--- ray/src/cv/mgflib/translat.txt 1994/09/07 16:32:20 1.1 +++ ray/src/cv/mgflib/translat.txt 2003/02/28 20:19:26 1.3 @@ -1,5 +1,5 @@ TRANSLATING TO MGF FROM OTHER FORMATS - SCCSid "$SunId$ LBL" + RCSid "$Id: translat.txt,v 1.3 2003/02/28 20:19:26 greg Exp $" The description of the parser and the MGF specification should provide enough information to get you started using MGF scene files, but we @@ -32,7 +32,7 @@ either select your MGF vertex names from a small, recy names, or figure out some way to share vertices that were not shared before. In the first case, you will just allocate as many vertex names as you need for any given object, then reuse these names and -therefore the parsers memory for other objects. In the second case, +therefore the parser's memory for other objects. In the second case, you will cache vertex names and values in some LRU table of predetermined size, and use this table to merge vertices in the file. (See rad2mgf.c as an example of how this can be done.) @@ -53,7 +53,7 @@ what do we do with these in MGF? If the idea is to pr or line on the final display that is one or two pixels wide, there is little one can do to guarantee such a thing will happen because the pixel size is dependent on view and display parameters as well -as scene location. +as object location. There are two ways of dealing with points and lines in MGF. The first is to say, "Hey, these are 0 and 1 dimensional entities, so @@ -111,7 +111,7 @@ some rendering systems may not give sane results if yo hole with part of your seam. If we had chosen to create the seam between v2 and v5 in the above example instead of v4 and v5, the seam would cross our hole and may not render correctly. (For systems that -are sensitive to this, it is probably necessary that their MGF +are sensitive to this, it is probably safest for their MGF loader/translator re-expresses seams in terms of holes again, which can be done easily so long as vertices are shared in the above fashion.) @@ -121,7 +121,7 @@ Polygons in MGF should be planar. There is nothing ab that enforces this, but the rendering or modeling software on the other end may have real problems if this requirement is violated. The parser itself does not test for non-planar polygons, so when in doubt about a -model it is safest to test for planarity and break a polygon into triangles +model, it is safest to test for planarity and break a polygon into triangles if it is even slightly non-planar. NURBS, CSG, Blobbies, Etc. @@ -159,7 +159,7 @@ volume, such as a pane of glass, and this also can pro calculational savings in an image-space algorithm (such as ray-tracing). Since both types of surfaces are useful and both types of rendering algorithms may ultimately be applied, MGF provides a way -to specify sidedness rather than picking one model or the other. +to specify sidedness rather than picking one interpretation or the other. So-called specular reflection and transmission are modeled using a Gaussian distribution of surface normals. The "alpha_r" and @@ -191,10 +191,11 @@ Unlike most graphics languages, MGF does not use an RG simply because there is no recognized definition for this model. It is based on computer monitor phosphors, which vary from one CRT to the next. (There is an RGB standard defined in the TV -industry, but this has a rather poor correlation to most graphics.) +industry, but this has a rather poor correlation to most computer +monitors.) MGF uses two alternative, well-defined standards. The first is the CIE -standard for chromaticity coordinates. With this standard, any viewable +standard xy chromaticity coordinates. With this standard, any viewable color may be exactly reproduced. Unfortunately, the interaction between colors (i.e. colored light sources and interreflections) cannot be specified exactly with any finite coordinate set, including CIE @@ -203,7 +204,7 @@ transmittance or emittance as a function of wavelength spectrum. This function is still discretized, but at a user-selectable resolution. Furthermore, spectral colors may be mixed, providing (nearly) arbitrary basis functions, which can produce more accurate results in -some cases and are a convenience in others. +some cases and are merely a convenience for translation in others. Conversion back and forth between CIE chromaticity coordinates and spectral samples is provided within the MGF parser. Unfortunately, conversion @@ -299,8 +300,9 @@ register float *ciecolor, *rgbcolor; rgb2xyzmat[i][2]*rgbcolor[2] ; } -Another alternative is to use the MGF "cmix" entity to convert from RGB -directly by naming the three primaries in terms of their chromaticities, e.g: +An alternative to adopting the above code is to use the MGF "cmix" +entity to convert from RGB directly by naming the three primaries in +terms of their chromaticities, e.g: c r = cxy 0.640 0.330 @@ -321,5 +323,6 @@ that cmix uses relative luminance as the standard for blue is less luminous for the same energy than red, which is in turn less luminous than green, the weights cannot be the same to achieve an even spectral balance. Unfortunately, computing these relative weights -is not straightforward, so it is given in the above macros as CIE_rf, -CIE_gf and CIE_bf. +is not straightforward, though it is given in the above macros as CIE_rf, +CIE_gf and CIE_bf. (The common factors in these macros may of course +be removed for simplification purposes.)
