1 |
MATERIALS AND GEOMETRY FORMAT |
2 |
SCCSid "$SunId$ LBL" |
3 |
4 |
Introduction |
5 |
6 |
The following file format is a simple ASCII representation of surface |
7 |
geometry and materials for the purpose of visible-light simulation |
8 |
and rendering. The overall objective of this format is to provide |
9 |
a very simple yet fairly complete modeling language that does not |
10 |
place unreasonable demands on the applications programmer or the |
11 |
object library creator. |
12 |
13 |
Similar to Wavefront's .OBJ file format, our format utilizes a |
14 |
number of object entities, one per line, some of which establish |
15 |
a context for the entities that follow. Specifically, there is |
16 |
a context for the current vertex, the current color, and the |
17 |
current material. The current vertex is used only for setting |
18 |
values related to that vertex. The current color is used for |
19 |
setting values related to that color, as well as by certain |
20 |
material attributes which take an optional color setting. |
21 |
The current material is used for setting material-related |
22 |
parameters, and for establishing the material for the following |
23 |
geometric entities. In addition to these three named contexts, |
24 |
there are two hierarchical (i.e. cumulative) contexts, the |
25 |
current transform and the current object name. |
26 |
27 |
Each entity is given by a short keyword, followed by space- or tab- |
28 |
delimited arguments on a single line. A single entity may be extended |
29 |
over multiple lines using a backslash ('\') character right before the |
30 |
end of line, though no extended line may exceed 4096 characters in total |
31 |
length. |
32 |
33 |
Entities and Contexts |
34 |
35 |
There are three contexts in effect at all times, current vertex, |
36 |
current color and current material. Initially, these contexts are |
37 |
unnamed, and have specific default values. The unnamed vertex is the |
38 |
origin. The unnamed color is neutral gray. The unnamed material is a |
39 |
perfect (two-sided) absorber. The unnamed contexts may be modified, |
40 |
but those modifications will not be saved. Thus, reestablishing an |
41 |
unnamed context always gets its initial default value. To save a new |
42 |
context or modify an old one, it must first be named. Entities |
43 |
associated with named contexts (i.e. "v", "c" and "m") may be followed |
44 |
by an identifier and an equals sign ('='), indicating a new context. |
45 |
If there is no equals, then the context must already be defined, and |
46 |
the appearance of the entity merely reestablishes this context. If the |
47 |
context id is followed by an equals, then a new context is defined, |
48 |
destroying any previous instance of that context name. Redefining or |
49 |
changing values of a context does not affect earlier uses of the same |
50 |
name, however. Contexts are always associated with a name id, which is |
51 |
any non-blank sequence of printing ASCII characters. An optional |
52 |
template may be given following the equals, which is a previously |
53 |
defined context to use as a source of default values for this |
54 |
definition. If no template is given, then the unnamed context of that |
55 |
type is used to set initial values. Named contexts continue until the |
56 |
next context definition of the same type. |
57 |
58 |
Hierarchical Contexts |
59 |
60 |
Two entities define a second type of context, which is hierarchical. |
61 |
These are the transform ("xf") entity and the object ("o") entity. |
62 |
The object entity is used simply for naming collections of surfaces. |
63 |
An object entity with a name applies to the following surfaces up |
64 |
until an object entity with no name, which signifies the end of this |
65 |
object's scope. Object entities may be nested to any level, and |
66 |
can be thought of as parts and subparts of an enclosing global object. |
67 |
Note that this is strictly for ease of identification, and has no |
68 |
real meaning as far as the geometric description goes. In contrast, |
69 |
the transform entity is very significant as it determines how enclosing |
70 |
objects are to be scaled and placed in the final description. Hierarchical |
71 |
contexts may be nested in any way, but should not overlap. |
72 |
73 |
Without further ado, here are the proposed entities and their interpretations: |
74 |
75 |
Keyword Arguments Meaning |
76 |
77 |
# anything a comment |
78 |
i filename [xform] include file (with transformation) |
79 |
ies filename [-m f][xform] include IES luminaire (with transformation) |
80 |
v [id [= [template]]] get/set vertex context |
81 |
p x y z set point position for current vertex |
82 |
n dx dy dz set surface normal for current vertex |
83 |
c [id [= [template]]] get/set color context |
84 |
cxy x y set CIE (x,y) chromaticity for current color |
85 |
cspec l_min l_max v1 v2 .. set relative spectrum for current color |
86 |
cct temperature set spectrum based on black body temperature |
87 |
cmix w1 c1 w2 c2 .. mix named colors to make current color |
88 |
m [id [= [template]]] get/set material context |
89 |
sides {1|2} set number of sides for current material |
90 |
rd rho_d set diffuse reflectance for current material |
91 |
td tau_d set diffuse transmittance for current material |
92 |
ed epsilon_d set diffuse emittance for current material |
93 |
rs rho_s alpha_r set specular reflectance for current material |
94 |
ts tau_s alpha_t set specular transmittance for current material |
95 |
o [name] begin/end object context |
96 |
f v1 v2 v3 .. polygon using current material, spec. vertices |
97 |
sph vc radius sphere |
98 |
cyl v1 radius v2 truncated right cylinder (open-ended) |
99 |
cone v1 rad1 v2 rad2 truncated right cone (open-ended) |
100 |
prism v1 v2 v3 .. length truncated right prism (closed solid) |
101 |
ring vc rmin rmax circular ring with inner and outer radii |
102 |
torus vc rmin rmax circular torus with inner and outer radii |
103 |
xf [xform] begin/end transformation context |
104 |
105 |
These are the context dependencies of each entity: |
106 |
107 |
Entities Contexts |
108 |
109 |
p, n vertex |
110 |
cxy, cspec, cmix color |
111 |
sides material |
112 |
rd, td, ed, rs, ts color, material |
113 |
f, sph, cyl, cone, ring, torus, prism material, object, transformation |
114 |
115 |
Transformations |
116 |
117 |
A rigid body transformation is given with the transform entity, or as |
118 |
part of an included file. The following transformation flags and |
119 |
arguments are defined: |
120 |
121 |
-t dx dy dz translate objects along the given vector |
122 |
-rx degrees rotate objects about the X-axis |
123 |
-ry degrees rotate objects about the Y-axis |
124 |
-rz degrees rotate objects about the Z-axis |
125 |
-s scalefactor scale objects by the given factor |
126 |
-mx mirror objects about the Y-Z plane |
127 |
-my mirror objects about the X-Z plane |
128 |
-mz mirror objects about the X-Y plane |
129 |
-i N repeat the following arguments N times |
130 |
-a N make an array of N geometric instances |
131 |
132 |
Transform arguments have a cumulative effect. That is, a rotation |
133 |
about X of 20 degrees followed by a rotation about X of -50 degrees |
134 |
results in a total rotation of -30 degrees. However, if the two |
135 |
rotations are separated by some translation vector, the cumulative |
136 |
effect is quite different. It is best to think of each argument as |
137 |
acting on the included geometric objects, and each subsequent transformation |
138 |
argument affects the objects relative to their new position/orientation. |
139 |
140 |
For example, rotating an object about its center requires translating |
141 |
the object back to the origin, applying the desired rotation, and translating |
142 |
it again back to its original position. |
143 |
144 |
Rotations are given in degrees counter-clockwise about a principal axis. |
145 |
That is, with the thumb of the right hand pointing in the direction |
146 |
of the axis, rotation follows the curl of the fingers. |
147 |
148 |
The transform command itself is also cumulative, but in the reverse |
149 |
order. That is, later transformations (i.e. enclosed transformations) |
150 |
are prepended to existing (i.e. enclosing) ones. A transform command |
151 |
with no arguments is used to return to the previous condition. It is |
152 |
necessary that transforms and their end statements ("xf" by itself) be |
153 |
balanced in a file, so that later or enclosing files are not affected. |
154 |
155 |
Transformations apply only to geometric types, e.g. polygons, spheres, etc. |
156 |
Vertices and the components that go into geometry are not directly affected. |
157 |
This is to avoid confusion and the inadvertent multiple application of a |
158 |
given transformation. |
159 |
160 |
Arrays |
161 |
162 |
The -a N transform specification causes the following transform |
163 |
arguments to be repeated along with the contents of the included |
164 |
objects N times. The first instance of the geometry will be in its |
165 |
initial location; the second instance will be repositioned according |
166 |
to the named transformation; the third instance will be repositioned by |
167 |
applying this transformation twice, and so on up to N-1 applications. |
168 |
169 |
Multi-dimensional arrays may be specified with a single include |
170 |
entity by giving multiple array commands separated by their |
171 |
corresponding transforms. A final transformation may be given |
172 |
by preceeding it with a -i 1 specification. In other words, the |
173 |
scope of an array command continues until the next -i or -a option. |
174 |
175 |
Other Details |
176 |
177 |
End of line may be any one of the sequences: linefeed ('\n'), carriage- |
178 |
return ('\r'), or a carriage return followed by a linefeed. |
179 |
180 |
Blank lines are ignored on the input, as are any blanks preceeding |
181 |
a keyword on a line. Indentation may improve readability, especially |
182 |
in context definitions. |
183 |
184 |
The comment character ('#') must be followed by at least one blank |
185 |
character (space or tab) for easy parsing. Like any other line, |
186 |
a comment may be extended to multiple lines using a backslash ('\'). |
187 |
188 |
Include filename paths are relative to the current file. Absolute |
189 |
paths are expressly forbidden. UNIX conventions should be used for the |
190 |
path separator ('/') and disk names should not be used (i.e. no |
191 |
"C:\file"). To further enhance portability across systems, directory |
192 |
names should be 8 characters or fewer with no suffix, filenames should |
193 |
fit within an 8.3 format, and all characters should be lower case. |
194 |
(They will be automatically promoted to upper case by DOS systems.) |
195 |
We suggest the standard suffix ".mgf" for "materials and geometry format". |
196 |
197 |
The XYZ coordinate system is right-handed, and lengths are always in |
198 |
SI meters. This is not really a limitation as the first statement |
199 |
in the file can always be a transform with the -s option to convert |
200 |
to a more convenient set of units. Included IES files will also start |
201 |
out in meters, and it is important to specify a transform into the |
202 |
local coordinate system. The -m option (preceeding any transform) |
203 |
may be used to specify an output multiplication factor. |
204 |
205 |
Vertex normals need not be normalized, and a normal equal to (0,0,0) indicates |
206 |
that the exact surface normal should be used. (This is the default.) |
207 |
208 |
Color in this system does not include intensity, only hue and |
209 |
saturation. Intensity, such as reflectance or emittance, is explicitly |
210 |
included in the other material parameters. All colors are absolute, |
211 |
e.g. spectral reflectance or transmittance under uniform white light. |
212 |
213 |
A CIE xy chromaticity pair is the most basic color specification. A |
214 |
full spectrum is the most general specification, and the starting (i.e. |
215 |
minimum) and ending (i.e. maximum) wavelengths are given along with a |
216 |
set of evenly spaced values. Wavelengths are given in nanometers, and |
217 |
should be within the range of 380-780. The spectral values themselves, |
218 |
which can be thought of as relative power density per nanometer, start |
219 |
at the first wavelength and proceed at even increments to the last |
220 |
wavelength. The values in between will be interpolated as necessary, |
221 |
so there must be at least two specified points. The color temperature |
222 |
entity corresponds to the spectrum of a black body at the specified |
223 |
temperature (in degrees Kelvin). The color mixing entity is intended |
224 |
not only for the mixing of named colors, but also for color |
225 |
specifications using an arbitrary set of basis functions. The mixing |
226 |
coefficients are in effect relative luminances for each color |
227 |
"primary." The actual total of the mixing coefficients or spectral |
228 |
values is irrelevant, since the results will always be normalized. |
229 |
230 |
Diffuse emittance is always given in SI units of lumens/meter^2. Note that |
231 |
this is emittance, not exitance, and does not include light reflected or |
232 |
transmitted by the surface. |
233 |
234 |
The roughness associated with specular reflectance and transmittance |
235 |
is the RMS surface facet slope. A value of 0 indicates a perfectly |
236 |
smooth surface, meaning that reflected or transmitted rays will not |
237 |
be scattered. |
238 |
239 |
The sum of the diffuse and specular reflectances and transmittances |
240 |
must be strictly less than one (with no negative values, obviously). |
241 |
242 |
The object entity establishes a hierarchical context, consisting of |
243 |
this identifier and all those preceding. It has no real meaning except |
244 |
to group the following surfaces up until an empty object statement |
245 |
under a descriptive name for improved file readability. |
246 |
247 |
Surfaces are two-sided unless the "sides" entity is used to set the |
248 |
number of sides for a material to one. If a surfaces is one-sided, |
249 |
then it appears invisible when viewed from the back side. This means |
250 |
that a transmitting object will affect the light coming in through the |
251 |
front surface and ignore the characteristics of the back surface. As |
252 |
long as the characteristics are the same, the results should be |
253 |
correct. If the rendering technique does not allow for one-sided |
254 |
surfaces, an approximately correct result can be obtained for one-sided |
255 |
transmitting surfaces by using the square root of the given tau_s and |
256 |
half the given alpha_t. If a rendering technique does not permit |
257 |
two-sided surfaces, then each surface must be made into two for |
258 |
full compliance if "sides" is set to 2 (the default). |
259 |
260 |
The surface normal of a face is oriented by the right-hand rule. |
261 |
Specifically, the surface normal faces towards the viewer when the |
262 |
vertices circulate counter-clockwise. Faces may be concave or convex, |
263 |
but must be planar. Holes may be represented as concave polygons with |
264 |
coincident sides (i.e. seams). |
265 |
266 |
A prism consists of a set of coplanar vertices specifying an end-face, |
267 |
and a length value. The prism will be extruded so that the end-face |
268 |
points outward, unless the length value is negative, in which case the |
269 |
object is extruded in the opposite direction, resulting in inward- |
270 |
directed surface normals. If surface normals are specified for the |
271 |
vertices, they will be applied to the side faces but not the end |
272 |
faces, and they must generally point in the appropriate direction |
273 |
(i.e. in or out depending on whether extrusion is negative or positive). |
274 |
275 |
A sphere, cylinder or cone with negative radii is interpreted as having |
276 |
an inward facing surface normal. Otherwise, the normal is assumed |
277 |
to face outwards. (It is illegal for a cone to have one positive and |
278 |
one negative radius.) |
279 |
280 |
The central vertex for a ring or torus must have an associated normal, |
281 |
which serves to orient the ring. The inner radius must be given first, |
282 |
and must be strictly less than the outer radius. The inner radius may |
283 |
be zero but not negative. There is an exception for a torus with |
284 |
inward-pointing normal, which is identified by a negative outer radius |
285 |
and a non-positive inner radius. |
286 |
287 |
Examples |
288 |
289 |
The following is a complete example input file (don't ask me what it is): |
290 |
291 |
# Define some materials: |
292 |
m red_plastic = |
293 |
c red = |
294 |
cxy .8 .1 |
295 |
rd 0.5 |
296 |
# reestablish unnamed (neutral) color context: |
297 |
c |
298 |
rs 0.04 0.02 |
299 |
m green_plastic = |
300 |
c green = |
301 |
cxy .2 .6 |
302 |
rd 0.4 |
303 |
c |
304 |
rs .05 0 |
305 |
m bright_emitter = |
306 |
c |
307 |
ed 1000 |
308 |
m dark = |
309 |
c |
310 |
rd .08 |
311 |
# Define some vertices: |
312 |
v v1 = |
313 |
p 10 5 7 |
314 |
v v2 = |
315 |
p 15 3 9 |
316 |
v v3 = |
317 |
p 20 -7 6 |
318 |
v v4 = |
319 |
p 20 10 6 |
320 |
v v5 = |
321 |
p 10 10 6 |
322 |
v v6 = |
323 |
p 10 -7 6 |
324 |
v cv1 = |
325 |
p -5 3 8 |
326 |
n 0 0 -1 |
327 |
v cv2 = |
328 |
p -3 3 8 |
329 |
n 0 0 1 |
330 |
# make some faces: |
331 |
m green_plastic |
332 |
f v1 v3 v4 |
333 |
m red_plastic |
334 |
f v3 v4 v5 |
335 |
f v5 v6 v7 |
336 |
m bright_emitter |
337 |
f v3 v4 v5 v6 |
338 |
# make a cylindrical source with dark end caps: |
339 |
m bright_emitter |
340 |
cyl cv1 .15 cv2 |
341 |
m dark |
342 |
ring cv1 0 .15 |
343 |
ring cv2 0 .15 |
344 |
345 |
The following is a more typical example, which relies on a material library: |
346 |
347 |
# Include our materials: |
348 |
i material.mgf |
349 |
# Modify red_plastic to have no specular component: |
350 |
m red_plastic |
351 |
rs 0 0 |
352 |
# Make an alias for blue_plastic: |
353 |
m outer_material = blue_plastic |
354 |
# Make a new material based on brass, with greater roughness: |
355 |
m rough_brass = brass |
356 |
c brass_color |
357 |
rs 0.9 0.15 |
358 |
# Load our vertices: |
359 |
i lum1vert.mgf |
360 |
# Modify appropriate vertices to make luminaire longer: |
361 |
v v10 |
362 |
p 5 -2 -.1 |
363 |
v v11 |
364 |
p 5 2 -.1 |
365 |
v v8 |
366 |
p 5 2 0 |
367 |
v v9 |
368 |
p 5 -2 0 |
369 |
# Load our surfaces, rotating them -90 degrees about Z: |
370 |
i lum1face.mgf -rz -90 |
371 |
# Make a 2-D array of sequins covering the face of the fixture: |
372 |
m silver |
373 |
i sequin.mgf -a 5 -t .5 0 0 -a 4 -t 0 .75 0 |
374 |
375 |
Note that by using libraries and modifying values, it is possible to create |
376 |
a variety of fixtures without requiring large files to describe each one. |
377 |
378 |
Interpretation |
379 |
380 |
Interpretation of this language will be simplified by the creation |
381 |
of a general parser that will be able to express the defined entities |
382 |
in simpler forms and remove entities that would not be understood by |
383 |
the caller. |
384 |
385 |
For example, a caller may ask the standard parser to produce only |
386 |
the entities for diffuse uncolored materials, vertices without normals, |
387 |
and polygons. The parser would then expand all include statements, |
388 |
remove all color statements, convert spheres and cones to polygonal |
389 |
approximations, and so forth. |
390 |
391 |
This way, a single general parser can permit software to operate |
392 |
at whatever level it is capable, with a minimal loss of generality. |
393 |
Furthermore, distribution of a standard parser will improve |
394 |
both forward and backward compatibility as new entities are added |
395 |
to the specification. |
396 |
397 |
Rationale |
398 |
399 |
Why create yet another file format for geometric data, when so many |
400 |
others already exist? The main answer to this question is that we |
401 |
are not merely defining geometry, but materials as well. Though the |
402 |
number of committee and de facto standards for geometric data is large, |
403 |
the number of standards for geometry + materials is small. Of these, |
404 |
almost all are non-physical in origin, i.e. they are based on common, |
405 |
ad hoc computer graphics rendering practices and cannot be used to create |
406 |
physical simulations. Of the one or two formats that were intended |
407 |
for or could be adapted to physical simulation, the syntax and semantics |
408 |
are at the same time too complex and too limiting to serve as a suitable |
409 |
standard. |
410 |
411 |
Specifically, establishing the above, new standard has the following |
412 |
advantages: |
413 |
414 |
o It is easy to parse. |
415 |
o It is easy to support, at least as a least common denominator. |
416 |
o It is ASCII and fairly easy for a person to read and understand. |
417 |
o It supports simple color, material and vertex libraries. |
418 |
o It includes a simple yet fairly complete material specification. |
419 |
o It is easy to skip unsupported entities (e.g. color, vertex normals) |
420 |
o It supports transformations and instances. |
421 |
o It is easy to add new entities, and as long as these entities can |
422 |
be approximated by the original set, backwards compatibility |
423 |
can be maintained through a standard parsing library. |
424 |
425 |
Most of the disadvantages of this format relate to its simplicity, but |
426 |
since simplicity was our most essential goal, this could not be helped. |
427 |
Specifically: |
428 |
429 |
o There is no general representation of curved surfaces (though |
430 |
vertex normals make approximations straightforward). |
431 |
o There are no general surface scattering functions. |
432 |
o There are no textures or bump-maps. |
433 |
434 |
If any of these seems particularly important, I will look into adding them, |
435 |
though they will tend to complicate the specification and make it more |
436 |
difficult to support. |
