root/radiance/ray/src/cv/mgflib/readme.txt
Revision: 1.1
Committed: Sat Jun 25 09:57:52 1994 UTC (30 years, 10 months ago) by greg
1 MGF PACKAGE DESCRIPTION
2 SCCSid "$SunId$ LBL"
3
4 This package includes a description and parser for a new scene
5 description standard, called for the lack of a better name, MGF
6 for Materials and Geometry Format. It was developed by Greg
7 Ward of the Lawrence Berkeley Laboratory <[email protected]> with
8 help and advice from Rob Shakespeare of Indiana University
9 <[email protected]>, Ian Ashdown of Ledalite Corporation
10 <[email protected]> and Holly Rushmeier of the National
11 Institute for Standards and Technology <[email protected]>.
12
13 The language itself is described in the file "spec.txt", and
14 the included Makefile should make building the parser library
15 fairly straightforward on most systems. What's left then, is
16 explaining the why and how of using this package.
17
18 The initial purpose of developing a scene description standard
19 was for inclusion in the Illumination Engineering Society's (IES)
20 standard data representation for luminaires. It occurred to us
21 early on that such a standard might have broader applications,
22 so an effort was made to create a fairly general description
23 language, while keeping it as simple as possible for the people
24 who have to create descriptions with it as well as the programmers
25 who have to support it.
26
27 Why create a new standard rather than exploiting an existing one?
28 Some of the rationale for our decision is explained at the end of
29 the specification document, but it mostly boils down to materials.
30 As easy as it is to describe physically valid materials, most
31 scene description languages cannot do it. The material specification
32 included in the MGF standard may not be perfect, but at least it's
33 physically plausible. Furthermore, we are committed to making any
34 future modifications to the standard backwards-compatible -- a rather
35 tricky proposition.
36
37 This takes us to the how of supporting this new standard. The basic
38 approach is to use the standard parser, which does a lot of the work
39 in supporting the language itself. The programmer tells the parser
40 which entities it will support, and the parser does the rest.
41 That way, it isn't necessary to modify the program when a new version
42 of the standard comes out; all one has to do is link to the new
43 standard's parser. (The include file will change as well, so it's
44 not QUITE that simple, but close.)
45
46 There are two ways to support the language, by linking the parser to
47 the program itself, or by linking the parser to a translator program
48 that expresses MGF entities in the native scene description format.
49 The differences in the two approaches are slight, and we will explain
50 them following a general explanation of the parser and support library.
51
52 The Parser
53 ==========
54 The MGF parser is written in ANSI-C (though the -DNOPROTO flag may be
55 used to get back K&R compatibility). All of the declarations and
56 definitions needed are in the single include file "parser.h". This
57 file is a good place to look for details on using the various support
58 routines as well. The parser itself is parser.c, though it relies for
59 some translations on other C modules. These same support routines will
60 no doubt be useful for applications programmers, and we will explain
61 some of them in the following sections.
62
63 Initializing the parser is the most important part of writing an MGF
64 program, and it is done through the mg_ehand array and a call to mg_init.
65 The global mg_ehand variable is an array of pointers to entity handler
66 functions. The arguments to these functions is always the same, an
67 argument count and an array of argument pointers (ala main). The return
68 value for these integer functions is one of the error codes defined in
69 parser.h, or MG_OK if the entity was handled correctly. You must
70 set the appropriate entries for the entities you can support, then call
71 mg_init to fill in the rest. Most of the entities you cannot support
72 will be translated into (approximately) equivalent ones you can.
73 Entities that have no equivalent (such as color), will be safely
74 ignored on the input. If you have specified support for some entities
75 without offering support to their prerequisites, mg_init will report an
76 error and exit.
77
78 Once the parser has been properly initialized, MGF input files may be
79 loaded at will with the mg_load call. This function takes a single
80 argument, which is the name of the MGF file. (The NULL pointer may be
81 used to specify standard input.) The behavior of the parser in part
82 depends on input history, so the mg_clear call should be used after
83 each file if starting fresh is important. This also frees any data
84 structures used by the parser, which may be desirable if the program
85 is going to do something after loading besides exit.
86
87 Support Functions
88 =================
89 In translating unsupported entities, the parser makes use of a number
90 of support functions, contained in associated C modules. The most
91 important of these are in context.c, which includes three handler
92 functions that can support all color, material and vertex entities.
93 To understand what these functions do, it is necessary to know a
94 little about the MGF language itself, so please familiarize yourself
95 with it now if you haven't already. (See the file "spec.txt".)
96
97 Context Support
98 ===============
99 The MGF language defines three named contexts, the current vertex,
100 the current color and the current material. (The current color is
101 used mostly for setting parameters in the current material.) There
102 are three handler routines defined in context.c, and they can handle
103 all entities related to these three contexts. The simplest way to
104 support materials, for example, is to initialize the mg_ehand array
105 such that the MG_E_MATERIAL, MG_E_RD, MG_E_RS, etc. entries all point
106 to c_hmaterial. Then, whenever a material is needed, the global
107 c_cmaterial variable will be pointing to a structure with all the
108 current settings. (Note that you would have to also set the color
109 mg_ehand entries to c_hcolor if you intended to support color
110 materials.)
111
112 In addition to the three handler functions, context.c contains a
113 few support routines that make life simpler. For vertices, there
114 is the c_getvertex call, which returns a pointer to a named vertex
115 structure (or NULL if there is no corresponding definition for the
116 given name). This function is needed for support of most surface
117 entities. For color support, there is the analogous c_getcolor call,
118 and the c_ccvt routine, which is used to convert from one color
119 representation to another (e.g. spectral color to xy chromaticity
120 coordinates). Also, there is a function called c_isgrey, which
121 simply returns 1 or 0 based on whether the passed color structure
122 is close to grey or not. Finally, there is the c_clearall routine,
123 which clears and frees all context data structures, and is the
124 principle action of the parser's mg_clear function.
125
126 Transform Support
127 =================
128 If your program is supporting any geometry at all (and what would be
129 the point if it wasn't?) you will need to support the transform
130 entity (MG_E_XF). This would be tricky, if it weren't for the support
131 routines provided, which make the task fairly painless. First, there
132 is the transform handler itself, xf_handler. Just set the MG_E_XF
133 entry of the mg_ehand array to this function. Then, anytime you want
134 to transform something, call one of the associated functions, xf_xfmpoint,
135 xf_xfmvect, xf_rotvect or xf_scale. These functions transform a 3-D
136 point, 3-D vector (without translation), rotate a 3-D vector (without
137 scaling) and scale a floating-point value, respectively.
138
139 Examples
140 ========
141 Two example translator programs are included with this package.
142
143 The simplest is a translator from MGF to MGF called mgfilt.c, which
144 produces on the standard output only those entities from the standard
145 input that are supported according to the command line arguments. For
146 example, one could remove everything but the raw, flat polygonal
147 geometry with the following command:
148
149 mgfilt v p f xf < any.mgf > faces.mgf
150
151 Note that the xf entity must also be included, for its support is
152 required by all geometric entities.
153
154 The second translator converts from MGF to the Radiance scene description
155 language, and is a more practical example of parser use. Unfortunately,
156 we did not include all of the support functions required by this translator,
157 so it serves as a source code example only. If you wish to get the rest
158 of it because you intend to run it, contact Greg Ward <[email protected]>
159 and he'll be happy to provide you with the missing pieces.
160
161 Copyright
162 =========
163 At this point, the legal issues related to this parser have not been
164 considered. The intent is to offer it free of charge to all those who
165 wish to use it (with no guarantees, of course). However, we may decide
166 that copyright protections are necessary to prevent unauthorized versions
167 of the parser that do not properly support the MGF standard from getting
168 spread around. Since this is a pre-release, we trust that you will not
169 share it with anyone without getting our permission first.
170
171 Questions
172 =========
173 Questions should be directed to Greg Ward <[email protected]>, who will be
174 happy to offer any reasonable assistance in using this standard. (Greg's
175 telephone is 1-510-486-4757, fax 1-510-486-4089.)
