--- ray/src/cv/mgflib/spec.txt 1994/07/01 18:07:02 1.3 +++ ray/src/cv/mgflib/spec.txt 1995/03/07 14:53:31 1.7 @@ -27,9 +27,8 @@ current transform and the current object name. Each entity is given by a short keyword, followed by space- or tab- delimited arguments on a single line. A single entity may be extended over multiple lines using a backslash ('\') character right before the -end of line, though no extended line may exceed 512 characters in total -length. (Given the current set of entities, even approaching 80 -characters would be highly unusual.) +end of line, though no extended line may exceed 4096 characters in total +length. Entities and Contexts ===================== @@ -68,7 +67,8 @@ can be thought of as parts and subparts of an enclosin Note that this is strictly for ease of identification, and has no real meaning as far as the geometric description goes. In contrast, the transform entity is very significant as it determines how enclosing -objects are to be scaled and placed in the final description. +objects are to be scaled and placed in the final description. Hierarchical +contexts may be nested in any way, but should not overlap. Without further ado, here are the proposed entities and their interpretations: @@ -83,6 +83,7 @@ n dx dy dz set surface normal for current vertex c [id [= [template]]] get/set color context cxy x y set CIE (x,y) chromaticity for current color cspec l_min l_max v1 v2 .. set relative spectrum for current color +cct temperature set spectrum based on black body temperature cmix w1 c1 w2 c2 .. mix named colors to make current color m [id [= [template]]] get/set material context sides {1|2} set number of sides for current material @@ -96,7 +97,7 @@ f v1 v2 v3 .. polygon using current material, spec. v sph vc radius sphere cyl v1 radius v2 truncated right cylinder (open-ended) cone v1 rad1 v2 rad2 truncated right cone (open-ended) -prism v1 v2 v3 .. length right prism (closed solid) +prism v1 v2 v3 .. length truncated right prism (closed solid) ring vc rmin rmax circular ring with inner and outer radii torus vc rmin rmax circular torus with inner and outer radii xf [xform] begin/end transformation context @@ -144,11 +145,12 @@ Rotations are given in degrees counter-clockwise about That is, with the thumb of the right hand pointing in the direction of the axis, rotation follows the curl of the fingers. -The transform command itself is also cumulative, and a transform -command with no arguments is used to return to the previous -condition. It is necessary that transforms and their end statements -("xf" by itself) be balanced in a file, so that later or enclosing -files are not affected. +The transform command itself is also cumulative, but in the reverse +order. That is, later transformations (i.e. enclosed transformations) +are prepended to existing (i.e. enclosing) ones. A transform command +with no arguments is used to return to the previous condition. It is +necessary that transforms and their end statements ("xf" by itself) be +balanced in a file, so that later or enclosing files are not affected. Transformations apply only to geometric types, e.g. polygons, spheres, etc. Vertices and the components that go into geometry are not directly affected. @@ -208,18 +210,22 @@ saturation. Intensity, such as reflectance or emittan included in the other material parameters. All colors are absolute, e.g. spectral reflectance or transmittance under uniform white light. -A CIE xy chromaticity pair is the most basic color specification. -A full spectrum is the most general specification, and the starting -(i.e. minimum) and ending (i.e. maximum) wavelengths are given along -with a set of evenly spaced values. Wavelengths are given in nanometers, -and must be within the range of 380-780. The spectral values themselves -are located starting at the first wavelength and proceeding at even -increments to the ending wavelength. The values in between will be -interpolated as necessary, so there must be at least two specified points. -The color mixing entity is intended not only for the mixing of named -colors, but also for color specifications using an arbitrary set -of basis functions. The actual totals for spectral and mixing -coefficients is irrelevant, since the results will be normalized. +A CIE xy chromaticity pair is the most basic color specification. A +full spectrum is the most general specification, and the starting (i.e. +minimum) and ending (i.e. maximum) wavelengths are given along with a +set of evenly spaced values. Wavelengths are given in nanometers, and +should be within the range of 380-780. The spectral values themselves, +which can be thought of as relative power density per nanometer, start +at the first wavelength and proceed at even increments to the last +wavelength. The values in between will be interpolated as necessary, +so there must be at least two specified points. The color temperature +entity corresponds to the spectrum of a black body at the specified +temperature (in degrees Kelvin). The color mixing entity is intended +not only for the mixing of named colors, but also for color +specifications using an arbitrary set of basis functions. The mixing +coefficients are in effect relative luminances for each color +"primary." The actual total of the mixing coefficients or spectral +values is irrelevant, since the results will always be normalized. Diffuse emittance is always given in SI units of lumens/meter^2. Note that this is emittance, not exitance, and does not include light reflected or @@ -261,7 +267,10 @@ A prism consists of a set of coplanar vertices specify and a length value. The prism will be extruded so that the end-face points outward, unless the length value is negative, in which case the object is extruded in the opposite direction, resulting in inward- -directed surface normals. +directed surface normals. If surface normals are specified for the +vertices, they will be applied to the side faces but not the end +faces, and they must generally point in the appropriate direction +(i.e. in or out depending on whether extrusion is negative or positive). A sphere, cylinder or cone with negative radii is interpreted as having an inward facing surface normal. Otherwise, the normal is assumed
