--- ray/src/cv/mgflib/xf.c 1994/07/11 14:47:12 1.6 +++ ray/src/cv/mgflib/xf.c 1997/12/15 09:41:37 1.13 @@ -1,4 +1,4 @@ -/* Copyright (c) 1994 Regents of the University of California */ +/* Copyright (c) 1995 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -10,6 +10,7 @@ static char SCCSid[] = "$SunId$ LBL"; #include #include +#include #include #include "parser.h" @@ -21,17 +22,11 @@ MAT4 m4ident = MAT4IDENT; static MAT4 m4tmp; /* for efficiency */ -int xf_argc; /* total # transform args. */ -char **xf_argv; /* transform arguments */ -XF_SPEC *xf_context; /* current context */ +XF_SPEC *xf_context; /* current context */ +char **xf_argend; /* end of transform argument list */ +static char **xf_argbeg; /* beginning of transform argument list */ -static int xf_maxarg; /* # allocated arguments */ -static XF_SPEC *new_xf(); -static long comp_xfid(); -static int put_oname(); - - int xf_handler(ac, av) /* handle xf entity */ int ac; @@ -40,16 +35,15 @@ char **av; register XF_SPEC *spec; register int n; int rv; - XF thisxf; if (ac == 1) { /* something with existing transform */ if ((spec = xf_context) == NULL) - return(MG_OK); /* should be error? */ + return(MG_ECNTXT); n = -1; if (spec->xarr != NULL) { /* check for iteration */ register struct xf_array *ap = spec->xarr; - (void)put_oname((struct xf_array *)NULL); + (void)xf_aname((struct xf_array *)NULL); n = ap->ndim; while (n--) { if (++ap->aarg[n].i < ap->aarg[n].n) @@ -61,37 +55,42 @@ char **av; if ((rv = mg_fgoto(&ap->spos)) != MG_OK) return(rv); sprintf(ap->aarg[n].arg, "%d", ap->aarg[n].i); - (void)put_oname(ap); - } else - free((MEM_PTR)ap); + (void)xf_aname(ap); + } } if (n < 0) { /* pop transform */ - xf_argv[xf_argc=spec->xav0] = NULL; xf_context = spec->prev; - free((MEM_PTR)spec); + free_xf(spec); return(MG_OK); } } else { /* else allocate transform */ if ((spec = new_xf(ac-1, av+1)) == NULL) return(MG_EMEM); + if (spec->xarr != NULL) + (void)xf_aname(spec->xarr); spec->prev = xf_context; /* push onto stack */ xf_context = spec; } /* translate new specification */ - if (xf(&thisxf, spec->xac, &xf_argv[spec->xav0]) != spec->xac) + n = xf_ac(spec); + n -= xf_ac(spec->prev); /* incremental comp. is more eff. */ + if (xf(&spec->xf, n, xf_av(spec)) != n) return(MG_ETYPE); + /* check for vertex reversal */ + if ((spec->rev = (spec->xf.sca < 0.))) + spec->xf.sca = -spec->xf.sca; /* compute total transformation */ if (spec->prev != NULL) { - multmat4(spec->xf.xfm, thisxf.xfm, spec->prev->xf.xfm); - spec->xf.sca = thisxf.sca * spec->prev->xf.sca; - } else - spec->xf = thisxf; + multmat4(spec->xf.xfm, spec->xf.xfm, spec->prev->xf.xfm); + spec->xf.sca *= spec->prev->xf.sca; + spec->rev ^= spec->prev->rev; + } spec->xid = comp_xfid(spec->xf.xfm); /* compute unique ID */ return(MG_OK); } -static XF_SPEC * +XF_SPEC * new_xf(ac, av) /* allocate new transform structure */ int ac; char **av; @@ -122,41 +121,49 @@ char **av; spec->xarr->ndim = 0; /* incremented below */ } else spec->xarr = NULL; - spec->xav0 = xf_argc; - spec->xac = ac; + spec->xac = ac + xf_argc; /* and store new xf arguments */ - if (xf_argc+ac+1 > xf_maxarg) { - if (!xf_maxarg) - xf_argv = (char **)malloc( - (xf_maxarg=ac+1)*sizeof(char *)); - else - xf_argv = (char **)realloc((MEM_PTR)xf_argv, - (xf_maxarg=xf_argc+ac+1)*sizeof(char *)); - if (xf_argv == NULL) + if (xf_argbeg == NULL || xf_av(spec) < xf_argbeg) { + register char **newav = + (char **)malloc((spec->xac+1)*sizeof(char *)); + if (newav == NULL) return(NULL); + for (i = xf_argc; i-- > 0; ) + newav[ac+i] = xf_argend[i-xf_context->xac]; + *(xf_argend = newav + spec->xac) = NULL; + if (xf_argbeg != NULL) + free((MEM_PTR)xf_argbeg); + xf_argbeg = newav; } cp = (char *)(spec + 1); /* use memory allocated above */ for (i = 0; i < ac; i++) if (!strcmp(av[i], "-a")) { - xf_argv[xf_argc++] = "-i"; - xf_argv[xf_argc++] = strcpy( + xf_av(spec)[i++] = "-i"; + xf_av(spec)[i] = strcpy( spec->xarr->aarg[spec->xarr->ndim].arg, "0"); spec->xarr->aarg[spec->xarr->ndim].i = 0; - spec->xarr->aarg[spec->xarr->ndim++].n = atoi(av[++i]); + spec->xarr->aarg[spec->xarr->ndim++].n = atoi(av[i]); } else { - xf_argv[xf_argc++] = strcpy(cp, av[i]); + xf_av(spec)[i] = strcpy(cp, av[i]); cp += strlen(av[i]) + 1; } - xf_argv[xf_argc] = NULL; - if (spec->xarr != NULL) - (void)put_oname(spec->xarr); return(spec); } -static int -put_oname(ap) /* put out name for this instance */ +void +free_xf(spec) /* free a transform */ +register XF_SPEC *spec; +{ + if (spec->xarr != NULL) + free((MEM_PTR)spec->xarr); + free((MEM_PTR)spec); +} + + +int +xf_aname(ap) /* put out name for this instance */ register struct xf_array *ap; { static char oname[10*XF_MAXDIM]; @@ -178,7 +185,7 @@ register struct xf_array *ap; } -static long +long comp_xfid(xfm) /* compute unique ID from matrix */ register MAT4 xfm; { @@ -204,17 +211,13 @@ xf_clear() /* clear transform stack */ { register XF_SPEC *spec; - if (xf_maxarg) { - free((MEM_PTR)xf_argv); - xf_argv = NULL; - xf_maxarg = 0; + if (xf_argbeg != NULL) { + free((MEM_PTR)xf_argbeg); + xf_argbeg = xf_argend = NULL; } - xf_argc = 0; while ((spec = xf_context) != NULL) { xf_context = spec->prev; - if (spec->xarr != NULL) - free((MEM_PTR)spec->xarr); - free((MEM_PTR)spec); + free_xf(spec); } } @@ -224,9 +227,7 @@ xf_xfmpoint(v1, v2) /* transform a point by the curre FVECT v1, v2; { if (xf_context == NULL) { - v1[0] = v2[0]; - v1[1] = v2[1]; - v1[2] = v2[2]; + VCOPY(v1, v2); return; } multp3(v1, v2, xf_context->xf.xfm); @@ -238,9 +239,7 @@ xf_xfmvect(v1, v2) /* transform a vector using curren FVECT v1, v2; { if (xf_context == NULL) { - v1[0] = v2[0]; - v1[1] = v2[1]; - v1[2] = v2[2]; + VCOPY(v1, v2); return; } multv3(v1, v2, xf_context->xf.xfm);
