root/radiance/ray/src/cv/mgflib/xf.c
Revision: 1.4
Committed: Sat Jun 25 16:33:19 1994 UTC (30 years, 10 months ago) by greg
Changes since 1.3: +13 -0 lines
bug fixes and enhancements
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines for 4x4 homogeneous, rigid-body transformations
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <string.h>
14 #include "parser.h"
15
16 #define d2r(a) ((PI/180.)*(a))
17
18 #define checkarg(a,l) if (av[i][a] || badarg(ac-i-1,av+i+1,l)) goto done
19
20 MAT4 m4ident = MAT4IDENT;
21
22 static MAT4 m4tmp; /* for efficiency */
23
24 int xf_argc; /* total # transform args. */
25 char **xf_argv; /* transform arguments */
26 XF_SPEC *xf_context; /* current context */
27
28 static int xf_maxarg; /* # allocated arguments */
29
30
31 int
32 xf_handler(ac, av) /* handle xf entity */
33 int ac;
34 char **av;
35 {
36 #define randshift(x,n) ((long)(x) << shifttab[(n)&63])
37 static char shifttab[64] = { 15, 5, 11, 5, 6, 3,
38 9, 15, 13, 2, 13, 5, 2, 12, 14, 11,
39 11, 12, 12, 3, 2, 11, 8, 12, 1, 12,
40 5, 4, 15, 9, 14, 5, 13, 14, 2, 10,
41 10, 14, 12, 3, 5, 5, 14, 6, 12, 11,
42 13, 9, 12, 8, 1, 6, 5, 12, 7, 13,
43 15, 8, 9, 2, 6, 11, 9, 11 };
44 register int i;
45 register XF_SPEC *spec;
46 XF thisxf;
47
48 if (ac == 1) { /* pop top transform */
49 if ((spec = xf_context) == NULL)
50 return(MG_OK); /* should be error? */
51 while (xf_argc > spec->xav0)
52 free((MEM_PTR)xf_argv[--xf_argc]);
53 xf_argv[xf_argc] = NULL;
54 xf_context = spec->prev;
55 free((MEM_PTR)spec);
56 return(MG_OK);
57 }
58 /* translate new specification */
59 if (xf(&thisxf, ac-1, av+1) != ac-1)
60 return(MG_ETYPE);
61 /* allocate space for new transform */
62 spec = (XF_SPEC *)malloc(sizeof(XF_SPEC));
63 if (spec == NULL)
64 return(MG_EMEM);
65 spec->xav0 = xf_argc;
66 spec->xac = ac-1;
67 /* and store new xf arguments */
68 if (xf_argc+ac > xf_maxarg) {
69 if (!xf_maxarg)
70 xf_argv = (char **)malloc(
71 (xf_maxarg=ac)*sizeof(char *));
72 else
73 xf_argv = (char **)realloc((MEM_PTR)xf_argv,
74 (xf_maxarg+=ac)*sizeof(char *));
75 if (xf_argv == NULL)
76 return(MG_EMEM);
77 }
78 for (i = 0; i < ac-1; i++) {
79 xf_argv[xf_argc] = (char *)malloc(strlen(av[i+1])+1);
80 if (xf_argv[xf_argc] == NULL)
81 return(MG_EMEM);
82 strcpy(xf_argv[xf_argc++], av[i+1]);
83 }
84 xf_argv[xf_argc] = NULL;
85 /* compute total transformation */
86 if (xf_context != NULL) {
87 multmat4(spec->xf.xfm, xf_context->xf.xfm, thisxf.xfm);
88 spec->xf.sca = xf_context->xf.sca * thisxf.sca;
89 } else
90 spec->xf = thisxf;
91 spec->xid = 0; /* compute unique transform id */
92 for (i = 0; i < sizeof(MAT4)/sizeof(unsigned short); i++)
93 spec->xid ^= randshift(((unsigned short *)&spec->xf.xfm)[i],i);
94
95 spec->prev = xf_context; /* push new transform onto stack */
96 xf_context = spec;
97 return(MG_OK);
98 #undef randshift
99 }
100
101
102 void
103 xf_clear() /* clear transform stack */
104 {
105 register XF_SPEC *spec;
106
107 while (xf_argc)
108 free((MEM_PTR)xf_argv[--xf_argc]);
109 if (xf_maxarg) {
110 free((MEM_PTR)xf_argv);
111 xf_argv = NULL;
112 xf_maxarg = 0;
113 }
114 while ((spec = xf_context) != NULL) {
115 xf_context = spec->prev;
116 free((MEM_PTR)spec);
117 }
118 }
119
120
121 void
122 xf_xfmpoint(v1, v2) /* transform a point by the current matrix */
123 FVECT v1, v2;
124 {
125 if (xf_context == NULL) {
126 v1[0] = v2[0];
127 v1[1] = v2[1];
128 v1[2] = v2[2];
129 return;
130 }
131 multp3(v1, v2, xf_context->xf.xfm);
132 }
133
134
135 void
136 xf_xfmvect(v1, v2) /* transform a vector using current matrix */
137 FVECT v1, v2;
138 {
139 if (xf_context == NULL) {
140 v1[0] = v2[0];
141 v1[1] = v2[1];
142 v1[2] = v2[2];
143 return;
144 }
145 multv3(v1, v2, xf_context->xf.xfm);
146 }
147
148
149 void
150 xf_rotvect(v1, v2) /* rotate a vector using current matrix */
151 FVECT v1, v2;
152 {
153 xf_xfmvect(v1, v2);
154 if (xf_context == NULL)
155 return;
156 v1[0] /= xf_context->xf.sca;
157 v1[1] /= xf_context->xf.sca;
158 v1[2] /= xf_context->xf.sca;
159 }
160
161
162 double
163 xf_scale(d) /* scale a number by the current transform */
164 double d;
165 {
166 if (xf_context == NULL)
167 return(d);
168 return(d*xf_context->xf.sca);
169 }
170
171
172 void
173 multmat4(m4a, m4b, m4c) /* multiply m4b X m4c and put into m4a */
174 MAT4 m4a;
175 register MAT4 m4b, m4c;
176 {
177 register int i, j;
178
179 for (i = 4; i--; )
180 for (j = 4; j--; )
181 m4tmp[i][j] = m4b[i][0]*m4c[0][j] +
182 m4b[i][1]*m4c[1][j] +
183 m4b[i][2]*m4c[2][j] +
184 m4b[i][3]*m4c[3][j];
185
186 copymat4(m4a, m4tmp);
187 }
188
189
190 void
191 multv3(v3a, v3b, m4) /* transform vector v3b by m4 and put into v3a */
192 FVECT v3a;
193 register FVECT v3b;
194 register MAT4 m4;
195 {
196 m4tmp[0][0] = v3b[0]*m4[0][0] + v3b[1]*m4[1][0] + v3b[2]*m4[2][0];
197 m4tmp[0][1] = v3b[0]*m4[0][1] + v3b[1]*m4[1][1] + v3b[2]*m4[2][1];
198 m4tmp[0][2] = v3b[0]*m4[0][2] + v3b[1]*m4[1][2] + v3b[2]*m4[2][2];
199
200 v3a[0] = m4tmp[0][0];
201 v3a[1] = m4tmp[0][1];
202 v3a[2] = m4tmp[0][2];
203 }
204
205
206 void
207 multp3(p3a, p3b, m4) /* transform p3b by m4 and put into p3a */
208 register FVECT p3a;
209 FVECT p3b;
210 register MAT4 m4;
211 {
212 multv3(p3a, p3b, m4); /* transform as vector */
213 p3a[0] += m4[3][0]; /* translate */
214 p3a[1] += m4[3][1];
215 p3a[2] += m4[3][2];
216 }
217
218
219 int
220 xf(ret, ac, av) /* get transform specification */
221 register XF *ret;
222 int ac;
223 char **av;
224 {
225 MAT4 xfmat, m4;
226 double xfsca, dtmp;
227 int i, icnt;
228
229 setident4(ret->xfm);
230 ret->sca = 1.0;
231
232 icnt = 1;
233 setident4(xfmat);
234 xfsca = 1.0;
235
236 for (i = 0; i < ac && av[i][0] == '-'; i++) {
237
238 setident4(m4);
239
240 switch (av[i][1]) {
241
242 case 't': /* translate */
243 checkarg(2,"fff");
244 m4[3][0] = atof(av[++i]);
245 m4[3][1] = atof(av[++i]);
246 m4[3][2] = atof(av[++i]);
247 break;
248
249 case 'r': /* rotate */
250 switch (av[i][2]) {
251 case 'x':
252 checkarg(3,"f");
253 dtmp = d2r(atof(av[++i]));
254 m4[1][1] = m4[2][2] = cos(dtmp);
255 m4[2][1] = -(m4[1][2] = sin(dtmp));
256 break;
257 case 'y':
258 checkarg(3,"f");
259 dtmp = d2r(atof(av[++i]));
260 m4[0][0] = m4[2][2] = cos(dtmp);
261 m4[0][2] = -(m4[2][0] = sin(dtmp));
262 break;
263 case 'z':
264 checkarg(3,"f");
265 dtmp = d2r(atof(av[++i]));
266 m4[0][0] = m4[1][1] = cos(dtmp);
267 m4[1][0] = -(m4[0][1] = sin(dtmp));
268 break;
269 default:
270 goto done;
271 }
272 break;
273
274 case 's': /* scale */
275 checkarg(2,"f");
276 dtmp = atof(av[i+1]);
277 if (dtmp == 0.0) goto done;
278 i++;
279 xfsca *=
280 m4[0][0] =
281 m4[1][1] =
282 m4[2][2] = dtmp;
283 break;
284
285 case 'm': /* mirror */
286 switch (av[i][2]) {
287 case 'x':
288 checkarg(3,"");
289 xfsca *=
290 m4[0][0] = -1.0;
291 break;
292 case 'y':
293 checkarg(3,"");
294 xfsca *=
295 m4[1][1] = -1.0;
296 break;
297 case 'z':
298 checkarg(3,"");
299 xfsca *=
300 m4[2][2] = -1.0;
301 break;
302 default:
303 goto done;
304 }
305 break;
306
307 case 'i': /* iterate */
308 checkarg(2,"i");
309 while (icnt-- > 0) {
310 multmat4(ret->xfm, ret->xfm, xfmat);
311 ret->sca *= xfsca;
312 }
313 icnt = atoi(av[++i]);
314 setident4(xfmat);
315 xfsca = 1.0;
316 continue;
317
318 default:
319 goto done;
320
321 }
322 multmat4(xfmat, xfmat, m4);
323 }
324 done:
325 while (icnt-- > 0) {
326 multmat4(ret->xfm, ret->xfm, xfmat);
327 ret->sca *= xfsca;
328 }
329 return(i);
330 }
