1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for 4x4 homogeneous, rigid-body transformations |
9 |
10 |
11 |
#include <stdio.h> |
12 |
#include <math.h> |
13 |
#include <string.h> |
14 |
#include "parser.h" |
15 |
16 |
#define d2r(a) ((PI/180.)*(a)) |
17 |
18 |
#define checkarg(a,l) if (av[i][a] || badarg(ac-i-1,av+i+1,l)) goto done |
19 |
20 |
MAT4 m4ident = MAT4IDENT; |
21 |
22 |
static MAT4 m4tmp; /* for efficiency */ |
23 |
24 |
XF_SPEC *xf_context; /* current context */ |
25 |
char **xf_argend; /* end of transform argument list */ |
26 |
static char **xf_argbeg; /* beginning of transform argument list */ |
27 |
28 |
static XF_SPEC *new_xf(); |
29 |
static long comp_xfid(); |
30 |
static int put_oname(); |
31 |
32 |
33 |
int |
34 |
xf_handler(ac, av) /* handle xf entity */ |
35 |
int ac; |
36 |
char **av; |
37 |
38 |
register XF_SPEC *spec; |
39 |
register int n; |
40 |
int rv; |
41 |
42 |
if (ac == 1) { /* something with existing transform */ |
43 |
if ((spec = xf_context) == NULL) |
44 |
return(MG_ECNTXT); |
45 |
n = -1; |
46 |
if (spec->xarr != NULL) { /* check for iteration */ |
47 |
register struct xf_array *ap = spec->xarr; |
48 |
49 |
(void)put_oname((struct xf_array *)NULL); |
50 |
n = ap->ndim; |
51 |
while (n--) { |
52 |
if (++ap->aarg[n].i < ap->aarg[n].n) |
53 |
break; |
54 |
(void)strcpy(ap->aarg[n].arg, "0"); |
55 |
ap->aarg[n].i = 0; |
56 |
57 |
if (n >= 0) { |
58 |
if ((rv = mg_fgoto(&ap->spos)) != MG_OK) |
59 |
return(rv); |
60 |
sprintf(ap->aarg[n].arg, "%d", ap->aarg[n].i); |
61 |
(void)put_oname(ap); |
62 |
} else |
63 |
free((MEM_PTR)ap); |
64 |
65 |
if (n < 0) { /* pop transform */ |
66 |
xf_context = spec->prev; |
67 |
free((MEM_PTR)spec); |
68 |
return(MG_OK); |
69 |
70 |
} else { /* else allocate transform */ |
71 |
if ((spec = new_xf(ac-1, av+1)) == NULL) |
72 |
return(MG_EMEM); |
73 |
spec->prev = xf_context; /* push onto stack */ |
74 |
xf_context = spec; |
75 |
76 |
/* translate new specification */ |
77 |
n = xf_ac(spec); |
78 |
if (spec->prev != NULL) /* incremental comp. is more eff. */ |
79 |
n -= xf_ac(spec->prev); |
80 |
if (xf(&spec->xf, n, xf_av(spec)) != n) |
81 |
return(MG_ETYPE); |
82 |
/* check for vertex reversal */ |
83 |
if ((spec->rev = (spec->xf.sca < 0.))) |
84 |
spec->xf.sca = -spec->xf.sca; |
85 |
/* compute total transformation */ |
86 |
if (spec->prev != NULL) { |
87 |
multmat4(spec->xf.xfm, spec->xf.xfm, spec->prev->xf.xfm); |
88 |
spec->xf.sca *= spec->prev->xf.sca; |
89 |
spec->rev ^= spec->prev->rev; |
90 |
91 |
spec->xid = comp_xfid(spec->xf.xfm); /* compute unique ID */ |
92 |
return(MG_OK); |
93 |
94 |
95 |
96 |
static XF_SPEC * |
97 |
new_xf(ac, av) /* allocate new transform structure */ |
98 |
int ac; |
99 |
char **av; |
100 |
101 |
102 |
register int i; |
103 |
char *cp; |
104 |
int n, ndim; |
105 |
106 |
ndim = 0; |
107 |
n = 0; /* compute space req'd by arguments */ |
108 |
for (i = 0; i < ac; i++) |
109 |
if (!strcmp(av[i], "-a")) { |
110 |
ndim++; |
111 |
i++; |
112 |
} else |
113 |
n += strlen(av[i]) + 1; |
114 |
if (ndim > XF_MAXDIM) |
115 |
return(NULL); |
116 |
spec = (XF_SPEC *)malloc(sizeof(XF_SPEC) + n); |
117 |
if (spec == NULL) |
118 |
return(NULL); |
119 |
if (ndim) { |
120 |
spec->xarr = (struct xf_array *)malloc(sizeof(struct xf_array)); |
121 |
if (spec->xarr == NULL) |
122 |
return(NULL); |
123 |
mg_fgetpos(&spec->xarr->spos); |
124 |
spec->xarr->ndim = 0; /* incremented below */ |
125 |
} else |
126 |
spec->xarr = NULL; |
127 |
spec->xac = ac + xf_argc; |
128 |
/* and store new xf arguments */ |
129 |
if (xf_argbeg == NULL || xf_av(spec) < xf_argbeg) { |
130 |
register char **newav = |
131 |
(char **)malloc((spec->xac+1)*sizeof(char *)); |
132 |
if (newav == NULL) |
133 |
return(NULL); |
134 |
for (i = xf_argc; i-- > 0; ) |
135 |
newav[ac+i] = xf_argend[i-xf_context->xac]; |
136 |
*(xf_argend = newav + spec->xac) = NULL; |
137 |
if (xf_argbeg != NULL) |
138 |
free((MEM_PTR)xf_argbeg); |
139 |
xf_argbeg = newav; |
140 |
141 |
cp = (char *)(spec + 1); /* use memory allocated above */ |
142 |
143 |
144 |
xf_av(spec)[i++] = "-i"; |
145 |
xf_av(spec)[i] = strcpy( |
146 |
spec->xarr->aarg[spec->xarr->ndim].arg, |
147 |
"0"); |
148 |
spec->xarr->aarg[spec->xarr->ndim].i = 0; |
149 |
spec->xarr->aarg[spec->xarr->ndim++].n = atoi(av[i]); |
150 |
} else { |
151 |
xf_av(spec)[i] = strcpy(cp, av[i]); |
152 |
cp += strlen(av[i]) + 1; |
153 |
154 |
if (spec->xarr != NULL) |
155 |
(void)put_oname(spec->xarr); |
156 |
return(spec); |
157 |
158 |
159 |
160 |
static int |
161 |
put_oname(ap) /* put out name for this instance */ |
162 |
register struct xf_array *ap; |
163 |
164 |
static char oname[10*XF_MAXDIM]; |
165 |
static char *oav[3] = {mg_ename[MG_E_OBJECT], oname}; |
166 |
register int i; |
167 |
register char *cp1, *cp2; |
168 |
169 |
if (ap == NULL) |
170 |
return(mg_handle(MG_E_OBJECT, 1, oav)); |
171 |
cp1 = oname; |
172 |
*cp1 = 'a'; |
173 |
for (i = 0; i < ap->ndim; i++) { |
174 |
for (cp2 = ap->aarg[i].arg; *cp2; ) |
175 |
*++cp1 = *cp2++; |
176 |
*++cp1 = '.'; |
177 |
178 |
*cp1 = '\0'; |
179 |
return(mg_handle(MG_E_OBJECT, 2, oav)); |
180 |
181 |
182 |
183 |
static long |
184 |
comp_xfid(xfm) /* compute unique ID from matrix */ |
185 |
register MAT4 xfm; |
186 |
187 |
static char shifttab[64] = { 15, 5, 11, 5, 6, 3, |
188 |
9, 15, 13, 2, 13, 5, 2, 12, 14, 11, |
189 |
11, 12, 12, 3, 2, 11, 8, 12, 1, 12, |
190 |
5, 4, 15, 9, 14, 5, 13, 14, 2, 10, |
191 |
10, 14, 12, 3, 5, 5, 14, 6, 12, 11, |
192 |
13, 9, 12, 8, 1, 6, 5, 12, 7, 13, |
193 |
15, 8, 9, 2, 6, 11, 9, 11 }; |
194 |
register int i; |
195 |
register long xid; |
196 |
197 |
xid = 0; /* compute unique transform id */ |
198 |
for (i = 0; i < sizeof(MAT4)/sizeof(unsigned short); i++) |
199 |
xid ^= (long)(((unsigned short *)xfm)[i]) << shifttab[i&63]; |
200 |
return(xid); |
201 |
202 |
203 |
204 |
void |
205 |
xf_clear() /* clear transform stack */ |
206 |
207 |
208 |
209 |
if (xf_argbeg != NULL) { |
210 |
211 |
xf_argbeg = xf_argend = NULL; |
212 |
213 |
while ((spec = xf_context) != NULL) { |
214 |
215 |
216 |
free((MEM_PTR)spec->xarr); |
217 |
218 |
219 |
220 |
221 |
222 |
void |
223 |
xf_xfmpoint(v1, v2) /* transform a point by the current matrix */ |
224 |
FVECT v1, v2; |
225 |
226 |
if (xf_context == NULL) { |
227 |
VCOPY(v1, v2); |
228 |
return; |
229 |
230 |
multp3(v1, v2, xf_context->xf.xfm); |
231 |
232 |
233 |
234 |
void |
235 |
xf_xfmvect(v1, v2) /* transform a vector using current matrix */ |
236 |
FVECT v1, v2; |
237 |
238 |
239 |
VCOPY(v1, v2); |
240 |
return; |
241 |
242 |
multv3(v1, v2, xf_context->xf.xfm); |
243 |
244 |
245 |
246 |
void |
247 |
xf_rotvect(v1, v2) /* rotate a vector using current matrix */ |
248 |
FVECT v1, v2; |
249 |
250 |
xf_xfmvect(v1, v2); |
251 |
if (xf_context == NULL) |
252 |
return; |
253 |
v1[0] /= xf_context->xf.sca; |
254 |
v1[1] /= xf_context->xf.sca; |
255 |
v1[2] /= xf_context->xf.sca; |
256 |
257 |
258 |
259 |
double |
260 |
xf_scale(d) /* scale a number by the current transform */ |
261 |
double d; |
262 |
263 |
264 |
return(d); |
265 |
return(d*xf_context->xf.sca); |
266 |
267 |
268 |
269 |
void |
270 |
multmat4(m4a, m4b, m4c) /* multiply m4b X m4c and put into m4a */ |
271 |
MAT4 m4a; |
272 |
register MAT4 m4b, m4c; |
273 |
274 |
register int i, j; |
275 |
276 |
for (i = 4; i--; ) |
277 |
for (j = 4; j--; ) |
278 |
m4tmp[i][j] = m4b[i][0]*m4c[0][j] + |
279 |
m4b[i][1]*m4c[1][j] + |
280 |
m4b[i][2]*m4c[2][j] + |
281 |
m4b[i][3]*m4c[3][j]; |
282 |
283 |
copymat4(m4a, m4tmp); |
284 |
285 |
286 |
287 |
void |
288 |
multv3(v3a, v3b, m4) /* transform vector v3b by m4 and put into v3a */ |
289 |
FVECT v3a; |
290 |
register FVECT v3b; |
291 |
register MAT4 m4; |
292 |
293 |
m4tmp[0][0] = v3b[0]*m4[0][0] + v3b[1]*m4[1][0] + v3b[2]*m4[2][0]; |
294 |
m4tmp[0][1] = v3b[0]*m4[0][1] + v3b[1]*m4[1][1] + v3b[2]*m4[2][1]; |
295 |
m4tmp[0][2] = v3b[0]*m4[0][2] + v3b[1]*m4[1][2] + v3b[2]*m4[2][2]; |
296 |
297 |
v3a[0] = m4tmp[0][0]; |
298 |
v3a[1] = m4tmp[0][1]; |
299 |
v3a[2] = m4tmp[0][2]; |
300 |
301 |
302 |
303 |
void |
304 |
multp3(p3a, p3b, m4) /* transform p3b by m4 and put into p3a */ |
305 |
register FVECT p3a; |
306 |
FVECT p3b; |
307 |
register MAT4 m4; |
308 |
309 |
multv3(p3a, p3b, m4); /* transform as vector */ |
310 |
p3a[0] += m4[3][0]; /* translate */ |
311 |
p3a[1] += m4[3][1]; |
312 |
p3a[2] += m4[3][2]; |
313 |
314 |
315 |
316 |
int |
317 |
xf(ret, ac, av) /* get transform specification */ |
318 |
register XF *ret; |
319 |
int ac; |
320 |
char **av; |
321 |
322 |
MAT4 xfmat, m4; |
323 |
double xfsca, dtmp; |
324 |
int i, icnt; |
325 |
326 |
setident4(ret->xfm); |
327 |
ret->sca = 1.0; |
328 |
329 |
icnt = 1; |
330 |
setident4(xfmat); |
331 |
xfsca = 1.0; |
332 |
333 |
for (i = 0; i < ac && av[i][0] == '-'; i++) { |
334 |
335 |
setident4(m4); |
336 |
337 |
switch (av[i][1]) { |
338 |
339 |
case 't': /* translate */ |
340 |
checkarg(2,"fff"); |
341 |
m4[3][0] = atof(av[++i]); |
342 |
m4[3][1] = atof(av[++i]); |
343 |
m4[3][2] = atof(av[++i]); |
344 |
break; |
345 |
346 |
case 'r': /* rotate */ |
347 |
switch (av[i][2]) { |
348 |
case 'x': |
349 |
checkarg(3,"f"); |
350 |
dtmp = d2r(atof(av[++i])); |
351 |
m4[1][1] = m4[2][2] = cos(dtmp); |
352 |
m4[2][1] = -(m4[1][2] = sin(dtmp)); |
353 |
break; |
354 |
case 'y': |
355 |
checkarg(3,"f"); |
356 |
357 |
m4[0][0] = m4[2][2] = cos(dtmp); |
358 |
m4[0][2] = -(m4[2][0] = sin(dtmp)); |
359 |
break; |
360 |
case 'z': |
361 |
checkarg(3,"f"); |
362 |
363 |
m4[0][0] = m4[1][1] = cos(dtmp); |
364 |
m4[1][0] = -(m4[0][1] = sin(dtmp)); |
365 |
break; |
366 |
default: |
367 |
goto done; |
368 |
369 |
break; |
370 |
371 |
case 's': /* scale */ |
372 |
checkarg(2,"f"); |
373 |
dtmp = atof(av[i+1]); |
374 |
if (dtmp == 0.0) goto done; |
375 |
i++; |
376 |
xfsca *= |
377 |
m4[0][0] = |
378 |
m4[1][1] = |
379 |
m4[2][2] = dtmp; |
380 |
break; |
381 |
382 |
case 'm': /* mirror */ |
383 |
384 |
case 'x': |
385 |
checkarg(3,""); |
386 |
xfsca *= |
387 |
m4[0][0] = -1.0; |
388 |
break; |
389 |
case 'y': |
390 |
checkarg(3,""); |
391 |
xfsca *= |
392 |
m4[1][1] = -1.0; |
393 |
break; |
394 |
case 'z': |
395 |
checkarg(3,""); |
396 |
xfsca *= |
397 |
m4[2][2] = -1.0; |
398 |
break; |
399 |
default: |
400 |
goto done; |
401 |
402 |
break; |
403 |
404 |
case 'i': /* iterate */ |
405 |
checkarg(2,"i"); |
406 |
while (icnt-- > 0) { |
407 |
multmat4(ret->xfm, ret->xfm, xfmat); |
408 |
ret->sca *= xfsca; |
409 |
410 |
icnt = atoi(av[++i]); |
411 |
setident4(xfmat); |
412 |
xfsca = 1.0; |
413 |
continue; |
414 |
415 |
default: |
416 |
goto done; |
417 |
418 |
419 |
multmat4(xfmat, xfmat, m4); |
420 |
421 |
done: |
422 |
423 |
424 |
425 |
426 |
return(i); |
427 |
