--- ray/src/cv/mgflib/xf.c 1995/04/18 16:52:28 1.8 +++ ray/src/cv/mgflib/xf.c 1995/11/22 16:09:23 1.10 @@ -21,12 +21,10 @@ MAT4 m4ident = MAT4IDENT; static MAT4 m4tmp; /* for efficiency */ -int xf_argc; /* total # transform args. */ -char **xf_argv; /* transform arguments */ -XF_SPEC *xf_context; /* current context */ +XF_SPEC *xf_context; /* current context */ +char **xf_argend; /* end of transform argument list */ +static char **xf_argbeg; /* beginning of transform argument list */ -static int xf_maxarg; /* # allocated arguments */ - static XF_SPEC *new_xf(); static long comp_xfid(); static int put_oname(); @@ -65,7 +63,6 @@ char **av; free((MEM_PTR)ap); } if (n < 0) { /* pop transform */ - xf_argv[xf_argc=spec->xav0] = NULL; xf_context = spec->prev; free((MEM_PTR)spec); return(MG_OK); @@ -77,7 +74,10 @@ char **av; xf_context = spec; } /* translate new specification */ - if (xf(&spec->xf, spec->xac, &xf_argv[spec->xav0]) != spec->xac) + n = xf_ac(spec); + if (spec->prev != NULL) /* incremental comp. is more eff. */ + n -= xf_ac(spec->prev); + if (xf(&spec->xf, n, xf_av(spec)) != n) return(MG_ETYPE); /* check for vertex reversal */ if ((spec->rev = (spec->xf.sca < 0.))) @@ -124,33 +124,33 @@ char **av; spec->xarr->ndim = 0; /* incremented below */ } else spec->xarr = NULL; - spec->xav0 = xf_argc; - spec->xac = ac; + spec->xac = ac + xf_argc; /* and store new xf arguments */ - if (xf_argc+ac+1 > xf_maxarg) { - if (!xf_maxarg) - xf_argv = (char **)malloc( - (xf_maxarg=ac+1)*sizeof(char *)); - else - xf_argv = (char **)realloc((MEM_PTR)xf_argv, - (xf_maxarg=xf_argc+ac+1)*sizeof(char *)); - if (xf_argv == NULL) + if (xf_argbeg == NULL || xf_av(spec) < xf_argbeg) { + register char **newav = + (char **)malloc((spec->xac+1)*sizeof(char *)); + if (newav == NULL) return(NULL); + for (i = xf_argc; i-- > 0; ) + newav[ac+i] = xf_argend[i-xf_context->xac]; + *(xf_argend = newav + spec->xac) = NULL; + if (xf_argbeg != NULL) + free((MEM_PTR)xf_argbeg); + xf_argbeg = newav; } cp = (char *)(spec + 1); /* use memory allocated above */ for (i = 0; i < ac; i++) if (!strcmp(av[i], "-a")) { - xf_argv[xf_argc++] = "-i"; - xf_argv[xf_argc++] = strcpy( + xf_av(spec)[i++] = "-i"; + xf_av(spec)[i] = strcpy( spec->xarr->aarg[spec->xarr->ndim].arg, "0"); spec->xarr->aarg[spec->xarr->ndim].i = 0; - spec->xarr->aarg[spec->xarr->ndim++].n = atoi(av[++i]); + spec->xarr->aarg[spec->xarr->ndim++].n = atoi(av[i]); } else { - xf_argv[xf_argc++] = strcpy(cp, av[i]); + xf_av(spec)[i] = strcpy(cp, av[i]); cp += strlen(av[i]) + 1; } - xf_argv[xf_argc] = NULL; if (spec->xarr != NULL) (void)put_oname(spec->xarr); return(spec); @@ -206,12 +206,10 @@ xf_clear() /* clear transform stack */ { register XF_SPEC *spec; - if (xf_maxarg) { - free((MEM_PTR)xf_argv); - xf_argv = NULL; - xf_maxarg = 0; + if (xf_argbeg != NULL) { + free((MEM_PTR)xf_argbeg); + xf_argbeg = xf_argend = NULL; } - xf_argc = 0; while ((spec = xf_context) != NULL) { xf_context = spec->prev; if (spec->xarr != NULL) @@ -226,9 +224,7 @@ xf_xfmpoint(v1, v2) /* transform a point by the curre FVECT v1, v2; { if (xf_context == NULL) { - v1[0] = v2[0]; - v1[1] = v2[1]; - v1[2] = v2[2]; + VCOPY(v1, v2); return; } multp3(v1, v2, xf_context->xf.xfm); @@ -240,9 +236,7 @@ xf_xfmvect(v1, v2) /* transform a vector using curren FVECT v1, v2; { if (xf_context == NULL) { - v1[0] = v2[0]; - v1[1] = v2[1]; - v1[2] = v2[2]; + VCOPY(v1, v2); return; } multv3(v1, v2, xf_context->xf.xfm);
