--- ray/src/cv/mgflib/xf.c 1994/06/25 16:33:19 1.4 +++ ray/src/cv/mgflib/xf.c 1997/12/15 09:41:37 1.13 @@ -1,4 +1,4 @@ -/* Copyright (c) 1994 Regents of the University of California */ +/* Copyright (c) 1995 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -10,6 +10,7 @@ static char SCCSid[] = "$SunId$ LBL"; #include #include +#include #include #include "parser.h" @@ -21,81 +22,187 @@ MAT4 m4ident = MAT4IDENT; static MAT4 m4tmp; /* for efficiency */ -int xf_argc; /* total # transform args. */ -char **xf_argv; /* transform arguments */ -XF_SPEC *xf_context; /* current context */ +XF_SPEC *xf_context; /* current context */ +char **xf_argend; /* end of transform argument list */ +static char **xf_argbeg; /* beginning of transform argument list */ -static int xf_maxarg; /* # allocated arguments */ - int xf_handler(ac, av) /* handle xf entity */ int ac; char **av; { -#define randshift(x,n) ((long)(x) << shifttab[(n)&63]) - static char shifttab[64] = { 15, 5, 11, 5, 6, 3, - 9, 15, 13, 2, 13, 5, 2, 12, 14, 11, - 11, 12, 12, 3, 2, 11, 8, 12, 1, 12, - 5, 4, 15, 9, 14, 5, 13, 14, 2, 10, - 10, 14, 12, 3, 5, 5, 14, 6, 12, 11, - 13, 9, 12, 8, 1, 6, 5, 12, 7, 13, - 15, 8, 9, 2, 6, 11, 9, 11 }; - register int i; register XF_SPEC *spec; - XF thisxf; + register int n; + int rv; - if (ac == 1) { /* pop top transform */ + if (ac == 1) { /* something with existing transform */ if ((spec = xf_context) == NULL) - return(MG_OK); /* should be error? */ - while (xf_argc > spec->xav0) - free((MEM_PTR)xf_argv[--xf_argc]); - xf_argv[xf_argc] = NULL; - xf_context = spec->prev; - free((MEM_PTR)spec); - return(MG_OK); + return(MG_ECNTXT); + n = -1; + if (spec->xarr != NULL) { /* check for iteration */ + register struct xf_array *ap = spec->xarr; + + (void)xf_aname((struct xf_array *)NULL); + n = ap->ndim; + while (n--) { + if (++ap->aarg[n].i < ap->aarg[n].n) + break; + (void)strcpy(ap->aarg[n].arg, "0"); + ap->aarg[n].i = 0; + } + if (n >= 0) { + if ((rv = mg_fgoto(&ap->spos)) != MG_OK) + return(rv); + sprintf(ap->aarg[n].arg, "%d", ap->aarg[n].i); + (void)xf_aname(ap); + } + } + if (n < 0) { /* pop transform */ + xf_context = spec->prev; + free_xf(spec); + return(MG_OK); + } + } else { /* else allocate transform */ + if ((spec = new_xf(ac-1, av+1)) == NULL) + return(MG_EMEM); + if (spec->xarr != NULL) + (void)xf_aname(spec->xarr); + spec->prev = xf_context; /* push onto stack */ + xf_context = spec; } /* translate new specification */ - if (xf(&thisxf, ac-1, av+1) != ac-1) + n = xf_ac(spec); + n -= xf_ac(spec->prev); /* incremental comp. is more eff. */ + if (xf(&spec->xf, n, xf_av(spec)) != n) return(MG_ETYPE); - /* allocate space for new transform */ - spec = (XF_SPEC *)malloc(sizeof(XF_SPEC)); + /* check for vertex reversal */ + if ((spec->rev = (spec->xf.sca < 0.))) + spec->xf.sca = -spec->xf.sca; + /* compute total transformation */ + if (spec->prev != NULL) { + multmat4(spec->xf.xfm, spec->xf.xfm, spec->prev->xf.xfm); + spec->xf.sca *= spec->prev->xf.sca; + spec->rev ^= spec->prev->rev; + } + spec->xid = comp_xfid(spec->xf.xfm); /* compute unique ID */ + return(MG_OK); +} + + +XF_SPEC * +new_xf(ac, av) /* allocate new transform structure */ +int ac; +char **av; +{ + register XF_SPEC *spec; + register int i; + char *cp; + int n, ndim; + + ndim = 0; + n = 0; /* compute space req'd by arguments */ + for (i = 0; i < ac; i++) + if (!strcmp(av[i], "-a")) { + ndim++; + i++; + } else + n += strlen(av[i]) + 1; + if (ndim > XF_MAXDIM) + return(NULL); + spec = (XF_SPEC *)malloc(sizeof(XF_SPEC) + n); if (spec == NULL) - return(MG_EMEM); - spec->xav0 = xf_argc; - spec->xac = ac-1; + return(NULL); + if (ndim) { + spec->xarr = (struct xf_array *)malloc(sizeof(struct xf_array)); + if (spec->xarr == NULL) + return(NULL); + mg_fgetpos(&spec->xarr->spos); + spec->xarr->ndim = 0; /* incremented below */ + } else + spec->xarr = NULL; + spec->xac = ac + xf_argc; /* and store new xf arguments */ - if (xf_argc+ac > xf_maxarg) { - if (!xf_maxarg) - xf_argv = (char **)malloc( - (xf_maxarg=ac)*sizeof(char *)); - else - xf_argv = (char **)realloc((MEM_PTR)xf_argv, - (xf_maxarg+=ac)*sizeof(char *)); - if (xf_argv == NULL) - return(MG_EMEM); + if (xf_argbeg == NULL || xf_av(spec) < xf_argbeg) { + register char **newav = + (char **)malloc((spec->xac+1)*sizeof(char *)); + if (newav == NULL) + return(NULL); + for (i = xf_argc; i-- > 0; ) + newav[ac+i] = xf_argend[i-xf_context->xac]; + *(xf_argend = newav + spec->xac) = NULL; + if (xf_argbeg != NULL) + free((MEM_PTR)xf_argbeg); + xf_argbeg = newav; } - for (i = 0; i < ac-1; i++) { - xf_argv[xf_argc] = (char *)malloc(strlen(av[i+1])+1); - if (xf_argv[xf_argc] == NULL) - return(MG_EMEM); - strcpy(xf_argv[xf_argc++], av[i+1]); + cp = (char *)(spec + 1); /* use memory allocated above */ + for (i = 0; i < ac; i++) + if (!strcmp(av[i], "-a")) { + xf_av(spec)[i++] = "-i"; + xf_av(spec)[i] = strcpy( + spec->xarr->aarg[spec->xarr->ndim].arg, + "0"); + spec->xarr->aarg[spec->xarr->ndim].i = 0; + spec->xarr->aarg[spec->xarr->ndim++].n = atoi(av[i]); + } else { + xf_av(spec)[i] = strcpy(cp, av[i]); + cp += strlen(av[i]) + 1; + } + return(spec); +} + + +void +free_xf(spec) /* free a transform */ +register XF_SPEC *spec; +{ + if (spec->xarr != NULL) + free((MEM_PTR)spec->xarr); + free((MEM_PTR)spec); +} + + +int +xf_aname(ap) /* put out name for this instance */ +register struct xf_array *ap; +{ + static char oname[10*XF_MAXDIM]; + static char *oav[3] = {mg_ename[MG_E_OBJECT], oname}; + register int i; + register char *cp1, *cp2; + + if (ap == NULL) + return(mg_handle(MG_E_OBJECT, 1, oav)); + cp1 = oname; + *cp1 = 'a'; + for (i = 0; i < ap->ndim; i++) { + for (cp2 = ap->aarg[i].arg; *cp2; ) + *++cp1 = *cp2++; + *++cp1 = '.'; } - xf_argv[xf_argc] = NULL; - /* compute total transformation */ - if (xf_context != NULL) { - multmat4(spec->xf.xfm, xf_context->xf.xfm, thisxf.xfm); - spec->xf.sca = xf_context->xf.sca * thisxf.sca; - } else - spec->xf = thisxf; - spec->xid = 0; /* compute unique transform id */ - for (i = 0; i < sizeof(MAT4)/sizeof(unsigned short); i++) - spec->xid ^= randshift(((unsigned short *)&spec->xf.xfm)[i],i); + *cp1 = '\0'; + return(mg_handle(MG_E_OBJECT, 2, oav)); +} - spec->prev = xf_context; /* push new transform onto stack */ - xf_context = spec; - return(MG_OK); -#undef randshift + +long +comp_xfid(xfm) /* compute unique ID from matrix */ +register MAT4 xfm; +{ + static char shifttab[64] = { 15, 5, 11, 5, 6, 3, + 9, 15, 13, 2, 13, 5, 2, 12, 14, 11, + 11, 12, 12, 3, 2, 11, 8, 12, 1, 12, + 5, 4, 15, 9, 14, 5, 13, 14, 2, 10, + 10, 14, 12, 3, 5, 5, 14, 6, 12, 11, + 13, 9, 12, 8, 1, 6, 5, 12, 7, 13, + 15, 8, 9, 2, 6, 11, 9, 11 }; + register int i; + register long xid; + + xid = 0; /* compute unique transform id */ + for (i = 0; i < sizeof(MAT4)/sizeof(unsigned short); i++) + xid ^= (long)(((unsigned short *)xfm)[i]) << shifttab[i&63]; + return(xid); } @@ -104,16 +211,13 @@ xf_clear() /* clear transform stack */ { register XF_SPEC *spec; - while (xf_argc) - free((MEM_PTR)xf_argv[--xf_argc]); - if (xf_maxarg) { - free((MEM_PTR)xf_argv); - xf_argv = NULL; - xf_maxarg = 0; + if (xf_argbeg != NULL) { + free((MEM_PTR)xf_argbeg); + xf_argbeg = xf_argend = NULL; } while ((spec = xf_context) != NULL) { xf_context = spec->prev; - free((MEM_PTR)spec); + free_xf(spec); } } @@ -123,9 +227,7 @@ xf_xfmpoint(v1, v2) /* transform a point by the curre FVECT v1, v2; { if (xf_context == NULL) { - v1[0] = v2[0]; - v1[1] = v2[1]; - v1[2] = v2[2]; + VCOPY(v1, v2); return; } multp3(v1, v2, xf_context->xf.xfm); @@ -137,9 +239,7 @@ xf_xfmvect(v1, v2) /* transform a vector using curren FVECT v1, v2; { if (xf_context == NULL) { - v1[0] = v2[0]; - v1[1] = v2[1]; - v1[2] = v2[2]; + VCOPY(v1, v2); return; } multv3(v1, v2, xf_context->xf.xfm);
