root/radiance/ray/src/cv/mgflib/parser.h
Revision: 1.30
Committed: Tue Mar 18 11:05:40 1997 UTC (27 years, 1 month ago) by greg
Changes since 1.29: +35 -5 lines
added fh entity and general cleanup
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for MGF interpreter
7 */
8
9 #ifndef MG_VMAJOR
10
11 /* must include stdio.h before us */
12
13 #define MG_VMAJOR 2 /* major version number */
14 #define MG_VMINOR 0 /* minor version number */
15
16 /* Entities (list is only appended, never modified) */
17 #define MG_E_COMMENT 0 /* # */
18 #define MG_E_COLOR 1 /* c */
19 #define MG_E_CCT 2 /* cct */
20 #define MG_E_CONE 3 /* cone */
21 #define MG_E_CMIX 4 /* cmix */
22 #define MG_E_CSPEC 5 /* cspec */
23 #define MG_E_CXY 6 /* cxy */
24 #define MG_E_CYL 7 /* cyl */
25 #define MG_E_ED 8 /* ed */
26 #define MG_E_FACE 9 /* f */
27 #define MG_E_INCLUDE 10 /* i */
28 #define MG_E_IES 11 /* ies */
29 #define MG_E_IR 12 /* ir */
30 #define MG_E_MATERIAL 13 /* m */
31 #define MG_E_NORMAL 14 /* n */
32 #define MG_E_OBJECT 15 /* o */
33 #define MG_E_POINT 16 /* p */
34 #define MG_E_PRISM 17 /* prism */
35 #define MG_E_RD 18 /* rd */
36 #define MG_E_RING 19 /* ring */
37 #define MG_E_RS 20 /* rs */
38 #define MG_E_SIDES 21 /* sides */
39 #define MG_E_SPH 22 /* sph */
40 #define MG_E_TD 23 /* td */
41 #define MG_E_TORUS 24 /* torus */
42 #define MG_E_TS 25 /* ts */
43 #define MG_E_VERTEX 26 /* v */
44 #define MG_E_XF 27 /* xf */
45 /* end of Version 1 entities */
46 #define MG_E_FACEH 28 /* fh */
47 /* end of Version 2 entities */
48
49 #define MG_NENTITIES 29 /* total # entities */
50
51 #define MG_NELIST {28,29} /* entity count for version 1 and up */
52
53 #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\
54 "f","i","ies","ir","m","n","o","p","prism","rd",\
55 "ring","rs","sides","sph","td","torus","ts","v","xf",\
56 "fh"}
57
58 #define MG_MAXELEN 6
59
60 extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
61
62 /* Handler routines for each entity and unknown ones */
63 #ifdef NOPROTO
64 extern int (*mg_ehand[MG_NENTITIES])();
65 extern int (*mg_uhand)();
66 extern int mg_defuhand();
67 #else
68 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
69 extern int (*mg_uhand)(int argc, char **argv);
70 extern int mg_defuhand(int, char **);
71 #endif
72
73 extern unsigned mg_nunknown; /* count of unknown entities */
74
75 /* Error codes */
76 #define MG_OK 0 /* normal return value */
77 #define MG_EUNK 1 /* unknown entity */
78 #define MG_EARGC 2 /* wrong number of arguments */
79 #define MG_ETYPE 3 /* argument type error */
80 #define MG_EILL 4 /* illegal argument value */
81 #define MG_EUNDEF 5 /* undefined reference */
82 #define MG_ENOFILE 6 /* cannot open input file */
83 #define MG_EINCL 7 /* error in included file */
84 #define MG_EMEM 8 /* out of memory */
85 #define MG_ESEEK 9 /* file seek error */
86 #define MG_EBADMAT 10 /* bad material specification */
87 #define MG_ELINE 11 /* input line too long */
88 #define MG_ECNTXT 12 /* unmatched context close */
89
90 #define MG_NERRS 13
91
92 extern char *mg_err[MG_NERRS]; /* list of error messages */
93
94 /*
95 * The general process for running the parser is to fill in the mg_ehand
96 * array with handlers for each entity you know how to handle.
97 * Then, call mg_init to fill in the rest. This function will report
98 * an error and quit if you try to support an inconsistent set of entities.
99 * For each file you want to parse, call mg_load with the file name.
100 * To read from standard input, use NULL as the file name.
101 * For additional control over error reporting and file management,
102 * use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
103 * To pass an entity of your own construction to the parser, use
104 * the mg_handle function rather than the mg_ehand routines directly.
105 * (The first argument to mg_handle is the entity #, or -1.)
106 * To free any data structures and clear the parser, use mg_clear.
107 * If there is an error, mg_load, mg_open, mg_parse, mg_handle and
108 * mg_fgoto will return an error from the list above. In addition,
109 * mg_load will report the error to stderr. The mg_read routine
110 * returns 0 when the end of file has been reached.
111 */
112
113 #define MG_MAXLINE 4096 /* maximum input line length */
114 #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
115
116 typedef struct mg_fctxt {
117 char fname[96]; /* file name */
118 FILE *fp; /* stream pointer */
119 int fid; /* unique file context id */
120 char inpline[MG_MAXLINE]; /* input line */
121 int lineno; /* line number */
122 struct mg_fctxt *prev; /* previous context */
123 } MG_FCTXT;
124
125 typedef struct {
126 int fid; /* file this position is for */
127 int lineno; /* line number in file */
128 long offset; /* offset from beginning */
129 } MG_FPOS;
130
131 extern MG_FCTXT *mg_file; /* current file context */
132
133 #ifdef NOPROTO
134 extern void mg_init(); /* fill in mg_ehand array */
135 extern int mg_load(); /* parse a file */
136 extern int mg_open(); /* open new input file */
137 extern int mg_read(); /* read next line */
138 extern int mg_parse(); /* parse current line */
139 extern void mg_fgetpos(); /* get position on input file */
140 extern int mg_fgoto(); /* go to position on input file */
141 extern void mg_close(); /* close input file */
142 extern void mg_clear(); /* clear parser */
143 extern int mg_handle(); /* handle an entity */
144 #else
145 extern void mg_init(void); /* fill in mg_ehand array */
146 extern int mg_load(char *); /* parse a file */
147 extern int mg_open(MG_FCTXT *, char *); /* open new input file */
148 extern int mg_read(void); /* read next line */
149 extern int mg_parse(void); /* parse current line */
150 extern void mg_fgetpos(MG_FPOS *); /* get position on input file */
151 extern int mg_fgoto(MG_FPOS *); /* go to position on input file */
152 extern void mg_close(void); /* close input file */
153 extern void mg_clear(void); /* clear parser */
154 extern int mg_handle(int, int, char **); /* handle an entity */
155 #endif
156
157 #ifndef MG_NQCD
158 #define MG_NQCD 5 /* default number of divisions */
159 #endif
160
161 extern int mg_nqcdivs; /* divisions per quarter circle */
162
163 /*
164 * The following library routines are included for your convenience:
165 */
166
167 #ifdef NOPROTO
168 extern int mg_entity(); /* get entity number from its name */
169 extern int isint(); /* non-zero if integer format */
170 extern int isintd(); /* same with delimiter set */
171 extern int isflt(); /* non-zero if floating point format */
172 extern int isfltd(); /* same with delimiter set */
173 extern int isname(); /* non-zero if legal identifier name */
174 extern int badarg(); /* check argument format */
175 extern int e_include(); /* expand include entity */
176 extern int e_sph(); /* expand sphere as other entities */
177 extern int e_torus(); /* expand torus as other entities */
178 extern int e_cyl(); /* expand cylinder as other entities */
179 extern int e_ring(); /* expand ring as other entities */
180 extern int e_cone(); /* expand cone as other entities */
181 extern int e_prism(); /* expand prism as other entities */
182 extern int e_faceh(); /* expand face w/ holes as face */
183 #else
184 extern int mg_entity(char *); /* get entity number from its name */
185 extern int isint(char *); /* non-zero if integer format */
186 extern int isintd(char *, char *); /* same with delimiter set */
187 extern int isflt(char *); /* non-zero if floating point format */
188 extern int isfltd(char *, char *); /* same with delimiter set */
189 extern int isname(char *); /* non-zero if legal identifier name */
190 extern int badarg(int, char **, char *);/* check argument format */
191 extern int e_include(int, char **); /* expand include entity */
192 extern int e_sph(int, char **); /* expand sphere as other entities */
193 extern int e_torus(int, char **); /* expand torus as other entities */
194 extern int e_cyl(int, char **); /* expand cylinder as other entities */
195 extern int e_ring(int, char **); /* expand ring as other entities */
196 extern int e_cone(int, char **); /* expand cone as other entities */
197 extern int e_prism(int, char **); /* expand prism as other entities */
198 extern int e_faceh(int, char **); /* expand face w/ holes as face */
199 #endif
200
201 /************************************************************************
202 * Definitions for 3-d vector manipulation functions
203 */
204
205 #ifdef SMLFLT
206 #define FLOAT float
207 #define FTINY (1e-3)
208 #else
209 #define FLOAT double
210 #define FTINY (1e-6)
211 #endif
212 #define FHUGE (1e10)
213
214 typedef FLOAT FVECT[3];
215
216 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
217 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
218 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
219 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
220 (vr)[2]=(v1)[2]+(f)*(v2)[2])
221
222 #define is0vect(v) (DOT(v,v) <= FTINY*FTINY)
223
224 #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
225
226 #ifdef NOPROTO
227 extern double normalize(); /* normalize a vector */
228 #else
229 extern double normalize(FVECT); /* normalize a vector */
230 extern void fcross(FVECT,FVECT,FVECT);/* cross product of two vectors */
231 #endif
232
233 /************************************************************************
234 * Definitions for context handling routines
235 * (materials, colors, vectors)
236 */
237
238 #define C_CMINWL 380 /* minimum wavelength */
239 #define C_CMAXWL 780 /* maximum wavelength */
240 #define C_CNSS 41 /* number of spectral samples */
241 #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
242 #define C_CMAXV 10000 /* nominal maximum sample value */
243 #define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */
244
245 #define C_CSSPEC 01 /* flag if spectrum is set */
246 #define C_CDSPEC 02 /* flag if defined w/ spectrum */
247 #define C_CSXY 04 /* flag if xy is set */
248 #define C_CDXY 010 /* flag if defined w/ xy */
249 #define C_CSEFF 020 /* flag if efficacy set */
250
251 typedef struct {
252 int clock; /* incremented each change */
253 short flags; /* what's been set */
254 short ssamp[C_CNSS]; /* spectral samples, min wl to max */
255 long ssum; /* straight sum of spectral values */
256 float cx, cy; /* xy chromaticity value */
257 float eff; /* efficacy (lumens/watt) */
258 } C_COLOR;
259
260 #define C_DEFCOLOR { 1, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\
261 {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
262 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
263 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
264 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
265 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
266 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
267 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\
268 (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 }
269
270 #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum)
271
272 #define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */
273
274 typedef struct {
275 int clock; /* incremented each change -- resettable */
276 int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
277 float nr, ni; /* index of refraction, real and imaginary */
278 float rd; /* diffuse reflectance */
279 C_COLOR rd_c; /* diffuse reflectance color */
280 float td; /* diffuse transmittance */
281 C_COLOR td_c; /* diffuse transmittance color */
282 float ed; /* diffuse emittance */
283 C_COLOR ed_c; /* diffuse emittance color */
284 float rs; /* specular reflectance */
285 C_COLOR rs_c; /* specular reflectance color */
286 float rs_a; /* specular reflectance roughness */
287 float ts; /* specular transmittance */
288 C_COLOR ts_c; /* specular transmittance color */
289 float ts_a; /* specular transmittance roughness */
290 } C_MATERIAL; /* material context */
291
292 typedef struct {
293 int clock; /* incremented each change -- resettable */
294 FVECT p, n; /* point and normal */
295 } C_VERTEX; /* vertex context */
296
297 #define C_DEFMATERIAL {1,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\
298 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
299 #define C_DEFVERTEX {1,{0.,0.,0.},{0.,0.,0.}}
300
301 extern C_COLOR *c_ccolor; /* the current color */
302 extern char *c_ccname; /* current color name */
303 extern C_MATERIAL *c_cmaterial; /* the current material */
304 extern char *c_cmname; /* current material name */
305 extern C_VERTEX *c_cvertex; /* the current vertex */
306 extern char *c_cvname; /* current vertex name */
307
308 #ifdef NOPROTO
309 extern int c_hcolor(); /* handle color entity */
310 extern int c_hmaterial(); /* handle material entity */
311 extern int c_hvertex(); /* handle vertex entity */
312 extern void c_clearall(); /* clear context tables */
313 extern C_MATERIAL *c_getmaterial(); /* get a named material */
314 extern C_VERTEX *c_getvert(); /* get a named vertex */
315 extern C_COLOR *c_getcolor(); /* get a named color */
316 extern void c_ccvt(); /* fix color representation */
317 extern int c_isgrey(); /* check if color is grey */
318 #else
319 extern int c_hcolor(int, char **); /* handle color entity */
320 extern int c_hmaterial(int, char **); /* handle material entity */
321 extern int c_hvertex(int, char **); /* handle vertex entity */
322 extern void c_clearall(void); /* clear context tables */
323 extern C_MATERIAL *c_getmaterial(char *); /* get a named material */
324 extern C_VERTEX *c_getvert(char *); /* get a named vertex */
325 extern C_COLOR *c_getcolor(char *); /* get a named color */
326 extern void c_ccvt(C_COLOR *, int); /* fix color representation */
327 extern int c_isgrey(C_COLOR *); /* check if color is grey */
328 #endif
329
330 /*************************************************************************
331 * Definitions for hierarchical object name handler
332 */
333
334 extern int obj_nnames; /* depth of name hierarchy */
335 extern char **obj_name; /* names in hierarchy */
336
337 #ifdef NOPROTO
338 extern int obj_handler(); /* handle an object entity */
339 extern void obj_clear(); /* clear object stack */
340 #else
341 extern int obj_handler(int, char **); /* handle an object entity */
342 extern void obj_clear(void); /* clear object stack */
343 #endif
344
345 /**************************************************************************
346 * Definitions for hierarchical transformation handler
347 */
348
349 typedef FLOAT MAT4[4][4];
350
351 #ifdef BSD
352 #define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4))
353 #else
354 #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
355 #endif
356
357 #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
358 {0.,0.,1.,0.}, {0.,0.,0.,1.} }
359
360 extern MAT4 m4ident;
361
362 #define setident4(m4) copymat4(m4, m4ident)
363
364 /* regular transformation */
365 typedef struct {
366 MAT4 xfm; /* transform matrix */
367 FLOAT sca; /* scalefactor */
368 } XF;
369
370 #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
371
372 #define XF_MAXDIM 8 /* maximum array dimensions */
373
374 struct xf_array {
375 MG_FPOS spos; /* starting position on input */
376 int ndim; /* number of array dimensions */
377 struct {
378 short i, n; /* current count and maximum */
379 char arg[8]; /* string argument value */
380 } aarg[XF_MAXDIM];
381 };
382
383 typedef struct xf_spec {
384 long xid; /* unique transform id */
385 short xac; /* context argument count */
386 short rev; /* boolean true if vertices reversed */
387 XF xf; /* cumulative transformation */
388 struct xf_array *xarr; /* transformation array pointer */
389 struct xf_spec *prev; /* previous transformation context */
390 } XF_SPEC; /* followed by argument buffer */
391
392 extern XF_SPEC *xf_context; /* current transform context */
393 extern char **xf_argend; /* last transform argument */
394
395 #define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac)
396 #define xf_av(xf) (xf_argend - (xf)->xac)
397
398 #define xf_argc xf_ac(xf_context)
399 #define xf_argv xf_av(xf_context)
400
401 /*
402 * The transformation handler should do most of the work that needs
403 * doing. Just pass it any xf entities, then use the associated
404 * functions to transform and translate points, transform vectors
405 * (without translation), rotate vectors (without scaling) and scale
406 * values appropriately.
407 *
408 * The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
409 * 3-D vectors (which may be identical), transforms the second and
410 * puts the result into the first.
411 */
412
413 #ifdef NOPROTO
414
415 extern int xf_handler(); /* handle xf entity */
416 extern void xf_xfmpoint(); /* transform point */
417 extern void xf_xfmvect(); /* transform vector */
418 extern void xf_rotvect(); /* rotate vector */
419 extern double xf_scale(); /* scale a value */
420 extern void xf_clear(); /* clear xf stack */
421
422 /* The following are support routines you probably won't call directly */
423
424 XF_SPEC *new_xf(); /* allocate new transform */
425 void free_xf(); /* free a transform */
426 int xf_aname(); /* name this instance */
427 long comp_xfid(); /* compute unique ID */
428 extern void multmat4(); /* m4a = m4b X m4c */
429 extern void multv3(); /* v3a = v3b X m4 (vectors) */
430 extern void multp3(); /* p3a = p3b X m4 (points) */
431 extern int xf(); /* interpret transform spec. */
432
433 #else
434
435 extern int xf_handler(int, char **); /* handle xf entity */
436 extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
437 extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
438 extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
439 extern double xf_scale(double); /* scale a value */
440 extern void xf_clear(void); /* clear xf stack */
441
442 /* The following are support routines you probably won't call directly */
443
444 XF_SPEC *new_xf(int, char **); /* allocate new transform */
445 void free_xf(XF_SPEC *); /* free a transform */
446 int xf_aname(struct xf_array *); /* name this instance */
447 long comp_xfid(MAT4); /* compute unique ID */
448 extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
449 extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
450 extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
451 extern int xf(XF *, int, char **); /* interpret transform spec. */
452
453 #endif
454
455 /************************************************************************
456 * Miscellaneous definitions
457 */
458
459 #ifndef PI
460 #ifdef M_PI
461 #define PI M_PI
462 #else
463 #define PI 3.14159265358979323846
464 #endif
465 #endif
466
467 #ifdef DCL_ATOF
468 extern double atof();
469 #endif
470
471 #ifndef MEM_PTR
472 #define MEM_PTR void *
473 #endif
474
475 extern MEM_PTR malloc();
476 extern MEM_PTR calloc();
477 extern MEM_PTR realloc();
478 extern void free();
479
480 #endif /*MG_VMAJOR*/
