1 |
/* RCSid: $Id: parser.h,v 1.35 2003/06/26 00:58:09 schorsch Exp $ */ |
2 |
3 |
* Header file for MGF interpreter |
4 |
5 |
#ifndef _MGF_PARSER_H_ |
6 |
#define _MGF_PARSER_H_ |
7 |
#ifdef __cplusplus |
8 |
extern "C" { |
9 |
#endif |
10 |
11 |
12 |
#ifndef MG_VMAJOR |
13 |
14 |
/* must include stdio.h and stdlib.h before us */ |
15 |
16 |
#define MG_VMAJOR 2 /* major version number */ |
17 |
#define MG_VMINOR 0 /* minor version number */ |
18 |
19 |
/* Entities (list is only appended, never modified) */ |
20 |
#define MG_E_COMMENT 0 /* # */ |
21 |
#define MG_E_COLOR 1 /* c */ |
22 |
#define MG_E_CCT 2 /* cct */ |
23 |
#define MG_E_CONE 3 /* cone */ |
24 |
#define MG_E_CMIX 4 /* cmix */ |
25 |
#define MG_E_CSPEC 5 /* cspec */ |
26 |
#define MG_E_CXY 6 /* cxy */ |
27 |
#define MG_E_CYL 7 /* cyl */ |
28 |
#define MG_E_ED 8 /* ed */ |
29 |
#define MG_E_FACE 9 /* f */ |
30 |
#define MG_E_INCLUDE 10 /* i */ |
31 |
#define MG_E_IES 11 /* ies */ |
32 |
#define MG_E_IR 12 /* ir */ |
33 |
#define MG_E_MATERIAL 13 /* m */ |
34 |
#define MG_E_NORMAL 14 /* n */ |
35 |
#define MG_E_OBJECT 15 /* o */ |
36 |
#define MG_E_POINT 16 /* p */ |
37 |
#define MG_E_PRISM 17 /* prism */ |
38 |
#define MG_E_RD 18 /* rd */ |
39 |
#define MG_E_RING 19 /* ring */ |
40 |
#define MG_E_RS 20 /* rs */ |
41 |
#define MG_E_SIDES 21 /* sides */ |
42 |
#define MG_E_SPH 22 /* sph */ |
43 |
#define MG_E_TD 23 /* td */ |
44 |
#define MG_E_TORUS 24 /* torus */ |
45 |
#define MG_E_TS 25 /* ts */ |
46 |
#define MG_E_VERTEX 26 /* v */ |
47 |
#define MG_E_XF 27 /* xf */ |
48 |
/* end of Version 1 entities */ |
49 |
#define MG_E_FACEH 28 /* fh */ |
50 |
/* end of Version 2 entities */ |
51 |
52 |
#define MG_NENTITIES 29 /* total # entities */ |
53 |
54 |
#define MG_NELIST {28,29} /* entity count for version 1 and up */ |
55 |
56 |
#define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\ |
57 |
"f","i","ies","ir","m","n","o","p","prism","rd",\ |
58 |
"ring","rs","sides","sph","td","torus","ts","v","xf",\ |
59 |
"fh"} |
60 |
61 |
#define MG_MAXELEN 6 |
62 |
63 |
extern char mg_ename[MG_NENTITIES][MG_MAXELEN]; |
64 |
65 |
/* Handler routines for each entity and unknown ones */ |
66 |
extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv); |
67 |
extern int (*mg_uhand)(int argc, char **argv); |
68 |
extern int mg_defuhand(int, char **); |
69 |
70 |
extern unsigned mg_nunknown; /* count of unknown entities */ |
71 |
72 |
/* Error codes */ |
73 |
#define MG_OK 0 /* normal return value */ |
74 |
#define MG_EUNK 1 /* unknown entity */ |
75 |
#define MG_EARGC 2 /* wrong number of arguments */ |
76 |
#define MG_ETYPE 3 /* argument type error */ |
77 |
#define MG_EILL 4 /* illegal argument value */ |
78 |
#define MG_EUNDEF 5 /* undefined reference */ |
79 |
#define MG_ENOFILE 6 /* cannot open input file */ |
80 |
#define MG_EINCL 7 /* error in included file */ |
81 |
#define MG_EMEM 8 /* out of memory */ |
82 |
#define MG_ESEEK 9 /* file seek error */ |
83 |
#define MG_EBADMAT 10 /* bad material specification */ |
84 |
#define MG_ELINE 11 /* input line too long */ |
85 |
#define MG_ECNTXT 12 /* unmatched context close */ |
86 |
87 |
#define MG_NERRS 13 |
88 |
89 |
extern char *mg_err[MG_NERRS]; /* list of error messages */ |
90 |
91 |
92 |
* The general process for running the parser is to fill in the mg_ehand |
93 |
* array with handlers for each entity you know how to handle. |
94 |
* Then, call mg_init to fill in the rest. This function will report |
95 |
* an error and quit if you try to support an inconsistent set of entities. |
96 |
* For each file you want to parse, call mg_load with the file name. |
97 |
* To read from standard input, use NULL as the file name. |
98 |
* For additional control over error reporting and file management, |
99 |
* use mg_open, mg_read, mg_parse and mg_close instead of mg_load. |
100 |
* To pass an entity of your own construction to the parser, use |
101 |
* the mg_handle function rather than the mg_ehand routines directly. |
102 |
* (The first argument to mg_handle is the entity #, or -1.) |
103 |
* To free any data structures and clear the parser, use mg_clear. |
104 |
* If there is an error, mg_load, mg_open, mg_parse, mg_handle and |
105 |
* mg_fgoto will return an error from the list above. In addition, |
106 |
* mg_load will report the error to stderr. The mg_read routine |
107 |
* returns 0 when the end of file has been reached. |
108 |
109 |
110 |
#define MG_MAXLINE 4096 /* maximum input line length */ |
111 |
#define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */ |
112 |
113 |
typedef struct mg_fctxt { |
114 |
char fname[96]; /* file name */ |
115 |
FILE *fp; /* stream pointer */ |
116 |
int fid; /* unique file context id */ |
117 |
char inpline[MG_MAXLINE]; /* input line */ |
118 |
int lineno; /* line number */ |
119 |
struct mg_fctxt *prev; /* previous context */ |
120 |
} MG_FCTXT; |
121 |
122 |
typedef struct { |
123 |
int fid; /* file this position is for */ |
124 |
int lineno; /* line number in file */ |
125 |
long offset; /* offset from beginning */ |
126 |
} MG_FPOS; |
127 |
128 |
extern MG_FCTXT *mg_file; /* current file context */ |
129 |
130 |
extern void mg_init(void); /* fill in mg_ehand array */ |
131 |
extern int mg_load(char *); /* parse a file */ |
132 |
extern int mg_open(MG_FCTXT *, char *); /* open new input file */ |
133 |
extern int mg_read(void); /* read next line */ |
134 |
extern int mg_parse(void); /* parse current line */ |
135 |
extern void mg_fgetpos(MG_FPOS *); /* get position on input file */ |
136 |
extern int mg_fgoto(MG_FPOS *); /* go to position on input file */ |
137 |
extern void mg_close(void); /* close input file */ |
138 |
extern void mg_clear(void); /* clear parser */ |
139 |
extern int mg_handle(int, int, char **); /* handle an entity */ |
140 |
141 |
#ifndef MG_NQCD |
142 |
#define MG_NQCD 5 /* default number of divisions */ |
143 |
#endif |
144 |
145 |
extern int mg_nqcdivs; /* divisions per quarter circle */ |
146 |
147 |
148 |
* The following library routines are included for your convenience: |
149 |
150 |
151 |
extern int mg_entity(char *); /* get entity number from its name */ |
152 |
extern int isint(char *); /* non-zero if integer format */ |
153 |
extern int isintd(char *, char *); /* same with delimiter set */ |
154 |
extern int isflt(char *); /* non-zero if floating point format */ |
155 |
extern int isfltd(char *, char *); /* same with delimiter set */ |
156 |
extern int isname(char *); /* non-zero if legal identifier name */ |
157 |
extern int badarg(int, char **, char *);/* check argument format */ |
158 |
extern int e_include(int, char **); /* expand include entity */ |
159 |
extern int e_pipe(int, char **); /* expand piped command */ |
160 |
extern int e_sph(int, char **); /* expand sphere as other entities */ |
161 |
extern int e_torus(int, char **); /* expand torus as other entities */ |
162 |
extern int e_cyl(int, char **); /* expand cylinder as other entities */ |
163 |
extern int e_ring(int, char **); /* expand ring as other entities */ |
164 |
extern int e_cone(int, char **); /* expand cone as other entities */ |
165 |
extern int e_prism(int, char **); /* expand prism as other entities */ |
166 |
extern int e_faceh(int, char **); /* expand face w/ holes as face */ |
167 |
168 |
169 |
* Definitions for 3-d vector manipulation functions |
170 |
171 |
172 |
#ifdef SMLFLT |
173 |
#define RREAL float |
174 |
#define FTINY (1e-3) |
175 |
#else |
176 |
#define RREAL double |
177 |
#define FTINY (1e-6) |
178 |
#endif |
179 |
#define FHUGE (1e10) |
180 |
181 |
typedef RREAL FVECT[3]; |
182 |
183 |
#define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2]) |
184 |
#define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2]) |
185 |
#define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \ |
186 |
(vr)[1]=(v1)[1]+(f)*(v2)[1], \ |
187 |
(vr)[2]=(v1)[2]+(f)*(v2)[2]) |
188 |
189 |
#define is0vect(v) (DOT(v,v) <= FTINY*FTINY) |
190 |
191 |
#define round0(x) if (x <= FTINY && x >= -FTINY) x = 0 |
192 |
193 |
extern double normalize(FVECT); /* normalize a vector */ |
194 |
extern void fcross(FVECT,FVECT,FVECT);/* cross product of two vectors */ |
195 |
196 |
197 |
* Definitions for context handling routines |
198 |
* (materials, colors, vectors) |
199 |
200 |
201 |
#define C_CMINWL 380 /* minimum wavelength */ |
202 |
#define C_CMAXWL 780 /* maximum wavelength */ |
203 |
#define C_CNSS 41 /* number of spectral samples */ |
204 |
#define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1)) |
205 |
#define C_CMAXV 10000 /* nominal maximum sample value */ |
206 |
#define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */ |
207 |
208 |
#define C_CSSPEC 01 /* flag if spectrum is set */ |
209 |
#define C_CDSPEC 02 /* flag if defined w/ spectrum */ |
210 |
#define C_CSXY 04 /* flag if xy is set */ |
211 |
#define C_CDXY 010 /* flag if defined w/ xy */ |
212 |
#define C_CSEFF 020 /* flag if efficacy set */ |
213 |
214 |
typedef struct { |
215 |
int clock; /* incremented each change */ |
216 |
char *client_data; /* pointer to private client-owned data */ |
217 |
short flags; /* what's been set */ |
218 |
short ssamp[C_CNSS]; /* spectral samples, min wl to max */ |
219 |
long ssum; /* straight sum of spectral values */ |
220 |
float cx, cy; /* xy chromaticity value */ |
221 |
float eff; /* efficacy (lumens/watt) */ |
222 |
} C_COLOR; |
223 |
224 |
#define C_DEFCOLOR { 1, NULL, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\ |
225 |
{C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ |
226 |
C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ |
227 |
228 |
229 |
230 |
231 |
C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\ |
232 |
(long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 } |
233 |
234 |
#define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum) |
235 |
236 |
#define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */ |
237 |
238 |
typedef struct { |
239 |
int clock; /* incremented each change -- resettable */ |
240 |
241 |
int sided; /* 1 if surface is 1-sided, 0 for 2-sided */ |
242 |
float nr, ni; /* index of refraction, real and imaginary */ |
243 |
float rd; /* diffuse reflectance */ |
244 |
C_COLOR rd_c; /* diffuse reflectance color */ |
245 |
float td; /* diffuse transmittance */ |
246 |
C_COLOR td_c; /* diffuse transmittance color */ |
247 |
float ed; /* diffuse emittance */ |
248 |
C_COLOR ed_c; /* diffuse emittance color */ |
249 |
float rs; /* specular reflectance */ |
250 |
C_COLOR rs_c; /* specular reflectance color */ |
251 |
float rs_a; /* specular reflectance roughness */ |
252 |
float ts; /* specular transmittance */ |
253 |
C_COLOR ts_c; /* specular transmittance color */ |
254 |
float ts_a; /* specular transmittance roughness */ |
255 |
} C_MATERIAL; /* material context */ |
256 |
257 |
typedef struct { |
258 |
259 |
260 |
FVECT p, n; /* point and normal */ |
261 |
} C_VERTEX; /* vertex context */ |
262 |
263 |
#define C_DEFMATERIAL {1,NULL,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,\ |
264 |
C_DEFCOLOR,0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.} |
265 |
#define C_DEFVERTEX {1,NULL,{0.,0.,0.},{0.,0.,0.}} |
266 |
267 |
extern C_COLOR *c_ccolor; /* the current color */ |
268 |
extern char *c_ccname; /* current color name */ |
269 |
extern C_MATERIAL *c_cmaterial; /* the current material */ |
270 |
extern char *c_cmname; /* current material name */ |
271 |
extern C_VERTEX *c_cvertex; /* the current vertex */ |
272 |
extern char *c_cvname; /* current vertex name */ |
273 |
274 |
extern int c_hcolor(int, char **); /* handle color entity */ |
275 |
extern int c_hmaterial(int, char **); /* handle material entity */ |
276 |
extern int c_hvertex(int, char **); /* handle vertex entity */ |
277 |
extern void c_clearall(void); /* clear context tables */ |
278 |
extern C_MATERIAL *c_getmaterial(char *); /* get a named material */ |
279 |
extern C_VERTEX *c_getvert(char *); /* get a named vertex */ |
280 |
extern C_COLOR *c_getcolor(char *); /* get a named color */ |
281 |
extern void c_ccvt(C_COLOR *, int); /* fix color representation */ |
282 |
extern int c_isgrey(C_COLOR *); /* check if color is grey */ |
283 |
284 |
285 |
* Definitions for hierarchical object name handler |
286 |
287 |
288 |
extern int obj_nnames; /* depth of name hierarchy */ |
289 |
extern char **obj_name; /* names in hierarchy */ |
290 |
291 |
extern int obj_handler(int, char **); /* handle an object entity */ |
292 |
extern void obj_clear(void); /* clear object stack */ |
293 |
294 |
295 |
* Definitions for hierarchical transformation handler |
296 |
297 |
298 |
typedef RREAL MAT4[4][4]; |
299 |
300 |
#define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4)) |
301 |
302 |
#define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \ |
303 |
{0.,0.,1.,0.}, {0.,0.,0.,1.} } |
304 |
305 |
extern MAT4 m4ident; |
306 |
307 |
#define setident4(m4) copymat4(m4, m4ident) |
308 |
309 |
/* regular transformation */ |
310 |
typedef struct { |
311 |
MAT4 xfm; /* transform matrix */ |
312 |
RREAL sca; /* scalefactor */ |
313 |
} XF; |
314 |
315 |
#define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0) |
316 |
317 |
#define XF_MAXDIM 8 /* maximum array dimensions */ |
318 |
319 |
struct xf_array { |
320 |
MG_FPOS spos; /* starting position on input */ |
321 |
int ndim; /* number of array dimensions */ |
322 |
struct { |
323 |
short i, n; /* current count and maximum */ |
324 |
char arg[8]; /* string argument value */ |
325 |
} aarg[XF_MAXDIM]; |
326 |
327 |
328 |
typedef struct xf_spec { |
329 |
long xid; /* unique transform id */ |
330 |
short xac; /* context argument count */ |
331 |
short rev; /* boolean true if vertices reversed */ |
332 |
XF xf; /* cumulative transformation */ |
333 |
struct xf_array *xarr; /* transformation array pointer */ |
334 |
struct xf_spec *prev; /* previous transformation context */ |
335 |
} XF_SPEC; /* followed by argument buffer */ |
336 |
337 |
extern XF_SPEC *xf_context; /* current transform context */ |
338 |
extern char **xf_argend; /* last transform argument */ |
339 |
340 |
#define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac) |
341 |
#define xf_av(xf) (xf_argend - (xf)->xac) |
342 |
343 |
#define xf_argc xf_ac(xf_context) |
344 |
#define xf_argv xf_av(xf_context) |
345 |
346 |
347 |
* The transformation handler should do most of the work that needs |
348 |
* doing. Just pass it any xf entities, then use the associated |
349 |
* functions to transform and translate points, transform vectors |
350 |
* (without translation), rotate vectors (without scaling) and scale |
351 |
* values appropriately. |
352 |
353 |
* The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two |
354 |
* 3-D vectors (which may be identical), transforms the second and |
355 |
* puts the result into the first. |
356 |
357 |
358 |
359 |
extern int xf_handler(int, char **); /* handle xf entity */ |
360 |
extern void xf_xfmpoint(FVECT, FVECT); /* transform point */ |
361 |
extern void xf_xfmvect(FVECT, FVECT); /* transform vector */ |
362 |
extern void xf_rotvect(FVECT, FVECT); /* rotate vector */ |
363 |
extern double xf_scale(double); /* scale a value */ |
364 |
extern void xf_clear(void); /* clear xf stack */ |
365 |
366 |
/* The following are support routines you probably won't call directly */ |
367 |
368 |
XF_SPEC *new_xf(int, char **); /* allocate new transform */ |
369 |
void free_xf(XF_SPEC *); /* free a transform */ |
370 |
int xf_aname(struct xf_array *); /* name this instance */ |
371 |
long comp_xfid(MAT4); /* compute unique ID */ |
372 |
extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */ |
373 |
extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */ |
374 |
extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */ |
375 |
extern int xf(XF *, int, char **); /* interpret transform spec. */ |
376 |
377 |
378 |
379 |
* Miscellaneous definitions |
380 |
381 |
382 |
#ifndef PI |
383 |
#ifdef M_PI |
384 |
#define PI ((double)M_PI) |
385 |
#else |
386 |
#define PI 3.14159265358979323846 |
387 |
#endif |
388 |
#endif |
389 |
390 |
#ifndef MEM_PTR |
391 |
#define MEM_PTR void * |
392 |
#endif |
393 |
394 |
#endif /*MG_VMAJOR*/ |
395 |
396 |
397 |
398 |
399 |
#endif |
400 |
#endif /* _MGF_PARSER_H_ */ |
401 |
