--- ray/src/cv/mgflib/readme.txt 1994/09/01 09:50:27 1.5 +++ ray/src/cv/mgflib/readme.txt 2003/02/28 20:19:26 1.8 @@ -1,5 +1,5 @@ MGF PACKAGE DESCRIPTION - SCCSid "$SunId$ LBL" + RCSid "$Id: readme.txt,v 1.8 2003/02/28 20:19:26 greg Exp $" This package includes a description and parser for a new scene description standard, called for the lack of a better name, MGF @@ -110,10 +110,12 @@ mg_ehand entries to c_hcolor if you intended to suppor materials.) A list of related mg_ehand assignments is given below: mg_ehand[MG_E_COLOR] = c_hcolor; + mg_ehand[MG_E_CCT] = c_hcolor; mg_ehand[MG_E_CMIX] = c_hcolor; mg_ehand[MG_E_CSPEC] = c_hcolor; mg_ehand[MG_E_CXY] = c_hcolor; mg_ehand[MG_E_ED] = c_hmaterial; + mg_ehand[MG_E_IR] = c_hmaterial; mg_ehand[MG_E_MATERIAL] = c_hmaterial; mg_ehand[MG_E_NORMAL] = c_hvertex; mg_ehand[MG_E_POINT] = c_hvertex; @@ -232,11 +234,11 @@ Two example translator programs are included with this The simplest is a translator from MGF to MGF called mgfilt.c, which produces on the standard output only those entities from the standard -input that are supported according to the command line arguments. For -example, one could remove everything but the raw, flat polygonal +input that are supported according to the first command line argument. +For example, one could remove everything but the raw, flat polygonal geometry with the following command: - mgfilt v p f xf < any.mgf > faces.mgf + mgfilt v,p,f,xf any.mgf > faces.mgf Note that the xf entity must also be included, for its support is required by all geometric entities.
