root/radiance/ray/src/cv/mgflib/vect.c
Revision: 1.4
Committed: Tue Feb 22 15:58:42 2011 UTC (14 years, 2 months ago) by greg
State: FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
2 static const char RCSid[] = "$Id: vect.c,v 1.3 2003/02/28 20:11:30 greg Exp $";
4 #include <math.h>
5 #include <string.h>
6 #include "vect.h"
7
8 #ifndef M_PI
9 #define M_PI 3.14159265358979323846
10 #endif
11 #define PI ((double)M_PI)
12
13 #define EPSILON 1e-6
14
15 void adjoint (Matrix mat);
16 double det4x4 (Matrix mat);
17 double det3x3 (double a1, double a2, double a3, double b1, double b2,
18 double b3, double c1, double c2, double c3);
19 double det2x2 (double a, double b, double c, double d);
20
21
22 void vect_init (Vector v, float x, float y, float z)
23 {
24 v[X] = x;
25 v[Y] = y;
26 v[Z] = z;
27 }
28
29
30 void vect_copy (Vector v1, Vector v2)
31 {
32 v1[X] = v2[X];
33 v1[Y] = v2[Y];
34 v1[Z] = v2[Z];
35 }
36
37
38 int vect_equal (Vector v1, Vector v2)
39 {
40 if (v1[X] == v2[X] && v1[Y] == v2[Y] && v1[Z] == v2[Z])
41 return 1;
42 else
43 return 0;
44 }
45
46
47 void vect_add (Vector v1, Vector v2, Vector v3)
48 {
49 v1[X] = v2[X] + v3[X];
50 v1[Y] = v2[Y] + v3[Y];
51 v1[Z] = v2[Z] + v3[Z];
52 }
53
54
55 void vect_sub (Vector v1, Vector v2, Vector v3)
56 {
57 v1[X] = v2[X] - v3[X];
58 v1[Y] = v2[Y] - v3[Y];
59 v1[Z] = v2[Z] - v3[Z];
60 }
61
62
63 void vect_scale (Vector v1, Vector v2, float k)
64 {
65 v1[X] = k * v2[X];
66 v1[Y] = k * v2[Y];
67 v1[Z] = k * v2[Z];
68 }
69
70
71 float vect_mag (Vector v)
72 {
73 float mag = sqrt(v[X]*v[X] + v[Y]*v[Y] + v[Z]*v[Z]);
74
75 return mag;
76 }
77
78
79 void vect_normalize (Vector v)
80 {
81 float mag = vect_mag (v);
82
83 if (mag > 0.0)
84 vect_scale (v, v, 1.0/mag);
85 }
86
87
88 float vect_dot (Vector v1, Vector v2)
89 {
90 return (v1[X]*v2[X] + v1[Y]*v2[Y] + v1[Z]*v2[Z]);
91 }
92
93
94 void vect_cross (Vector v1, Vector v2, Vector v3)
95 {
96 v1[X] = (v2[Y] * v3[Z]) - (v2[Z] * v3[Y]);
97 v1[Y] = (v2[Z] * v3[X]) - (v2[X] * v3[Z]);
98 v1[Z] = (v2[X] * v3[Y]) - (v2[Y] * v3[X]);
99 }
100
101 void vect_min (Vector v1, Vector v2, Vector v3)
102 {
103 v1[X] = (v2[X] < v3[X]) ? v2[X] : v3[X];
104 v1[Y] = (v2[Y] < v3[Y]) ? v2[Y] : v3[Y];
105 v1[Z] = (v2[Z] < v3[Z]) ? v2[Z] : v3[Z];
106 }
107
108
109 void vect_max (Vector v1, Vector v2, Vector v3)
110 {
111 v1[X] = (v2[X] > v3[X]) ? v2[X] : v3[X];
112 v1[Y] = (v2[Y] > v3[Y]) ? v2[Y] : v3[Y];
113 v1[Z] = (v2[Z] > v3[Z]) ? v2[Z] : v3[Z];
114 }
115
116
117 /* Return the angle between two vectors */
118 float vect_angle (Vector v1, Vector v2)
119 {
120 float mag1, mag2, angle, cos_theta;
121
122 mag1 = vect_mag(v1);
123 mag2 = vect_mag(v2);
124
125 if (mag1 * mag2 == 0.0)
126 angle = 0.0;
127 else {
128 cos_theta = vect_dot(v1,v2) / (mag1 * mag2);
129
130 if (cos_theta <= -1.0)
131 angle = 180.0;
132 else if (cos_theta >= +1.0)
133 angle = 0.0;
134 else
135 angle = (180.0/PI) * acos(cos_theta);
136 }
137
138 return angle;
139 }
140
141
142 void vect_print (FILE *f, Vector v, int dec, char sep)
143 {
144 char fstr[] = "%.4f, %.4f, %.4f";
145
146 if (dec < 0) dec = 0;
147 if (dec > 9) dec = 9;
148
149 fstr[2] = '0' + dec;
150 fstr[8] = '0' + dec;
151 fstr[14] = '0' + dec;
152
153 fstr[4] = sep;
154 fstr[10] = sep;
155
156 fprintf (f, fstr, v[X], v[Y], v[Z]);
157 }
158
159
160 /* Rotate a vector about the X, Y or Z axis */
161 void vect_rotate (Vector v1, Vector v2, int axis, float angle)
162 {
163 float cosa, sina;
164
165 cosa = cos ((PI/180.0) * angle);
166 sina = sin ((PI/180.0) * angle);
167
168 switch (axis) {
169 case X:
170 v1[X] = v2[X];
171 v1[Y] = v2[Y] * cosa + v2[Z] * sina;
172 v1[Z] = v2[Z] * cosa - v2[Y] * sina;
173 break;
174
175 case Y:
176 v1[X] = v2[X] * cosa - v2[Z] * sina;
177 v1[Y] = v2[Y];
178 v1[Z] = v2[Z] * cosa + v2[X] * sina;
179 break;
180
181 case Z:
182 v1[X] = v2[X] * cosa + v2[Y] * sina;
183 v1[Y] = v2[Y] * cosa - v2[X] * sina;
184 v1[Z] = v2[Z];
185 break;
186 }
187 }
188
189
190 /* Rotate a vector about a specific axis */
191 void vect_axis_rotate (Vector v1, Vector v2, Vector axis, float angle)
192 {
193 float cosa, sina;
194 Matrix mat;
195
196 cosa = cos ((PI/180.0) * angle);
197 sina = sin ((PI/180.0) * angle);
198
199 mat[0][0] = (axis[X] * axis[X]) + ((1.0 - (axis[X] * axis[X]))*cosa);
200 mat[0][1] = (axis[X] * axis[Y] * (1.0 - cosa)) - (axis[Z] * sina);
201 mat[0][2] = (axis[X] * axis[Z] * (1.0 - cosa)) + (axis[Y] * sina);
202 mat[0][3] = 0.0;
203
204 mat[1][0] = (axis[X] * axis[Y] * (1.0 - cosa)) + (axis[Z] * sina);
205 mat[1][1] = (axis[Y] * axis[Y]) + ((1.0 - (axis[Y] * axis[Y])) * cosa);
206 mat[1][2] = (axis[Y] * axis[Z] * (1.0 - cosa)) - (axis[X] * sina);
207 mat[1][3] = 0.0;
208
209 mat[2][0] = (axis[X] * axis[Z] * (1.0 - cosa)) - (axis[Y] * sina);
210 mat[2][1] = (axis[Y] * axis[Z] * (1.0 - cosa)) + (axis[X] * sina);
211 mat[2][2] = (axis[Z] * axis[Z]) + ((1.0 - (axis[Z] * axis[Z])) * cosa);
212 mat[2][3] = 0.0;
213
214 mat[3][0] = mat[3][1] = mat[3][2] = mat[3][3] = 0.0;
215
216 vect_transform (v1, v2, mat);
217 }
218
219
220 /* Transform the given vector */
221 void vect_transform (Vector v1, Vector v2, Matrix mat)
222 {
223 Vector tmp;
224
225 tmp[X] = (v2[X] * mat[0][0]) + (v2[Y] * mat[1][0]) + (v2[Z] * mat[2][0]) + mat[3][0];
226 tmp[Y] = (v2[X] * mat[0][1]) + (v2[Y] * mat[1][1]) + (v2[Z] * mat[2][1]) + mat[3][1];
227 tmp[Z] = (v2[X] * mat[0][2]) + (v2[Y] * mat[1][2]) + (v2[Z] * mat[2][2]) + mat[3][2];
228
229 vect_copy (v1, tmp);
230 }
231
232
233 /* Create an identity matrix */
234 void mat_identity (Matrix mat)
235 {
236 int i, j;
237
238 for (i = 0; i < 4; i++)
239 for (j = 0; j < 4; j++)
240 mat[i][j] = 0.0;
241
242 for (i = 0; i < 4; i++)
243 mat[i][i] = 1.0;
244 }
245
246
247 void mat_copy (Matrix mat1, Matrix mat2)
248 {
249 int i, j;
250
251 for (i = 0; i < 4; i++)
252 for (j = 0; j < 4; j++)
253 mat1[i][j] = mat2[i][j];
254 }
255
256
257 /* Rotate a matrix about the X, Y or Z axis */
258 void mat_rotate (Matrix mat1, Matrix mat2, int axis, float angle)
259 {
260 Matrix mat;
261 float cosa, sina;
262
263 cosa = cos ((PI/180.0) * angle);
264 sina = sin ((PI/180.0) * angle);
265
266 mat_identity (mat);
267
268 switch (axis) {
269 case X:
270 mat[1][1] = cosa;
271 mat[1][2] = sina;
272 mat[2][1] = -sina;
273 mat[2][2] = cosa;
274 break;
275
276 case Y:
277 mat[0][0] = cosa;
278 mat[0][2] = -sina;
279 mat[2][0] = sina;
280 mat[2][2] = cosa;
281 break;
282
283 case Z:
284 mat[0][0] = cosa;
285 mat[0][1] = sina;
286 mat[1][0] = -sina;
287 mat[1][1] = cosa;
288 break;
289 }
290
291 mat_mult (mat1, mat2, mat);
292 }
293
294
295 void mat_axis_rotate (Matrix mat1, Matrix mat2, Vector axis, float angle)
296 {
297 float cosa, sina;
298 Matrix mat;
299
300 cosa = cos ((PI/180.0) * angle);
301 sina = sin ((PI/180.0) * angle);
302
303 mat[0][0] = (axis[X] * axis[X]) + ((1.0 - (axis[X] * axis[X]))*cosa);
304 mat[0][1] = (axis[X] * axis[Y] * (1.0 - cosa)) - (axis[Z] * sina);
305 mat[0][2] = (axis[X] * axis[Z] * (1.0 - cosa)) + (axis[Y] * sina);
306 mat[0][3] = 0.0;
307
308 mat[1][0] = (axis[X] * axis[Y] * (1.0 - cosa)) + (axis[Z] * sina);
309 mat[1][1] = (axis[Y] * axis[Y]) + ((1.0 - (axis[Y] * axis[Y])) * cosa);
310 mat[1][2] = (axis[Y] * axis[Z] * (1.0 - cosa)) - (axis[X] * sina);
311 mat[1][3] = 0.0;
312
313 mat[2][0] = (axis[X] * axis[Z] * (1.0 - cosa)) - (axis[Y] * sina);
314 mat[2][1] = (axis[Y] * axis[Z] * (1.0 - cosa)) + (axis[X] * sina);
315 mat[2][2] = (axis[Z] * axis[Z]) + ((1.0 - (axis[Z] * axis[Z])) * cosa);
316 mat[2][3] = 0.0;
317
318 mat[3][0] = mat[3][1] = mat[3][2] = mat[3][3] = 0.0;
319
320 mat_mult (mat1, mat2, mat);
321 }
322
323
324 /* mat1 <-- mat2 * mat3 */
325 void mat_mult (Matrix mat1, Matrix mat2, Matrix mat3)
326 {
327 float sum;
328 int i, j, k;
329 Matrix result;
330
331 for (i = 0; i < 4; i++) {
332 for (j = 0; j < 4; j++) {
333 sum = 0.0;
334
335 for (k = 0; k < 4; k++)
336 sum = sum + mat2[i][k] * mat3[k][j];
337
338 result[i][j] = sum;
339 }
340 }
341
342 for (i = 0; i < 4; i++)
343 for (j = 0; j < 4; j++)
344 mat1[i][j] = result[i][j];
345 }
346
347
348 /*
349 Decodes a 3x4 transformation matrix into separate scale, rotation,
350 translation, and shear vectors. Based on a program by Spencer W.
351 Thomas (Graphics Gems II)
352 */
353 void mat_decode (Matrix mat, Vector scale, Vector shear, Vector rotate,
354 Vector transl)
355 {
356 int i;
357 Vector row[3], temp;
358
359 for (i = 0; i < 3; i++)
360 transl[i] = mat[3][i];
361
362 for (i = 0; i < 3; i++) {
363 row[i][X] = mat[i][0];
364 row[i][Y] = mat[i][1];
365 row[i][Z] = mat[i][2];
366 }
367
368 scale[X] = vect_mag (row[0]);
369 vect_normalize (row[0]);
370
371 shear[X] = vect_dot (row[0], row[1]);
372 row[1][X] = row[1][X] - shear[X]*row[0][X];
373 row[1][Y] = row[1][Y] - shear[X]*row[0][Y];
374 row[1][Z] = row[1][Z] - shear[X]*row[0][Z];
375
376 scale[Y] = vect_mag (row[1]);
377 vect_normalize (row[1]);
378
379 if (scale[Y] != 0.0)
380 shear[X] /= scale[Y];
381
382 shear[Y] = vect_dot (row[0], row[2]);
383 row[2][X] = row[2][X] - shear[Y]*row[0][X];
384 row[2][Y] = row[2][Y] - shear[Y]*row[0][Y];
385 row[2][Z] = row[2][Z] - shear[Y]*row[0][Z];
386
387 shear[Z] = vect_dot (row[1], row[2]);
388 row[2][X] = row[2][X] - shear[Z]*row[1][X];
389 row[2][Y] = row[2][Y] - shear[Z]*row[1][Y];
390 row[2][Z] = row[2][Z] - shear[Z]*row[1][Z];
391
392 scale[Z] = vect_mag (row[2]);
393 vect_normalize (row[2]);
394
395 if (scale[Z] != 0.0) {
396 shear[Y] /= scale[Z];
397 shear[Z] /= scale[Z];
398 }
399
400 vect_cross (temp, row[1], row[2]);
401 if (vect_dot (row[0], temp) < 0.0) {
402 for (i = 0; i < 3; i++) {
403 scale[i] *= -1.0;
404 row[i][X] *= -1.0;
405 row[i][Y] *= -1.0;
406 row[i][Z] *= -1.0;
407 }
408 }
409
410 if (row[0][Z] < -1.0) row[0][Z] = -1.0;
411 if (row[0][Z] > +1.0) row[0][Z] = +1.0;
412
413 rotate[Y] = asin(-row[0][Z]);
414
415 if (fabs(cos(rotate[Y])) > EPSILON) {
416 rotate[X] = atan2 (row[1][Z], row[2][Z]);
417 rotate[Z] = atan2 (row[0][Y], row[0][X]);
418 }
419 else {
420 rotate[X] = atan2 (row[1][X], row[1][Y]);
421 rotate[Z] = 0.0;
422 }
423
424 /* Convert the rotations to degrees */
425 rotate[X] = (180.0/PI)*rotate[X];
426 rotate[Y] = (180.0/PI)*rotate[Y];
427 rotate[Z] = (180.0/PI)*rotate[Z];
428 }
429
430
431 /* Matrix inversion code from Graphics Gems */
432
433 /* mat1 <-- mat2^-1 */
434 float mat_inv (Matrix mat1, Matrix mat2)
435 {
436 int i, j;
437 float det;
438
439 if (mat1 != mat2) {
440 for (i = 0; i < 4; i++)
441 for (j = 0; j < 4; j++)
442 mat1[i][j] = mat2[i][j];
443 }
444
445 det = det4x4 (mat1);
446
447 if (fabs (det) < EPSILON)
448 return 0.0;
449
450 adjoint (mat1);
451
452 for (i = 0; i < 4; i++)
453 for(j = 0; j < 4; j++)
454 mat1[i][j] = mat1[i][j] / det;
455
456 return det;
457 }
458
459
460 void adjoint (Matrix mat)
461 {
462 double a1, a2, a3, a4, b1, b2, b3, b4;
463 double c1, c2, c3, c4, d1, d2, d3, d4;
464
465 a1 = mat[0][0]; b1 = mat[0][1];
466 c1 = mat[0][2]; d1 = mat[0][3];
467
468 a2 = mat[1][0]; b2 = mat[1][1];
469 c2 = mat[1][2]; d2 = mat[1][3];
470
471 a3 = mat[2][0]; b3 = mat[2][1];
472 c3 = mat[2][2]; d3 = mat[2][3];
473
474 a4 = mat[3][0]; b4 = mat[3][1];
475 c4 = mat[3][2]; d4 = mat[3][3];
476
477 /* row column labeling reversed since we transpose rows & columns */
478 mat[0][0] = det3x3 (b2, b3, b4, c2, c3, c4, d2, d3, d4);
479 mat[1][0] = -det3x3 (a2, a3, a4, c2, c3, c4, d2, d3, d4);
480 mat[2][0] = det3x3 (a2, a3, a4, b2, b3, b4, d2, d3, d4);
481 mat[3][0] = -det3x3 (a2, a3, a4, b2, b3, b4, c2, c3, c4);
482
483 mat[0][1] = -det3x3 (b1, b3, b4, c1, c3, c4, d1, d3, d4);
484 mat[1][1] = det3x3 (a1, a3, a4, c1, c3, c4, d1, d3, d4);
485 mat[2][1] = -det3x3 (a1, a3, a4, b1, b3, b4, d1, d3, d4);
486 mat[3][1] = det3x3 (a1, a3, a4, b1, b3, b4, c1, c3, c4);
487
488 mat[0][2] = det3x3 (b1, b2, b4, c1, c2, c4, d1, d2, d4);
489 mat[1][2] = -det3x3 (a1, a2, a4, c1, c2, c4, d1, d2, d4);
490 mat[2][2] = det3x3 (a1, a2, a4, b1, b2, b4, d1, d2, d4);
491 mat[3][2] = -det3x3 (a1, a2, a4, b1, b2, b4, c1, c2, c4);
492
493 mat[0][3] = -det3x3 (b1, b2, b3, c1, c2, c3, d1, d2, d3);
494 mat[1][3] = det3x3 (a1, a2, a3, c1, c2, c3, d1, d2, d3);
495 mat[2][3] = -det3x3 (a1, a2, a3, b1, b2, b3, d1, d2, d3);
496 mat[3][3] = det3x3 (a1, a2, a3, b1, b2, b3, c1, c2, c3);
497 }
498
499
500 double det4x4 (Matrix mat)
501 {
502 double ans;
503 double a1, a2, a3, a4, b1, b2, b3, b4, c1, c2, c3, c4, d1, d2, d3, d4;
504
505 a1 = mat[0][0]; b1 = mat[0][1];
506 c1 = mat[0][2]; d1 = mat[0][3];
507
508 a2 = mat[1][0]; b2 = mat[1][1];
509 c2 = mat[1][2]; d2 = mat[1][3];
510
511 a3 = mat[2][0]; b3 = mat[2][1];
512 c3 = mat[2][2]; d3 = mat[2][3];
513
514 a4 = mat[3][0]; b4 = mat[3][1];
515 c4 = mat[3][2]; d4 = mat[3][3];
516
517 ans = a1 * det3x3 (b2, b3, b4, c2, c3, c4, d2, d3, d4) -
518 b1 * det3x3 (a2, a3, a4, c2, c3, c4, d2, d3, d4) +
519 c1 * det3x3 (a2, a3, a4, b2, b3, b4, d2, d3, d4) -
520 d1 * det3x3 (a2, a3, a4, b2, b3, b4, c2, c3, c4);
521
522 return ans;
523 }
524
525
526 double det3x3 (double a1, double a2, double a3, double b1, double b2,
527 double b3, double c1, double c2, double c3)
528 {
529 double ans;
530
531 ans = a1 * det2x2 (b2, b3, c2, c3)
532 - b1 * det2x2 (a2, a3, c2, c3)
533 + c1 * det2x2 (a2, a3, b2, b3);
534
535 return ans;
536 }
537
538
539 double det2x2 (double a, double b, double c, double d)
540 {
541 double ans;
542 ans = a * d - b * c;
543 return ans;
544 }
545
