--- ray/src/cv/mgflib/spec.txt 1994/09/02 16:04:13 1.6 +++ ray/src/cv/mgflib/spec.txt 1995/04/13 12:38:33 1.8 @@ -27,9 +27,8 @@ current transform and the current object name. Each entity is given by a short keyword, followed by space- or tab- delimited arguments on a single line. A single entity may be extended over multiple lines using a backslash ('\') character right before the -end of line, though no extended line may exceed 512 characters in total -length. (Given the current set of entities, even approaching 80 -characters would be highly unusual.) +end of line, though no extended line may exceed 4096 characters in total +length. Entities and Contexts ===================== @@ -84,6 +83,7 @@ n dx dy dz set surface normal for current vertex c [id [= [template]]] get/set color context cxy x y set CIE (x,y) chromaticity for current color cspec l_min l_max v1 v2 .. set relative spectrum for current color +cct temperature set spectrum based on black body temperature cmix w1 c1 w2 c2 .. mix named colors to make current color m [id [= [template]]] get/set material context sides {1|2} set number of sides for current material @@ -92,6 +92,7 @@ td tau_d set diffuse transmittance for current mater ed epsilon_d set diffuse emittance for current material rs rho_s alpha_r set specular reflectance for current material ts tau_s alpha_t set specular transmittance for current material +ir n_real n_imag set index of refraction for current material o [name] begin/end object context f v1 v2 v3 .. polygon using current material, spec. vertices sph vc radius sphere @@ -214,17 +215,18 @@ A CIE xy chromaticity pair is the most basic color spe full spectrum is the most general specification, and the starting (i.e. minimum) and ending (i.e. maximum) wavelengths are given along with a set of evenly spaced values. Wavelengths are given in nanometers, and -must be within the range of 380-780. The spectral values themselves, +should be within the range of 380-780. The spectral values themselves, which can be thought of as relative power density per nanometer, start at the first wavelength and proceed at even increments to the last wavelength. The values in between will be interpolated as necessary, -so there must be at least two specified points. The color mixing -entity is intended not only for the mixing of named colors, but also -for color specifications using an arbitrary set of basis functions. -The mixing coefficients are in effect relative luminances for each -color "primary." The actual total of the mixing coefficients or -spectral values is irrelevant, since the results will always be -normalized. +so there must be at least two specified points. The color temperature +entity corresponds to the spectrum of a black body at the specified +temperature (in degrees Kelvin). The color mixing entity is intended +not only for the mixing of named colors, but also for color +specifications using an arbitrary set of basis functions. The mixing +coefficients are in effect relative luminances for each color +"primary." The actual total of the mixing coefficients or spectral +values is irrelevant, since the results will always be normalized. Diffuse emittance is always given in SI units of lumens/meter^2. Note that this is emittance, not exitance, and does not include light reflected or @@ -237,6 +239,17 @@ be scattered. The sum of the diffuse and specular reflectances and transmittances must be strictly less than one (with no negative values, obviously). +These values are assumed to be measured at normal incidence. If an +index of refraction is given, this may modify the balance between +diffuse and specular reflectance at other incident angles. If the +material is one-sided (see below), then it may be a dielectric interface. +In this case, the specular transmittance given is that which would be +measured at normal incidence for a pane of the material 5 mm thick. +This is important for figuring the actual transmittance for non-planar +geometries assuming a uniformly absorbing medium. If the index of +refraction has an imaginary part, then the surface is a metal and this +implies other properties according to physics. The default index of +refraction is that of a vacuum, i.e. (1,0). The object entity establishes a hierarchical context, consisting of this identifier and all those preceding. It has no real meaning except @@ -244,12 +257,12 @@ to group the following surfaces up until an empty obje under a descriptive name for improved file readability. Surfaces are two-sided unless the "sides" entity is used to set the -number of sides for a material to one. If a surfaces is one-sided, +number of sides for a material to one. If a surface is one-sided, then it appears invisible when viewed from the back side. This means that a transmitting object will affect the light coming in through the front surface and ignore the characteristics of the back surface. As -long as the characteristics are the same, the results should be -correct. If the rendering technique does not allow for one-sided +long as the transmission characteristics are the same, the results should +be correct. If the rendering technique does not allow for one-sided surfaces, an approximately correct result can be obtained for one-sided transmitting surfaces by using the square root of the given tau_s and half the given alpha_t. If a rendering technique does not permit
