root/radiance/ray/src/cv/mgflib/words.c
Revision: 1.5
Committed: Tue Feb 22 15:58:42 2011 UTC (14 years, 2 months ago) by greg
State: FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
2 static const char RCSid[] = "$Id: words.c,v 1.4 2003/03/11 17:08:55 greg Exp $";
5 * Routines for recognizing and moving about words in strings.
6 */
7
8 #include <string.h>
9 #include <ctype.h>
10
11
12 char *
13 iskip(s) /* skip integer in string */
14 register char *s;
15 {
16 while (isspace(*s))
17 s++;
18 if (*s == '-' || *s == '+')
19 s++;
20 if (!isdigit(*s))
21 return(NULL);
22 do
23 s++;
24 while (isdigit(*s));
25 return(s);
26 }
27
28
29 char *
30 fskip(s) /* skip float in string */
31 register char *s;
32 {
33 register char *cp;
34
35 while (isspace(*s))
36 s++;
37 if (*s == '-' || *s == '+')
38 s++;
39 cp = s;
40 while (isdigit(*cp))
41 cp++;
42 if (*cp == '.') {
43 cp++; s++;
44 while (isdigit(*cp))
45 cp++;
46 }
47 if (cp == s)
48 return(NULL);
49 if (*cp == 'e' || *cp == 'E')
50 return(iskip(cp+1));
51 return(cp);
52 }
53
54
55 int
56 isint(s) /* check integer format */
57 char *s;
58 {
59 register char *cp;
60
61 cp = iskip(s);
62 return(cp != NULL && *cp == '\0');
63 }
64
65
66 int
67 isintd(s, ds) /* check integer format with delimiter set */
68 char *s, *ds;
69 {
70 register char *cp;
71
72 cp = iskip(s);
73 return(cp != NULL && strchr(ds, *cp) != NULL);
74 }
75
76
77 int
78 isflt(s) /* check float format */
79 char *s;
80 {
81 register char *cp;
82
83 cp = fskip(s);
84 return(cp != NULL && *cp == '\0');
85 }
86
87
88 int
89 isfltd(s, ds) /* check integer format with delimiter set */
90 char *s, *ds;
91 {
92 register char *cp;
93
94 cp = fskip(s);
95 return(cp != NULL && strchr(ds, *cp) != NULL);
96 }
97
98
99 int
100 isname(s) /* check for legal identifier name */
101 register char *s;
102 {
103 while (*s == '_') /* skip leading underscores */
104 s++;
105 if (!isascii(*s) || !isalpha(*s)) /* start with a letter */
106 return(0);
107 while (isascii(*++s) && isgraph(*s)) /* all visible characters */
108 ;
109 return(*s == '\0'); /* ending in nul */
110 }
