root/radiance/ray/src/cv/mgflib/xf.c
Revision 1.16
Tue Feb 22 15:58:42 2011 UTC (13 years, 2 months ago) by greg
FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
Fri Jan 14 05:46:12 2011 UTC (13 years, 4 months ago) by greg
Changes since 1.14: +5 -5 lines
Diff to previous 1.14 , to selected 1.3
Eliminated unnecessary MEM_PTR
Fri Feb 28 20:11:30 2003 UTC (21 years, 2 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0
Changes since 1.13: +2 -5 lines
Diff to previous 1.13 , to selected 1.3
Updates for 3.5 release
Mon Dec 15 09:41:37 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 1.12 , to selected 1.3
added stdlib.h for better reliability on some systems
Wed Nov 29 19:55:45 1995 UTC (28 years, 5 months ago) by greg
Changes since 1.11: +23 -21 lines
Diff to previous 1.11 , to selected 1.3
made some of xf.c's internal (static) routines global
Wed Nov 29 16:45:10 1995 UTC (28 years, 5 months ago) by greg
Diff to previous 1.10 , to selected 1.3
added error for unmatched xf or o context close
Wed Nov 22 16:09:23 1995 UTC (28 years, 6 months ago) by greg
Changes since 1.9: +2 -6 lines
Diff to previous 1.9 , to selected 1.3
applied VCOPY macro
Wed May 10 22:20:57 1995 UTC (29 years ago) by greg
Changes since 1.8: +25 -27 lines
Diff to previous 1.8 , to selected 1.3
fixed bug in order of global transform arguments
Tue Apr 18 16:52:28 1995 UTC (29 years, 1 month ago) by greg
Changes since 1.7: +6 -8 lines
Diff to previous 1.7 , to selected 1.3
minor optimization
Thu Jul 21 14:56:39 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.6: +4 -0 lines
Diff to previous 1.6 , to selected 1.3
added rev field to XF_SPEC structure to indicate vertex reversal
Mon Jul 11 14:47:12 1994 UTC (29 years, 10 months ago) by greg
Diff to previous 1.5 , to selected 1.3
fixed order of transformation accumulation (serious bug!)
Wed Jun 29 16:15:25 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.4: +147 -46 lines
Diff to previous 1.4 , to selected 1.3
made the -a (array) option work within files as well
Sat Jun 25 16:33:19 1994 UTC (29 years, 11 months ago) by greg
Changes since 1.3: +13 -0 lines
Diff to previous 1.3
bug fixes and enhancements
Revision 1.3 - (view) (download) (annotate) - [selected]
Fri Jun 24 15:32:40 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 1.2
fix in prototype declaration
Wed Jun 22 15:33:50 1994 UTC (29 years, 11 months ago) by greg
Changes since 1.1: +19 -0 lines
Diff to previous 1.1 , to selected 1.3
various enhancements and fixes
Tue Jun 21 14:45:48 1994 UTC (29 years, 11 months ago) by greg
Diff to selected 1.3
