--- ray/src/cv/mgflib/xf.c 1994/06/24 15:32:40 1.3 +++ ray/src/cv/mgflib/xf.c 1994/07/11 14:47:12 1.6 @@ -27,79 +27,193 @@ XF_SPEC *xf_context; /* current context */ static int xf_maxarg; /* # allocated arguments */ +static XF_SPEC *new_xf(); +static long comp_xfid(); +static int put_oname(); + int xf_handler(ac, av) /* handle xf entity */ int ac; char **av; { - register int i; register XF_SPEC *spec; + register int n; + int rv; XF thisxf; - if (ac == 1) { /* pop top transform */ + if (ac == 1) { /* something with existing transform */ if ((spec = xf_context) == NULL) return(MG_OK); /* should be error? */ - while (xf_argc > spec->xav0) - free((MEM_PTR)xf_argv[--xf_argc]); - xf_argv[xf_argc] = NULL; - xf_context = spec->prev; - free((MEM_PTR)spec); - return(MG_OK); + n = -1; + if (spec->xarr != NULL) { /* check for iteration */ + register struct xf_array *ap = spec->xarr; + + (void)put_oname((struct xf_array *)NULL); + n = ap->ndim; + while (n--) { + if (++ap->aarg[n].i < ap->aarg[n].n) + break; + (void)strcpy(ap->aarg[n].arg, "0"); + ap->aarg[n].i = 0; + } + if (n >= 0) { + if ((rv = mg_fgoto(&ap->spos)) != MG_OK) + return(rv); + sprintf(ap->aarg[n].arg, "%d", ap->aarg[n].i); + (void)put_oname(ap); + } else + free((MEM_PTR)ap); + } + if (n < 0) { /* pop transform */ + xf_argv[xf_argc=spec->xav0] = NULL; + xf_context = spec->prev; + free((MEM_PTR)spec); + return(MG_OK); + } + } else { /* else allocate transform */ + if ((spec = new_xf(ac-1, av+1)) == NULL) + return(MG_EMEM); + spec->prev = xf_context; /* push onto stack */ + xf_context = spec; } /* translate new specification */ - if (xf(&thisxf, ac-1, av+1) != ac-1) + if (xf(&thisxf, spec->xac, &xf_argv[spec->xav0]) != spec->xac) return(MG_ETYPE); - /* allocate space for new transform */ - spec = (XF_SPEC *)malloc(sizeof(XF_SPEC)); + /* compute total transformation */ + if (spec->prev != NULL) { + multmat4(spec->xf.xfm, thisxf.xfm, spec->prev->xf.xfm); + spec->xf.sca = thisxf.sca * spec->prev->xf.sca; + } else + spec->xf = thisxf; + spec->xid = comp_xfid(spec->xf.xfm); /* compute unique ID */ + return(MG_OK); +} + + +static XF_SPEC * +new_xf(ac, av) /* allocate new transform structure */ +int ac; +char **av; +{ + register XF_SPEC *spec; + register int i; + char *cp; + int n, ndim; + + ndim = 0; + n = 0; /* compute space req'd by arguments */ + for (i = 0; i < ac; i++) + if (!strcmp(av[i], "-a")) { + ndim++; + i++; + } else + n += strlen(av[i]) + 1; + if (ndim > XF_MAXDIM) + return(NULL); + spec = (XF_SPEC *)malloc(sizeof(XF_SPEC) + n); if (spec == NULL) - return(MG_EMEM); + return(NULL); + if (ndim) { + spec->xarr = (struct xf_array *)malloc(sizeof(struct xf_array)); + if (spec->xarr == NULL) + return(NULL); + mg_fgetpos(&spec->xarr->spos); + spec->xarr->ndim = 0; /* incremented below */ + } else + spec->xarr = NULL; spec->xav0 = xf_argc; - spec->xac = ac-1; + spec->xac = ac; /* and store new xf arguments */ - if (xf_argc+ac > xf_maxarg) { + if (xf_argc+ac+1 > xf_maxarg) { if (!xf_maxarg) xf_argv = (char **)malloc( - (xf_maxarg=ac)*sizeof(char *)); + (xf_maxarg=ac+1)*sizeof(char *)); else xf_argv = (char **)realloc((MEM_PTR)xf_argv, - (xf_maxarg+=ac)*sizeof(char *)); + (xf_maxarg=xf_argc+ac+1)*sizeof(char *)); if (xf_argv == NULL) - return(MG_EMEM); + return(NULL); } - for (i = 0; i < ac-1; i++) { - xf_argv[xf_argc] = (char *)malloc(strlen(av[i+1])+1); - if (xf_argv[xf_argc] == NULL) - return(MG_EMEM); - strcpy(xf_argv[xf_argc++], av[i+1]); - } + cp = (char *)(spec + 1); /* use memory allocated above */ + for (i = 0; i < ac; i++) + if (!strcmp(av[i], "-a")) { + xf_argv[xf_argc++] = "-i"; + xf_argv[xf_argc++] = strcpy( + spec->xarr->aarg[spec->xarr->ndim].arg, + "0"); + spec->xarr->aarg[spec->xarr->ndim].i = 0; + spec->xarr->aarg[spec->xarr->ndim++].n = atoi(av[++i]); + } else { + xf_argv[xf_argc++] = strcpy(cp, av[i]); + cp += strlen(av[i]) + 1; + } xf_argv[xf_argc] = NULL; - /* compute total transformation */ - if (xf_context != NULL) { - multmat4(spec->xf.xfm, xf_context->xf.xfm, thisxf.xfm); - spec->xf.sca = xf_context->xf.sca * thisxf.sca; - } else - spec->xf = thisxf; - spec->prev = xf_context; /* push new transform onto stack */ - xf_context = spec; - return(MG_OK); + if (spec->xarr != NULL) + (void)put_oname(spec->xarr); + return(spec); } +static int +put_oname(ap) /* put out name for this instance */ +register struct xf_array *ap; +{ + static char oname[10*XF_MAXDIM]; + static char *oav[3] = {mg_ename[MG_E_OBJECT], oname}; + register int i; + register char *cp1, *cp2; + + if (ap == NULL) + return(mg_handle(MG_E_OBJECT, 1, oav)); + cp1 = oname; + *cp1 = 'a'; + for (i = 0; i < ap->ndim; i++) { + for (cp2 = ap->aarg[i].arg; *cp2; ) + *++cp1 = *cp2++; + *++cp1 = '.'; + } + *cp1 = '\0'; + return(mg_handle(MG_E_OBJECT, 2, oav)); +} + + +static long +comp_xfid(xfm) /* compute unique ID from matrix */ +register MAT4 xfm; +{ + static char shifttab[64] = { 15, 5, 11, 5, 6, 3, + 9, 15, 13, 2, 13, 5, 2, 12, 14, 11, + 11, 12, 12, 3, 2, 11, 8, 12, 1, 12, + 5, 4, 15, 9, 14, 5, 13, 14, 2, 10, + 10, 14, 12, 3, 5, 5, 14, 6, 12, 11, + 13, 9, 12, 8, 1, 6, 5, 12, 7, 13, + 15, 8, 9, 2, 6, 11, 9, 11 }; + register int i; + register long xid; + + xid = 0; /* compute unique transform id */ + for (i = 0; i < sizeof(MAT4)/sizeof(unsigned short); i++) + xid ^= (long)(((unsigned short *)xfm)[i]) << shifttab[i&63]; + return(xid); +} + + void xf_clear() /* clear transform stack */ { register XF_SPEC *spec; - while (xf_argc) - free((MEM_PTR)xf_argv[--xf_argc]); if (xf_maxarg) { free((MEM_PTR)xf_argv); xf_argv = NULL; xf_maxarg = 0; } + xf_argc = 0; while ((spec = xf_context) != NULL) { xf_context = spec->prev; + if (spec->xarr != NULL) + free((MEM_PTR)spec->xarr); free((MEM_PTR)spec); } }
