root/radiance/ray/src/cv/mgflib/rayopt.h
Revision: 1.3
Committed: Sat Jun 7 01:11:17 2003 UTC (22 years ago) by schorsch
CVS Tags: rad3R7P1, rad3R6, rad3R6P1, rad3R8, rad3R7P2
Changes since 1.2: +12 -3 lines
Removed NOPROTO sections.
# User Rev Content
1 schorsch 1.3 /* RCSid: $Id: rayopt.h,v 1.2 2003/02/28 20:11:30 greg Exp $ */
2 greg 1.1 /*-------------------------------------------------------------------------
3
4     Triangle Bounder/Smoother for POV-Ray
5     Copyright (c) 1993 Steve Anger
6
7     A number of C routines that can be used to generate POV-Ray ray tracer
8     files from triangle data. Supports generation of smooth triangles and an
9     optimal set of bounding shapes for much faster traces. This program may be
10     freely modified and distributed.
11
12     CompuServe: 70714,3113
13     YCCMR BBS: (708)358-5611
14
15     --------------------------------------------------------------------------*/
16
17 schorsch 1.3 #ifndef _MGF_RAYOPT_H
18     #define _MGF_RAYOPT_H
19     #ifdef __cplusplus
20     extern "C" {
21     #endif
22
23 greg 1.1
24     #include "vect.h"
25
26     void opt_set_format (int format);
27     void opt_set_fname (char *pov_name, char *inc_name);
28     void opt_set_quiet (int quiet);
29     void opt_set_bound (int bound);
30     void opt_set_smooth (float smooth);
31     void opt_set_vert (unsigned vert);
32     void opt_set_dec (int dec);
33
34     void opt_set_color (float red, float green, float blue);
35     void opt_set_texture (char *texture_name);
36     void opt_set_transform (Matrix mat);
37     void opt_clear_transform();
38     int opt_add_tri (float ax, float ay, float az,
39     float bx, float by, float bz,
40     float cx, float cy, float cz);
41
42     void opt_write_pov (char *obj_name);
43     void opt_write_file (char *obj_name);
44     void opt_write_box (char *obj_name);
45     void opt_finish (void);
46
47     void opt_get_limits (float *min_x, float *min_y, float *min_z,
48     float *max_x, float *max_y, float *max_z);
49     void opt_get_glimits (float *min_x, float *min_y, float *min_z,
50     float *max_x, float *max_y, float *max_z);
51     unsigned opt_get_vert_cnt (void);
52     unsigned opt_get_tri_cnt (void);
53     float opt_get_index (void);
54     unsigned opt_get_bounds (void);
55
56     void abortmsg (char *msg, int exit_code);
57     void add_ext (char *fname, char *ext, int force);
58     void cleanup_name (char *name);
59
60 schorsch 1.3
61     #ifdef __cplusplus
62     }
63 greg 1.1 #endif
64 schorsch 1.3 #endif /* _MGF_RAYOPT_H */
65
