root/radiance/ray/src/cv/mgflib/rayopt.h
Revision: 1.4
Committed: Wed Sep 5 01:36:37 2007 UTC (16 years, 8 months ago) by greg
CVS Tags: rad4R0, rad3R9
Changes since 1.3: +3 -7 lines
Copyright fixes
1 /* RCSid: $Id: rayopt.h,v 1.3 2003/06/07 01:11:17 schorsch Exp $ */
2 /*-------------------------------------------------------------------------
3
4 Triangle Bounder/Smoother for POV-Ray
5 by Steve Anger 1993
6
7 A number of C routines that can be used to generate POV-Ray ray tracer
8 files from triangle data. Supports generation of smooth triangles and an
9 optimal set of bounding shapes for much faster traces.
10
11 --------------------------------------------------------------------------*/
12
13 #ifndef _MGF_RAYOPT_H
14 #define _MGF_RAYOPT_H
15 #ifdef __cplusplus
16 extern "C" {
17 #endif
18
19
20 #include "vect.h"
21
22 void opt_set_format (int format);
23 void opt_set_fname (char *pov_name, char *inc_name);
24 void opt_set_quiet (int quiet);
25 void opt_set_bound (int bound);
26 void opt_set_smooth (float smooth);
27 void opt_set_vert (unsigned vert);
28 void opt_set_dec (int dec);
29
30 void opt_set_color (float red, float green, float blue);
31 void opt_set_texture (char *texture_name);
32 void opt_set_transform (Matrix mat);
33 void opt_clear_transform();
34 int opt_add_tri (float ax, float ay, float az,
35 float bx, float by, float bz,
36 float cx, float cy, float cz);
37
38 void opt_write_pov (char *obj_name);
39 void opt_write_file (char *obj_name);
40 void opt_write_box (char *obj_name);
41 void opt_finish (void);
42
43 void opt_get_limits (float *min_x, float *min_y, float *min_z,
44 float *max_x, float *max_y, float *max_z);
45 void opt_get_glimits (float *min_x, float *min_y, float *min_z,
46 float *max_x, float *max_y, float *max_z);
47 unsigned opt_get_vert_cnt (void);
48 unsigned opt_get_tri_cnt (void);
49 float opt_get_index (void);
50 unsigned opt_get_bounds (void);
51
52 void abortmsg (char *msg, int exit_code);
53 void add_ext (char *fname, char *ext, int force);
54 void cleanup_name (char *name);
55
56
57 #ifdef __cplusplus
58 }
59 #endif
60 #endif /* _MGF_RAYOPT_H */
61
