--- ray/src/cv/mgflib/readme.txt 1994/06/25 16:33:12 1.3 +++ ray/src/cv/mgflib/readme.txt 1995/03/07 14:53:29 1.6 @@ -63,7 +63,7 @@ some of them in the following sections. Initializing the parser is the most important part of writing an MGF program, and it is done through the mg_ehand array and a call to mg_init. The global mg_ehand variable is an array of pointers to entity handler -functions. The arguments to these functions is always the same, an +functions. The arguments to these functions are always the same, an argument count and an array of argument pointers (ala main). The return value for these integer functions is one of the error codes defined in parser.h, or MG_OK if the entity was handled correctly. You must @@ -107,8 +107,24 @@ to c_hmaterial. Then, whenever a material is needed, c_cmaterial variable will be pointing to a structure with all the current settings. (Note that you would have to also set the color mg_ehand entries to c_hcolor if you intended to support color -materials.) +materials.) A list of related mg_ehand assignments is given below: + mg_ehand[MG_E_COLOR] = c_hcolor; + mg_ehand[MG_E_CCT] = c_hcolor; + mg_ehand[MG_E_CMIX] = c_hcolor; + mg_ehand[MG_E_CSPEC] = c_hcolor; + mg_ehand[MG_E_CXY] = c_hcolor; + mg_ehand[MG_E_ED] = c_hmaterial; + mg_ehand[MG_E_MATERIAL] = c_hmaterial; + mg_ehand[MG_E_NORMAL] = c_hvertex; + mg_ehand[MG_E_POINT] = c_hvertex; + mg_ehand[MG_E_RD] = c_hmaterial; + mg_ehand[MG_E_RS] = c_hmaterial; + mg_ehand[MG_E_SIDES] = c_hmaterial; + mg_ehand[MG_E_TD] = c_hmaterial; + mg_ehand[MG_E_TS] = c_hmaterial; + mg_ehand[MG_E_VERTEX] = c_hvertex; + In addition to the three handler functions, context.c contains a few support routines that make life simpler. For vertices, there is the c_getvertex call, which returns a pointer to a named vertex @@ -121,7 +137,7 @@ coordinates). Also, there is a function called c_isgr simply returns 1 or 0 based on whether the passed color structure is close to grey or not. Finally, there is the c_clearall routine, which clears and frees all context data structures, and is the -principle action of the parser's mg_clear function. +principal action of the parser's mg_clear function. Transform Support ================= @@ -207,7 +223,7 @@ that the same vertices will appear under different nam of the above would help to merge them. The most sure-fire approach to linking identical vertices is therefore to hash the point and normal values directly and use the functions in lookup.c to associate them. -You will have to write your own hash function, and I recommend making +You will have to write your own hash function, and we recommend making one that allows a little slop so that nearly identical points hash to the same value. @@ -217,11 +233,11 @@ Two example translator programs are included with this The simplest is a translator from MGF to MGF called mgfilt.c, which produces on the standard output only those entities from the standard -input that are supported according to the command line arguments. For -example, one could remove everything but the raw, flat polygonal +input that are supported according to the first command line argument. +For example, one could remove everything but the raw, flat polygonal geometry with the following command: - mgfilt v p f xf < any.mgf > faces.mgf + mgfilt v,p,f,xf any.mgf > faces.mgf Note that the xf entity must also be included, for its support is required by all geometric entities. @@ -239,9 +255,9 @@ At this point, the legal issues related to this parser worked out. The intent is to offer it free of charge to all those who wish to use it (with no guarantees, of course). However, we may decide that copyright protections are necessary to prevent unauthorized versions -of the parser that do not properly support the MGF standard from getting -spread around. Since this is a pre-release, we trust that you will not -share it with anyone without getting our permission first. +of the parser, which do not properly support the MGF standard, from +getting spread around. Since this is a pre-release, we trust that you +will not share it with anyone without getting our permission first. Questions =========
