1 |
MGF PACKAGE DESCRIPTION |
2 |
SCCSid "$SunId$ LBL" |
3 |
4 |
This package includes a description and parser for a new scene |
5 |
description standard, called for the lack of a better name, MGF |
6 |
for Materials and Geometry Format. It was developed by Greg |
7 |
Ward of the Lawrence Berkeley Laboratory <[email protected]> with |
8 |
help and advice from Rob Shakespeare of Indiana University |
9 |
<[email protected]>, Ian Ashdown of Ledalite Corporation |
10 |
<[email protected]> and Holly Rushmeier of the National |
11 |
Institute for Standards and Technology <[email protected]>. |
12 |
13 |
The language itself is described in the file "spec.txt", and |
14 |
the included Makefile should make building the parser library |
15 |
fairly straightforward on most systems. What's left then, is |
16 |
explaining the why and how of using this package. |
17 |
18 |
The initial purpose of developing a scene description standard |
19 |
was for inclusion in the Illumination Engineering Society's (IES) |
20 |
standard data representation for luminaires. It occurred to us |
21 |
early on that such a standard might have broader applications, |
22 |
so an effort was made to create a fairly general description |
23 |
language, while keeping it as simple as possible for the people |
24 |
who have to create descriptions with it as well as the programmers |
25 |
who have to support it. |
26 |
27 |
Why create a new standard rather than exploiting an existing one? |
28 |
Some of the rationale for our decision is explained at the end of |
29 |
the specification document, but it mostly boils down to materials. |
30 |
As easy as it is to describe physically valid materials, most |
31 |
scene description languages cannot do it. The material specification |
32 |
included in the MGF standard may not be perfect, but at least it's |
33 |
physically plausible. Furthermore, we are committed to making any |
34 |
future modifications to the standard backwards-compatible -- a rather |
35 |
tricky proposition. |
36 |
37 |
This takes us to the how of supporting this new standard. The basic |
38 |
approach is to use the standard parser, which does a lot of the work |
39 |
in supporting the language itself. The programmer tells the parser |
40 |
which entities it will support, and the parser does the rest. |
41 |
That way, it isn't necessary to modify the program when a new version |
42 |
of the standard comes out; all one has to do is link to the new |
43 |
standard's parser. (The include file will change as well, so it's |
44 |
not QUITE that simple, but close.) |
45 |
46 |
There are two ways to support the language, by linking the parser to |
47 |
the program itself, or by linking the parser to a translator program |
48 |
that expresses MGF entities in the native scene description format. |
49 |
The differences in the two approaches are slight, and we will mention |
50 |
them following a general explanation of the parser and support library. |
51 |
52 |
The Parser |
53 |
54 |
The MGF parser is written in ANSI-C (though the -DNOPROTO flag may be |
55 |
used to get back K&R compatibility). All of the declarations and |
56 |
definitions needed are in the single include file "parser.h". This |
57 |
file is a good place to look for details on using the various support |
58 |
routines as well. The parser itself is parser.c, though it relies for |
59 |
some translations on other C modules. These same support routines will |
60 |
no doubt be useful for applications programmers, and we will explain |
61 |
some of them in the following sections. |
62 |
63 |
Initializing the parser is the most important part of writing an MGF |
64 |
program, and it is done through the mg_ehand array and a call to mg_init. |
65 |
The global mg_ehand variable is an array of pointers to entity handler |
66 |
functions. The arguments to these functions are always the same, an |
67 |
argument count and an array of argument pointers (ala main). The return |
68 |
value for these integer functions is one of the error codes defined in |
69 |
parser.h, or MG_OK if the entity was handled correctly. You must |
70 |
set the appropriate entries for the entities you can support, then call |
71 |
mg_init to fill in the rest. Most of the entities you cannot support |
72 |
will be translated into (approximately) equivalent ones you can. |
73 |
Entities that have no equivalent (such as color), will be safely |
74 |
ignored on the input. If you have specified support for some entities |
75 |
without offering support to their prerequisites, mg_init will report an |
76 |
error and exit. |
77 |
78 |
Once the parser has been properly initialized, MGF input files may be |
79 |
loaded at will with the mg_load call. This function takes a single |
80 |
argument, which is the name of the MGF file. (The NULL pointer may be |
81 |
used to specify standard input.) The behavior of the parser in part |
82 |
depends on input history, so the mg_clear call should be used after |
83 |
each file if starting fresh is important. This also frees any data |
84 |
structures used by the parser, which may be desirable if the program |
85 |
is going to do something after loading besides exit. |
86 |
87 |
Support Functions |
88 |
89 |
In translating unsupported entities, the parser makes use of a number |
90 |
of support functions, contained in associated C modules. The most |
91 |
important of these are in context.c, which includes three handler |
92 |
functions that can support all color, material and vertex entities. |
93 |
To understand what these functions do, it is necessary to know a |
94 |
little about the MGF language itself, so please familiarize yourself |
95 |
with it now if you haven't already. (See the file "spec.txt".) |
96 |
97 |
Context Support |
98 |
99 |
The MGF language defines three named contexts, the current vertex, |
100 |
the current color and the current material. (The current color is |
101 |
used mostly for setting parameters in the current material.) There |
102 |
are three handler routines defined in context.c, and they can handle |
103 |
all entities related to these three contexts. The simplest way to |
104 |
support materials, for example, is to initialize the mg_ehand array |
105 |
such that the MG_E_MATERIAL, MG_E_RD, MG_E_RS, etc. entries all point |
106 |
to c_hmaterial. Then, whenever a material is needed, the global |
107 |
c_cmaterial variable will be pointing to a structure with all the |
108 |
current settings. (Note that you would have to also set the color |
109 |
mg_ehand entries to c_hcolor if you intended to support color |
110 |
materials.) A list of related mg_ehand assignments is given below: |
111 |
112 |
mg_ehand[MG_E_COLOR] = c_hcolor; |
113 |
mg_ehand[MG_E_CCT] = c_hcolor; |
114 |
mg_ehand[MG_E_CMIX] = c_hcolor; |
115 |
mg_ehand[MG_E_CSPEC] = c_hcolor; |
116 |
mg_ehand[MG_E_CXY] = c_hcolor; |
117 |
mg_ehand[MG_E_ED] = c_hmaterial; |
118 |
mg_ehand[MG_E_IR] = c_hmaterial; |
119 |
mg_ehand[MG_E_MATERIAL] = c_hmaterial; |
120 |
mg_ehand[MG_E_NORMAL] = c_hvertex; |
121 |
mg_ehand[MG_E_POINT] = c_hvertex; |
122 |
mg_ehand[MG_E_RD] = c_hmaterial; |
123 |
mg_ehand[MG_E_RS] = c_hmaterial; |
124 |
mg_ehand[MG_E_SIDES] = c_hmaterial; |
125 |
mg_ehand[MG_E_TD] = c_hmaterial; |
126 |
mg_ehand[MG_E_TS] = c_hmaterial; |
127 |
mg_ehand[MG_E_VERTEX] = c_hvertex; |
128 |
129 |
In addition to the three handler functions, context.c contains a |
130 |
few support routines that make life simpler. For vertices, there |
131 |
is the c_getvertex call, which returns a pointer to a named vertex |
132 |
structure (or NULL if there is no corresponding definition for the |
133 |
given name). This function is needed for support of most surface |
134 |
entities. For color support, there is the analogous c_getcolor call, |
135 |
and the c_ccvt routine, which is used to convert from one color |
136 |
representation to another (e.g. spectral color to xy chromaticity |
137 |
coordinates). Also, there is a function called c_isgrey, which |
138 |
simply returns 1 or 0 based on whether the passed color structure |
139 |
is close to grey or not. Finally, there is the c_clearall routine, |
140 |
which clears and frees all context data structures, and is the |
141 |
principal action of the parser's mg_clear function. |
142 |
143 |
Transform Support |
144 |
145 |
If your program is supporting any geometry at all (and what would be |
146 |
the point if it wasn't?) you will need to support the transform |
147 |
entity (MG_E_XF). This would be tricky, if it weren't for the support |
148 |
routines provided, which make the task fairly painless. First, there |
149 |
is the transform handler itself, xf_handler. Just set the MG_E_XF |
150 |
entry of the mg_ehand array to this function. Then, anytime you want |
151 |
to transform something, call one of the associated functions, xf_xfmpoint, |
152 |
xf_xfmvect, xf_rotvect or xf_scale. These functions transform a 3-D |
153 |
point, 3-D vector (without translation), rotate a 3-D vector (without |
154 |
scaling) and scale a floating-point value, respectively. |
155 |
156 |
Object Support |
157 |
158 |
The MGF language includes a single entity for naming objects, MG_E_OBJECT. |
159 |
It is mostly provided as a convenience for the user, so that individual |
160 |
geometric parts may be easily identified. Although supporting this entity |
161 |
directly is possible, it's hierarchical nature requires maintaining a stack |
162 |
of object names. The object handler in object.c provides this functionality. |
163 |
Simply set the MG_E_OBJECT entry of the mg_ehand array to obj_handler, |
164 |
and the current object name list will be kept in the global array obj_name. |
165 |
The number of names is stored in the global obj_nnames variable. To clear |
166 |
this array (freeing any memory used in the process), call obj_clear. |
167 |
168 |
Loading vs. Translating |
169 |
170 |
As mentioned in the introduction, the parser may be used either to load |
171 |
data into a rendering program directly, or to get MGF input for translation |
172 |
to another file format. In either case, the procedure is nearly identical. |
173 |
The only important difference is what you do with the parser data structures |
174 |
after loading. For a translator, this is not an issue, but rendering |
175 |
programs usually need all the memory they can get. Therefore, once the |
176 |
input process is complete, you should call the mg_clear function to free |
177 |
the parser data structures and return to an initialized state (i.e. it |
178 |
is never necessary to recall the mg_init routine). |
179 |
180 |
Also, if you use some of the support functions, you should call their |
181 |
specific clearing functions. For the transform module, the call is |
182 |
xf_clear. For the object support module, the call is obj_clear. The |
183 |
context routines use the c_clearall function, but this is actually |
184 |
called by mg_clear, so calling it again is unnecessary. |
185 |
186 |
Linking Vertices |
187 |
188 |
Although the MGF language was designed with linking vertices in mind, |
189 |
there are certain aspects which make this goal more challenging. |
190 |
Specifically, the ability to redefine values for a previously named |
191 |
vertex is troublesome for the programmer, since the same vertex can |
192 |
have different values at different points in the input. Likewise, the |
193 |
effect of the transform entity on surfaces rather than vertices means |
194 |
that the same named vertex can appear in many positions. |
195 |
196 |
It is not possible to use the parser data structures directly for |
197 |
linking vertices, but we've taken a couple of steps in the support |
198 |
routines to make the task of organizing your own data structures a |
199 |
little easier. First, there is a clock member in the C_VERTEX |
200 |
structure that is incremented on each change. (The same member is |
201 |
contained in the C_COLOR and C_MATERIAL structures.) Second, the |
202 |
current transform (pointed to by xf_context) contains a unique |
203 |
identifier, xf_context->xid. This is a long integer that will be |
204 |
different for each unique transform. (It is actually a hash key on the |
205 |
transformation matrix, and there is about 1 chance in 2 billion that |
206 |
two different matrices will hash to the same value. Is this a bug? |
207 |
I guess it depends on how long the programmer lives -- or vice versa.) |
208 |
209 |
There are two ways to use of this additional information. One |
210 |
is to record the vertex clock value along with it's id and the |
211 |
current xf_context->xid value. If another vertex comes along with |
212 |
the same name, but one of these two additional values fails to match, |
213 |
then it (probably) is a different vertex. Alternatively, one can reset |
214 |
the clock member every time a new vertex is stored. That way, it is |
215 |
only necessary to check the clock against zero rather than storing this |
216 |
value along with the vertex name and transform id. If the name and |
217 |
transform are the same and the clock is zero, then it's the same vertex |
218 |
as last time. |
219 |
220 |
Yet another approach is to ignore the parser structures entirely and |
221 |
focus on the actual vertex values. After all, the user is not compelled |
222 |
to reuse the same vertex names for the same points. It is just as likely |
223 |
that the same vertices will appear under different names, so that none |
224 |
of the above would help to merge them. The most sure-fire approach to |
225 |
linking identical vertices is therefore to hash the point and normal |
226 |
values directly and use the functions in lookup.c to associate them. |
227 |
You will have to write your own hash function, and we recommend making |
228 |
one that allows a little slop so that nearly identical points hash to |
229 |
the same value. |
230 |
231 |
Examples |
232 |
233 |
Two example translator programs are included with this package. |
234 |
235 |
The simplest is a translator from MGF to MGF called mgfilt.c, which |
236 |
produces on the standard output only those entities from the standard |
237 |
input that are supported according to the first command line argument. |
238 |
For example, one could remove everything but the raw, flat polygonal |
239 |
geometry with the following command: |
240 |
241 |
mgfilt v,p,f,xf any.mgf > faces.mgf |
242 |
243 |
Note that the xf entity must also be included, for its support is |
244 |
required by all geometric entities. |
245 |
246 |
The second translator converts from MGF to the Radiance scene description |
247 |
language, and is a more practical example of parser use. Unfortunately, |
248 |
we did not include all of the support functions required by this translator, |
249 |
so it serves as a source code example only. If you wish to get the rest |
250 |
of it because you intend to run it, contact Greg Ward <[email protected]> |
251 |
and he'll be happy to provide you with the missing pieces. |
252 |
253 |
Copyright |
254 |
255 |
At this point, the legal issues related to this parser have not been |
256 |
worked out. The intent is to offer it free of charge to all those who |
257 |
wish to use it (with no guarantees, of course). However, we may decide |
258 |
that copyright protections are necessary to prevent unauthorized versions |
259 |
of the parser, which do not properly support the MGF standard, from |
260 |
getting spread around. Since this is a pre-release, we trust that you |
261 |
will not share it with anyone without getting our permission first. |
262 |
263 |
Questions |
264 |
265 |
Questions should be directed to Greg Ward <[email protected]>, who will be |
266 |
happy to offer any reasonable assistance in using this standard. (Greg's |
267 |
telephone is 1-510-486-4757, fax 1-510-486-4089.) |
