root/radiance/ray/src/cv/mgflib/spec.txt
Fri Feb 28 20:19:26 2003 UTC (21 years, 3 months ago) by greg
CVS Tags: HEAD, rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Diff to previous 1.8 , to selected 1.4
Fixed RCSid's
Thu Apr 13 12:38:33 1995 UTC (29 years, 1 month ago) by greg
Changes since 1.7: +15 -3 lines
Diff to previous 1.7 , to selected 1.4
added index of refraction
Tue Mar 7 14:53:31 1995 UTC (29 years, 3 months ago) by greg
Changes since 1.6: +12 -11 lines
Diff to previous 1.6 , to selected 1.4
added cct entity
Fri Sep 2 16:04:13 1994 UTC (29 years, 9 months ago) by greg
Changes since 1.5: +15 -12 lines
Diff to previous 1.5 , to selected 1.4
corrected problems with cmix function (I think -- needs checking!)
Fri Jul 22 09:58:52 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.4: +7 -3 lines
Diff to previous 1.4
added surface normal interpolation to prism's
Revision 1.4 - (view) (download) (annotate) - [selected]
Mon Jul 11 14:47:09 1994 UTC (29 years, 11 months ago) by greg
Changes since 1.3: +6 -5 lines
Diff to previous 1.3
fixed order of transformation accumulation (serious bug!)
Fri Jul 1 18:07:02 1994 UTC (29 years, 11 months ago) by greg
Changes since 1.2: +32 -26 lines
Diff to previous 1.2 , to selected 1.4
added "sides" entity for one- vs. two-sided surfaces
Wed Jun 29 16:15:27 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 1.1 , to selected 1.4
made the -a (array) option work within files as well
Sat Jun 25 09:46:58 1994 UTC (29 years, 11 months ago) by greg
Diff to selected 1.4
