCream", {0.960784 , 1.000000 , 0.980392 }},
| 750 |
{"MistyRose", {1.000000 , 0.894118 , 0.882353 }},
| 751 |
{"MistyRose1", {1.000000 , 0.894118 , 0.882353 }},
| 752 |
{"MistyRose2", {0.933333 , 0.835294 , 0.823529 }},
| 753 |
{"MistyRose3", {0.803922 , 0.717647 , 0.709804 }},
| 754 |
{"MistyRose4", {0.545098 , 0.490196 , 0.482353 }},
| 755 |
{"NavajoWhite", {1.000000 , 0.870588 , 0.678431 }},
| 756 |
{"NavajoWhite1", {1.000000 , 0.870588 , 0.678431 }},
| 757 |
{"NavajoWhite2", {0.933333 , 0.811765 , 0.631373 }},
| 758 |
{"NavajoWhite3", {0.803922 , 0.701961 , 0.545098 }},
| 759 |
{"NavajoWhite4", {0.545098 , 0.474510 , 0.368627 }},
| 760 |
{"NavyBlue", {0.000000 , 0.000000 , 0.501961 }},
| 761 |
{"OldLace", {0.992157 , 0.960784 , 0.901961 }},
| 762 |
{"OliveDrab", {0.419608 , 0.556863 , 0.137255 }},
| 763 |
{"OliveDrab1", {0.752941 , 1.000000 , 0.243137 }},
| 764 |
{"OliveDrab2", {0.701961 , 0.933333 , 0.227451 }},
| 765 |
{"OliveDrab3", {0.603922 , 0.803922 , 0.196078 }},
| 766 |
{"OliveDrab4", {0.411765 , 0.545098 , 0.133333 }},
| 767 |
{"OrangeRed", {1.000000 , 0.270588 , 0.000000 }},
| 768 |
{"OrangeRed1", {1.000000 , 0.270588 , 0.000000 }},
| 769 |
{"OrangeRed2", {0.933333 , 0.250980 , 0.000000 }},
| 770 |
{"OrangeRed3", {0.803922 , 0.215686 , 0.000000 }},
| 771 |
{"OrangeRed4", {0.545098 , 0.145098 , 0.000000 }},
| 772 |
{"PaleGoldenrod", {0.933333 , 0.909804 , 0.666667 }},
| 773 |
{"PaleGreen", {0.596078 , 0.984314 , 0.596078 }},
| 774 |
{"PaleGreen1", {0.603922 , 1.000000 , 0.603922 }},
| 775 |
{"PaleGreen2", {0.564706 , 0.933333 , 0.564706 }},
| 776 |
{"PaleGreen3", {0.486275 , 0.803922 , 0.486275 }},
| 777 |
{"PaleGreen4", {0.329412 , 0.545098 , 0.329412 }},
| 778 |
{"PaleTurquoise", {0.686275 , 0.933333 , 0.933333 }},
| 779 |
{"PaleTurquoise1", {0.733333 , 1.000000 , 1.000000 }},
| 780 |
{"PaleTurquoise2", {0.682353 , 0.933333 , 0.933333 }},
| 781 |
{"PaleTurquoise3", {0.588235 , 0.803922 , 0.803922 }},
| 782 |
{"PaleTurquoise4", {0.400000 , 0.545098 , 0.545098 }},
| 783 |
{"PaleVioletRed", {0.858824 , 0.439216 , 0.576471 }},
| 784 |
{"PaleVioletRed1", {1.000000 , 0.509804 , 0.670588 }},
| 785 |
{"PaleVioletRed2", {0.933333 , 0.474510 , 0.623529 }},
| 786 |
{"PaleVioletRed3", {0.803922 , 0.407843 , 0.537255 }},
| 787 |
{"PaleVioletRed4", {0.545098 , 0.278431 , 0.364706 }},
| 788 |
{"PapayaWhip", {1.000000 , 0.937255 , 0.835294 }},
| 789 |
{"PeachPuff", {1.000000 , 0.854902 , 0.725490 }},
| 790 |
{"PeachPuff1", {1.000000 , 0.854902 , 0.725490 }},
| 791 |
{"PeachPuff2", {0.933333 , 0.796078 , 0.678431 }},
| 792 |
{"PeachPuff3", {0.803922 , 0.686275 , 0.584314 }},
| 793 |
{"PeachPuff4", {0.545098 , 0.466667 , 0.396078 }},
| 794 |
{"PowderBlue", {0.690196 , 0.878431 , 0.901961 }},
| 795 |
{"RosyBrown", {0.737255 , 0.560784 , 0.560784 }},
| 796 |
{"RosyBrown1", {1.000000 , 0.756863 , 0.756863 }},
| 797 |
{"RosyBrown2", {0.933333 , 0.705882 , 0.705882 }},
| 798 |
{"RosyBrown3", {0.803922 , 0.607843 , 0.607843 }},
| 799 |
{"RosyBrown4", {0.545098 , 0.411765 , 0.411765 }},
| 800 |
{"RoyalBlue", {0.254902 , 0.411765 , 0.882353 }},
| 801 |
{"RoyalBlue1", {0.282353 , 0.462745 , 1.000000 }},
| 802 |
{"RoyalBlue2", {0.262745 , 0.431373 , 0.933333 }},
| 803 |
{"RoyalBlue3", {0.227451 , 0.372549 , 0.803922 }},
| 804 |
{"RoyalBlue4", {0.152941 , 0.250980 , 0.545098 }},
| 805 |
{"SaddleBrown", {0.545098 , 0.270588 , 0.074510 }},
| 806 |
{"SandyBrown", {0.956863 , 0.643137 , 0.376471 }},
| 807 |
{"SeaGreen", {0.180392 , 0.545098 , 0.341176 }},
| 808 |
{"SeaGreen1", {0.329412 , 1.000000 , 0.623529 }},
| 809 |
{"SeaGreen2", {0.305882 , 0.933333 , 0.580392 }},
| 810 |
{"SeaGreen3", {0.262745 , 0.803922 , 0.501961 }},
| 811 |
{"SeaGreen4", {0.180392 , 0.545098 , 0.341176 }},
| 812 |
{"SkyBlue", {0.529412 , 0.807843 , 0.921569 }},
| 813 |
{"SkyBlue1", {0.529412 , 0.807843 , 1.000000 }},
| 814 |
{"SkyBlue2", {0.494118 , 0.752941 , 0.933333 }},
| 815 |
{"SkyBlue3", {0.423529 , 0.650980 , 0.803922 }},
| 816 |
{"SkyBlue4", {0.290196 , 0.439216 , 0.545098 }},
| 817 |
{"SlateBlue", {0.415686 , 0.352941 , 0.803922 }},
| 818 |
{"SlateBlue1", {0.513725 , 0.435294 , 1.000000 }},
| 819 |
{"SlateBlue2", {0.478431 , 0.403922 , 0.933333 }},
| 820 |
{"SlateBlue3", {0.411765 , 0.349020 , 0.803922 }},
| 821 |
{"SlateBlue4", {0.278431 , 0.235294 , 0.545098 }},
| 822 |
{"SlateGray", {0.439216 , 0.501961 , 0.564706 }},
| 823 |
{"SlateGray1", {0.776471 , 0.886275 , 1.000000 }},
| 824 |
{"SlateGray2", {0.725490 , 0.827451 , 0.933333 }},
| 825 |
{"SlateGray3", {0.623529 , 0.713725 , 0.803922 }},
| 826 |
{"SlateGray4", {0.423529 , 0.482353 , 0.545098 }},
| 827 |
{"SlateGrey", {0.439216 , 0.501961 , 0.564706 }},
| 828 |
{"SpringGreen", {0.000000 , 1.000000 , 0.498039 }},
| 829 |
{"SpringGreen1", {0.000000 , 1.000000 , 0.498039 }},
| 830 |
{"SpringGreen2", {0.000000 , 0.933333 , 0.462745 }},
| 831 |
{"SpringGreen3", {0.000000 , 0.803922 , 0.400000 }},
| 832 |
{"SpringGreen4", {0.000000 , 0.545098 , 0.270588 }},
| 833 |
{"SteelBlue", {0.274510 , 0.509804 , 0.705882 }},
| 834 |
{"SteelBlue1", {0.388235 , 0.721569 , 1.000000 }},
| 835 |
{"SteelBlue2", {0.360784 , 0.674510 , 0.933333 }},
| 836 |
{"SteelBlue3", {0.309804 , 0.580392 , 0.803922 }},
| 837 |
{"SteelBlue4", {0.211765 , 0.392157 , 0.545098 }},
| 838 |
{"VioletRed", {0.815686 , 0.125490 , 0.564706 }},
| 839 |
{"VioletRed1", {1.000000 , 0.243137 , 0.588235 }},
| 840 |
{"VioletRed2", {0.933333 , 0.227451 , 0.549020 }},
| 841 |
{"VioletRed3", {0.803922 , 0.196078 , 0.470588 }},
| 842 |
{"VioletRed4", {0.545098 , 0.133333 , 0.321569 }},
| 843 |
{"WhiteSmoke", {0.960784 , 0.960784 , 0.960784 }},
| 844 |
{"YellowGreen", {0.603922 , 0.803922 , 0.196078 }},
| 845 |
{"alice_blue", {0.941176 , 0.972549 , 1.000000 }},
| 846 |
{"antique_white", {0.980392 , 0.921569 , 0.843137 }},
| 847 |
{"aquamarine", {0.498039 , 1.000000 , 0.831373 }},
| 848 |
{"aquamarine1", {0.498039 , 1.000000 , 0.831373 }},
| 849 |
{"aquamarine2", {0.462745 , 0.933333 , 0.776471 }},
| 850 |
{"aquamarine3", {0.400000 , 0.803922 , 0.666667 }},
| 851 |
{"aquamarine4", {0.270588 , 0.545098 , 0.454902 }},
| 852 |
{"azure", {0.941176 , 1.000000 , 1.000000 }},
| 853 |
{"azure1", {0.941176 , 1.000000 , 1.000000 }},
| 854 |
{"azure2", {0.878431 , 0.933333 , 0.933333 }},
| 855 |
{"azure3", {0.756863 , 0.803922 , 0.803922 }},
| 856 |
{"azure4", {0.513725 , 0.545098 , 0.545098 }},
| 857 |
{"beige", {0.960784 , 0.960784 , 0.862745 }},
| 858 |
{"bisque", {1.000000 , 0.894118 , 0.768627 }},
| 859 |
{"bisque1", {1.000000 , 0.894118 , 0.768627 }},
| 860 |
{"bisque2", {0.933333 , 0.835294 , 0.717647 }},
| 861 |
{"bisque3", {0.803922 , 0.717647 , 0.619608 }},
| 862 |
{"bisque4", {0.545098 , 0.490196 , 0.419608 }},
| 863 |
{"black", {0.000000 , 0.000000 , 0.000000 }},
| 864 |
{"blanched_almond", {1.000000 , 0.921569 , 0.803922 }},
| 865 |
{"blue", {0.000000 , 0.000000 , 1.000000 }},
| 866 |
{"blue1", {0.000000 , 0.000000 , 1.000000 }},
| 867 |
{"blue2", {0.000000 , 0.000000 , 0.933333 }},
| 868 |
{"blue3", {0.000000 , 0.000000 , 0.803922 }},
| 869 |
{"blue4", {0.000000 , 0.000000 , 0.545098 }},
| 870 |
{"blue_violet", {0.541176 , 0.168627 , 0.886275 }},
| 871 |
{"brown", {0.647059 , 0.164706 , 0.164706 }},
| 872 |
{"brown1", {1.000000 , 0.250980 , 0.250980 }},
| 873 |
{"brown2", {0.933333 , 0.231373 , 0.231373 }},
| 874 |
{"brown3", {0.803922 , 0.200000 , 0.200000 }},
| 875 |
{"brown4", {0.545098 , 0.137255 , 0.137255 }},
| 876 |
{"burlywood", {0.870588 , 0.721569 , 0.529412 }},
| 877 |
{"burlywood1", {1.000000 , 0.827451 , 0.607843 }},
| 878 |
{"burlywood2", {0.933333 , 0.772549 , 0.568627 }},
| 879 |
{"burlywood3", {0.803922 , 0.666667 , 0.490196 }},
| 880 |
{"burlywood4", {0.545098 , 0.450980 , 0.333333 }},
| 881 |
{"cadet_blue", {0.372549 , 0.619608 , 0.627451 }},
| 882 |
{"chartreuse", {0.498039 , 1.000000 , 0.000000 }},
| 883 |
{"chartreuse1", {0.498039 , 1.000000 , 0.000000 }},
| 884 |
{"chartreuse2", {0.462745 , 0.933333 , 0.000000 }},
| 885 |
{"chartreuse3", {0.400000 , 0.803922 , 0.000000 }},
| 886 |
{"chartreuse4", {0.270588 , 0.545098 , 0.000000 }},
| 887 |
{"chocolate", {0.823529 , 0.411765 , 0.117647 }},
| 888 |
{"chocolate1", {1.000000 , 0.498039 , 0.141176 }},
| 889 |
{"chocolate2", {0.933333 , 0.462745 , 0.129412 }},
| 890 |
{"chocolate3", {0.803922 , 0.400000 , 0.113725 }},
| 891 |
{"chocolate4", {0.545098 , 0.270588 , 0.074510 }},
| 892 |
{"coral", {1.000000 , 0.498039 , 0.313725 }},
| 893 |
{"coral1", {1.000000 , 0.447059 , 0.337255 }},
| 894 |
{"coral2", {0.933333 , 0.415686 , 0.313725 }},
| 895 |
{"coral3", {0.803922 , 0.356863 , 0.270588 }},
| 896 |
{"coral4", {0.545098 , 0.243137 , 0.184314 }},
| 897 |
{"cornflower_blue", {0.392157 , 0.584314 , 0.929412 }},
| 898 |
{"cornsilk", {1.000000 , 0.972549 , 0.862745 }},
| 899 |
{"cornsilk1", {1.000000 , 0.972549 , 0.862745 }},
| 900 |
{"cornsilk2", {0.933333 , 0.909804 , 0.803922 }},
| 901 |
{"cornsilk3", {0.803922 , 0.784314 , 0.694118 }},
| 902 |
{"cornsilk4", {0.545098 , 0.533333 , 0.470588 }},
| 903 |
{"cyan", {0.000000 , 1.000000 , 1.000000 }},
| 904 |
{"cyan1", {0.000000 , 1.000000 , 1.000000 }},
| 905 |
{"cyan2", {0.000000 , 0.933333 , 0.933333 }},
| 906 |
{"cyan3", {0.000000 , 0.803922 , 0.803922 }},
| 907 |
{"cyan4", {0.000000 , 0.545098 , 0.545098 }},
| 908 |
{"dark_goldenrod", {0.721569 , 0.525490 , 0.043137 }},
| 909 |
{"dark_green", {0.000000 , 0.392157 , 0.000000 }},
| 910 |
{"dark_khaki", {0.741176 , 0.717647 , 0.419608 }},
| 911 |
{"dark_olive_green", {0.333333 , 0.419608 , 0.184314 }},
| 912 |
{"dark_orange", {1.000000 , 0.549020 , 0.000000 }},
| 913 |
{"dark_orchid", {0.600000 , 0.196078 , 0.800000 }},
| 914 |
{"dark_salmon", {0.913725 , 0.588235 , 0.478431 }},
| 915 |
{"dark_sea_green", {0.560784 , 0.737255 , 0.560784 }},
| 916 |
{"dark_slate_blue", {0.282353 , 0.239216 , 0.545098 }},
| 917 |
{"dark_slate_gray", {0.184314 , 0.309804 , 0.309804 }},
| 918 |
{"dark_slate_grey", {0.184314 , 0.309804 , 0.309804 }},
| 919 |
{"dark_turquoise", {0.000000 , 0.807843 , 0.819608 }},
| 920 |
{"dark_violet", {0.580392 , 0.000000 , 0.827451 }},
| 921 |
{"deep_pink", {1.000000 , 0.078431 , 0.576471 }},
| 922 |
{"deep_sky_blue", {0.000000 , 0.749020 , 1.000000 }},
| 923 |
{"dim_gray", {0.411765 , 0.411765 , 0.411765 }},
| 924 |
{"dim_grey", {0.411765 , 0.411765 , 0.411765 }},
| 925 |
{"dodger_blue", {0.117647 , 0.564706 , 1.000000 }},
| 926 |
{"firebrick", {0.698039 , 0.133333 , 0.133333 }},
| 927 |
{"firebrick1", {1.000000 , 0.188235 , 0.188235 }},
| 928 |
{"firebrick2", {0.933333 , 0.172549 , 0.172549 }},
| 929 |
{"firebrick3", {0.803922 , 0.149020 , 0.149020 }},
| 930 |
{"firebrick4", {0.545098 , 0.101961 , 0.101961 }},
| 931 |
{"floral_white", {1.000000 , 0.980392 , 0.941176 }},
| 932 |
{"forest_green", {0.133333 , 0.545098 , 0.133333 }},
| 933 |
{"gainsboro", {0.862745 , 0.862745 , 0.862745 }},
| 934 |
{"ghost_white", {0.972549 , 0.972549 , 1.000000 }},
| 935 |
{"gold", {1.000000 , 0.843137 , 0.000000 }},
| 936 |
{"gold1", {1.000000 , 0.843137 , 0.000000 }},
| 937 |
{"gold2", {0.933333 , 0.788235 , 0.000000 }},
| 938 |
{"gold3", {0.803922 , 0.678431 , 0.000000 }},
| 939 |
{"gold4", {0.545098 , 0.458824 , 0.000000 }},
| 940 |
{"goldenrod", {0.854902 , 0.647059 , 0.125490 }},
| 941 |
{"goldenrod1", {1.000000 , 0.756863 , 0.145098 }},
| 942 |
{"goldenrod2", {0.933333 , 0.705882 , 0.133333 }},
| 943 |
{"goldenrod3", {0.803922 , 0.607843 , 0.113725 }},
| 944 |
{"goldenrod4", {0.545098 , 0.411765 , 0.078431 }},
| 945 |
{"gray", {0.752941 , 0.752941 , 0.752941 }},
| 946 |
{"gray0", {0.000000 , 0.000000 , 0.000000 }},
| 947 |
{"gray1", {0.011765 , 0.011765 , 0.011765 }},
| 948 |
{"gray10", {0.101961 , 0.101961 , 0.101961 }},
| 949 |
{"gray100", {1.000000 , 1.000000 , 1.000000 }},
| 950 |
{"gray11", {0.109804 , 0.109804 , 0.109804 }},
| 951 |
{"gray12", {0.121569 , 0.121569 , 0.121569 }},
| 952 |
{"gray13", {0.129412 , 0.129412 , 0.129412 }},
| 953 |
{"gray14", {0.141176 , 0.141176 , 0.141176 }},
| 954 |
{"gray15", {0.149020 , 0.149020 , 0.149020 }},
| 955 |
{"gray16", {0.160784 , 0.160784 , 0.160784 }},
| 956 |
{"gray17", {0.168627 , 0.168627 , 0.168627 }},
| 957 |
{"gray18", {0.180392 , 0.180392 , 0.180392 }},
| 958 |
{"gray19", {0.188235 , 0.188235 , 0.188235 }},
| 959 |
{"gray2", {0.019608 , 0.019608 , 0.019608 }},
| 960 |
{"gray20", {0.200000 , 0.200000 , 0.200000 }},
| 961 |
{"gray21", {0.211765 , 0.211765 , 0.211765 }},
| 962 |
{"gray22", {0.219608 , 0.219608 , 0.219608 }},
| 963 |
{"gray23", {0.231373 , 0.231373 , 0.231373 }},
| 964 |
{"gray24", {0.239216 , 0.239216 , 0.239216 }},
| 965 |
{"gray25", {0.250980 , 0.250980 , 0.250980 }},
| 966 |
{"gray26", {0.258824 , 0.258824 , 0.258824 }},
| 967 |
{"gray27", {0.270588 , 0.270588 , 0.270588 }},
| 968 |
{"gray28", {0.278431 , 0.278431 , 0.278431 }},
| 969 |
{"gray29", {0.290196 , 0.290196 , 0.290196 }},
| 970 |
{"gray3", {0.031373 , 0.031373 , 0.031373 }},
| 971 |
{"gray30", {0.301961 , 0.301961 , 0.301961 }},
| 972 |
{"gray31", {0.309804 , 0.309804 , 0.309804 }},
| 973 |
{"gray32", {0.321569 , 0.321569 , 0.321569 }},
| 974 |
{"gray33", {0.329412 , 0.329412 , 0.329412 }},
| 975 |
{"gray34", {0.341176 , 0.341176 , 0.341176 }},
| 976 |
{"gray35", {0.349020 , 0.349020 , 0.349020 }},
| 977 |
{"gray36", {0.360784 , 0.360784 , 0.360784 }},
| 978 |
{"gray37", {0.368627 , 0.368627 , 0.368627 }},
| 979 |
{"gray38", {0.380392 , 0.380392 , 0.380392 }},
| 980 |
{"gray39", {0.388235 , 0.388235 , 0.388235 }},
| 981 |
{"gray4", {0.039216 , 0.039216 , 0.039216 }},
| 982 |
{"gray40", {0.400000 , 0.400000 , 0.400000 }},
| 983 |
{"gray41", {0.411765 , 0.411765 , 0.411765 }},
| 984 |
{"gray42", {0.419608 , 0.419608 , 0.419608 }},
| 985 |
{"gray43", {0.431373 , 0.431373 , 0.431373 }},
| 986 |
{"gray44", {0.439216 , 0.439216 , 0.439216 }},
| 987 |
{"gray45", {0.450980 , 0.450980 , 0.450980 }},
| 988 |
{"gray46", {0.458824 , 0.458824 , 0.458824 }},
| 989 |
{"gray47", {0.470588 , 0.470588 , 0.470588 }},
| 990 |
{"gray48", {0.478431 , 0.478431 , 0.478431 }},
| 991 |
{"gray49", {0.490196 , 0.490196 , 0.490196 }},
| 992 |
{"gray5", {0.050980 , 0.050980 , 0.050980 }},
| 993 |
{"gray50", {0.498039 , 0.498039 , 0.498039 }},
| 994 |
{"gray51", {0.509804 , 0.509804 , 0.509804 }},
| 995 |
{"gray52", {0.521569 , 0.521569 , 0.521569 }},
| 996 |
{"gray53", {0.529412 , 0.529412 , 0.529412 }},
| 997 |
{"gray54", {0.541176 , 0.541176 , 0.541176 }},
| 998 |
{"gray55", {0.549020 , 0.549020 , 0.549020 }},
| 999 |
{"gray56", {0.560784 , 0.560784 , 0.560784 }},
| 1000 |
{"gray57", {0.568627 , 0.568627 , 0.568627 }},
| 1001 |
{"gray58", {0.580392 , 0.580392 , 0.580392 }},
| 1002 |
{"gray59", {0.588235 , 0.588235 , 0.588235 }},
| 1003 |
{"gray6", {0.058824 , 0.058824 , 0.058824 }},
| 1004 |
{"gray60", {0.600000 , 0.600000 , 0.600000 }},
| 1005 |
{"gray61", {0.611765 , 0.611765 , 0.611765 }},
| 1006 |
{"gray62", {0.619608 , 0.619608 , 0.619608 }},
| 1007 |
{"gray63", {0.631373 , 0.631373 , 0.631373 }},
| 1008 |
{"gray64", {0.639216 , 0.639216 , 0.639216 }},
| 1009 |
{"gray65", {0.650980 , 0.650980 , 0.650980 }},
| 1010 |
{"gray66", {0.658824 , 0.658824 , 0.658824 }},
| 1011 |
{"gray67", {0.670588 , 0.670588 , 0.670588 }},
| 1012 |
{"gray68", {0.678431 , 0.678431 , 0.678431 }},
| 1013 |
{"gray69", {0.690196 , 0.690196 , 0.690196 }},
| 1014 |
{"gray7", {0.070588 , 0.070588 , 0.070588 }},
| 1015 |
{"gray70", {0.701961 , 0.701961 , 0.701961 }},
| 1016 |
{"gray71", {0.709804 , 0.709804 , 0.709804 }},
| 1017 |
{"gray72", {0.721569 , 0.721569 , 0.721569 }},
| 1018 |
{"gray73", {0.729412 , 0.729412 , 0.729412 }},
| 1019 |
{"gray74", {0.741176 , 0.741176 , 0.741176 }},
| 1020 |
{"gray75", {0.749020 , 0.749020 , 0.749020 }},
| 1021 |
{"gray76", {0.760784 , 0.760784 , 0.760784 }},
| 1022 |
{"gray77", {0.768627 , 0.768627 , 0.768627 }},
| 1023 |
{"gray78", {0.780392 , 0.780392 , 0.780392 }},
| 1024 |
{"gray79", {0.788235 , 0.788235 , 0.788235 }},
| 1025 |
{"gray8", {0.078431 , 0.078431 , 0.078431 }},
| 1026 |
{"gray80", {0.800000 , 0.800000 , 0.800000 }},
| 1027 |
{"gray81", {0.811765 , 0.811765 , 0.811765 }},
| 1028 |
{"gray82", {0.819608 , 0.819608 , 0.819608 }},
| 1029 |
{"gray83", {0.831373 , 0.831373 , 0.831373 }},
| 1030 |
{"gray84", {0.839216 , 0.839216 , 0.839216 }},
| 1031 |
{"gray85", {0.850980 , 0.850980 , 0.850980 }},
| 1032 |
{"gray86", {0.858824 , 0.858824 , 0.858824 }},
| 1033 |
{"gray87", {0.870588 , 0.870588 , 0.870588 }},
| 1034 |
{"gray88", {0.878431 , 0.878431 , 0.878431 }},
| 1035 |
{"gray89", {0.890196 , 0.890196 , 0.890196 }},
| 1036 |
{"gray9", {0.090196 , 0.090196 , 0.090196 }},
| 1037 |
{"gray90", {0.898039 , 0.898039 , 0.898039 }},
| 1038 |
{"gray91", {0.909804 , 0.909804 , 0.909804 }},
| 1039 |
{"gray92", {0.921569 , 0.921569 , 0.921569 }},
| 1040 |
{"gray93", {0.929412 , 0.929412 , 0.929412 }},
| 1041 |
{"gray94", {0.941176 , 0.941176 , 0.941176 }},
| 1042 |
{"gray95", {0.949020 , 0.949020 , 0.949020 }},
| 1043 |
{"gray96", {0.960784 , 0.960784 , 0.960784 }},
| 1044 |
{"gray97", {0.968627 , 0.968627 , 0.968627 }},
| 1045 |
{"gray98", {0.980392 , 0.980392 , 0.980392 }},
| 1046 |
{"gray99", {0.988235 , 0.988235 , 0.988235 }},
| 1047 |
{"green", {0.000000 , 1.000000 , 0.000000 }},
| 1048 |
{"green1", {0.000000 , 1.000000 , 0.000000 }},
| 1049 |
{"green2", {0.000000 , 0.933333 , 0.000000 }},
| 1050 |
{"green3", {0.000000 , 0.803922 , 0.000000 }},
| 1051 |
{"green4", {0.000000 , 0.545098 , 0.000000 }},
| 1052 |
{"green_yellow", {0.678431 , 1.000000 , 0.184314 }},
| 1053 |
{"grey", {0.752941 , 0.752941 , 0.752941 }},
| 1054 |
{"grey0", {0.000000 , 0.000000 , 0.000000 }},
| 1055 |
{"grey1", {0.011765 , 0.011765 , 0.011765 }},
| 1056 |
{"grey10", {0.101961 , 0.101961 , 0.101961 }},
| 1057 |
{"grey100", {1.000000 , 1.000000 , 1.000000 }},
| 1058 |
{"grey11", {0.109804 , 0.109804 , 0.109804 }},
| 1059 |
{"grey12", {0.121569 , 0.121569 , 0.121569 }},
| 1060 |
{"grey13", {0.129412 , 0.129412 , 0.129412 }},
| 1061 |
{"grey14", {0.141176 , 0.141176 , 0.141176 }},
| 1062 |
{"grey15", {0.149020 , 0.149020 , 0.149020 }},
| 1063 |
{"grey16", {0.160784 , 0.160784 , 0.160784 }},
| 1064 |
{"grey17", {0.168627 , 0.168627 , 0.168627 }},
| 1065 |
{"grey18", {0.180392 , 0.180392 , 0.180392 }},
| 1066 |
{"grey19", {0.188235 , 0.188235 , 0.188235 }},
| 1067 |
{"grey2", {0.019608 , 0.019608 , 0.019608 }},
| 1068 |
{"grey20", {0.200000 , 0.200000 , 0.200000 }},
| 1069 |
{"grey21", {0.211765 , 0.211765 , 0.211765 }},
| 1070 |
{"grey22", {0.219608 , 0.219608 , 0.219608 }},
| 1071 |
{"grey23", {0.231373 , 0.231373 , 0.231373 }},
| 1072 |
{"grey24", {0.239216 , 0.239216 , 0.239216 }},
| 1073 |
{"grey25", {0.250980 , 0.250980 , 0.250980 }},
| 1074 |
{"grey26", {0.258824 , 0.258824 , 0.258824 }},
| 1075 |
{"grey27", {0.270588 , 0.270588 , 0.270588 }},
| 1076 |
{"grey28", {0.278431 , 0.278431 , 0.278431 }},
| 1077 |
{"grey29", {0.290196 , 0.290196 , 0.290196 }},
| 1078 |
{"grey3", {0.031373 , 0.031373 , 0.031373 }},
| 1079 |
{"grey30", {0.301961 , 0.301961 , 0.301961 }},
| 1080 |
{"grey31", {0.309804 , 0.309804 , 0.309804 }},
| 1081 |
{"grey32", {0.321569 , 0.321569 , 0.321569 }},
| 1082 |
{"grey33", {0.329412 , 0.329412 , 0.329412 }},
| 1083 |
{"grey34", {0.341176 , 0.341176 , 0.341176 }},
| 1084 |
{"grey35", {0.349020 , 0.349020 , 0.349020 }},
| 1085 |
{"grey36", {0.360784 , 0.360784 , 0.360784 }},
| 1086 |
{"grey37", {0.368627 , 0.368627 , 0.368627 }},
| 1087 |
{"grey38", {0.380392 , 0.380392 , 0.380392 }},
| 1088 |
{"grey39", {0.388235 , 0.388235 , 0.388235 }},
| 1089 |
{"grey4", {0.039216 , 0.039216 , 0.039216 }},
| 1090 |
{"grey40", {0.400000 , 0.400000 , 0.400000 }},
| 1091 |
{"grey41", {0.411765 , 0.411765 , 0.411765 }},
| 1092 |
{"grey42", {0.419608 , 0.419608 , 0.419608 }},
| 1093 |
{"grey43", {0.431373 , 0.431373 , 0.431373 }},
| 1094 |
{"grey44", {0.439216 , 0.439216 , 0.439216 }},
| 1095 |
{"grey45", {0.450980 , 0.450980 , 0.450980 }},
| 1096 |
{"grey46", {0.458824 , 0.458824 , 0.458824 }},
| 1097 |
{"grey47", {0.470588 , 0.470588 , 0.470588 }},
| 1098 |
{"grey48", {0.478431 , 0.478431 , 0.478431 }},
| 1099 |
{"grey49", {0.490196 , 0.490196 , 0.490196 }},
| 1100 |
{"grey5", {0.050980 , 0.050980 , 0.050980 }},
| 1101 |
{"grey50", {0.498039 , 0.498039 , 0.498039 }},
| 1102 |
{"grey51", {0.509804 , 0.509804 , 0.509804 }},
| 1103 |
{"grey52", {0.521569 , 0.521569 , 0.521569 }},
| 1104 |
{"grey53", {0.529412 , 0.529412 , 0.529412 }},
| 1105 |
{"grey54", {0.541176 , 0.541176 , 0.541176 }},
| 1106 |
{"grey55", {0.549020 , 0.549020 , 0.549020 }},
| 1107 |
{"grey56", {0.560784 , 0.560784 , 0.560784 }},
| 1108 |
{"grey57", {0.568627 , 0.568627 , 0.568627 }},
| 1109 |
{"grey58", {0.580392 , 0.580392 , 0.580392 }},
| 1110 |
{"grey59", {0.588235 , 0.588235 , 0.588235 }},
| 1111 |
{"grey6", {0.058824 , 0.058824 , 0.058824 }},
| 1112 |
{"grey60", {0.600000 , 0.600000 , 0.600000 }},
| 1113 |
{"grey61", {0.611765 , 0.611765 , 0.611765 }},
| 1114 |
{"grey62", {0.619608 , 0.619608 , 0.619608 }},
| 1115 |
{"grey63", {0.631373 , 0.631373 , 0.631373 }},
| 1116 |
{"grey64", {0.639216 , 0.639216 , 0.639216 }},
| 1117 |
{"grey65", {0.650980 , 0.650980 , 0.650980 }},
| 1118 |
{"grey66", {0.658824 , 0.658824 , 0.658824 }},
| 1119 |
{"grey67", {0.670588 , 0.670588 , 0.670588 }},
| 1120 |
{"grey68", {0.678431 , 0.678431 , 0.678431 }},
| 1121 |
{"grey69", {0.690196 , 0.690196 , 0.690196 }},
| 1122 |
{"grey7", {0.070588 , 0.070588 , 0.070588 }},
| 1123 |
{"grey70", {0.701961 , 0.701961 , 0.701961 }},
| 1124 |
{"grey71", {0.709804 , 0.709804 , 0.709804 }},
| 1125 |
{"grey72", {0.721569 , 0.721569 , 0.721569 }},
| 1126 |
{"grey73", {0.729412 , 0.729412 , 0.729412 }},
| 1127 |
{"grey74", {0.741176 , 0.741176 , 0.741176 }},
| 1128 |
{"grey75", {0.749020 , 0.749020 , 0.749020 }},
| 1129 |
{"grey76", {0.760784 , 0.760784 , 0.760784 }},
| 1130 |
{"grey77", {0.768627 , 0.768627 , 0.768627 }},
| 1131 |
{"grey78", {0.780392 , 0.780392 , 0.780392 }},
| 1132 |
{"grey79", {0.788235 , 0.788235 , 0.788235 }},
| 1133 |
{"grey8", {0.078431 , 0.078431 , 0.078431 }},
| 1134 |
{"grey80", {0.800000 , 0.800000 , 0.800000 }},
| 1135 |
{"grey81", {0.811765 , 0.811765 , 0.811765 }},
| 1136 |
{"grey82", {0.819608 , 0.819608 , 0.819608 }},
| 1137 |
{"grey83", {0.831373 , 0.831373 , 0.831373 }},
| 1138 |
{"grey84", {0.839216 , 0.839216 , 0.839216 }},
| 1139 |
{"grey85", {0.850980 , 0.850980 , 0.850980 }},
| 1140 |
{"grey86", {0.858824 , 0.858824 , 0.858824 }},
| 1141 |
{"grey87", {0.870588 , 0.870588 , 0.870588 }},
| 1142 |
{"grey88", {0.878431 , 0.878431 , 0.878431 }},
| 1143 |
{"grey89", {0.890196 , 0.890196 , 0.890196 }},
| 1144 |
{"grey9", {0.090196 , 0.090196 , 0.090196 }},
| 1145 |
{"grey90", {0.898039 , 0.898039 , 0.898039 }},
| 1146 |
{"grey91", {0.909804 , 0.909804 , 0.909804 }},
| 1147 |
{"grey92", {0.921569 , 0.921569 , 0.921569 }},
| 1148 |
{"grey93", {0.929412 , 0.929412 , 0.929412 }},
| 1149 |
{"grey94", {0.941176 , 0.941176 , 0.941176 }},
| 1150 |
{"grey95", {0.949020 , 0.949020 , 0.949020 }},
| 1151 |
{"grey96", {0.960784 , 0.960784 , 0.960784 }},
| 1152 |
{"grey97", {0.968627 , 0.968627 , 0.968627 }},
| 1153 |
{"grey98", {0.980392 , 0.980392 , 0.980392 }},
| 1154 |
{"grey99", {0.988235 , 0.988235 , 0.988235 }},
| 1155 |
{"honeydew", {0.941176 , 1.000000 , 0.941176 }},
| 1156 |
{"honeydew1", {0.941176 , 1.000000 , 0.941176 }},
| 1157 |
{"honeydew2", {0.878431 , 0.933333 , 0.878431 }},
| 1158 |
{"honeydew3", {0.756863 , 0.803922 , 0.756863 }},
| 1159 |
{"honeydew4", {0.513725 , 0.545098 , 0.513725 }},
| 1160 |
{"hot_pink", {1.000000 , 0.411765 , 0.705882 }},
| 1161 |
{"indian_red", {0.803922 , 0.360784 , 0.360784 }},
| 1162 |
{"ivory", {1.000000 , 1.000000 , 0.941176 }},
| 1163 |
{"ivory1", {1.000000 , 1.000000 , 0.941176 }},
| 1164 |
{"ivory2", {0.933333 , 0.933333 , 0.878431 }},
| 1165 |
{"ivory3", {0.803922 , 0.803922 , 0.756863 }},
| 1166 |
{"ivory4", {0.545098 , 0.545098 , 0.513725 }},
| 1167 |
{"khaki", {0.941176 , 0.901961 , 0.549020 }},
| 1168 |
{"khaki1", {1.000000 , 0.964706 , 0.560784 }},
| 1169 |
{"khaki2", {0.933333 , 0.901961 , 0.521569 }},
| 1170 |
{"khaki3", {0.803922 , 0.776471 , 0.450980 }},
| 1171 |
{"khaki4", {0.545098 , 0.525490 , 0.305882 }},
| 1172 |
{"lavender", {0.901961 , 0.901961 , 0.980392 }},
| 1173 |
{"lavender_blush", {1.000000 , 0.941176 , 0.960784 }},
| 1174 |
{"lawn_green", {0.486275 , 0.988235 , 0.000000 }},
| 1175 |
{"lemon_chiffon", {1.000000 , 0.980392 , 0.803922 }},
| 1176 |
{"light_blue", {0.678431 , 0.847059 , 0.901961 }},
| 1177 |
{"light_coral", {0.941176 , 0.501961 , 0.501961 }},
| 1178 |
{"light_cyan", {0.878431 , 1.000000 , 1.000000 }},
| 1179 |
{"light_goldenrod", {0.933333 , 0.866667 , 0.509804 }},
| 1180 |
{"light_goldenrod_yellow", {0.980392 , 0.980392 , 0.823529 }},
| 1181 |
{"light_gray", {0.827451 , 0.827451 , 0.827451 }},
| 1182 |
{"light_grey", {0.827451 , 0.827451 , 0.827451 }},
| 1183 |
{"light_pink", {1.000000 , 0.713725 , 0.756863 }},
| 1184 |
{"light_salmon", {1.000000 , 0.627451 , 0.478431 }},
| 1185 |
{"light_sea_green", {0.125490 , 0.698039 , 0.666667 }},
| 1186 |
{"light_sky_blue", {0.529412 , 0.807843 , 0.980392 }},
| 1187 |
{"light_slate_blue", {0.517647 , 0.439216 , 1.000000 }},
| 1188 |
{"light_slate_gray", {0.466667 , 0.533333 , 0.600000 }},
| 1189 |
{"light_slate_grey", {0.466667 , 0.533333 , 0.600000 }},
| 1190 |
{"light_steel_blue", {0.690196 , 0.768627 , 0.870588 }},
| 1191 |
{"light_yellow", {1.000000 , 1.000000 , 0.878431 }},
| 1192 |
{"lime_green", {0.196078 , 0.803922 , 0.196078 }},
| 1193 |
{"linen", {0.980392 , 0.941176 , 0.901961 }},
| 1194 |
{"magenta", {1.000000 , 0.000000 , 1.000000 }},
| 1195 |
{"magenta1", {1.000000 , 0.000000 , 1.000000 }},
| 1196 |
{"magenta2", {0.933333 , 0.000000 , 0.933333 }},
| 1197 |
{"magenta3", {0.803922 , 0.000000 , 0.803922 }},
| 1198 |
{"magenta4", {0.545098 , 0.000000 , 0.545098 }},
| 1199 |
{"maroon", {0.690196 , 0.188235 , 0.376471 }},
| 1200 |
{"maroon1", {1.000000 , 0.203922 , 0.701961 }},
| 1201 |
{"maroon2", {0.933333 , 0.188235 , 0.654902 }},
| 1202 |
{"maroon3", {0.803922 , 0.160784 , 0.564706 }},
| 1203 |
{"maroon4", {0.545098 , 0.109804 , 0.384314 }},
| 1204 |
{"medium_aquamarine", {0.400000 , 0.803922 , 0.666667 }},
| 1205 |
{"medium_blue", {0.000000 , 0.000000 , 0.803922 }},
| 1206 |
{"medium_orchid", {0.729412 , 0.333333 , 0.827451 }},
| 1207 |
{"medium_purple", {0.576471 , 0.439216 , 0.858824 }},
| 1208 |
{"medium_sea_green", {0.235294 , 0.701961 , 0.443137 }},
| 1209 |
{"medium_slate_blue", {0.482353 , 0.407843 , 0.933333 }},
| 1210 |
{"medium_spring_green", {0.000000 , 0.980392 , 0.603922 }},
| 1211 |
{"medium_turquoise", {0.282353 , 0.819608 , 0.800000 }},
| 1212 |
{"medium_violet_red", {0.780392 , 0.082353 , 0.521569 }},
| 1213 |
{"midnight_blue", {0.098039 , 0.098039 , 0.439216 }},
| 1214 |
{"mint_cream", {0.960784 , 1.000000 , 0.980392 }},
| 1215 |
{"misty_rose", {1.000000 , 0.894118 , 0.882353 }},
| 1216 |
{"moccasin", {1.000000 , 0.894118 , 0.709804 }},
| 1217 |
{"navajo_white", {1.000000 , 0.870588 , 0.678431 }},
| 1218 |
{"navy", {0.000000 , 0.000000 , 0.501961 }},
| 1219 |
{"navy_blue", {0.000000 , 0.000000 , 0.501961 }},
| 1220 |
{"old_lace", {0.992157 , 0.960784 , 0.901961 }},
| 1221 |
{"olive_drab", {0.419608 , 0.556863 , 0.137255 }},
| 1222 |
{"orange", {1.000000 , 0.647059 , 0.000000 }},
| 1223 |
{"orange1", {1.000000 , 0.647059 , 0.000000 }},
| 1224 |
{"orange2", {0.933333 , 0.603922 , 0.000000 }},
| 1225 |
{"orange3", {0.803922 , 0.521569 , 0.000000 }},
| 1226 |
{"orange4", {0.545098 , 0.352941 , 0.000000 }},
| 1227 |
{"orange_red", {1.000000 , 0.270588 , 0.000000 }},
| 1228 |
{"orchid", {0.854902 , 0.439216 , 0.839216 }},
| 1229 |
{"orchid1", {1.000000 , 0.513725 , 0.980392 }},
| 1230 |
{"orchid2", {0.933333 , 0.478431 , 0.913725 }},
| 1231 |
{"orchid3", {0.803922 , 0.411765 , 0.788235 }},
| 1232 |
{"orchid4", {0.545098 , 0.278431 , 0.537255 }},
| 1233 |
{"pale_goldenrod", {0.933333 , 0.909804 , 0.666667 }},
| 1234 |
{"pale_green", {0.596078 , 0.984314 , 0.596078 }},
| 1235 |
{"pale_turquoise", {0.686275 , 0.933333 , 0.933333 }},
| 1236 |
{"pale_violet_red", {0.858824 , 0.439216 , 0.576471 }},
| 1237 |
{"papaya_whip", {1.000000 , 0.937255 , 0.835294 }},
| 1238 |
{"peach_puff", {1.000000 , 0.854902 , 0.725490 }},
| 1239 |
{"peru", {0.803922 , 0.521569 , 0.247059 }},
| 1240 |
{"pink", {1.000000 , 0.752941 , 0.796078 }},
| 1241 |
{"pink1", {1.000000 , 0.709804 , 0.772549 }},
| 1242 |
{"pink2", {0.933333 , 0.662745 , 0.721569 }},
| 1243 |
{"pink3", {0.803922 , 0.568627 , 0.619608 }},
| 1244 |
{"pink4", {0.545098 , 0.388235 , 0.423529 }},
| 1245 |
{"plum", {0.866667 , 0.627451 , 0.866667 }},
| 1246 |
{"plum1", {1.000000 , 0.733333 , 1.000000 }},
| 1247 |
{"plum2", {0.933333 , 0.682353 , 0.933333 }},
| 1248 |
{"plum3", {0.803922 , 0.588235 , 0.803922 }},
| 1249 |
{"plum4", {0.545098 , 0.400000 , 0.545098 }},
| 1250 |
{"powder_blue", {0.690196 , 0.878431 , 0.901961 }},
| 1251 |
{"purple", {0.627451 , 0.125490 , 0.941176 }},
| 1252 |
{"purple1", {0.607843 , 0.188235 , 1.000000 }},
| 1253 |
{"purple2", {0.568627 , 0.172549 , 0.933333 }},
| 1254 |
{"purple3", {0.490196 , 0.149020 , 0.803922 }},
| 1255 |
{"purple4", {0.333333 , 0.101961 , 0.545098 }},
| 1256 |
{"red", {1.000000 , 0.000000 , 0.000000 }},
| 1257 |
{"red1", {1.000000 , 0.000000 , 0.000000 }},
| 1258 |
{"red2", {0.933333 , 0.000000 , 0.000000 }},
| 1259 |
{"red3", {0.803922 , 0.000000 , 0.000000 }},
| 1260 |
{"red4", {0.545098 , 0.000000 , 0.000000 }},
| 1261 |
{"rosy_brown", {0.737255 , 0.560784 , 0.560784 }},
| 1262 |
{"royal_blue", {0.254902 , 0.411765 , 0.882353 }},
| 1263 |
{"saddle_brown", {0.545098 , 0.270588 , 0.074510 }},
| 1264 |
{"salmon", {0.980392 , 0.501961 , 0.447059 }},
| 1265 |
{"salmon1", {1.000000 , 0.549020 , 0.411765 }},
| 1266 |
{"salmon2", {0.933333 , 0.509804 , 0.384314 }},
| 1267 |
{"salmon3", {0.803922 , 0.439216 , 0.329412 }},
| 1268 |
{"salmon4", {0.545098 , 0.298039 , 0.223529 }},
| 1269 |
{"sandy_brown", {0.956863 , 0.643137 , 0.376471 }},
| 1270 |
{"sea_green", {0.180392 , 0.545098 , 0.341176 }},
| 1271 |
{"seashell", {1.000000 , 0.960784 , 0.933333 }},
| 1272 |
{"seashell1", {1.000000 , 0.960784 , 0.933333 }},
| 1273 |
{"seashell2", {0.933333 , 0.898039 , 0.870588 }},
| 1274 |
{"seashell3", {0.803922 , 0.772549 , 0.749020 }},
| 1275 |
{"seashell4", {0.545098 , 0.525490 , 0.509804 }},
| 1276 |
{"sienna", {0.627451 , 0.321569 , 0.176471 }},
| 1277 |
{"sienna1", {1.000000 , 0.509804 , 0.278431 }},
| 1278 |
{"sienna2", {0.933333 , 0.474510 , 0.258824 }},
| 1279 |
{"sienna3", {0.803922 , 0.407843 , 0.223529 }},
| 1280 |
{"sienna4", {0.545098 , 0.278431 , 0.149020 }},
| 1281 |
{"sky_blue", {0.529412 , 0.807843 , 0.921569 }},
| 1282 |
{"slate_blue", {0.415686 , 0.352941 , 0.803922 }},
| 1283 |
{"slate_gray", {0.439216 , 0.501961 , 0.564706 }},
| 1284 |
{"slate_grey", {0.439216 , 0.501961 , 0.564706 }},
| 1285 |
{"snow", {1.000000 , 0.980392 , 0.980392 }},
| 1286 |
{"snow1", {1.000000 , 0.980392 , 0.980392 }},
| 1287 |
{"snow2", {0.933333 , 0.913725 , 0.913725 }},
| 1288 |
{"snow3", {0.803922 , 0.788235 , 0.788235 }},
| 1289 |
{"snow4", {0.545098 , 0.537255 , 0.537255 }},
| 1290 |
{"spring_green", {0.000000 , 1.000000 , 0.498039 }},
| 1291 |
{"steel_blue", {0.274510 , 0.509804 , 0.705882 }},
| 1292 |
{"tan", {0.823529 , 0.705882 , 0.549020 }},
| 1293 |
{"tan1", {1.000000 , 0.647059 , 0.309804 }},
| 1294 |
{"tan2", {0.933333 , 0.603922 , 0.286275 }},
| 1295 |
{"tan3", {0.803922 , 0.521569 , 0.247059 }},
| 1296 |
{"tan4", {0.545098 , 0.352941 , 0.168627 }},
| 1297 |
{"thistle", {0.847059 , 0.749020 , 0.847059 }},
| 1298 |
{"thistle1", {1.000000 , 0.882353 , 1.000000 }},
| 1299 |
{"thistle2", {0.933333 , 0.823529 , 0.933333 }},
| 1300 |
{"thistle3", {0.803922 , 0.709804 , 0.803922 }},
| 1301 |
{"thistle4", {0.545098 , 0.482353 , 0.545098 }},
| 1302 |
{"tomato", {1.000000 , 0.388235 , 0.278431 }},
| 1303 |
{"tomato1", {1.000000 , 0.388235 , 0.278431 }},
| 1304 |
{"tomato2", {0.933333 , 0.360784 , 0.258824 }},
| 1305 |
{"tomato3", {0.803922 , 0.309804 , 0.223529 }},
| 1306 |
{"tomato4", {0.545098 , 0.211765 , 0.149020 }},
| 1307 |
{"turquoise", {0.250980 , 0.878431 , 0.815686 }},
| 1308 |
{"turquoise1", {0.000000 , 0.960784 , 1.000000 }},
| 1309 |
{"turquoise2", {0.000000 , 0.898039 , 0.933333 }},
| 1310 |
{"turquoise3", {0.000000 , 0.772549 , 0.803922 }},
| 1311 |
{"turquoise4", {0.000000 , 0.525490 , 0.545098 }},
| 1312 |
{"violet", {0.933333 , 0.509804 , 0.933333 }},
| 1313 |
{"violet_red", {0.815686 , 0.125490 , 0.564706 }},
| 1314 |
{"wheat", {0.960784 , 0.870588 , 0.701961 }},
| 1315 |
{"wheat1", {1.000000 , 0.905882 , 0.729412 }},
| 1316 |
{"wheat2", {0.933333 , 0.847059 , 0.682353 }},
| 1317 |
{"wheat3", {0.803922 , 0.729412 , 0.588235 }},
| 1318 |
{"wheat4", {0.545098 , 0.494118 , 0.400000 }},
| 1319 |
{"white", {1.000000 , 1.000000 , 1.000000 }},
| 1320 |
{"white_smoke", {0.960784 , 0.960784 , 0.960784 }},
| 1321 |
{"yellow", {1.000000 , 1.000000 , 0.000000 }},
| 1322 |
{"yellow1", {1.000000 , 1.000000 , 0.000000 }},
| 1323 |
{"yellow2", {0.933333 , 0.933333 , 0.000000 }},
| 1324 |
{"yellow3", {0.803922 , 0.803922 , 0.000000 }},
| 1325 |
{"yellow4", {0.545098 , 0.545098 , 0.000000 }},
| 1326 |
{"yellow_green", {0.603922 , 0.803922 , 0.196078} }
| 1327 |
| 1328 |
| 1329 |
int
| 1330 |
LookupColorByName(name, color)
| 1331 |
char * name ;
| 1332 |
Vec color ;
| 1333 |
| 1334 |
int rc ;
| 1335 |
rc = BinarySearch(name, 0, NCOLORS - 1 , Colors) ;
| 1336 |
if (rc < 0) {
| 1337 |
return(0) ;
| 1338 |
| 1339 |
| 1340 |
VecCopy(Colors[rc].ce_color, color) ;
| 1341 |
return 1 ;
| 1342 |
| 1343 |
| 1344 |
| 1345 |
int
| 1346 |
BinarySearch(name, l, h, array)
| 1347 |
char * name ;
| 1348 |
int l, h ;
| 1349 |
ColorEntry array[] ;
| 1350 |
| 1351 |
int m, rc ;
| 1352 |
if (l > h)
| 1353 |
return(-1) ;
| 1354 |
| 1355 |
m = (l + h) / 2 ;
| 1356 |
| 1357 |
rc = strcmp(name, array[m].ce_name) ;
| 1358 |
if (rc == 0)
| 1359 |
return m ;
| 1360 |
else if (rc < 0)
| 1361 |
return BinarySearch(name, l, m-1, array) ;
| 1362 |
else
| 1363 |
return BinarySearch(name, m + 1, h, array) ;
| 1364 |
