root/radiance/ray/src/cv/mgflib/spec.txt
Revision: 1.1
Committed: Sat Jun 25 09:46:58 1994 UTC (29 years, 11 months ago) by greg
1 MATERIALS AND GEOMETRY FORMAT
2 SCCSid "$SunId$ LBL"
3
4 Introduction
5 ============
6 The following file format is a simple ASCII representation of surface
7 geometry and materials for the purpose of visible-light simulation
8 and rendering. The overall objective of this format is to provide
9 a very simple yet fairly complete modeling language that does not
10 place unreasonable demands on the applications programmer or the
11 object library creator.
12
13 Similar to Wavefront's .OBJ file format, our format utilizes a
14 number of object entities, one per line, some of which establish
15 a context for the entities that follow. Specifically, there is
16 a context for the current vertex, the current color, and the
17 current material. The current vertex is used only for setting
18 values related to that vertex. The current color is used for
19 setting values related to that color, as well as by certain
20 material attributes which take an optional color setting.
21 The current material is used for setting material-related
22 parameters, and for establishing the material for the following
23 geometric entities. In addition to these three named contexts,
24 there are two hierarchical (i.e. cumulative) contexts, the
25 current transform and the current object name.
26
27 Each entity is given by a short keyword, followed by space- or tab-
28 delimited arguments on a single line. A single entity may be extended
29 over multiple lines using a backslash ('\') character right before the
30 end of line, though no extended line may exceed 512 characters in total
31 length. (Given the current set of entities, even approaching 80
32 characters would be highly unusual.)
33
34 Entities and Contexts
35 =====================
36 There are three contexts in effect at all times, current vertex,
37 current color and current material. Initially, these contexts are
38 unnamed, and have specific default values. The unnamed vertex is the
39 origin. The unnamed color is neutral gray. The unnamed material is a
40 perfect absorber. The unnamed contexts may be modified, but those
41 modifications will not be saved. Thus, reestablishing an unnamed
42 context always gets its initial default value. To save a new context
43 or modify an old one, it must first be named. Entities associated with
44 named contexts (i.e. "v", "c" and "m") may be followed by an identifier
45 and an equals sign ('='), indicating a new context. If there is no
46 equals, then the context must already be defined, and the appearance of
47 the entity merely reestablishes this context. If the context id is
48 followed by an equals, then a new context is defined, destroying any
49 previous instance of that context name. Redefining or changing values
50 of a context does not affect earlier uses of the same name, however.
51 Contexts are always associated with a name id, which is any non-blank
52 sequence of printing ASCII characters. An optional template may be
53 given following the equals, which is a previously defined context to
54 use as a source of default values for this definition. If no template
55 is given, then the unnamed context of that type is used to set initial
56 values. Named contexts continue until the next context definition of
57 the same type.
58
59 Hierarchical Contexts
60 =====================
61 Two entities define a second type of context, which is hierarchical.
62 These are the transform ("xf") entity and the object ("o") entity.
63 The object entity is used simply for naming collections of surfaces.
64 An object entity with a name applies to the following surfaces up
65 until an object entity with no name, which signifies the end of this
66 object's scope. Object entities may be nested to any level, and
67 can be thought of as parts and subparts of an enclosing global object.
68 Note that this is strictly for ease of identification, and has no
69 real meaning as far as the geometric description goes. In contrast,
70 the transform entity is very significant as it determines how enclosing
71 objects are to be scaled and placed in the final description.
72
73 Without further ado, here are the proposed entities and their interpretations:
74
75 Keyword Arguments Meaning
76 ------- --------- -------
77 # anything a comment
78 i filename [xform] include file (with transformation)
79 ies filename [-m f][xform] include IES luminaire (with transformation)
80 v [id [= [template]]] get/set vertex context
81 p x y z set point position for current vertex
82 n dx dy dz set surface normal for current vertex
83 c [id [= [template]]] get/set color context
84 cxy x y set CIE (x,y) chromaticity for current color
85 cspec l_min l_max v1 v2 .. set relative spectrum for current color
86 cmix w1 c1 w2 c2 .. mix named colors to make current color
87 m [id [= [template]]] get/set material context
88 rd rho_d set diffuse reflectance for current material
89 td tau_d set diffuse transmittance for current material
90 ed epsilon_d set diffuse emittance for current material
91 rs rho_s alpha_r set specular reflectance for current material
92 ts tau_s alpha_t set specular transmittance for current material
93 o [name] begin/end object context
94 f v1 v2 v3 .. polygon using current material, spec. vertices
95 sph vc radius sphere
96 cyl v1 radius v2 truncated right cylinder (open-ended)
97 cone v1 rad1 v2 rad2 truncated right cone (open-ended)
98 prism v1 v2 v3 .. length right prism (closed solid)
99 ring vc rmin rmax circular ring with inner and outer radii
100 torus vc rmin rmax circular torus with inner and outer radii
101 xf [xform] begin/end transformation context
102
103 These are the context dependencies of each entity:
104
105 Entities Contexts
106 -------- --------
107 p, n vertex
108 cxy, cspec, cmix color
109 rd, td, ed, rs, ts color, material
110 f, sph, cyl, cone, ring, torus, prism material, object, transformation
111
112 Transformations
113 ===============
114 A rigid body transformation is given with the transform entity, or as
115 part of an included file. The following transformation flags and
116 arguments are defined:
117
118 -t dx dy dz translate objects along the given vector
119 -rx degrees rotate objects about the X-axis
120 -ry degrees rotate objects about the Y-axis
121 -rz degrees rotate objects about the Z-axis
122 -s scalefactor scale objects by the given factor
123 -mx mirror objects about the Y-Z plane
124 -my mirror objects about the X-Z plane
125 -mz mirror objects about the X-Y plane
126 -i N repeat the following arguments N times
127 -a N make an array of N geometric instances
128
129 Transform arguments have a cumulative effect. That is, a rotation
130 about X of 20 degrees followed by a rotation about X of -50 degrees
131 results in a total rotation of -30 degrees. However, if the two
132 rotations are separated by some translation vector, the cumulative
133 effect is quite different. It is best to think of each argument as
134 acting on the included geometric objects, and each subsequent transformation
135 argument affects the objects relative to their new position/orientation.
136
137 For example, rotating an object about its center requires translating
138 the object back to the origin, applying the desired rotation, and translating
139 it again back to its original position.
140
141 Rotations are given in degrees counter-clockwise about a principal axis.
142 That is, with the thumb of the right hand pointing in the direction
143 of the axis, rotation follows the curl of the fingers.
144
145 The transform command itself is also cumulative, and a transform
146 command with no arguments is used to return to the previous
147 condition. It is best if transforms and their end statements
148 ("xf" by itself) are balanced in a file, so that later or enclosing
149 files are not affected.
150
151 Transformations apply only to geometric types, e.g. polygons, spheres, etc.
152 Vertices and the components that go into geometry are not directly affected.
153 This is to avoid confusion and the inadvertent multiple application of a
154 given transformation.
155
156 Arrays
157 ======
158 The -a N transform specification causes the following transform
159 arguments to be repeated along with the contents of the included
160 file N times. (Note that this option is supported only for included
161 files.) The first instance of the geometry will be in its initial
162 location; the second instance will be repositioned according to the
163 named transformation; the third instance will be repositioned by
164 applying this transformation twice, and so on up to N-1 applications.
165
166 Multi-dimensional arrays may be specified with a single include
167 entity by giving multiple array commands separated by their
168 corresponding transforms. A final transformation may be given
169 by preceeding it with a -i 1 specification. In other words, the
170 scope of an array command continues until the next -i or -a option.
171
172 Other Details
173 =============
174 End of line may be any one of the sequences: linefeed ('\n'), carriage-
175 return ('\r'), or a carriage return followed by a linefeed.
176
177 Blank lines are ignored on the input, as are any blanks preceeding
178 a keyword on a line. Indentation may improve readability, especially
179 in context definitions.
180
181 The comment character ('#') must be followed by at least one blank
182 character (space or tab) for easy parsing. Like any other line,
183 a comment may be extended to multiple lines using a backslash ('\').
184
185 Include filename paths are relative to the current file. Absolute
186 paths are expressly forbidden. UNIX conventions should be used for the
187 path separator ('/') and disk names should not be used (i.e. no
188 "C:\file"). To further enhance portability across systems, directory
189 names should be 8 characters or fewer with no suffix, filenames should
190 fit within an 8.3 format, and all characters should be lower case.
191 (They will be automatically promoted to upper case by DOS systems.)
192 We suggest the standard suffix ".mgf" for "materials and geometry format".
193
194 The XYZ coordinate system is right-handed, and lengths are always in
195 SI meters. This is not really a limitation as the first statement
196 in the file can always be a transform with the -s option to convert
197 to a more convenient set of units. Included IES files will also start
198 out in meters, and it is important to specify a transform into the
199 local coordinate system. The -m option (preceeding any transform)
200 may be used to specify an output multiplication factor.
201
202 Vertex normals need not be normalized, and a normal equal to (0,0,0) indicates
203 that the exact surface normal should be used. (This is the default.)
204
205 Color in this system does not include intensity, only hue and
206 saturation. Intensity, such as reflectance or emittance, is explicitly
207 included in the other material parameters. All colors are absolute,
208 e.g. spectral reflectance or transmittance under uniform white light.
209
210 A CIE xy chromaticity pair is the most basic color specification.
211 A full spectrum is the most general specification, and the starting
212 (i.e. minimum) and ending (i.e. maximum) wavelengths are given along
213 with a set of evenly spaced values. Wavelengths are given in nanometers,
214 and must be within the range of 380-780. The spectral values themselves
215 are located starting at the first wavelength and proceeding at even
216 increments to the ending wavelength. The values in between will be
217 interpolated as necessary, so there must be at least two specified points.
218 The color mixing entity is intended not only for the mixing of named
219 colors, but also for color specifications using an arbitrary set
220 of basis functions. The actual totals for spectral and mixing
221 coefficients is irrelevant, since the results will be normalized.
222
223 Diffuse emittance is always given in SI units of lumens/meter^2. Note that
224 this is emittance, not exitance, and does not include light reflected or
225 transmitted by the surface.
226
227 The roughness associated with specular reflectance and transmittance
228 is the RMS surface facet slope. A value of 0 indicates a perfectly
229 smooth surface, meaning that reflected or transmitted rays will not
230 be scattered.
231
232 The sum of the diffuse and specular reflectances and transmittances
233 must be strictly less than one (with no negative values, obviously).
234
235 The object entity establishes a hierarchical context, consisting of
236 this identifier and all those preceding. It has no real meaning except
237 to group the following surfaces up until an empty object statement
238 under a descriptive name for improved file readability.
239
240 Surfaces are one-sided, and appear invisible when viewed from the
241 back side. This means that a transmitting object will affect the
242 light coming in through the front surface and ignore the characteristics
243 of the back surface. As long as the characteristics are the same,
244 the results should be correct. If the rendering technique does not
245 allow for one-sided surfaces, an approximately correct result can
246 be obtained for transmitting surfaces by using the square root of
247 the given tau_s and half the given alpha_t.
248
249 The surface normal of a face is oriented by the right-hand rule.
250 Specifically, the surface normal faces towards the viewer when the
251 vertices circulate counter-clockwise. Faces may be concave or convex,
252 but must be planar. Holes may be represented as concave polygons with
253 coincident sides (i.e. seams).
254
255 A prism consists of a set of coplanar vertices specifying an end-face,
256 and a length value. The prism will be extruded so that the end-face
257 points outward, unless the length value is negative, in which case the
258 object is extruded in the opposite direction, resulting in inward-
259 directed surface normals.
260
261 A sphere, cylinder or cone with negative radii is interpreted as having
262 an inward facing surface normal. Otherwise, the normal is assumed
263 to face outwards. (It is illegal for a cone to have one positive and
264 one negative radius.)
265
266 The central vertex for a ring or torus must have an associated normal,
267 which serves to orient the ring. The inner radius must be given first,
268 and must be strictly less than the outer radius. The inner radius may
269 be zero but not negative. There is an exception for a torus with
270 inward-pointing normal, which is identified by a negative outer radius
271 and a non-positive inner radius.
272
273 Examples
274 ========
275 The following is a complete example input file (don't ask me what it is):
276
277 # Define some materials:
278 m red_plastic =
279 c red =
280 cxy .8 .1
281 rd 0.5
282 # reestablish unnamed (neutral) color context:
283 c
284 rs 0.04 0.02
285 m green_plastic =
286 c green =
287 cxy .2 .6
288 rd 0.4
289 c
290 rs .05 0
291 m bright_emitter =
292 c
293 ed 1000
294 m dark =
295 c
296 rd .08
297 # Define some vertices:
298 v v1 =
299 p 10 5 7
300 v v2 =
301 p 15 3 9
302 v v3 =
303 p 20 -7 6
304 v v4 =
305 p 20 10 6
306 v v5 =
307 p 10 10 6
308 v v6 =
309 p 10 -7 6
310 v cv1 =
311 p -5 3 8
312 n 0 0 -1
313 v cv2 =
314 p -3 3 8
315 n 0 0 1
316 # make some faces:
317 m green_plastic
318 f v1 v3 v4
319 m red_plastic
320 f v3 v4 v5
321 f v5 v6 v7
322 m bright_emitter
323 f v3 v4 v5 v6
324 # make a cylindrical source with dark end caps:
325 m bright_emitter
326 cyl cv1 .15 cv2
327 m dark
328 ring cv1 0 .15
329 ring cv2 0 .15
330
331 The following is a more typical example, which relies on a material library:
332
333 # Include our materials:
334 i material.mgf
335 # Modify red_plastic to have no specular component:
336 m red_plastic
337 rs 0 0
338 # Make an alias for blue_plastic:
339 m outer_material = blue_plastic
340 # Make a new material based on brass, with greater roughness:
341 m rough_brass = brass
342 c brass_color
343 rs 0.9 0.15
344 # Load our vertices:
345 i lum1vert.mgf
346 # Modify appropriate vertices to make luminaire longer:
347 v v10
348 p 5 -2 -.1
349 v v11
350 p 5 2 -.1
351 v v8
352 p 5 2 0
353 v v9
354 p 5 -2 0
355 # Load our surfaces, rotating them -90 degrees about Z:
356 i lum1face.mgf -rz -90
357 # Make a 2-D array of sequins covering the face of the fixture:
358 m silver
359 i sequin.mgf -a 5 -t .5 0 0 -a 4 -t 0 .75 0
360
361 Note that by using libraries and modifying values, it is possible to create
362 a variety of fixtures without requiring large files to describe each one.
363
364 Interpretation
365 ==============
366 Interpretation of this language will be simplified by the creation
367 of a general parser that will be able to express the defined entities
368 in simpler forms and remove entities that would not be understood by
369 the caller.
370
371 For example, a caller may ask the standard parser to produce only
372 the entities for diffuse uncolored materials, vertices without normals,
373 and polygons. The parser would then expand all include statements,
374 remove all color statements, convert spheres and cones to polygonal
375 approximations, and so forth.
376
377 This way, a single general parser can permit software to operate
378 at whatever level it is capable, with a minimal loss of generality.
379 Furthermore, distribution of a standard parser will improve
380 both forward and backward compatibility as new entities are added
381 to the specification.
382
383 Rationale
384 =========
385 Why create yet another file format for geometric data, when so many
386 others already exist? The main answer to this question is that we
387 are not merely defining geometry, but materials as well. Though the
388 number of committee and de facto standards for geometric data is large,
389 the number of standards for geometry + materials is small. Of these,
390 almost all are non-physical in origin, i.e. they are based on common,
391 ad hoc computer graphics rendering practices and cannot be used to create
392 physical simulations. Of the one or two formats that were intended
393 for or could be adapted to physical simulation, the syntax and semantics
394 are at the same time too complex and too limiting to serve as a suitable
395 standard.
396
397 Specifically, establishing the above, new standard has the following
398 advantages:
399
400 o It is easy to parse.
401 o It is easy to support, at least as a least common denominator.
402 o It is ASCII and fairly easy for a person to read and understand.
403 o It supports simple color, material and vertex libraries.
404 o It includes a simple yet fairly complete material specification.
405 o It is easy to skip unsupported entities (e.g. color, vertex normals)
406 o It supports transformations and instances.
407 o It is easy to add new entities, and as long as these entities can
408 be approximated by the original set, backwards compatibility
409 can be maintained through a standard parsing library.
410
411 Most of the disadvantages of this format relate to its simplicity, but
412 since simplicity was our most essential goal, this could not be helped.
413 Specifically:
414
415 o There is no general representation of curved surfaces (though
416 vertex normals make approximations straightforward).
417 o There are no general surface scattering functions.
418 o There are no textures or bump-maps.
419
420 If any of these seems particularly important, I will look into adding them,
421 though they will tend to complicate the specification and make it more
422 difficult to support.
